View Full Version : Golf
Pages : 1 2 [3] 4 5
  1. golf parts on a fox
  2. engine swap
  3. Help!
  4. remote won't lock doors (99 golf GLS)
  5. Chipping a Golf...
  6. Euro Bumper doh!
  7. door swap
  8. 1997 Golf GTi dies when idling with AC
  9. Golf III GL Crankshaft/Pulley shaking
  10. clutch
  11. golf/rabbit seats
  12. 97 Golf Alarm/electrical problem
  13. conversion to manual ingition distributor
  14. '00 2.0l
  15. oil leack from the carburettor
  16. 89 golf
  17. Noises
  18. Heater Control on 2000 TDI
  19. engine chokes in hot weather
  20. air conditioning plague...im dying in this heat!
  21. oil....air filter...why?
  22. Short Shifter help please...
  23. Radiator fan not working
  24. Help. How to open gas tank cover(1994 Golf.III-4 door hatchback)
  25. stereo in 94 golf needs attitude adjustment
  26. 1992 Golf Diesel
  27. 97 golf 1.8 does not start.
  28. im a bigginer
  29. timing belt
  30. 94 Golf Daytime running lights stopped working.
  31. Used Golf
  32. Newbie
  33. Air conditioner evaporator drain, 88 Golf
  34. automatic gearbox
  35. Intake Issues?!?!?! Argh?
  36. 2000 golf trouble codes
  37. VW Golf '99 Brake Lights Not Working!
  38. 92 Golf wont start
  39. i have a P1476 P0411???
  40. Leaks!!! HELP!!!
  41. Thanks a grip!!
  42. Golf T plate - no dash/clock illumination?
  43. mk1 golf cabrio cutting out
  44. 2000 golf overheating?
  45. Resurface Rotors?
  46. Best Cold Air Intake for a 93 golf III
  47. 1999 Mk IV golf starting problems
  48. 1987 golf gl stereo wiring diagram
  49. 96 golf won't start
  50. VW Golf IV alarm won't disarm & power locks wont work
  51. occasional stall
  52. lights-on warning buzzer
  53. 94 golf cranks wont start
  54. 2000 GLS 4L tail light lens
  55. Wet start electrics.
  56. driving on ice?
  57. 1996 Golf Oil Light
  58. ignition timing
  59. 96 golf starting problem, starter sound but engine doesn't turn
  60. 2 problems
  61. wipers
  62. engine code
  63. wiper confusion
  64. VW Golf Oil Consumption
  65. Golf 4 technichal manual
  66. Over fueling problems in golf mk3
  67. Sunroof working intermittently
  68. Golf 3 Turbo Diesel Stalling
  69. Chiltons For Sale
  70. Complicated exhaust question
  71. Remove window
  72. Alarm problem Drivers door 1996 Golf
  73. safe radio
  74. FS 17 inch flik wasp black with tires
  75. Loud???
  76. MKIII muffler
  77. climate control lights come on intermitently
  78. Alarm goes off if I leave motor running.
  79. Cold Air Intake
  80. Replacing Oil Pump
  81. Golf stereo
  82. remove service light
  83. Golf Auto Trans problems...won't upshift
  84. Sunroof conversion- power to manual
  85. Golf
  86. 96 golf good car ????
  87. 96 golf good car ????
  88. What oil brands can I use with my new TDI?
  89. Intermittant Seat Belt Light and Clock, trip counter reset on their own!
  90. engine won't start after rain
  91. Should I buy - Golf '92?
  92. 96 Golf overheating!!
  93. Golf 1.3 H Reg - Another Non-Starter
  94. 94 Golf 111 won't start when cool,ughhh!
  95. '86 vw golf gt stalling
  96. Airbag suspension
  97. 95 Golf lock problem
  98. Newbie to AF and an engine stalling problem
  99. Radio Unlock Code for 1990 Golf
  100. rear bumper
  101. Sorry if this is off subject...
  102. Standard trans,no reverse
  103. a plethora of questions
  104. 88 16v golf accelerator
  105. Stalling problem!
  106. Cluster Lights
  107. painting a golf
  108. Golf mk. 4 V5 egine pics
  109. How to make a 93 cl faster for cheap?
  110. 88 16v golf idling problem
  111. No Headlights, wipers, fan blower!
  112. 1990 Golf Headlights/ fogs
  113. Should VW make a new R32?
  114. Temp light flashing and temp guage not working
  115. Mk3 Dodgy 12v ignition line due to key switch?!
  116. vw golf won't fire hellllp please
  117. possible engine swaps
  118. Ignition Switch on a 95 Golf
  119. 2000 Golf Bad Electrical Problems
  120. 1.8 or 2.0
  121. Green Lights To Red?
  122. Golf Crank Seal Replacement
  123. 1993 Golf stalling
  124. Help!!!!!!
  125. 87 Golf 16V idles at 3000RPM!!!
