Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Oldsmobile
> Intrigue |
View Full Version :
Intrigue
Web
AF
Pages :
1
2
3
4
5
6
7
8
Transmission questions
wind noise from mirrors
A/C problem (works after ~10 miles)
Sun visor
2001 Frontend popping
Leaky oil pan gasket
3.5 Shift points
Shift knob...
Service engine soon code P0440
99 Intrigue Horn Blows Intermittently (usually when cold outside)
Found Great tires
Sun roof problem
2000 Altenator blues
01 Intrigue, metal scraping noise?
How do you find error codes?
Fuel Pump problem is possible?
Water thru AC filter
98 Intrigue shuts off when driving
since their wont be a new intrigue
How many miles are on your Intrigue?
automatic headlights problem
intrigue abs light
Car turns over but takes 5 seconds to start...
idler pulley 3.8
intrigue
A/C blows cold air in only 2 vents
Can you adjust the seat height in Intrigues? If so, where are the controls?
Acceleration Lull/Response question
Door Paint Peel - 1999 Intrigue
More cooling problems
how to
98 intrigue pass side rattle
shaking in park ..
Automatic Climate Control
Heater/AC Control Switch "Issues" 98 Intrigue GL
oldsmobile a/c trouble please help
Noise of water running 2000
1999 Intrigue Rumbuling Noise from Front
Electrical/Water Problem?
a/c drain
gas peddal?
'99 3.5 Speed sensor failure @ 86k - $500
Intrique 99 Remote
ABS computer
Coolant light on
air pump fuse
Digital Climate Control Problem
Bad Key Ignition
Ignition Switch Lockup
3.5 Intrigue shift points.
problem when turning
gas and trunk release problems
98 intirgue alloy wheels problem
Bearing Assembly
Automatic headlights... can anyone disable this...
Intrigue Exhaust
Power Gas Door latch failure
V6 3.5L Engine Shot at 42,000 KM
More Turn Signal Problems
AC cycles off/light blinks?
Almost stall after startup/synthetic myths?
2001 Intrigue tranny question
Service Engine Soon - Code P-0446B
electric problem
Alt. replacement on 99 olds 3.5L
Control Buttons Running Hot
High-pitched whurr - ABS motor?
left blinker
Left rear tire noise
Power Door Locks
Is my window motor going?
Starting problems and Anti-Lock Brake light
Programming Instructions for 02 Olds Intrigue
Intrigue Transmissions are problems!
Starting Problem...just click
Gas Mileage
Spark Plug Gap
1999 Intrigue Cam Sensor
2000 Intrique Power windows
Removing the u-bend and resonator from Intrigue exhaust
A/C light blinks
Overheating
Oil sensor plug
Fuel pressure regulator or not?
Coolant leaking
Brake warning light
Service Vehicle Soon light and Air Pump Relay
Question:Rear Air??
1998 Intrigue Front Cupholder
interior lights
Transmission shifting
'99, 3.8l engine movement
Power window problem
Oil Problems
fuel pump location
Car Hesitation or Burp
p0410 code
2000 Intrigue PCS light
Turn Signal
1998 rear cup holder
AC question
Radio & A/C lights
High Idle Fixed!
Electrical behaviour
best superchager
Service Engine Light
Any of you Intique owners interested in a new Olds forum?
99 Intrigue burning oil
What is It??
Heater Control switch
Power Steering problem
99 Intrigue alternator
Oldsmobile intrigue 3.5 COLD AIR INTAKE
Blown Tranny 2000 GLS 102K miles
Hello all.
Newbie
99 Intrigue Engine Knock
How Serious is this engine code??
2001 intrigue wind noise
Car cranks for ever before starting, any clues?
To dex-cool or not to dex-cool...
2001 Intrigue Keyless Remote
New Forum member
my car tries to turn itself - kinda like Christine-what do ya think
98 intrigue engine light
99 olds hard starting
Coolant light came on
low idle
OEM cassette radio
Questions
High Blower stuck on
Emissions pump?
99 keyless remote for intrigue
Aftermarket receiver options?
1998 Olds Intrigue GLS & EGR
Update-2 on Thermostat and Service Engine Soon Light
98 windshield washer fluid will not pump
Update to Service Engine Soon Light
Temp Gauge acting funny - Possible Thermostat Problem?
2000 Factory Repair Manual
1999 Intrigue 3.8 Engine Hesitation
High Idle - Causing major headache!
Air and Oil Filters for 99 Intrigue
2001 Olds Intrigue Fog Lights Not Working
Horn not working and window is stuck
Consol indication
cruise control
Turn Signal problems
3.5L spark plug replacement, how to?
starting problem in 01 intrigue
99 Olds Intrigue - RPMs remain accelerated even while idle??
Whiney belt
Security Light 98 Intrigue
Three warning lights on at once - help! ('99 3.5 Liter Automatic)
Hello, need assistance
fuel filter whereabouts
Where is the in-door fuse panel?
1998 intrique purchase ?
newbie saying HELLO to the group!
Locked out of radio
Power Steering
excessive noise
On-line Parts Suppliers
1999 intrigue consumes oil
Headlights/Dashlights flickering
Hi, I have a 99' 3.5 with rod knock 29k can you replace rod bearings in car?
Knight Performance Intrigue Pictures
body kit
Other GM factory radios that fit a 2000 Intrigue?
Need Help: Replacing the map light bulbs on mirror
crankshaft position sensor question
Solution for intermittent no-start/no-run problem
1999 Int. Trans or alternator problems?
Intrigue tranny conversion
Oil filter wrench for 2000 Intrigue
Intrigue performance & troubleshooting source
1999 3.5L hard starting problem fixed
P1441 - Service Engine
fuel pressure regulator Q for the gurus
Intrigue electrical problem
Cabin Air Filter
Buick 1988 Torque Converter
security sucks
Does anybody answer questions on here? I'm sorry if I'm not a frickin' car tech
Oldsmobile Intrigue
Keyless Entry
Performance for intrigues
Fog Lights
Transmission problem?
Oldsmobile Intigue 1999 GL
Clock radio problem
What could be the problem?
98 Intrigue Front Air Dam
99 Intrigue not starting when hot!
Turn Signal Trouble
Keyless entry for '98 Intrigue
13 sec intrigue
Stop light race stories??
security system on 2001 Olds. Intrigue
Do I Have Keyless Remote ??98 Model
windshield washer
Keyless entry Remote Instructions
Olds Intrigue Performance Options
Oil change, 1999 Oldsmobile Intrigue
Question for Intrigue Owners
Olds 2001 Intrigue Change Oil light
Intrigue Headlight Questions
Web
AF
