View Full Version : 240
- 2006 volo s40
- 1989 Volvo Wagon 240 DL Windshield wipers stopped working.
- 240 dl Wagon not starting
- 1990 with Weird, Weird Electrical Problem
- Should I consider buying it?
- 85 240 stalling, please help
- 240 electrical issue killing me
- 1990 Automatic: Overdride Solenoid?
- Losing power
- 240 losing power
- 84' Mileage
- Reverse Only!
- Odometer Stopped working
- '88 VOLVO 240 DL EGR valve Location
- 1990 volvo 240dl
- Help please calipers
- mostly '84
- 1989 240 speedometer & odometer not working.
- 1985 Volvo w/stalling & cutting out problems
- Newbie with a speedometer cable issue.
- Overdrive
- 87 240dl badground?
- '90 240DL won't start
- Temperature
- 87 240 car cranks but will not start. no fire
- Where is fuel pump relay located?
- car wont move 89 wagon
- High Mileage 242 GT ?
- 240 stalling out problem
- 240 wagon for studen
- 1990 "Service" light
- Need help here...
- A/c compressor
- Instrument electrical troubles
- 79 volvo 240 cranks wont run
- 240 Wagon Replacement of Lens
- Replaced 240 Alternator -WIRING QUESTION
- Dealer repair gone bad....
- Broken Crankshaft Position Sensor Bracket Solution
- Directional Signals Out!
- Stalls when shifting out of park
- help
- Yet another starting puzzle
- Are 1984 taillights interchangeable with 1990?
- Popping overdrive relays like candy
- Making a 240 a non streetlegal monster toy
- Why does my car eat batteries
- 88 240 dl stalling problem !HELP!
- Thinking about buying a 240 wagon
- 91 240
- Your thoughts on an 1984 240
- Valve Shim Service Tools 5022 & 5026
- starting problem
- 240dl Radio install
- 1983 Volvo 240 DL for sale hunter green. good body orlando, FL . good price!!
- Big guy, need some driver's seat leg room
- 1988 volvo?
- Yet another problem...
- '90 240dl Engine Rebuild
- mods for volvo
- Jetronic hose missing?!
- convert b21 to b23
- 1990 240 w/ starting issues...2 new o2s, fuel pump and relay!
- Which theromstat? 240DL 88
- Need more power!
- Another "Cant Keep Running" post... PLS Read!
- Where are the window fuses?
- 88 240 starting gremlins
- 88 240 DL V-6 Running problem
- Rear brake caliper sticking?
- Volvo - hard starts and hesitates when accelerating
- 89 240DL no start, code 1-4-4
- turbo specs
- Volvo 240 Starting problem, think its the ignition
- starting problems
- Won't run!
- Speedometer and odometer stopped working !! help!
- is it hard to install strut mounts on 240 DL ?
- FOR SALE - 240 located in SoCal
- internal fuel pump
- exhaust system
- Cold Air Intake
- Fires but won't start
- removing brake hose
- tranny is having trouble shifting into 2nd (AT)
- Save the 81!!!
- seat covers sheepskin or? for '87 240Dl
- Brakes suddenly applied while driving!
- directionals not working HELP!!!
- 87 240 dl problem no start
- 240s Pre-Wired for tac?
- FYI oil from fill cap fixed
- 87 244DL 2.2LHjetronic 2.3LI4
- The Silver Bullet
- 84 240 DL wagon start then die then no start
- 87 240 oil from filler cap
- 240 fuel pump noise fixed
- 1989 240 Floorpans
- 89 240 stalls
- need help with alternator problem
- How can i Make my '90 240 DL faster
- Looking for a used 240 240 DL wagon (or sedan) w/ manual transmission
- 84 240DL Parts Station Wagon
- Aftermarket parts?
- 1989 240 PArts
- 240 is leaking oil
- Interchangeable Parts?
- won't start!
- My Volvo 240 doing a little run
- My Brick (volvo 240 GLT)
- Heat Fan Issue
- 88 volvo for parts or?
- cargo cover
- Non starting 240
- 90 Volvo 240 to turn into Turbo
- lights and wipers connected?
- What V-8 engine works best for swap
- V-6 Volvo engine swap
- Looking to buy a car, Volvo 240 GL
- Want to join a Volvo Club?
- 595hp 242 in Sweden... (Of course sweden)
- mtx amp
- Diesel,1982, 240, Volvo
- antifreeze
- Engine Swap
- not starting
- LSD
- suspension/braking
- make it nice
- Nice Volvo pic...
- 84 240 Diesel
- '87
- Anyone have any pics of this car??
Automotive Network, Inc., Copyright ©2021
