View Full Version : Golf
Pages : 1 [2] 3 4 5
  1. wheels for sail
  2. looking for a 98 golf
  3. mk3 GTI 16V! Does anyone Know?
  4. 97 GTI Wipers
  5. are all 2.0L 16V the same for parts?
  6. CHECK ENGINE light
  7. Need advice on finding a mod.
  8. Shift linkage bushings mklll
  9. Mk2 Golf for sale
  10. 2002 GLS losing power
  11. 1998 Golf GTI
  12. Golf 1996 power steering
  13. MK3 Diy thread
  14. Golf MK3 Air Filter/Intake????
  15. Air Baggin a Golf
  16. 96 golf 2.0 clutch cable question???
  17. VW Golf noisy power steering
  18. Golf VR6 Hiline 97 - Heated seat not working?
  19. moulding clips?
  20. 5 Cylinder Engines
  21. RPM Madness!!
  22. Mk V R32
  23. E-Brake problem
  24. UK MK3 1.8L CL owners....
  25. 96 4 cyl auto maybe running on 3?
  26. radio is killing my battery
  27. Mk3 Golf Engine Doesn't Idle
  28. Mk4 VR6 swap in Mk3 Golf
  29. Any 1.9L turbo diesel drivers out there??
  30. MK2 Golf Cooalnt problem can you help me?....please
  31. Smoked Angle Eyes Upgrade
  32. Spluttering 99' Golf 4 1.8 20v
  33. GOLF 96 Light and Fan question.
  34. 1992 Golf GL Overheating
  35. Opinions please.
  36. F/S NJ - 1999 Volkswagen Golf 5 Speed
  37. VW Golf 2006
  38. Diesel golf, gti, jetta
  39. help with my mk2 golf 1.6
  40. r32 1/4 mile time
  41. Oxygen Sensor
  42. Water Leak Under Dash 94 Golf
  43. looking for TDI
  44. Gaerbox oil issue
  45. Gaerbox oil
  46. Stalling problems with Golf 1.6CL
  47. Another Problem...
  48. buying a mk3/4 in the U.K
  49. Opinion on 97 golf
  50. Golf GL to GTI
  51. Starting and alarm problem...
  52. Volkwagen 1994 FORESALE
  53. 88digifant to a 84 gti motor swap
  54. Headlights Stay On!!!
  55. no reverse lights!!!!!
  56. 1st Time post...help needed?
  57. Golf Mk IV V5 Tail Light Replacement
  58. GTI 1990 1.8 manual - starting problem
  59. proper alternator.
  60. 94 golf diesel engine swap-or injector?
  61. 92 Golf Test Mass Air Flow Sensor (Hard Start and Hesitation)
  62. Need front left frame Golf MK4
  63. Need front left frame Golf MK4
  64. electrical problem...alternator maybe? MKIV 2.0
  65. mk4 indicators won't blink
  66. Gearbox problem
  67. Gearbox problem
  68. head bolts
  69. MkII engine cut out, won't start
  70. 2002 Golf TDI door lock blank
  71. HELP.....Overheating 93 Golf...
  72. Driver side door lock
  73. inner door panels
  74. Going crazy Electrical Problems
  75. 98 golf: remote alarms car but won't lock/unlock
  76. Golf Mk3 1.8 For Sale
  77. Can i get an induction kit for mk3 1.4cl
  78. Golf Mk3 Intermittent Stopping
  79. why wont my heater controls light up?
  80. timing issues 92 golf 1.8L 8-valve
  81. Quick question
  82. ECU chip (2.0 L 8V) and clear euro-style corner lights
  83. Clicking Relay ?
  84. dent removal?
  85. what does SR mean?
  86. Sunroof stuck open on tilt
  87. Where is the thermostat on 91 Golf
  88. Golf Mk 2 Engines
  89. Paint code
  90. Brake Fluid for '79 Golf GLD
  91. 1/4 time
  92. Oil light flashing Car wont start HELP! - VW Golf 1.4i
  93. mk3 engine problem
  94. Having problems staring my Golf 95 CL - HELP!!
  95. Exhaust?!?!?!?!?!
  96. Golf epc/ecu problem cranks but wont start
  97. 89 Mk2 1.8 idling probs
  98. I have a question about electric system
  99. look for spare mk3
  100. Steering Wheel
  101. Oil leak question???
  102. Cold Start Problem (Please HELP!!!)
  103. MK4 Heater has packed up
  104. Golf Mk3 engine running badly at low revs
  105. 1992 Golf GL: "Boots" on CV Joints!
  106. new to VW Golf
  107. Electrical Demons
  108. Knocking sound in 1st and 2nd gear
  109. E-brake Cables
  110. Looking for Used Diesel Golf or GTI
  111. Who has any idea which race this VW Golf ever raced?
  112. stud diameter for mk3??
  113. Central Locking
  114. Coolant Warning
  115. United Kingdom - R32 availability?
  116. Alarm not functioning correctly
  117. Mk4 Golf Central Locking Probs & WIPERS
  118. headlights.....not there...:P
  119. Auto trans not fully going into reverse
  120. '92 Golf - Directionals not working
  121. After rattle when acceperator is released ?
  122. spark plugs
  123. '95 VR6 wont start....HELP!?!
