View Full Version : Fiero
- Fiero won't time correctly
- Buyers for Automobiles
- My Fiero has some crazy idle problems
- Where is the slave cylinder on a 1985 Coupe?
- Major clutch/ transmission problem
- Exhaust Problem
- High idle problem.
- 1985 Pontiac Fiero For Sale
- import powered fiero
- fiero burn
- 1984 2m4 parts for sale
- Fuel tank access to fuel pump.....
- 1988 fiero handbrake for sale.
- Super Duty Fiero (SD4) For Sale
- 88 Formula Coupe - Unusual Starting Problem
- Fiero PROM chips. HELP!!
- 86 to 84-2.5 swap
- Another engine swap question
- Help with timing 85 GT 2.8L 4SP
- will a big block fit?
- what transmission will fit?
- '87 Fiero wont start and dont know why..HELP!
- Gutless Fiero
- All wheel drive
- Engine swap
- 85 fiero gt heater problem
- Transaxle fluid check location 5 speed 1986 Fiero
- belt
- Maybe Purchasing Fiero
- Will it run again?
- looking for a 4.3 vortec
- 327 Swap
- Stick Shift
- Do these injectors work?
- Transmission fluid
- engine swap
- Fiero A/C Help
- RR brake lights and blinkers don't work
- 88 Calipers? ANYONE?
- 85 Fiero RPMS jump after warm
- new temp guage issues
- Where can I find the "Hard 2 find" Fiero parts??
- 87 Fiero SE 2.5 auto sputters
- 88 fiero, empty fuel tank
- Dead 86 2.8
- 1988 fiero, has sat for most of its live, what should i do?
- light problems
- fuel gage/won't start
- General Fiero Questions
- 88 Formula for sale
- '86 Fiero GT Shifter - Manual Trans
- no oil to top end of my 2.8 V-6
- Crazy Fuel Gauge Problem
- Possible Engine swap???
- looking for help
- 87 Fiero SE
- Fiero ignition module
- 86 GT Fiero. Outer door window seal replacement problem. Please help!!
- 85 Fiero lighting question
- '86 fiero
- 87 gt help
- Can I put a 5-speed in an 84 Fiero?
- ? about a wrecked Fiero
- Help...any ideas on what's wrong with my fiero?
- 84 fiero
- ClassicFiero Electrical Drain Issue.
- Help a female out
- Got a Fiero in the Garage? I need a favor...
- Where is the reverse switch??
- Springs for an 88 - Help me find some!
- 87 pontiac fiero GT 2.8
- buick v6 swap
- 86 se thermostat flips in housing need help
- Oh.... My Gawd.... Ebay Depresses Me
- 1984 Pontiac 2M4 passenger side headlight
- 1984 Pontiac Fiero Starter issues?
- G6 trans
- Nissan turbo engine into my Fiero! (Dial-up users, beware)
- Looking at buying a 84
- window glass removal 86 SE
- outer window seals,86 se
- 1986 se wont start no power to starter, fuel pump, or fp relay NEED HELP!!!
- Can a tachometer break
- fiero wont run :(
- A 2.8 MFI to a 3.4?
- HVAC fan won't blow/headlights
- 1984 won't start
- Pick your brain on this one
- Anti STOP braks!
- It's alive! got the Fiero running today
- Fiero GT quarter panels
- Mom wants to keep her Fiero.
- Egr
- fiero trouble help
- My first car!
- Its Alive
- Fiero supercharger.
- Want To Buy A Fiero
- 2.5 to 2.8 tranie swap
- 3.1 to 2.8 swap
- Is a quad 4 worth it?
- Spark plug cable problem
- PCV valve grommet?Help!
- 84 Fiero w/T125C slips in reverse
- Engine compartment catch or stop cables.
- questions on an engine swap
- Northstar Powered 1987 Fiero - Twin Turbos
- Help 84 2.5L Sport
- 86 fiero starts but will shut off
- Clutch pedal stuck
- buying a fiero
- selling a custom 87 fiero gt 100,000 miles must look
- Clutch slave cylinder travel
- 88 Clutch issue
- Awesom!!!! Near Mint 86 Pontiac Fiero Gt 6500.00 Obo
- Map Sensor Problem?
