View Full Version : Intrigue
Pages : 1 2 3 4 5 6 7 [8] 9 10
  1. 1998 Intrigue 3800 Engine Trouble. (Missing/bucking under power)
  2. amp installation
  3. Brake pedal
  4. Need A stronger Alternator HELP!
  5. P0401 on '99 3.8
  6. service engine light and code 0410
  7. Gauges
  8. Aurora Owner
  9. replace ignition switch
  10. I'm REALLY worried!!
  11. led alarm light
  12. Overheating 99 intrigue
  13. 2001 Intrigue gas mileage
  14. Rear Window Problem
  15. 98 Intrigue issues. ABS & Brake light & transmission problems
  16. Transmission has no 4th gear
  17. altenator trouble
  18. Torque converter plug????
  19. water leaking onto passenger floor?
  20. P0440 OBDII Code
  21. possible fuel sending unit replacement
  22. squeaky belt
  23. stuttering at start occasionally
  24. Help!!!! 02 Intrique 3.5
  25. Replacing steering position sensor
  26. Ambient Temperature Sensor
  27. Starting problems
  28. ignition switch
  29. Intrigue ABS Prematurely Engaging??
  30. turn signal intermittent problem
  31. should I change my tranny fluid?
  32. window regulator
  33. Suspension Squeaks
  34. Hissing Sound
  35. A/C warm driver's side only
  36. New Exaust system parts
  37. Lost power and died
  38. ABS Light on Again (3rd time in a year)
  39. Keyless Entry Remote
  40. Engine/Transmission Diagnostic Parameters
  41. 290hp and 500hp (Turbo) ShortStar, LX5, 3.5L Twin-Cam
  42. Outdoor Temperature Sensor
  43. Lightbulb for transmission shifter panel
  44. Tool to open MAF sensor
  45. over heating & problem starting
  46. Coolant bleeders on the 3.5
  47. Ward's article on 3.5L engine
  48. Best place to find carpet
  49. Cheap Intrigue Parts
  50. Metal in tranny fluid
  51. wipers turn on by themselves
  52. vss and revers light wire
  53. Engine-Tranny Problem??
  54. Still Looking...
  55. Rear View Mirror not working
  56. Low Oil Light
  57. How to fix camber on passenger rear wheel
  58. Do I have anything to worry about (Overheating)
  59. sticky throttle
  60. Spark Plug Torque? (1998 Intrigue 3800)
  61. Fram Air Hog Air Filter
  62. Keyless entry reciver HELP!
  63. p0420, p0442
  64. Where is left side temp door servo (AC)
  65. Hot air from driver side
  66. Instrument panel
  67. 4T65-E whinning sound
  68. Transmission shudder Intrigue
  69. 99 Intrigue 3.5L - passenger rear window dead
  70. 1999 Intrigue braking problems
  71. E34 code on the radio?
  72. A/C Heater Control DEAD
  73. 99 Intrigue, water on passenger floor
  74. Broken shifter on '99 Intrigue
  75. Broken A/C
  76. Car keeps dieing
  77. brake caliper torque setting
  78. '98 Intrigue vs GLS...
  79. Windshield washer pump
  80. Idiot lights wont come on
  81. "Brake" light and "Change Oil" light...and other light issues...
  82. A/C not working
  83. a/c heater control
  84. "Adaptive" Transmission
  85. Burning Oil??
  86. struts
  87. Engine problems
  88. Transmission pan gasket reusable???
  89. Burned out front parking/directional sockets
  90. ignition/shifter stuck
  91. heater/ac control panel
  92. Replacing water pump
  93. 3.5L motor rpm limiter when not in gear?
  94. Removing Rearspeakers/Deck
  95. Post-gridlock, f Nighting the stall... Any ideas?
  96. abs / brake lights
  97. Front end & steering
  98. Headlight Clips?
  99. LT FTRM and ST FTRM
  100. Need exploded view diagram of rear struts
  101. Instument Panel removal
  102. Car seems to be running hot.. help!
  103. water in passenger side, L drain
  104. Mobil One Synthetic ATF
  105. brake light
  106. Wipers not working
  107. Hood Alignment How?
  108. Front Amber Drving/Marker Lights
  109. 3.5L engine problems
  110. Tires
  111. A/C Compressor Not running
  112. Dashboard Lights
  113. 2001 A/C dash switch
  114. Putting on New Rear Struts
  115. Intrigue Rear Hub replacment
  116. Heater blower not working
  117. Quick Question About Drilling Through Firewall
  118. Rack boot Blown!!!
  119. Getting Static Shocks
  120. AC/heater blower motor squeal
  121. '99 Brake Noise?
