Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Oldsmobile
> Intrigue |
View Full Version :
Intrigue
Web
AF
Pages :
1
2
3
4
5
6
7
8
Wipers not working
Hood Alignment How?
Front Amber Drving/Marker Lights
3.5L engine problems
Tires
A/C Compressor Not running
Dashboard Lights
2001 A/C dash switch
Putting on New Rear Struts
Intrigue Rear Hub replacment
Heater blower not working
Quick Question About Drilling Through Firewall
Rack boot Blown!!!
Getting Static Shocks
AC/heater blower motor squeal
'99 Brake Noise?
A/C Question
Transmission shifting hard, intermittent problem
pcs light
A/C vents blow warm on drivers side
Window regulator motor
climate control lighting
air injection pump
parking brake system 1998 Intrigue
Windshield Wiper problems
finding the vss
Sometimes it will not crank over
1998 olds intrigue trunk leaking
Final 500
Couple questions
Wiper Flys off Windshield
how do I turn off the governer
Abs
2001 3.5 intrigue oil filter changing
Aftermarket Stereo Fitment
ecu code-newby needs help
what is the name of this?
p0742 dtc
cold weather/coolant smell
front end rumble
service engine soon light
Rough at idle
starting problems
Starter & more problems
Stock Radio Aux Imputs?
Changing the plugs in a 99 Olds Intrigue
Drivers side Rear Seat belt
2000 Blinker Relay
Tape to Cd Player Swap
A whine in cold weather making left turn under power
99 intrigue 3800
Anyone have 2000 Intrigue specific remote program instructions?
Cruise control dead!
Squeaking from blower motor
Possible Tranmission problem???
battery light problem
Any way to check for faulty Oxygen Sensor?
Engine starting problems
1995 olds 3.1L radiator fan switch
Chirping sound coming from interior
Replacing stock radio
engine sound when under power
2001 Airbag Light
98 Olds Intrigue - Remote Question
Repair Manual
Clunking in front end on 99 Intrigue
help how to perform an obd 2 drive cycle.?
R. defrost = radio static
Removing the resonator
Erratic Temperature Gauge and Tachometer
Loud whiney sound
coolant smell?
power seats
Is this car really this junky?
Power Windows
Some parts for the Intrigue on EBay
Massive Oil Leak
Installing a Hitch
AIR pump pickup
FYI: Root cause of blower motor, fan setting problems. Water on passenger floor?
Shuttering noise from front end
Coolant smell.. No leak??
Spark plugs on 2000 Intrigue
how to replace maf sensor 99 intrigue.
Noisy A/C Compressor?
Think I found the problem (19 to 14MPG)
Battery/Voltage Indicator Pondering
Power Steering noises
anyone been in accident with there intrigue
Scymatics
Cabin Air Filter Seal
Chiltons Manual For Intigue
horn
Only two settings working on the blower motor
im hearing water
Blower Troubleshooting
Change Oil Light and Low Water Light
Coolant system woes
Headlight Flicker Fixed by Cardboard
Headlight problem fixed with new Alternator
broke my shifter
myfi mounting ideas
Heater Motor Stops - recovers when car dry
Replacing Blower Motor in '99 Intrigue
Starting Problem with 2001 Intrigue
service engin soon light.
cold weather starting
High beams will not go off
no low speed on blower
blower motor
Backseat removable??
Passenger side carpet wet...
paint codes
Chinese Bearing Assembly
Heater just stopped working.
Blower motor won't stop
Heater only works on High..
P300 Random Misfire - Troubleshooting Advice?
tail lights - fast blink, all lit
Radiator
Heater not working at all
Blower Motor Fan noiisy
Blower Motor problems
horn
water sounds
Whine when starting car
Dual Climate control issue
checking trans fluid
Weird Backfiring
Where's my lighter fuse??!!
engine was trashed
washer fluid pump circuit.
mirror installation
timing chain or belt?
service engine light
Bose radio question
Seat belt won't extend.
Scratch in center of window
Intrigue Driver Window
tape player dead
Air Intake Grilles
Delco radio error codes
2001 Intrigue Climate Control in Celsius
Headlight and Dashlight Flicker
looking for radio unlock codes
Oil and brake problems
Alternator replacement/electrical issues
Starting troubles (not turning over)
i need help
General Intrigue Fixes
Climate Control Problems
Where's the thermostat
Oil Life Monitor
Rattling Noise
98 Intrigue Intermittent Starting Problems
Automatic Headlights
Squeaky noise when brakes are depressed slightly
Olds Intrigue 99 A/C-Temp Control
how to dissconnect the governer
Replace Alternator ???
NOISY valve lifter(s) or rocker arm(s)
no heater display/heat
Wipers Stopped Vertical....
Engine Oil
Slight sticking of throttle
Blower Motor not coming on
coolant leak help please 98 GL 3.8
How to Tell Which Model I Have
99' intrigue overheating 3.5L 6Cyl 109,000 miles
A/C orifice tube
Burning Smell
Window creeking sound
headlight flicker
auto trans TSB's
Four Headlight Relay
19mpg to 16.5mpg after trip, causes?
What does a defective CV sound
Heavy Duty Brake Upgrade
Heater output
Intrigue Transmission (4T65E) prices.
Listing for GM transmissions. What tranny does my GM vehicle use?
Hi-Po 4T65E Raptor transmission
What size Socket, front wheel Hub
Help need to know were to start looking
Where are the Spark plugs
Funny Thing at the Bone Yard to-day
Heater Problems
Where is ecu or computer located 99 Intrigue
Warning replace your Plugs don't believe GM
What lights should be on?
99 intrigue trans problem?
Any-one with a code reader in Toronto area
Front-end Noise at 40mph & 60mph
Engine light on, Intrigue '99 3.8
3.5 L Engine
stereo codes
what the hell?
thought i'll give my fellow intriguers a heads up
burned CDs that skip in Intrigue CD player?
replacing your flasher
Bose CD Radio
Taking my Intrigue On A TRIP
transmission: fuel evaporation
Quick Questions (re: lights and sound system)
Oil Change light
oil service
Long Life Transmission
frequent fog light burnout
Backfire
The Cost of an Import vs the Reliablity of an Intrigue
Replacing CPS
timing belt?
A common problem so it seems... my turn signal issues.
Worst trade in value EVER?
Chrome Trim Moldings around doors
Cloud of White exhaust smoke
Paint Codes
how to change coolant?
Preventing The Window from falling?
A/C blinking information wanted....
Another window problem!
Window Problem!
coolant light
Stuck Shift Knob !!@#!@
A/C just stopped working and light blinks...
headlights and taillights
Help with "Change Oil"
Need Serious engine help!!!!
passlock problems
Oldsmobile Modifications
About the front end as well as a car accident
PCV Valve
Passenger Turn Signal failed
front end noise
PCV valve location
Towing
Coolant Temperature Sensor
replacing air filter
Traction Low Light Keep Coming On
rear speakers
Spark plug installation for 2000 Intrigue
Intrigue=Lemon
window down
intrigue grounding
NHTSA informations (recalls and complaints)
Throttle Body and EGR
1998 program remote....this worked for me
97 intrigue trouble starting?
Changing brakes on 2001 gx
Web
AF
