View Full Version : Golf
- 96 GL with antifreeze in the oil...
- 1995 vw golf 2.0 check engine light
- Golf Mk3 Estate interior light
- 98 golf, starter turns, doesn't seem to engage...
- 86 VW Golf Stopped Running-Electrical?
- 87 golf 1.8 no power warms up runs good
- vag dash can v5.17 with can-bus
- Radiator fan drains battery
- VW Golf speakers humming
- mk6 Golf Manuals
- Crazy Electrical Problem-2005 VW Golf
- Car dies in heavy rain...
- no ground to fuel pump relay
- 97 vw golf headlights don't work
- Car Similar to Subaru Impreza or VW Golf
- Should I? [Questions on my Golf]
- Calibrating The Speedometer
- 1996 VW golf rims
- MK2 Front seat removal
- Rerouting the power for my cigarette lighter
- golf mk3 gti central locking
- 1994 golf radiator fan problem
- 2001 Golf, 97K, $6,000 -- Should I buy?
- 97 Golf needs transmission fluid...
- 1997 Golf
- 1999 Golf 2.0GL Shuts Down While Driving
- 97' Golf has no signals
- New Volkswagen Golf coupe sketch
- golf gti 8v missfires
- 1985 VW diesel won't start?
- mk3 golf
- Radiator Fan makes terrible noise
- vw golf mk3 1994
- leak from proportion brake valve on golf mk3 '94
- VW 2005 cig lighter issue. Help.
- Replacing radiator procedure - 95 Golf 4 cyl
- '01 TDI turbo issue?
- fuel pressure
- 1992 Golf GTI
- alarm
- Dash light stays on
- engine problems in wet weather
- Un-explained dash light?
- hatch door of 2008 vw golf
- Golf 1.9 D idler bearing
- VR6 into a 2 door golf?
- Oil pressure alarm and light
- Does anyone know where I can get tints fitted?
- I can't tell if I have an AEG or AVH!
- 2001 Golf 4 1.6L gasoline engine injectors?
- Programming keyless remote...
- 96 Golf won't start
- 96 golf front wiper problem
- No rear brake pads or drums?
- Bleeding brakes on 97 Golf
- Spot lamp problem.Help needed.
- '01 Golf 1.8T coolant temp Q:
- R250: VW Golf5/Passat 2006/2007 Dashboard Programmer
- golf VI
- Microphone and Alarm
- Volkswagen Golf VI
- electrical issues
- 2004 golf fans and egr vave??
- VW Golf -04 Fuse chart
- golf 2.0 / 2003 AC Problem
- 92 VW Golf ECU/ECM Location!
- 96 golf overheating
- RE : Radio Installed.....was working now not ?
- How do I get the distributor back in right?
- Do I need a new ignition coil? etc... for passing CA smog test...
- 86 Golf Diesel
- Golf -04/ "Emissions workshop" / help pls
- City Golf '08: Reliable, or should I stay away?
- Tail Light help
- 1990 golf sputtering and dying
- Carfax Report please
- 1999 Golf cutting out and starting up again while driving.
- 92 Golf - Baby seat install
- 96 Golf GL Cuts Out while driving
- Where is the fuel door release??
- Evap leak (small)
- 1985 Golf warm hard starting problem
- 1998 Volkswagen Golf Electrical Issues
- VW Bora windows steaming up after rain
- OBD II for 1995 Golf ????
- ECU fails repeatedly on '97 Golf Cabrio
- i need a clutch kit for 98 golf
- MKV Radio Problems
- VW Golf-96
- Car turns over but wont start...
- 95 2.0 golf wont turn off...
- 2.0L Golf bogging and sluggish.. info??
- fuel filter change
- 97 golf immobiliser probs
- 1996 golf - trouble starting
- 2002 Golf Preventative Maintenance
- starting problem
- 96 Golf Classic - Intermittent Trouble Starting Car: Suggestions Please?
- Help please vr6 wont start
- 86 golf diesel
- Brakes Squeaking?
- Puzzle With Oil light...
- Electrical Problems w/ 1999 Golf
- 94 golf, very weak power
- VW part sites...
- 94 Golf Driver going through a lot of petrol any help
- 96' GL 2.0 Golf won't turn over...
- Radiator Problems
- OBd sensor
- MK 3 Golf front suspension bush replacement
- fuel/air mixture ratio
- 1987 golf gl won't run...
- 86 golf oil leak
- 94 VW Golf Shutting off
- Golf Mk3 Electric Window probs????
- wiper switch 95 Golf III
- 90amp to 140amp alternator
- 87 vw golf gl starting problem
- 96 golf
- 97 Golf radio problems
- 98 Golf GL Overheating but fluid looks ok
- Help Me Please!!!!!!!!
