View Full Version : Intrigue
Pages : [1] 2 3 4 5 6 7 8
  1. 99-3.8 Loosing Coolant, Can Smell it in engine area
  2. Water Pump Replacement 3.5l
  3. dashlights coming on
  4. 99 Intrigue Starting Problems
  5. Engine stops while on the highway
  6. Rocker panels shot
  7. Trunk Gasket
  8. Whining from engine bay when accelerating
  9. Upgrade Advice Needed - Prioritization??
  10. Intrigue 1998 - hard start damages starter
  11. Factory Battery Removal 2002 Intrigue How??
  12. installed new battery-now idles at 1,200 rpms
  13. Need to Know Wrench & Socket size
  14. Catalytic Converters
  15. What's Your Favorite Rotor & Pad Combos?
  16. Need a door!!!
  17. Keyless entry ??'s 02 3.5L
  18. P0420 o2 sensors 2002 Intrigue 3.5L
  19. Wierd ????? about Radio
  20. Heater Fan only works on speed 3 4 5
  21. Rockauto Clearance for Intrigue
  22. Help with torque specs please.
  23. Traction Control Switch
  24. I found a place that can Tune the LX5 Shortstar
  25. 2001 Olds Intrigue, inner and outer tie rods
  26. 2001 Olds Intrigue, need diagram for inner and outer tie rods, please
  27. Not Starting, did ignition switch - no help
  28. 99 Intrigue Oil & Coolant smell
  29. 2002 Intrigue air injection system fault
  30. Brake light on dash on!?
  31. AC: High Side Pressure Spikes Normal?
  32. Watch your odometer if you disconnect the battery!
  33. Use the turning signal blinkers engine shuts off!!
  34. A/C "Mode" switch not working
  35. 2000 Intrigue transmission filter change
  36. I over toruqe a thernostat bolt any solutions
  37. 98 3.8 Intrigue - Air from all vents
  38. overheating problem and what can cause it
  39. Low Trac/ABS
  40. Radio Reception
  41. 2002 Intrigue brake rotors
  42. 1998 intrigue won't crank...
  43. 2001 3.5L engine stutter intermittently
  44. 98 bleeding brakes/ABS light comes on
  45. Air Pump
  46. Only passenger side blows cold
  47. blower motor
  48. Heater Core Replacement - 98 Intrigue
  49. 3rd brake Light Add On Module
  50. intake plenum replacment
  51. Crankcase position sensor
  52. 2001 3.5L Intrigue Code P0300
  53. Must be a prototype.
  54. Front passenger-side headlamp assembly likely to be for sale
  55. Continuing problem with 98 intrigue - misfire #6 cylinder
  56. Gotta love the summer A/C threads
  57. Windshield Wipers Retarded!!!
  58. My 2000 Intrigue problems
  59. 02 Olds Intrigue driver door electrical panel
  60. Hard Shifts
  61. Rock Auto Clearance Items
  62. 99 Intrigure External Temp and Recirculate
  63. 00 Intrigue Hard Start, high revs
  64. Crankshaft balancer bolt
  65. 99 intrigue transmission issues
  66. broken sway bar
  67. 99 intrique
  68. 98 intrigue...clicking under hood
  69. Intrigue 99 Air Conditioning
  70. Power Window Regulator
  71. cylinder 6 misfire
  72. Fram Air Hog recharge
  73. '99 Intrigue A/C Questions
  74. AC compressor does not engage 00 intrigue
  75. Another one gone....
  76. How to change inner tierod end
  77. Key fob working intermitently
  78. 98 intrigue 3.8 intake help
  79. front speakers/bose
  80. thermostat on 02 olds intriqe
  81. Several Issues W/99 Intrigue
  82. 98 intrigue...pwr window cable.
  83. blend door for heat/ac
  84. cooling system problems!
  85. Low Coolant Light and Low Oil Pressure Light is on were are they located?
  86. Left front Turn Signal
  87. Anyone put led's in their Intrigue??
  88. Automatic Headlights Don't Come On
  89. Fog Light Assembly
  90. No Front, Rear Brakes only!!
  91. Torque specs for engine and Transmission?
  92. Third Brakelight Flasher Module
  93. 99' intrigue, engine lock?
  94. 3.5 Ticking
  95. Removing harmonic balancer/pully
  96. Oil suggestions for high mile 3.5
  97. Stipped Wipers
  98. Front struts
  99. intrigue overheating!
  100. 2001 Olds Intrigue 3.5 No Spark
  101. Starts When It Wants To
  102. a/c blowing heat on driver side and cold on pass
  103. UPDATE: Flashing dash on startup, accompanied by dieing randomly
  104. HELP! Good Samaritan Needed for Pix
  105. would you attempt an ignition switch change in your driveway?
  106. 2000 Oldsmobile Intrigue 3.5 transmission failure no D or R
  107. Leather Cleaning Suggestions
  108. Need Pointers on Replacing CV Assembly
  109. Small coolant leak
  110. When turning to the Right I hear a Cliking Sound
  111. 1999 Intrigue recall on steering shaft and joints
  112. weird stuff on startup problem (update)
  113. 3800's recalled.
  114. remote keyless entry problem
  115. Where to buy sheet metal?
  116. Climate control and Brake Issues
  117. How to clean the MAF sensor?
  118. Engine kicks to high rev, in reverse
  119. olds intrigue fuel door and trunk release issue
  120. significant sputtering @ 40 mpg ++
  121. 1999 Intrigue 3.5L - AC blows, but not cool air
  122. Different gauge cluster?
  123. Aurora V-8 to Intrgue engine swap.
  124. Wierd stuff on start up
  125. 99 Intrigue 3.5L - P0410 -Service Engine Code - Help
  126. Car will start and shut off
  127. Hazard Switch compatibility Question
  128. 99 olds intrigue sunroof issue!!!