- Check Engine Light
- subs locations
- WANTED: Fiero to buy
- got no gears in my 86 fiero help
- Alternator Belts
- Fiero Problems?
- 86 2m4 won't stay runninmg
- Wheel Alignment
- 87 Fiero won't start
- 84 fiero
- Upgrade time! But what's first?
- 87 fiero gt
- Fiero headlights - delay issue
- Battery cable keeps getting fried to the alternator.....
- push start egniton
- fiero has no heat
- Rebuilt perfect heads
- 2 missing bolts
- WTB 2.8 v6
- 84 2.5L Sport Fliplights and Flutters on Freeway
- Fuel Gauge Stuck on Full
- How to
- 88 s10 2.5 into 88 fiero
- 88 Fliplight issues
- turbo kit?
- 88 Fiero Rear Caliper Problems
- 84 fiero 2.5 egr
- Fiero Wont Start 88 5spd V6
- Electric Box Cover?
- Engine, Cam, Computer
- Water tempature and oil pressure sending unit location?
- Posting of Links to Other Automotive Forums (Please Read)
- 1987 5 Speed with NO Reverse Problem
- seems like these forums are pretty dead
- New to this site. 88 Fiero GT
- fiero cold air intake
- 87 FIERO Dies under load? help!
- 2M4 to V6?
- would you buy it???--
- 3400 For sale
- Nose Job
- stock fiero 1/4 mile time?
- GT and SE differences?
- heY HELP I NEED IT
- 88 GT for sale
- WTB: 1988 GT 5 Speed Close to Kansas
- RPM's get to 4000 and engin almost quits
- 2.8l parts interchange?
- Intake manifold
- Headers Please help
- performence gains
- 1987 fiero gt forsale
- 3800sc swap
- really need some help!
- Water sprays from muffler
- Ls1 tranny
- headers....aftermarket tail lights...intake manifold
- transmission swap auto to manual
- Fiero Conversion questions
- Replacing Door window 86 Fiero
- 4.9 SWAP questions...
- Engines
- Ls2 motor
- 1987 fiero 2m4 auto no reverse help !
- buying fiero's 2 87's need opinions!!!
- 85 GT V-8 Engine Swap Questions
- paint prep
- fiero for sale
- help
- speedomter not working
- I am gettin' a Fiero
- Weird Squeeling Belt Problem
- 2 gsxr 1100cc engines in the car?
- An Overheating Problem
- Headlights
- 86 2m4 starts but dies when i press the gas
- My 87 Fiero turns off at 60 mph
- Rather Urgent: Can I get home with a dying clutch?
- Update on $100 Fiero
- 84 fiero problem with wiring?
- major issues
- Timing
- Fiero stalling problem
- trans cooling line busted
- Cat. Converter
- Need help with Fiero engine swap
- This is odd...
- high idle
- Any one want to trade their car for this race quad? No quad can touch this!!
- engine problems. always engine problems.
- Wtb 86,87,88 Gt
- motor swap?
- 1986 Pontiac Fiero: for sale or trade
- Need Fiero info...
- Got some ideahs and want some help
- Wtb: 86-88 V-6
- 86 fiero gt 4 sale
- WTB: Fiero GT or .......
- Decklid bolts?
- question/help
- '86 SE V6 starter question
- FOR SALE A heavily Modded 2m4?
- 87 GT Tranny
- 1988 GT engine swaps??
- WTB fiero v6
- The "find" for sale
- strange back fire
- tuning a 2m4
- cluth bleeding
- 1987 2.8l sputter but not run right
- exhust manifolds
- exhust manifolds
- exhust manifolds
- 1986 SE Timing wire
- 87 fiero se v6 auto for sale
- Fiero Engine Cradle
- 3.4l
- big problem
- coolent line
- overhaul
- Fiero Clutch Issues????!!!!
- Building 4g63t MR festiva
- Which Is Easier???
- bout to goto the airforce
- Motor Swap
- just wondering...
- Questions about Fiero
- how much?
- egr selonoid vaccum hose
- Bigger Motor
- Are the Fieros FWD or RWD?
- 87 Fiero Tranny Swap
- transmission install
Automotive Network, Inc., Copyright ©2012