- wont start
- 97 Golf air conditioner quits
- How do you get rid of 'SERVICE NOW' msg???!!!
- 1996 'P' Mk3 Golf CL Diesel 5 speed manual gearbox
- Please Help!
- 01 Golf 1.8T Question?
- "Shake" at low rev and low power
- 94 golf3
- Mk3 1.6CL Cold Start Problems
- Driver 1.8 Oil Problem
- Golf 3, 1.6 won't start when its hot, ideas?
- 98 Golf Muffler rattles after tow hitch install
- side indicators (repeaters) not working
- 2 l 16v in a golf
- 1998 Golf Gti Problem Please Help
- Need Help With My Alarm On My 93 Golf
- 97 Golf 1.6 GL just cuts out when driving
- 97 Golf
- 1.6 abu to 2.0l gti
- 95 golf
- new rims
- GOLF 2.0 1995 it won't start HELP
- pic request
- aiming the headlights on a 2005 golf
- Golf Mach 3 96 - Fails to start after a long journey
- Light Notification Sound Not Working Anymore
- 99 Golf- Problems with driver door lock
- Front passenger seatbelt stuck & air bag light on!
- Thoughts on 98 Golf GL model?
- 1991 Golf Clipper not starting
- '97 Golf Diesel TD
- Golf 1997 takes time to start...
- Lock issues with 95 Golf 3
- Wierd Mk3 Overheating problem
- Mark 3 Golf Cabriolet Door Locks
- Load Capacity
- Auto aftermarket parts
- 4 doors
- 99 Golf won't start
- 94 Golf Cl Elec Problems
- Oil Light Problem
- Electrical problem Golf 1997
- Radio lock?
- VW Golf for sale
- 1995 2.0 Golf won't start...
- 1999 Golf Starting Problem
- Wierd Starting Problem after Engine shutdown while driving
- 92 Golf won't start
- No voltage/current to ignition
- MK3 2.0 Starting problem solved
- pollon filter mk4 golf
- EPC problem with golf Mk4 2001
- Just starting need direction HELP!
- city golf
- programming key
- VR6 Staring Problem-Help-
- Golf GTI tuning
- gti 16v mk2 prob 1991
- golf iv dumping fuel '99
- Volkswagen Golf R GTI – tuning for the year 2007
- 2000 Golf Auto trans deays from a stop
- 1986 Golf CL Gearbox problems
- A problem for true digi geeks
- Golf - vibrates when stationery
- golf 1.8T good way to make the BOV sound louder?
- Fuse location
- electrical (lights ) problem on my mk2
- NA fog light cover left!!!! help!
- Endless Problems
- electrical prob
- Fresno Car Clubs?????????
- Diesel Timing
- Diesel Timing
- Golf diesel camshaft problem
- 2000 Golf Rally Auto not changing Gears Properly
- 92 golf won't start!! help!!
- HELP 95 golf alarm wont turn off
- A/C or such
- 94 golf
- Disarming Alarm??
- 97 golf battery blew-up
- Golf hot starting problems
- 1991 golf gti 8v wont start, help please!
- MK3 Golf VR6 - MFA comp
- Mk3 Golf oil leak problem!
- MK4 Golf Problem with lock
- Cabin Air Filter
- VW Golf 5 GTI tuning
- 2000 tdi golf tie rod removal
- What Type Of Golf Is This???
- '99 Golf Electrical Gremlins
- Alert signal problems
- thinking of buying a 91 Golf diesel
- Leaking oil...on a 95 2.0
- vw golf mk 3 gearbox
- Mk3 radiator cooling fan and motor.
- The R32 or the 1.8T?
- Persistent misfire
- need to know firing order for 96 golf
- i found out how to open the fuel door on my golf
- Front wheel bearing problem
- Official Topic of all VW Golf III, make comments and upload pictures of your cars
- air conditioner won't work at idle
- how do i open the fuel door on my golf??
- VW Golf, VR6, '98 - No computer communication
- VW Golf VR6, '98 - 5th gear problem
- VW Golf VR6, '98 - Air Bag Light Reset
- Biodiesel Conversion
- battery problem
- 2001 VW Golf TDI engine oil pressure light
- 94 Golf no start in hot weather (no crank)
- Help needed starting Golf IV
- someone please help! 94 golf diesel
- cromodora alloy wheel center caps
- 1994 Golf - Oil pressure light keeps coming on
- Gear gater
- 2001 Golf Alarm/Keyless Entry Question.
- vibration damper question
- Unable to start when hot
- Light Bulbs
- WTB: Rubber Door Seals 91 Golf GL
- Aircon = -hp
- VR6 engine
- inner tie rods, WHERE TO BUY THEM?
- WTB: Exhaust Seal Ring for my 91' 1.8L 8V Golf MEX
Automotive Network, Inc., Copyright ©2012
