View Full Version : Intrigue
Pages :
[ 1]
2 3 4 5 6 7 8 9
- AC/Heat air flow problems
- Anybody know what this part is?
- Stupid "Low Light"
- Problmes, Part-Numbers, and Pictures.
- 01 intrigue oil leak
- Harmonic Balancer Puller question
- Intrigue front engine mount "how-to"
- P0442 SMall EVAP leak
- ABS Working fine, but have PCS, SVS, and TracOff lit up.
- Hard (locked-up) gas pedal
- Hard Shifting
- Stumbling engine?
- 01 Intrigue speedometer and odometer issues
- Broken shifter knob button.
- Replacement stabilizer bar for 2001 Intrigue
- Oil Pan Lower on 3.5
- Intermittent Secuirty Light
- keyless entry programming not working
- Struts
- Hot seat
- Windshield Wipers don't work..anyone with the abiliy to interpret FSM?
- Two questions
- Two Trouble Codes
- '98 olds break problems
- 01 intrigue dash,gas gauge issues
- Is there a safe, dependable sites to order GM parts?
- Could this actually be the starter?
- '00 GLS hard starting
- Electrical Problem?
- Do any one of you Intrigue owners have this annoying problem?
- 99 Intrigue trunk latch
- Rack and Pinion Problem?
- Windshield Wiper washer wont turn off 2002 Intriguq
- Proper jacking
- Starting issue-fuel pressure??
- Shifting problem
- Alternator problems
- Ripping out ignition cylinder?
- driver power window repair
- control arm bushings
- High RPM after start
- ABS swap on a 1998 intrigue
- Power steering problems
- Coolant leak on side of lower intake
- 98 Intrigue new electrical problem
- Outer tie-rod questions
- 2000 Olds Intrigue Trans Identification
- ABS Module
- auto headlight problem not ignition switch
- AC Compressor
- Rear brake lines
- Intrigue Owner's Manuals from 1998 to 2002
- Why does SES light up without engine running?
- HELP - P0410 - replaced air pump, now what?
- Tensioner pulley
- 4T65E shift kit
- Shift Kit 4T65E, Parts, Transmission Pan Gasket What Kind?
- Trunk Leak
- Sideview Mirror Cover Removal
- INADV Power Bus keeps blowing...
- Anyone have experience with this ignition switch?
- Another Intrigue w/ Tranny troubles
- Intrigue engine shuts of after warms up
- P0304 misfire, wont crank.
- torn cv boot
- P0300 multiple random misfire
- 2000 Intrigue...a few probs
- Driver side blowing halfway cold air....
- Replaced ignition switch
- 2001 New ingnition switch, new ignition cylinder, still no start.
- Seat belts locking
- Water leak from Visor anchors
- water manifold
- 99 Intrigue Passlock Problem
- SVS, Trac Off, ABS Lights on in Rain
- 99 Intrigue won't crank
- Coolant Recovery Tank Replacement
- Transmission issues
- key will not start car HELP
- Transmission Flush
- Discolored Headlights
- Serious intake problems 98 Intrigue
- transmission issue
- seatbelt question
- Should I get a 2nd opinion?
- Transmission shifts out of gear and acts like its in neutral
- No Low Beams
- Cooling Fan Assembly Upper Bolt
- a/c compressor question
- Common a/c problem
- Engine Coolant cap stuck. Any ideas?
- Replace Rubber Gasket on Oil Filter Cap for 3.5L Intrigue?
- Engine noise and vibration
- Popping Driver Side Wheel In Reverse
- Ac/heater fan
- Arrivederci!
- where is the washer fluid pump?
- Car shuts off with turn signals
- Alternator not Charging? Replace the Compressor Recently?
- Airbag Light on
- Head gasket, external Coolant leak?
- 99 Intrigue Climate Control
- 2000 Intrigue burning smell from engine
- won't run same as eveybody else
- O2 Sensor Replacement
- ASAP 1998 Olds Intrigue AC/Heat Problems
- 2001 No Crank
- securty light on
- 96 Intrigue won't start
- Crankshaft sensor replaced
- Strange Humming Noise?
- Replacing Steel Fuel Lines
- odd revs and engine buzzing
- broken starter shell three time in 6 months
- Low Tire Pressure?
- Oil Filter
- 02 gl wont start
- Timing Chain
- transmission shift
- Power Steering Fluid Leak
- 1998 Intrigue making weird thumping noise
- 2000 olds intrigue
- 2001 Intrigue Clicking when temp gauge gets halfway?!
- Windows gone bad
- 2000 intrigue won't stay running
- Replacing Passager Mirror
- No Start, Remote Start Bypass
- Uim
- How to replace rear strut mounts?
