View Full Version : Intrigue
Pages : 1 2 3 4 5 [6] 7 8
  1. Water pump removal
  2. Ticking Noise and Belt sounds
  3. Highway vibration
  4. Oil usage
  5. Gas Pedal
  6. Sensor Hell!
  7. Hard start smell gas (cold or hot) 98 Intrigue
  8. Noise from the front right side wheel
  9. Thermostat Replacement
  10. 1999 Osmobile Intrigue Service Engine Soon
  11. Anti-Lock light on
  12. service light
  13. dimming lights
  14. Replacing the Starter
  15. 98 Intrigue signal lights
  16. no heat, no seat warmers, no window
  17. Vibration from front of car.
  18. want better brakes?
  19. Service Engine Soon light
  20. Engine problem
  21. Lights for fuel filler door and trunk release
  22. Intrigue heating blower
  23. Hazard Button Removal Procedure?
  24. low coolant light 02 intrique 3.5
  25. performance chip
  26. Air bag light flashes
  27. instrument cluster not working
  28. Z-Max (linkite) Yes or No?
  29. problem solved..Thanks
  30. night illumination
  31. Vehicle Breakdown
  32. passlock problem
  33. 99 Intigue
  34. Change Oil Light
  35. heating, AC, headlights, cruise control
  36. heating problem
  37. Low Oil Light
  38. rough acceration
  39. Problems with Intrigue
  40. 2000 Intrigue windshield washer
  41. Intrigue downpipe size?
  42. Aux input
  43. temparture sensor
  44. No blower for the heat!
  45. "Advance" codes for Service Engine Soon light
  46. Serious Electrical Problem?
  47. engine swap
  48. 2001 olds intrigue
  49. intrigue sercive engine soon light
  50. A.c.
  51. New Window Motor, too weak
  52. Help !! 98' intrigue.. maf problem and more.
  53. wich alternator
  54. Sticky e-brake
  55. car shutting down
  56. radiator cap, stupid question
  57. heat is so slowly
  58. First Freeze
  59. Cleaning the MAF
  60. turn signals on '98 Intrigue
  61. 98 Intigue headlights
  62. headgasket/intake manifold issues
  63. 2000 Intrigue
  64. 00 Intrigue/ noise come from left side when braking
  65. 00 Intrigue/ noise come from left side when braking
  66. RockAuto 5% Discount
  67. Stereo problem
  68. can not start only "click" scan test B2960
  69. Rear coil springs 1998 Intrigue
  70. start problem "click"
  71. Good Bye Intrigue...Hello Optima
  72. Power Steering
  73. Driver's seat belt won't retract
  74. BCM draws 270 mA from battery, normal?
  75. '98 Olds Intrigue, repair manual, or brake help
  76. Need help with turn signal problem
  77. Car cranks but hard start when warm
  78. Help! I think I have a coolant leak!
  79. Aftermarket Headlights
  80. rear drivers window down
  81. Keyless entry ?'s
  82. Intrigue ?'s - struts
  83. 3.5L oil consumption, dealer says piston oil rings stuck
  84. trunk leaks....
  85. How do I replace Turn Signal Indicator Bulb(or LED)
  86. DRL and fan turning on issues
  87. 2 questions
  88. 98 Intrigue tranmission ?'s
  89. Apology
  90. 98 Intrigue tranmission ?'s
  91. 98 Intrigue tranmission ?'s
  92. Coolant Filling
  93. Who's not using DEX-Cool?
  94. Random Hard shifting
  95. Radiator Flush
  96. New tranny, same problems?
  97. Brake Light
  98. loosing air preasure
  99. Good to know about your alarm
  100. sticky door locks
  101. Vibration
  102. Alarm system woes HELP!!!!
  103. Drivers Side Windows no longer working
  104. Hard to Start after sitting
  105. wipers stop working
  106. pulls right on accel after repair
  107. 1998 Intrigue, Transmission question
  108. Need car smart opinions, please
  109. No Start/Crank
  110. NEW BODY KIT Oldsmobile Intrigue NEW BODY KIT
  111. 2000 Intrigue steering question?
  112. Scary suprise while adding oil-what is this?!?!
  113. How Much?
  114. Is this major enough to keep me from visiting inlaws?
  115. '99 Intrigue: a couple problems...
  116. Tie Rod Ends/Rotor Question
  117. Changing spark plugs
  118. Cracked Wheel?
  119. Tranny Problems
  120. temp light
  121. front end noises, help!
  122. Coolant looking funny
  123. Engine moves 1/8"....motor mounts?
  124. heater sensor
  125. Service Engine Light code-Multiple Missfire
  126. 1998 intrigue steering rack recall CANADA????????????????????????????????????????
  127. someone using ethanol e-85 on intrigue?