  129. 3157 Replacement DRL Bulb
  130. Need Help! Crank, No Start.
  131. Intermittent problem after driving in fog, high humidity
  132. 240,000 Club
  133. how do i get rid of the seatbelt reminder bell in '02 intrigue?
  134. 1999 transmission install
  135. 98 Intrigue engine failure?
  136. Transmission not shifting smoothly after using cruise control
  137. pwr. window cable..98 intrigue
  138. Anti-freeze leak
  139. Looking for a new window switch.
  140. Front right turn signal light not working ('02 intrigue)
  141. Time for New Wheels and Tires
  142. Blower motor stays on even after car is shut off.
  143. really stiff gas pedal?
  144. power steering hose
  145. Anti-Freeze Odors
  146. Cracked front bumper & headlamp assembly
  147. Intrigue Starting Problems '00 w/3.5L
  148. Replacing the coolant crossover pipe
  149. Hello. I'm new to this forum.
  150. Washer Fluid Pump
  151. replacing the rear valve cover gasket.
  152. Tranny fluid? Dexron III/ Or ATF4? 2002 Intrigue
  153. 98 intrigue..winter vs summer fuel consumption
  154. No Code, I/M EGR and Evap not ready.
  155. 1998 Oldsmobile Intrigue A/C
  156. 1998 Oldsmobile Intrigue HO2 Not Ready
  157. 98 Intrigue - Hard shift into reverse
  158. coolant sensor problems
  159. 3.5L Evaporative Emissions Canister Location?
  160. Alternator Replacement '00 Intrigue - here's how
  161. 3800 misfire @ idle HELP PLEASE!
  162. 3.5l Engine Replacement Advice
  163. Rough idle at first then smooths
  164. RF module?
  165. Clicking noise
  166. Help Me!!
  167. 2000 Intrigue--Service Vehicle, PCS, Trac Off Lights
  168. passlock or ignition switch
  169. Turn Signal Problem
  170. 1999 Intrigue 3.5 with a engine from a 2000
  171. 98 intrigue cd player says e20 ?
  172. Strut Tower Templates
  173. Heater Control Valve location
  174. Power Steering Gone
  175. No crank, P0340 code.
  176. High Mileage Lubricants Opinion
  177. 99 3.5L Intrigue MAJOR ISSUE
  178. Lambchop is not Intrigued
  179. Wipers just started stopping in upright position
  180. 2000 3.5 Intrigue running cool/poor heat
  181. Daytime Running Lights
  182. Adding Sirius to my Intrigue
  183. 98 intrigue intake manifold blew up. Any Help
  184. Blower Motor Not Working...
  185. 98 olds check engine light flashing & engine sputter
  186. 99 Intrigue stuck in park...
  187. coolant leak, water pump?
  188. Secondary Air Injection System
  189. Two Issues - Turn Signals and Dying on Corners
  190. giving up on the olds
  191. I'm ready for a road trip. '98 3.8.
  192. po101 code
  193. cyclinder 3 misfire
  194. 2001 Intrique
  195. 99 Intrigue power steering return line
  196. Wheel hubs / Tie rods
  197. Replacing Waterpump
  198. Window Issues
  199. Upgraded to 12 inch Brakes installed on car
  200. Block heater recommendation?
  201. Front sway bar replacement
  202. Replacing Your Cabin Air Filter (Or How To Install One...)
  203. 2000 Intrigue V6 Twin Cami
  204. Replacing Themostat and Thermostat Housing
  205. 99 Intrigue 3.5l, Hard Starting
  206. windsheild washers loose prime
  207. 98 acting odd (electrical)
  208. Cam and Crank sensors
  209. Wipers wont respond
  210. Running hot, cooling prob
  211. ANTI-LOCK ABS Light ON checked all wires
  212. Blower only works on High
  213. Low Coolant
  214. Wheel Hub or ECU?
  215. hot and cold air at the same time
  216. Won't start unless I pump gas
  217. MAF sensor output voltage?
  218. GMPP Handling kit drilling templates needed
  219. service engine, anti lock, trac light on
  220. Need new battery. Any suggestions?
  221. Bad High Beam Switch
  222. Changing Spark Plugs
  223. p0341 DTC on 02' alero
  224. Transmission whining after fluid change
  225. 99 Intrigue Starts then Dies
  226. 99 Olds Intrigue GLS 3.5, Random No Start, Ignition Switch?
  227. P0189 code
  228. Spark Plug Boots
  229. Taking out back seat 1998 intrigue
  230. Fuel Pressure Regulator (dealer or not)
  231. Ignition Switch Question
  232. Flushing cooling system without draining engine block?
  233. Battery dying after amp wiring install?
  234. EGR Valve Replacement
  235. 98 Intrigue Hard Starting - when warm
  236. 1999 Intrigue 3.8 Crankshaft Part #
  237. A cool gizmo and pics for eng monitoring
  238. White Smoke
  239. 99 Intrigue not running like it should
  240. Torque Converter acting up
  241. Bose Radio?
  242. '01 Intrigue: Gas Guage Not Working....
  243. P0446: Evaporative emission control system malfunction
  244. Radio Issue, please help !!!
  245. Cruise Control Issue
  246. Preignition pinging?
  247. Keyless entry on ALL 99's...are you sure???
  248. Transmisson fluid lube guard additive
  249. Which coolant? Green, Dex, Universal?
  250. Pics of cleaning the ignition switch security light gone