  124. ALARM Someone just shoot me and save the insanity
  125. Hot & Cold
  126. ingnition switch replacement procedure
  127. '95 Golf III Oil in Air Filter??
  128. VR6 Fuel Smell
  129. My new ride
  130. alarm bypass and still no start
  131. MK II Dash Lights?
  132. Timing Belt Replacement On Golf Mk3
  133. ??? Highest Mileage ???
  134. fuel filter removal....
  135. 96 golf few ?s
  136. 4-Motion Overheating
  137. golf stalls when i put it gear??
  138. hrlp electrical gremilins
  139. Special window tinting
  140. My vw wont start number 5000 ha
  141. Alarm and Central Locking Issues, MK4 Golf
  142. Wheel setback
  143. pcv valve
  144. wiring 03 golf 1.4
  145. need help finding a part
  146. squeal/whirl noise from mk4 golf on idle
  147. Head swap
  148. car wont start HELP
  149. Acceleration Issues
  150. Mk4 1.6 Auto Hesitation from standstill
  151. Mk4 1.6 Auto Excessive fuel consumption
  152. help! 85 diesel golf ignition switch removal
  153. various quirky problems 2000 Golf GLS 2.0
  154. Headlight hell
  155. Interior like a swimming pool
  156. Mk4 1.4 stalling for no aparant reason
  157. 1992 Golf GL - - BRAKES!
  158. confused front wipers.. 1 works 1 doesn't
  159. 1988 Mk 2 Golf Won't Idle
  160. Everything electical acting up, car won't start
  161. Electric windows don't work with doors closed.
  162. golf '97 stuttering!!
  163. Vw Golf 1.8 Gti Turbo 1998
  164. brake lines
  165. 2003 VW Golf GTi
  166. ECU remapping 95VW GOLF 2.0L 8V
  167. Any one know where to find to AC Evaporator Drain tube on a 95 VW Golf?
  168. Mk4 Golf GTI 1.8 20V alarm fault
  169. Mk 1 misfire
  170. New Fuel filter
  171. 88 golf smokes and idles bad
  172. upgrading stereo system
  173. 1995 golf 1.8 top end and a 2.0 bottom end I need more gas.
  174. Does anyone have a spare airbox laying around for a Mk3
  175. Corrado G60 parts, good for FI
  176. Golf 95 Gone Crazy !!!!
  177. 97 Golf...wet weather start problems!
  178. idling problems
  179. Outside passenger door handle problems
  180. '04 TDI 4 door banger project
  181. 95 golf won't idle
  182. 1992 Golf "oil separator(?)"
  183. Drivers Side Door Lock
  184. Please Help Me
  185. It wont start when hot weather
  186. Can ANyone Help WIth THese Questions?
  187. 95 golf 2.0 -> black smoke, erratic idle
  188. coolant/fuel gauges both out
  189. Audi A4 Wheels to fit Mk4 Golf?
  190. I have Gremlins....really
  191. Door handle swap
  192. golf gti 1999 non start in hot weather
  193. G-Spec
  194. smell
  195. ?Immobiliser prob golf mk3 vr6
  196. Cutting out problems on mk3 golf gti 2.0 8v
  197. Specs Of Mk3 2e 2.0l 8v
  198. Passenger Door will not open
  199. Help, I'm Overheating!!!!!
  200. Turbo, Prob on Gti Turbo 2000 please help
  201. Died! now wont start
  202. Lowering My 1993 Vw Golf...
  203. Turbo my 93 VW GOLF
  204. 1992 Golf GTI
  205. wipers problems 97 golf
  206. help with intake install
  207. Golf IV 2000 - Half my electrical system just gave up
  208. Golf MK4 coolant warning
  209. 97 golf won't start
  210. service manual for mk3 golf?
  211. remote for a 96 vw golf gl
  212. 97 Golf 1.6 GL intermittent starting and stalling
  213. OBDII Code P1296, new coolant temp sensor right?
  214. timing belt newbie
  215. HELP -HVAC lights not working-
  216. 1995 VW Golf Cabriolet won't start
  217. removing window cranks
  218. ECP light
  219. Passenger Window - little white clips broken
  220. need help check engine code PO442
  221. Random oil warning alarm (part 2) :)
  222. tempermental trunk
  223. 92 Golf GL wont Fire-up w/out starter fluid
  224. Reving Issues when starting car
  225. grime on light covers, what should i do?
  226. VW Golf 1999 Loss of power problem
  227. want to paint interior plastics
  228. Need pics of your gol gti
  229. mk4 1.4
  230. Looking For Euro or German Headlights
  231. 99 golf gearbox issue?
  232. 92 golf hates humidity
  233. What oil to use
  234. priming fuel system on 85 Golf diesel
  235. Free DIY mods?
  236. Oil Pan Replacement
  237. keyless entry
  238. Will They Fit?
  239. Catback Exhaust Furies
  240. Billet grill for a 93 golf.
  241. Tire Turmoil!
  242. intermittant high rev stall
  243. just bought 85 golf, lowbeams not working
  244. I'll post it again.....
  245. Will a Supercharger
  246. 1989 Golf SWAP!!!!!
  247. Faster car
  248. Gas Mileage - MKIII Golf
  249. 96 Golf 1.6cl overheating
  250. Oil pressure light blinks at a stop
