Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Volkswagen
> GTI
View Full Version :
GTI
Pages :
1
2
3
4
5
transmission or clutch failure of some sort
alarm issues and locks please help
car stopped while driving
Knocking when i turn the wheel
Rear Trunk hatch won't open
2010 GTI Issues So Far
mk3 golf gti start problem
GTI or VR6? mpg vs power
ccmtek smart remote help
OBDII VR6 help!!!!!!
Help! Does exhaust from VR6 GTI fix on 1.8T GTI??
double din+phat box/noise
Mkiii vr6????
performance-cafe.com+bad results
Loss of power on low fuel???
Futrell Autowerks VW MK6 GTI Project Unfinished business
Good Evening
I NEED QUICK ANSWER, what would win gti vr6 or 1.8 T stock for stock
What would win, a gti vr6 or a stratus sr stock for stock>
Vibration/Resonance between 65 and 75 mph
O2 sensor check engine light?
GTI power/ HID light out
How deep should the clutch be depressed?
GTI vs. Mitsubishi ralliart
Third clutch to fail and only 92,000 miles
GTI paint restoring suggestions
2010 Volkswagen GTI
hall sensor code 00515???
mk3 gti missfires
98 Golf GTI fires, but won't start
i need help...
newby here!
Engine light flash engine grinds
no pick up
03' GTI Cruise malfunction
higher mileage Mk 4 problems
rust problem
light selector switch
strut mounts
my baby is sick
91 Mk2 Gti - Electric Window Fuse
GTI Blow off valve
2002 GTI not starting
Brand New Gti Mk.V
2003 GTI-burn out
5th gear
2003 20th Anniv GTI jammed cruise control
saying hello
Buying a GTI vr6
Video: R32 vs. mazdaspeed 3
87 GTI no start
False Overheating Problem
03 GTI 1.8t electrical problems
Rain Gutters/Door Seals
trouble with my mk3 gti
97' GTI - ABS malfunct & signal
Ground Hum
WTT.MK2 for a mk4
1985 GTI Oil Filter Housing Leak
Transmission Dipstick??
Ignition Switch=Cold Start Problems?
Stock 1.8T vs. VR6
GTI 1.8T-Looking to chip it?
interior lights & power windows & sunroof not working? HELP
looking for info on 2002 golf gti vr6
Thinking about buying a VR6
Bad Vibration
how can i find parts!!
2001 GTI Interior fan problem
Car Service 75000+ miles
83 Rabbit/gti For Sale
2003 GTI mods-what can i do???
2003 GTI fog lights
91 GTI overheats every time it rains
gti vr6 or gti 1.8t
I have a GTI VR6 Wont start
2003 GTI 1.8T- new purchase
03 1.8T- remote controller stopped working
03 GTI 1.8t airbag light stays on when i drive
2003 GTI radio stations not clear
newb from philly area.....
02 gti trans problem
Newbie Oil Change
"Limp Mode"?? on a 1.8 T...
props on a gti
Fmic
Newbie Needs Help
2002 gti vr6 12v - question
oil
Fuse location
monster mats vs Weathertech floor liner or even the weathertech mat which is better?
87 GTI Ignition Lock Cylinder Replacement
2.0 turbo
Golf Questions
New Clutch
Buying VR6, need input
Vw Golf Gti 1.8t Airbag Light Problem.
BRAND NEW PAUTER RODS must sell
Re Map
Buying a R32 w/high miles.. Advise!
HELP!! Power Loss - GTI MKIV 1.8T
Diferentiating o2 sensors?
1,8t Suspension Noise
Help!!!
parts
VW previews the 2008 Scirocco production model
oil leak on a 88 gti engine, any ideas???
mpg question
1990 golf gti 2500rpm&3000
Preventive Maintenance
need help on starting/idle problem
mk3 gti golf gearbox
91 GTi just lost 5th gear!?!
87 GTI Digital Clock Module Setting
Random Spluttering - VW Mk2 Golf GTI 8v
03 GTI Died
my mods and comments
power steering- wrong fluid and leaks- any chemists out there?
FS: Brandnew Magnaflow
sensor?