  128. 98 Intrigue Gas Gage freaked out
  129. 1998 Intrigue steering rack recall
  130. Buzzing noise
  131. Same old problems
  132. true CAI for the 3.5
  133. couple suggestions
  134. Code C1226. RF Hub Replacement
  135. a few questions about my 2000 Intrigue
  136. Isn't it amazing?
  137. Problem starting 2000 Intrigue GLS
  138. 2000 Olds Intrigue Alternator Help
  139. Fuel gauge still not working proberly after replacing sending unit
  140. gas gauge going crazy
  141. Steering wheel clunking
  142. turn signal wont work even w new bulb
  143. Fog replacement how?
  144. Best Intrigue info poll:
  145. replaced my CKP Sensor (crankshaft position sensor)
  146. 1998 Intrigue 3800 Engine Trouble. (Missing/bucking under power)
  147. amp installation
  148. Brake pedal
  149. Need A stronger Alternator HELP!
  150. P0401 on '99 3.8
  151. service engine light and code 0410
  152. Gauges
  153. Aurora Owner
  154. replace ignition switch
  155. I'm REALLY worried!!
  156. led alarm light
  157. Overheating 99 intrigue
  158. 2001 Intrigue gas mileage
  159. Rear Window Problem
  160. 98 Intrigue issues. ABS & Brake light & transmission problems
  161. Transmission has no 4th gear
  162. altenator trouble
  163. Torque converter plug????
  164. water leaking onto passenger floor?
  165. P0440 OBDII Code
  166. possible fuel sending unit replacement
  167. squeaky belt
  168. stuttering at start occasionally
  169. Help!!!! 02 Intrique 3.5
  170. Replacing steering position sensor
  171. Ambient Temperature Sensor
  172. Starting problems
  173. ignition switch
  174. Intrigue ABS Prematurely Engaging??
  175. turn signal intermittent problem
  176. should I change my tranny fluid?
  177. window regulator
  178. Suspension Squeaks
  179. Hissing Sound
  180. A/C warm driver's side only
  181. New Exaust system parts
  182. Lost power and died
  183. ABS Light on Again (3rd time in a year)
  184. Keyless Entry Remote
  185. Engine/Transmission Diagnostic Parameters
  186. 290hp and 500hp (Turbo) ShortStar, LX5, 3.5L Twin-Cam
  187. Outdoor Temperature Sensor
  188. Lightbulb for transmission shifter panel
  189. Tool to open MAF sensor
  190. over heating & problem starting
  191. Coolant bleeders on the 3.5
  192. Ward's article on 3.5L engine
  193. Best place to find carpet
  194. Cheap Intrigue Parts
  195. Metal in tranny fluid
  196. wipers turn on by themselves
  197. vss and revers light wire
  198. Engine-Tranny Problem??
  199. Still Looking...
  200. Rear View Mirror not working
  201. Low Oil Light
  202. How to fix camber on passenger rear wheel
  203. Do I have anything to worry about (Overheating)
  204. sticky throttle
  205. Spark Plug Torque? (1998 Intrigue 3800)
  206. Fram Air Hog Air Filter
  207. Keyless entry reciver HELP!
  208. p0420, p0442
  209. Where is left side temp door servo (AC)
  210. Hot air from driver side
  211. Instrument panel
  212. 4T65-E whinning sound
  213. Transmission shudder Intrigue
  214. 99 Intrigue 3.5L - passenger rear window dead
  215. 1999 Intrigue braking problems
  216. E34 code on the radio?
  217. A/C Heater Control DEAD
  218. 99 Intrigue, water on passenger floor
  219. Broken shifter on '99 Intrigue
  220. Broken A/C
  221. Car keeps dieing
  222. brake caliper torque setting
  223. '98 Intrigue vs GLS...
  224. Windshield washer pump
  225. Idiot lights wont come on
  226. "Brake" light and "Change Oil" light...and other light issues...
  227. A/C not working
  228. a/c heater control
  229. "Adaptive" Transmission
  230. Burning Oil??
  231. struts
  232. Engine problems
  233. Transmission pan gasket reusable???
  234. Burned out front parking/directional sockets
  235. ignition/shifter stuck
  236. heater/ac control panel
  237. Replacing water pump
  238. 3.5L motor rpm limiter when not in gear?
  239. Removing Rearspeakers/Deck
  240. Post-gridlock, f Nighting the stall... Any ideas?
  241. abs / brake lights
  242. Front end & steering
  243. Headlight Clips?
  244. LT FTRM and ST FTRM
  245. Need exploded view diagram of rear struts
  246. Instument Panel removal
  247. Car seems to be running hot.. help!
  248. water in passenger side, L drain
  249. Mobil One Synthetic ATF
  250. brake light