  126. VR6 idle issue + other question
  127. 1996 vw golf 1.6 cl
  128. evaporator install 97 golf
  129. No Power
  130. No revs on TDI Golf
  131. sevice code display
  132. What's early vs late 99 Golf?
  133. Fan Belts
  134. Car horn gone crazy
  135. heater suddenly blows cold air at running temp
  136. mk3 golf gti gearstick knob
  137. head lights
  138. Door Adjustment
  139. Golf 1.8 CL 1993 cold start problem
  140. How do i add another transponder key Mk3 golf/Vento
  141. Burning Oil////90k maint.
  142. 1985 vw Golf axle nut size?
  143. 1996 G3 2.0 16v "WON'T START"
  144. 85 Golf trans swap with 92 Golf diesel
  145. 1989 1.3 Mk2 Golf, Cutting out when idling
  146. Help! Battery Install
  147. tach wire?
  148. MK4 Golf GTTDI 115bhp coolant problem
  149. 97 golf seats
  150. 2005 Volkswagen Golf GLS TDI
  151. Golf Mk2 1990 1275cc
  152. Post your Golf!
  153. engine swap
  154. Parting Out 97 MK3
  155. 1994 Golf question
  156. lectronic wiring?
  157. Rpm gauge
  158. Driver Electric Window not working but all the others are
  159. removal of steering rack and installation pls help
  160. cold air intake pipe
  161. problem with 1st and 2nd speed at first changes
  162. 94 golf 1.9 match diesel
  163. Programme key fob Golf VR6 1997
  164. 91 VW Golf GL won't start! HELP!
  165. 1993 Golf Gti won't start.
  166. 1992 Golf - stalls when cold
  167. Check Out this Twin Turbo R32
  168. how do you change a rear tail light bulb on a 1996 golf?
  169. 89 golf rattles/burnt rubber smell
  170. Door a jar light and the interiors
  171. New keyless entry transmitter
  172. Door lock problem
  173. hesitation in engine/cold air intake installation
  174. lights and heat
  175. 94 Golf III stopping when hot
  176. help..with warning sigals...driver side door
  177. Golf Driver Heater problems
  178. Stock speakers?
  179. Golf electrical mystery
  180. Reverse Lights
  181. 95 golf heater motor quit running
  182. help car won't start at all
  183. alarm malfunction
  184. XM Satellite Radio
  185. how much in germany?
  186. 2000 Golf engine warning light
  187. '89 steering rack
  188. I have a problem with my VR6...
  189. golf or rabbit?
  190. Micro switch in driver's door (98 Golf)?
  191. 98 Golf...Three Beeps? Electrical Problems? WTF?
  192. 96 won't retain coolant
  193. Need Chevy windshield in Iraq NOW
  194. removing battery
  195. 92 Golf Loses spark
  196. electrical problems in my 85 Golf
  197. bad electrical problem
  198. 98 golf won't start
  199. Alarm problem
  200. 'safe' radio
  201. Thanks for very little!! Waht a waste of time
  202. rainy day stalled my golf
  203. Why dosen't anyone help??
  204. Please help me on this thread
  205. Glof TDi 1997 Clutch Pedal
  206. Absolutely no spark!!! Is it junk?
  207. Clutch Pedal Problem
  208. Whats your Favorite golf?
  209. Rainbow Car Audio VW GOLF III Speakers
  210. mass air flow sensor
  211. Turbo 1.9 Diesel Swap
  212. replace bulb
  213. 1.8T Chip - APR or GIAC?
  214. 99 golf P0171 trouble code Bank 1 too lean
  215. tapping noise from camshaft
  216. help i need to check my oil pressure
  217. Clocks zero on startup
  218. 1990 golf heater problem
  219. My Door Wont Close
  220. required to stop every 30 mins
  221. Golf TDI max speed 75 mph
  222. Golf TDI glowplugs
  223. MK2 Golf- Problematic Auto choke
  224. oil leak (boschmann???)
  225. Help, 1998 Golf won't start in the cold (boschmann??)
  226. HID/Bright Headlight Conversion
  227. Overheating problems diong my head in!!!!
  228. 92 GTI gas tank needed
  229. heater lights, back up lights
  230. Proud of your car?
  231. 98 Golf Won't Start When Cold
  232. TDI Performance
  233. If it could just break a little slower...
  234. fuel delivery problems
  235. more factory alarm problems (boschman???)
  236. Won't Crank (Will push start)
  237. Nasty Sound On Accelleration
  238. GT TDi engine stopped...why?
  239. New.....R32
  240. high milage
  241. gas pedal flopped on floor
  242. mk2 1.3 '89 (carburetor)
  243. Temperature gauge
  244. 1990 1781cc Golf clipper cabriolet
  245. 96 alarm
  246. engine ID search
  247. Golf III 1997 1.6 GL Stops
  248. headlights
  249. body damage
  250. upgrades