New Brakes
rough idle and stumble at acceleration
Speedo and Tach
Red Flashing Light Problem
02 Gti T - Emission Warning light
2001 GTI VR6 - O2 Sensor or Mass Air Flow Sensor
My GTI Drawing !
2001 Volkswagen GTI- CEL PO420
GTI or VR6
98 GTI Should I buy it?
V Dub Nu Be
sweet GTi R Video From SEMA
mk2 gti questions
2001 gti Engine light blues
Audi 2.7T + trans
help!!! vr6 overheating
A/c?
golf gti problem
What mods do you guys recommend?
Golf G T I
Side marker light!!!/ autotech
Mk3 gti stalls then won't restart!
Should I Swap Rebuilt Engine??
should i buy this gti help asap!!!
Oil Pan Help
Stuck in Drive
Stop My ALARM!!!!
looking how to get factory race 8valve motor from japan
1990 GTi
vr6 misfire
Gti Issues!! Pls Help!!
New Volkswagen Polo GTI
Wiring diagram for mk3 GTI?
K&N Air Filters on 2.8 Vr6
turbo question
safe hp levels on ko3 and ko4
Curious...
89 gti cranks but no start, help?!
2004 R32
New Car
Any MkV's?
01'GTI VR6 GLX A/C Problem
safe boost on 06 getta gti?
Turbo Boost question
98 gti
a couple of questions about bov
Hatch not opening
Light Bulbs
87 GTI froont end damage What can I use
Information
Wheres my thermostat??
Golf Mk4 Gti 1.8t Intermittent Loss Of Power
need power steering motor... 2 much noise!
Boost!!!
Whats Your MPG? golf mk3 gti
suitcase exhaust replacement
Mk3 who knows anything about transmission?
wtb gti in midwest area
Help needed for a novice!
Help!!! Bad Vibration
wheels for sail
mk3 16V HELP!!.....please
vdubmech i need ur opin
Swapping speedometer?
04 GTI 1.8T braking on its own while driving/ parked!!
MK3 not starting
1985 2.0L 16V GTi
What should i expect?
87 Gti
Vee Dub New-B
04 GTI 1.8T needs a good home
89 golf gti wont start :(
Transmission troubles, PLEASE HELP!
ASR warning light stay on all the time
01 gti vr6
CEL will not stay off
Golf GTI relays
84 rabbit GTI problems
Underdrive Pulleys on 96 GTI VR6
Cheap Horsepower
Bulbs
03 gti turbo air/fuel
MK3 GTI 8v cut off
Golf Mark 5 GTI's commercial
was driving then cut off an want turn over or start
Cat removal - VR6 - someone's gotta know (?)
Did VW mess up with the New GTi???
Looking to buy a 02-05 GTI 1.8T
Lock function doesnt work on new/old Keyless remote
check engine light and airbag light failure
2001 vr6 gti 17" wheels
GTI Test drive
PLZ help MKIII VR6 exhaust questions
Blitz DTT (Wiring Harness; does it exist?)
Alarm Problems MK4 1.8T
MKII GTI - Fuel Gauge Adjusting...Possible?!?
'01 GTI VR6 Interior Weather Strip Problem
im gonna call my car a lemon soon
1998 vr6 won't start
How much
Any 1988-1989 GTI's for sale?
golf gti 16v mk2
91 GTi 8V Temp Sensor issues and heater fan issues among others
New R32
Belt Tensioner???
Car Needed For Sport Compact Car
front mounted inter cooler for 1.8 turbo
faulty indicators and in car heating
Dang am I surprised!!!
98 git vr6 power cutoff
car wont start alternator belt 88 gti
MY Door!!
Warning lights
Suspensio Weird sound HELP!
water in the spare tire area
vwmechanic i need ur help
'02 GTI Check engine light...
Important
gti 2002 1.8t teptronic
Newbie to VR6..
GTI or VR6
2002 GTI VR6 Electrial Failures!
things to think about... and pics!
fk cup kit
Type of bolt head on cv axle
cold air intake
Gti Mk2 engine power loss
Is it possible to use the switch-key from newer models on a 1998 Gti?
98 VR6 : remote "LOCK" no longer works...
Automotive Network, Inc., Copyright ©2012
