Our Community is 662,000 Strong. Join Us.
View Full Version : Cabrio
Pages : [1] 2
  1. 98 Cabrio giving me hell.
  2. Heater fan is intermittent on my 87 cabrio
  3. Help Cabriolet wont run
  4. 87 Cabrio Starts but press gas and dies
  5. PLEASE HELP: My engine was watered down now has 7 codes! :(
  6. 99 Cabrio Convertible top...no juice
  7. 2000 cabrio
  8. Power Steering Pump Frozen
  9. VW Cabrio alarm problem & key won't lock door
  10. Volkswagen up!: rear wheel traction but technical problems
  11. 01 VW Cabrio with the drivers seat airbag that blew out.?
  12. Peugeot 306 cabrio...radiator leak (water in footwell)?
  13. dammit!
  14. 2002 cabrio a/c
  15. 87 VW Cabriolet blinker/hazard problem
  16. Can't bleed RR brake cylinder!
  17. Cabrio starts to cut out after warm-up
  18. Cabrio starts to cut out after warm-up
  19. Cabrio starts to cut out after warm-up
  20. Water Pump
  21. Cannot shift into gear
  22. 1999 Cabrio Cruise Control Fuse
  23. Cold Air Intake Question
  24. Replacing starter in 99 Cabrio
  25. '86 cabrio starter/coil wiring
  26. 2001 cabrio wobbling?
  27. 2002 Cabrio, Need Column Cover
  28. 2000 Cabrio Does not initially start, Radio Safe, Clock 1200
  29. need guide to install convertible top VW cab '85
  30. DTC P0748 2001 Voltswagen VW Cabrio Automatic Trans
  31. 87 Cabriolet Charging Problems.
  32. 95 VW Cabrio wiper nightmare
  33. 95 cabrio radio
  34. 99 Cabrio - Water collecting on the floorboard
  35. getting very low mpg...
  36. Transmission Serrated Wrench Size?
  37. fuel pump and ignition
  38. fuel pump
  39. Water Issues
  40. contactgjh
  41. Engine Replacement?
  42. I Just Can't get it!!!!
  43. Finished H.G. Replacement - '88 Cabrio wont Start
  44. 98 Cabrio battery keeps dying. New battery and Alternator OK. WHAT IS IT?????
  45. Mpg
  46. 86 cabriolet valve adjustment??? is it hard?
  47. 96 Cabrio-2 problems speed/odo & starting
  48. 92 1.8 could timming belt be off 1 tooth
  49. 92 vw cabriolet (manual trans) 1.8
  50. 02 Cabrio Window Problems...Help Me Please
  51. How to I reset radio (it's in safe mode) for 2001 cabrio
  52. 92 1.8 head gasket
  53. My horn has a mind of its own!
  54. 2002 Cabrio Problems?
  55. Questions about my 87 cabrio
  56. 87 cabrio: manual tranny stuck in reverse
  57. 87 Cabriolet starts and dies ?
  58. Replacing front axles on a 98 Cabrio ?
  59. 1999 Cabrio Dead battery - now these?
  60. 1999 Cabrio Dead battery - now these?
  61. 1992 Cabrio Stalled/ Kill switch???
  62. 95 Cabrio- Multi faceted start problem
  63. 1990 Cabrio Hard to start
  64. Parking Brake '02' Cabrio
  65. VW cabriolet 1990 timing points lost
  66. help with fuel pump location
  67. 1998 VW Cabrio CEL After Intake Cleaning
  68. 2000 Cabrio convertible top
  69. Oil light and buxxer
  70. Left back wheel making noises when accelerating
  71. New Owner
  72. Turbo Install
  73. lots of issues....
  74. How difficult is it to replace the top?
  75. Stinky Cabrio!
  76. 95 Cabrio Starting Problem
  77. 2001 Cabrio - changing ignition switch
  78. 2001 Cabrio - auto roof not working
  79. 99 Cabrio a/c interior circulating fan problem
  80. 1987 Cabrio for sale
  81. 97 Cabrio roof seam
  82. cabrio radio power
  83. Odd 2001 Cabrio problem
  84. cabrio radio safe code
  85. Windows broken 1999 cabrio
  86. 99 Cabrio with electrical issues
  87. Who Wants My 1987 Vw Cabriolet?
  88. cabrio trouble starting
  89. '89 Cabrio Rebuild ~HELP~
  90. Transmission leak
  91. Keep Cabrio or go BMW????
  92. timing belt tensioner
  93. 1988 Top Broken
  94. 2002 Cabrio Transmission Fluid Check
  95. 2002 Cabrio stereo in SAFE mode!! AAARGH!
  96. temperature gauge
  97. problems with the alarm and windows when it rains
  98. Leaky Manual Top
  99. 2002 Cabrio - power top not working
  100. No Spark
  101. Cabrio TDI?
  102. 87 cabrio overheats fast ????
  103. speedometer and tachometer not working
  104. Where do I buy a 1987 Convertible Top?
  105. 1997 Cabrio For Sale!
  106. Help!!!!!
  107. Please help me with my temp & SRS lights
  108. key propgramming
  109. 87 cabrio WONT START ...HELP...
  110. Problems with Gear 1 & 2 - Need troubleshooting
  111. 99 Cabrio alarm problems
  112. my cabrio's radio just shut down!!