- Two questions: Slow starter cranking? GM or remanufactured?
- A/C Control Unit Quick Fix
- 98 Intrigue - electrical problem starting
- P0742...again
- 2002 3.5L Power Steering Stiff Even after new pump Flush
- Power Steering Flush Update
- '99 Intrigue Doors coming falling apart.
- Wierd thing with brakes
- SVS and Brake Warning lights are on.
- O2 Sensor & SES Light
- Could my PCM be bad?
- Intermittent SVS Light
- AC Compressor Bearing
- Oil filter
- 99 Intrigue-All 4 power windows just stopped working
- Replacing a BCM with a used one
- Radiator replacement
- Can you swap the front seats?
- Starting problem when hot
- Repair Manual and Rough Idle
- new cooling sensor but still no fans
- Oik pan removal
- 1998 Intrigue power window failure
- Fuel Filter
- 99 intrigue electrical problems
- Anybody know what this is? (Behind rotor)
- Front sidemarkers
- Power Steering Stiff, Pump vs. Rack? No ETBCM Codes
- Something with the oil
- Dumb Question
- Tranny smell
- TCC Lock up when warm / Code 742/ Which solenoid is the TCC solenoid?
- Any input on this??
- AC Condenser
- Sold the 99 today, A bit Sad, Many years of Great Service
- Clicking sound when I tUrn Right Only
- Cassette is stuck
- Tranny drain
- Which Intrigue to buy???
- 99 intrigue
- Shuts down after a hittiing bump.
- Bad Strut Causing Bad Alignment?
- Changing Spark Plugs
- 3.5L V-7 Compressor Removal and Reinstallation
- 02 Keyless Chirp/ 99 Headlight issue
- Diagrams
- ABS reset
- Paint Code
- Proper way to jack up Intrigue?
- Bouncing front end
- 2000 with P0122 DTC
- 2000 3.5L Coolant loss and misfire
- tie rods and ball joints
- AC blowing Hot/Cold air through vents, car has Manual climate control
- Anbody have a wet trunk???
- A/C Control Dual Zone switch assembly Not Working
- A/C fixed but need help
- 01 Intrigue-Slow Cooling Fans-Engine getting hot.
- Regrounding the Tranny?
- tranny cooler?
- car dead rotten egg smell, strange noise
- 2000 Intrigue front hub assembly replacement
- Intrigue 99 3.5L Engine Misfire Code P0300
- 2002 3.5L Vehicle History Report???'s
- 2002 3.5 problem with steering???
- A/C whining
- A strange sound
- P0101 & P1811, 20% Possitive Short term fuel Trims Need Help..
- ONLY 13 MPGS any ideas?
- Sold my Intrigue, sad but true
- Where can I buy Quick Struts for Rear
- SEL, ABS, Brake and Trac Off lts but no codes
- P1811 Transmission hard shifting replaced PCS Twice
- freeze plug leaking?
- HELP 99 Intrigue Pulsating
- Another Intrigue Trans Issue
- 3.5l V-7 A/C Compressor Rebuild/ Reseal
- Ambient Air Temp Sensor
- What extra Intrigue maintenance would you do at 100k miles?
- Intrigue motor swap 3.5 to 3.8
- Steering Gear / Steering Rack Replacement
- 02 olds intrigue 3.5 another tranny problem
- bcm problem
- Replacing PCV Valve for 3.5L Intrigue?
- Automatic transaxle removal (4T65E)
- What wires can I splice to Keep Rad Fans "ON"
- Fuel Filter for Intrigue
- Car Rotting at bottom of rear rocker area
- Four wheel alignment
- Alarm activated by garage door opener
- Step By Step Instructions to Replace 98 Intrigue Transmission?
- flasher location
- Windshield?
- 98 Intrigue Transmission Issue
- three problems happened !!!!
- Replacing Auto Transmission 4T65E
- Rough idle at freezing cold start - 2000 Intrigue
- Real wheel alignment - 2000 Intrigue
- HELP!!!!!! 2002 Intrigue3.5L wont start
- blower motor stay on!
- Heat not working 98 intrigue
- Car won't start
- Slight delay when shifting from park to drive
- Intrigue Right High Beam is out
- 2001 random missfire
- Do our cars have starter Interlock
- Replacing radio with steering controls, advice?
- 99 3.5L engine rebuild questions???
- Brake Recommendations
- Random Stalling & random lurch/miss
- Engine hesitates while accelerating
- Upper Intake Manifold - Intrigue 98, Service Engine Light on
- '01 Oldsmobile Intrigue Front speakers not working
- Corroded brake lines, but solved fuel econ. issue
- Head Gasket on 3.5L LX5 V-6
Automotive Network, Inc., Copyright ©2012
