View Full Version : Fiero
- Interior Paint
- Coil Blower Relay ?
- Tranny Problem
- ECM not getting power?
- New here
- Custom Wheels?
- steel brake lines
- iroc z rims on 86 fiero
- Clutch Questions.
- 88 2.5 Fuel Vapor Canister
- Need Help w/88 Fiero BAD!!!!!
- just started after 7 years lots of problems
- manual swap
- Need help with 84 2M4
- please help!!! fiero wont start
- Question
- Question
- injector question
- throw-out bearing
- 85 GT Transmission Grinding
- 86 Fiero GT Idle Problem
- Replacing a crankshaft/main bearings
- 1984 Pontiac Fiero SE for SALE
- fiero wont start PLEASE HELP!!!!!!!!!!!
- bad tranny lines
- shaved
- brake help
- laptop
- Transmission Swapping
- transmission
- Fiero 2M4 starting problem
- turbo/intercooler
- clutch line needed
- windshield needed
- fiero clutch issues
- 84 Fiero won't start
- fiero 3800 sc axle build
- Looking into making a Fiero project car w/ a 3.8SC or V8 swap in mind...
- How much is it worth
- Rare: 1988 Fiero Gt For Sale
- 1986 fiero 2m. HELP!!!
- transaxel
- Rearend Gears?????
- HOT! Fiero problem.
- fiero fuel problem
- dumb question
- Questions About Fiero Before I Buy One
- just a question
- Dash Upgrades
- northstar
- 1987 GT for SALE
- 86 Fiero Swap
- Sum GT stuff for sale or trade...need this stuff gone
- power issues fiero 87gt
- 1984 Fiero issues and questions
- help
- have a ?
- update~
- '84 FieroSE for sale 81000 Miles!!!
- Targa top
- Manual Fluid change
- door jammed
- front wheel bearing
- clutch problems
- Lost speedometer and odometer Help!!!
- console pod
- 88 GT instrument cluster for sale
- 87 fiero, ignition module
- smile if u own a fiero
- Flywheel compatibility
- TBI Injector
- fiero 2.8 rebuild
- Clutch
- Conversion, kit cars
- seats
- 86 SE starting problems..
- fuel problem, help
- FOR SALE 1987 GT Fastback
- fiero help, I beg of you
- Locked Out... help
- 1988 Fiero GT Wiper problem
- When the snow gets too bad...............
- turbo too big??
- 85 Fiero 2.5L
- Back-to-back dyno runs of Fiero parts/mods
- I got one today baby!
- F/S 86 Fiero GT 2.8 4spd.man. Braidwood, IL
- Looking for Fiero(s)
- 87 fiero gt
- Auto transmission problems
- Boyfriend is a Fiero owner...HELP!
- project on hold
- dead car..
- neutral safety switch
- My Fiero Died!!!
- Where is my gas tank?
- headlight motor spinning
- Fiero for sale
- Ecu
- Weird electrical problem...guages pegging/chime...
- Fiero se v6 for sale
- fiero gt 5spd for sale in VA
- fiero replica
- Need Ideas For Engine Swaps
- whats any parts worth?
- Help me please!!!!!!
- A/C compressor
- Photo edit of fieros
- 2m6
- Removing 86 Fiero GT window
- Need help trying to find fuel relay
- how strong is gt motor..boosting?
- A/c
- got he running
- Confused to hell and back
- how do suicide doors work?
- Maf
- lambo or suicide doors
- first car need help
- Help! Brake problem!
- 86 gt
- 2.5 tech 4 engine mods, are there any????
- Lug Pattern
- clutch line size
- fiero in gran turismo
- Fiero For Sale in Ontario....
- fiero problem
- bleeding the hydro clutch
- thinking of gettin a 84 se.....
- changing a 2.8 Problem or Not a problem???
- Overheating fiero
- Whats Wrong?
- i dont know what size?
- first sports car?
- fuel problems
- Crank position sensor
- Wing stands Fiero rear wing
- 84 Fiero se, 4 sale in Indiana
- Supercharging/Turbo 2.8L??
- dizzy question
- v8 fiero
- WTB: fiero-cheap, running or not
- 88 fiero 2,5 ru'nn on 3
- Obd
- Transmission Problems
- lock rod clip
- White Smoke
- Transmission issues
- Ecm
- Fiero For Sale, Southwest Missouri
- Yet another headlight question ...
- fuel problem?
- rear exaust manifod sources.
- Emergency brake cables-HELP
- need help
- 3800sc Ii
- No Power After Engine Rebuilt:Timing???????
- fiero exhaust manifold problem
- headlights won't come up
- window regulator
- 2 fiero's for sale Missouri $120, $80, no titles, 1984, 1985
- my first car need some advise
- Opening the gauge cluster lense
- carpet??
- H22 Prelude Engine in a Pontiac Fiero
- 86 SE For Sale
- help...oil drips on garage oil pressure gauge kaput!
- tach jmps violently when accelr8tng then engine stalls
- The movie
- push rods
- Grant steering wheel
- Boost - Swaps - Reliablity.NEED ADVICE - PLEASE HELP
- FS: 1986 Pontiac Fiero GT
- 85 fiero gt for free??
- 76 Pontiac Astre
- 94 3800 Supercharged in 87 Fiero
- starter electrical
- pedal play
- Ferrari rims
- fiero stalls
- A little smoke ...
- Are all radios exchangable from different years
- alternator drivebelt
- window tinting
- Turbo???
- Checked for Codes, Now Car wont start
- How do I change dew wipes?
- Finally on the road again.
- NJ/PA Pontiac Nationals
- Headlight Issue (not the same old prob)
- beads in catalitic converter
- Transmission Question
- Noise from underneath
- engine problem
- 87 2.5l - L67?
- TH125 Transmission
- performance
- new contol arm bushings
- What are they?
- exhaust manifold
- 4.5 Caddy swap,computer?
- engine problem
- V-6 engine races up to 5500 RPMS
- To All Looking for Detent Cables
- fiero engine cradle?
- fiero lambo door hinges
- 84 4cyl. bad idle
- FOR SALE 1985 Fiero GT 4SPEED in CHICAGO
- noisy fuel pump? bad tape player
- Do 86-88 GT's come with 4 cyl engines?
- transmission problem
- Wiper Problem
- Adding a Turbo
- Fiero Engine Help
- service engine soon light and hesitation
- Fiero headlight problems
- Rattle going uphill..
- fiero / northsatr engine swap
- Looking for oil drain plug for 85 Isuzu transmission
- Offset
- Battery keeps draining
- 87 GT worth $4000?
- rivet remover
- pittsburgh
- HELP detent cable
- Another one bites the dust
- Fiero With MR2 Scoops
- Reliability?
- detent cable AKA kickdown cable HELP!!!!
- need help with oil pan
- FOR SALE: 1984 Pontiac Fiero
- help with temp gauge
- Sad day, now need left tail light assembly
- Front Hood Release Question
- mi. insurance ?
- Good Car To Start With?
- removing engine hinge springs
- horn
- expensive insurance?
- injector question
- Fiero tranny slips
- Fiero VS. Firebird
- FOR SALE: 1986 Fiero GT (I Think)
- Aerodynamic improve ments
- Looking for 85 4 cyl transmission
- Brake Problem
- Trade or FS: complete exhaust with tips/cat/muffler
- Sick swap
- Engine Swap -
- www.kickhill.com???