  113. Problem with 99 Cabrio
  114. Removing/Repair Rust before Painting
  115. Fuel Leak
  116. 1995-2002 Cabrio Convertible Top boot cover
  117. 99 Cabrio Transmission Fluid
  118. 02 cabrio driver side window stops
  119. cabrio 2000 16v engine conversion
  120. 85 Cabrio over heating help please
  121. Differance between 93-99 and 00-03
  122. Yep a none starter
  123. Power Steering fluid
  124. VW Cabrio is stuck in park
  125. My fan stopped working!! (2002 Cabrio)
  126. '91 Cabriolet Restoration
  127. 96 Cabrio Transmission problems
  128. Obdii Problem Po411
  129. crankcase ventilation
  130. How do I replace V-Belt on 99 Cabrio
  131. Wanted-Opinion on paint job
  132. German built '84/85 Volks Cabrio-accident yesterday-Possible sale:parts? need advice
  133. 91 Cabriolet socket size?
  134. Heat Shield Rattle
  135. fuel pressure
  136. Sometimes can't press button on shifter
  137. 97 cabrio flooding no codes
  138. Help ! Driver's side won't turn off alarm
  139. Horn Replacement
  140. cabrio wont star
  141. I think It might be junk
  142. My cooling fan will not shut off after driving. Any Ideas?
  143. Rain or humidity Starting problem
  144. Speedometer does not work
  145. help with my 2001 vw cabrio convertble top not working
  146. ODB Codes
  147. 95 cabrio speed/tach does not work
  148. Who Knows The Firing Order??
  149. hesitation 87 cabrio
  150. in need of parts!
  151. Undergapped plugs a mystery
  152. Unexplainable non start
  153. 1992 4 sale
  154. Ghange Cabrio Headlights
  155. ?selling? recovered cabrio, please help
  156. By the way...my Cabrio Convertible is manual install
  157. Need covertible top for my VW Cabrio
  158. Fuel Pump For Sale- Yup.its Brand New!
  159. Lost Key
  160. Wheel jerks to the left when accelerating
  161. 1995 Golf Cabriolet intermittent non-starter
  162. Check Engine Light
  163. Hydraulic lift replacement
  164. Need a 2000 cabrio key
  165. Center Console
  166. starting problems after rain
  167. 84 cabriolet
  168. sequence for entering radio code 1999 VW Cabrio
  169. 1999 Cabrio, new battery, radio not working
  170. lights and air not working
  171. WTB: I'm looking to buy a cabrio anyone got one for sale?
  172. Starting Issues
  173. 2001 - Drivers window squeaks / rattles
  174. 2002 Cabrio Turn signal buzzes
  175. power goes out downshifting
  176. Turn Signals Do Not Work
  177. steering rack removal
  178. Temperature Gauge
  179. 2000 Cabrio CHECK ENGINE LIGHT
  180. 2000 Cabrio Steering Problem
  181. How to change 2000 Cabrio Headlights
  182. passenger door
  183. cabrio doesn't start
  184. 1987 Cabriolet AC system
  185. 1987 VW Cabriolet Power Steering
  186. gas tank leak
  187. back window broke
  188. alarm malfunction
  189. Der Diesel is dead
  190. Parts swap!!
  191. 2001 Cabrio GLX: Noise that Wont Stop
  192. Gas Pump Pops
  193. My car is evil
  194. Damn Starter
  195. 1.8t cabby for sale
  196. Battery & Check Engine Light
  197. Cabrio...hmmm
  198. Car Over Heating in Traffic
  199. Speedometer/Tachometer
  200. Jumpy Speedo Problem
  201. 1995 Cabrio Factory Stereo Lost Power
  202. Inner Headlights On 91 Cabrio
  203. 1996 Cabrio Head Unit install directions
  204. Wanting to buy one..need help
  205. How reliable are cabrios?
  206. Cost of brakes
  207. WTB cabby white interior 86-91
  208. charging system problem
  209. 1987 cabriolet no start
  210. Cabriolet Problems
  211. Cool Cabriolet Items - cleaning out garage
  212. Moldings
  213. FS 1985 Cabriolet IN PA
  214. new seats ????
  215. Broken Door Lock
  216. Cabrio convertible top lawsuit
  217. Roof Cover ?? How do I get one?
  218. Timing Belt Question (DIY?)
  219. Salvaged Title
  220. timing nightmare
  221. Power hood not working
  222. 1987 cabrio speedo out...
  223. Headlight out
  224. Corrado Brakes On Cabrio ?
  225. Fuel system problem 89 Wolfsburg Cabriolet
  226. Fuel system problem
  227. Drill bit size for front license bracket
  228. convertible top installation
  229. FS: 1990 VW Cabriolet Karmann Edition
  230. Is a Cabriolet a chick car?
  231. FI for the 2.0 8v
  232. head unit replacement
  233. Can't open hood
  234. Engine rattle.
  235. I Need Used Parts...
  236. convertible top cracking
  237. VWsites.com is a nice Volkswagen resource
  238. '87 Cabriolet Starting
  239. Reprogramming keyless Remotes
  240. Mercedes Style Cabrio Lights for sale
  241. MIL code 455 Evap control system, gross leak
  242. Check engine light
  243. Hello, new girl here...
  244. how much?
  245. bumper, fender i need repairs!!
  246. Vr6
  247. Technical questions, troubleshooting etc.
  248. cabrio headlights
  249. Carbon Fiber Steering Wheel --nice
  250. Hard starting an '89 Cabriolet