  122. A/C Question
  123. Transmission shifting hard, intermittent problem
  124. pcs light
  125. A/C vents blow warm on drivers side
  126. Window regulator motor
  127. climate control lighting
  128. air injection pump
  129. parking brake system 1998 Intrigue
  130. Windshield Wiper problems
  131. finding the vss
  132. Sometimes it will not crank over
  133. 1998 olds intrigue trunk leaking
  134. Final 500
  135. Couple questions
  136. Wiper Flys off Windshield
  137. how do I turn off the governer
  138. Abs
  139. 2001 3.5 intrigue oil filter changing
  140. Aftermarket Stereo Fitment
  141. ecu code-newby needs help
  142. what is the name of this?
  143. p0742 dtc
  144. cold weather/coolant smell
  145. front end rumble
  146. service engine soon light
  147. Rough at idle
  148. starting problems
  149. Starter & more problems
  150. Stock Radio Aux Imputs?
  151. Changing the plugs in a 99 Olds Intrigue
  152. Drivers side Rear Seat belt
  153. 2000 Blinker Relay
  154. Tape to Cd Player Swap
  155. A whine in cold weather making left turn under power
  156. 99 intrigue 3800
  157. Anyone have 2000 Intrigue specific remote program instructions?
  158. Cruise control dead!
  159. Squeaking from blower motor
  160. Possible Tranmission problem???
  161. battery light problem
  162. Any way to check for faulty Oxygen Sensor?
  163. Engine starting problems
  164. 1995 olds 3.1L radiator fan switch
  165. Chirping sound coming from interior
  166. Replacing stock radio
  167. engine sound when under power
  168. 2001 Airbag Light
  169. 98 Olds Intrigue - Remote Question
  170. Repair Manual
  171. Clunking in front end on 99 Intrigue
  172. help how to perform an obd 2 drive cycle.?
  173. R. defrost = radio static
  174. Removing the resonator
  175. Erratic Temperature Gauge and Tachometer
  176. Loud whiney sound
  177. coolant smell?
  178. power seats
  179. Is this car really this junky?
  180. Power Windows
  181. Some parts for the Intrigue on EBay
  182. Massive Oil Leak
  183. Installing a Hitch
  184. AIR pump pickup
  185. FYI: Root cause of blower motor, fan setting problems. Water on passenger floor?
  186. Shuttering noise from front end
  187. Coolant smell.. No leak??
  188. Spark plugs on 2000 Intrigue
  189. how to replace maf sensor 99 intrigue.
  190. Noisy A/C Compressor?
  191. Think I found the problem (19 to 14MPG)
  192. Battery/Voltage Indicator Pondering
  193. Power Steering noises
  194. anyone been in accident with there intrigue
  195. Scymatics
  196. Cabin Air Filter Seal
  197. Chiltons Manual For Intigue
  198. horn
  199. Only two settings working on the blower motor
  200. im hearing water
  201. Blower Troubleshooting
  202. Change Oil Light and Low Water Light
  203. Coolant system woes
  204. Headlight Flicker Fixed by Cardboard
  205. Headlight problem fixed with new Alternator
  206. broke my shifter
  207. myfi mounting ideas
  208. Heater Motor Stops - recovers when car dry
  209. Replacing Blower Motor in '99 Intrigue
  210. Starting Problem with 2001 Intrigue
  211. service engin soon light.
  212. cold weather starting
  213. High beams will not go off
  214. no low speed on blower
  215. blower motor
  216. Backseat removable??
  217. Passenger side carpet wet...
  218. paint codes
  219. Chinese Bearing Assembly
  220. Heater just stopped working.
  221. Blower motor won't stop
  222. Heater only works on High..
  223. P300 Random Misfire - Troubleshooting Advice?
  224. tail lights - fast blink, all lit
  225. Radiator
  226. Heater not working at all
  227. Blower Motor Fan noiisy
  228. Blower Motor problems
  229. horn
  230. water sounds
  231. Whine when starting car
  232. Dual Climate control issue
  233. checking trans fluid
  234. Weird Backfiring
  235. Where's my lighter fuse??!!
  236. engine was trashed
  237. washer fluid pump circuit.
  238. mirror installation
  239. timing chain or belt?
  240. service engine light
  241. Bose radio question
  242. Seat belt won't extend.
  243. Scratch in center of window
  244. Intrigue Driver Window
  245. tape player dead
  246. Air Intake Grilles
  247. Delco radio error codes
  248. 2001 Intrigue Climate Control in Celsius
  249. Headlight and Dashlight Flicker
  250. looking for radio unlock codes
