View Full Version : Intrigue
Pages :
1 2 3 4 [ 5]
6 7 8 9 10
- 99 intrigue- only driver can control windows
- Cleaning Mass Air Flow Sensor?
- Goodbye!!
- How to Replace Spark Plugs for 1999 Olds Intrigue
- Service Vechicle Soon/ABS/Trac Off
- Water Drainage
- 2000 GLS Blown Fuse Ign 0: PCM & BCM
- Car jolts
- Intrigue Starting/Passlock problem??!!! 1998 intrigue
- Transmission Problem
- My Overheating Issues
- help needed on front sway bar
- Transmission Drain Plug
- Ignition Switch Removal?
- Would you recommened Flushing Power Steering
- high pitch metallic sound
- Where to find tranny ID Code?
- I fixed my over-heating problem
- Disable automatic headlights
- Need some advise
- 2002 olds A/C mode control
- Looking for walkthrough ... electrical troubleshooting of TCC Stuck On tranny prob
- 99 Intrigue 3.5L rumbles when accelerating and when idlying in dirve
- driver a/c hot pass a/c cold, discovered FIX
- a/c compressor high pitched squeal
- service engine soon
- Whats the best exhaust diameter for Intrigues
- ISS Lube
- Transmission shift solenoid
- Crankshaft variance learn procedure
- 99 Intirgue Service Engine Soon warning light
- Weak Battery
- AC running when set to defrost?
- fog lights not working
- hard to start sometimes...hot or cold
- 2000 Intrigue - TCC Stuck On
- 2000 Intrige maintenance items
- Hope I can get some help...
- I've got a warning light problem
- Very Dissappointed With Gas Milage
- 1999 Intrique Fuel Gauge
- Service Engine Soon Light and Car Does Not Start
- Would you Trade a 1999 Intrigue fir a 300ZX
- 2001 Olds Intrigue
- misfire...wont rev past 4k
- how do I fill a/c with freon
- Oil drain plug stuck
- 1998 Intrigue Switch Problem
- Quick Question What Size fuel Tank in 99 I may be getting bad mileage
- TSB #010523011A - Rattle type noise coming from front of vehicle
- hot a/c on drivers side
- 99 Intrigue Front Sway Bar Replacement
- Adding Info Stalling 1998 Intrigue
- The Resonator split at the seem
- Body Control Module (BCM) HELP PLEASE
- 98 Olds Intrigue Ac Issues.
- Is the Intrigue's 3.5 Northstar a performance engine?
- AC vent ducting and warm drivers side air
- My Overheating problem
- I installed Michelin Hydro Edge Tires
- 11 or 12 inch rotors?
- Recharge A/C '99 (3.8L)
- Where is the odometer milage kept
- 2001 Intrigue 3.5 engine
- 99 intrigue, ever thought of cutting springs??
- The tach needle stuck to the very right
- airbag/antilock/brake lights on
- Is thare a way of Replacing coolant Elbo at base of lower intake
- 1999 Intrigue GLS(3.5 L) performance chip.
- Intrigue maintenance manual.
- 1999 Intrigue GLS(3.5 L) transmission slipping.
- atoyota4x4 post here about your overheating
- Passenger doors will not unlock
- High miler 98 with bad tranny shutter
- blower only works on high
- The Horror the Horror Loosing Coolant
- 2001 Intrigue CEL on.
- 2001 oldsmobile intrigue 3.5
- Rear View Mirror fell off
- Hesitation
- Temperature Gage gone crazy-3.8L
- Service Vehicle/Abs/Trac/PCS lights
- Po300, Po385, And Po1372 Error Codes For A 2000 Oldsmobile Intrigue
- Plugs and brakes...ugh
- Need some help
- Autolite Alt. For Olds?
- Windshield Washer Fluid Leak
- Hard Start when warm
- Replacing the Ignition Cylinder
- A/C light flickers but won't turn on, no cold air
- Anyone replace Neutral safety switch
- intrigue vacuum lines. Need boot
- warning lights illuminated last night while driving
- Help !! 99 3.5L Random Multiple Misfire
- Autobahn suspension
- Stainless fender well molding
- Rear end sways
- Am I Imagining Things
- A/C Condenser for 3.8L
- Fuel Gauge on Top Side of pin
- Chiltons Repair Manual
- What is a fair price for a 1999 Intrigue
- Radio stays on after doors open
- Parking lights(turn signals) not working right?
- Interior swap question
- 3800 Won't Fire (start)
- Warped Rotors?
- Squirrelly Odometer
- Overheating!?
- 1999 Intrigue 3.5 engine rough idle
- Lights flickering and car display going nuts
- I need a stock 98 intrigue PCM file
- Want Feed-back on Hercules Tires
- speedometer pinned at 140mph
- fuel pump and sending unit
- ac switch question
- 1998 - Thermostat location
- Attention '98-'99 Intrigue Owners with SII 3800 Engine
- sun roof stuck
- Stereo Question
- 1999 Intrigue with Problem Starting
- 2002 Olds Intrigue
- Want Feed-back on Husky Tires
- DEX-COOL vs GREEN
- AC making rattle noise
- Passlock
- Driver's Side A/C Blowing Warm
- Overdrive not working
- 02 Oldsmobile Intrigue vs 04 Malibu
- Engine Over-heating on my 99 3.8L
- External Temperature reading
- Shifting out of park without applying brake
- Rear wheel bearing replacement for 2000 Intrigue
- Grand Prix hub for Intrigue?
- Security light
- Timing Chains and Miles
- Will 215065016 fit the Intrigue
- Need Help "I want to Pimp my Olds with rims"
- 99 intrigue codes
- A/C Needs Recharging
- 2000 Intrigue key switch
- Dead A/C Condensor
- Intake Gasket leak.. how to fix
- How do I change this?
- 99 Intrigue spitting out marble size balls
- Water Pump
- Miscellaneous problems
- 99 Olds Intrigue Will start run, and then won't
- Mild shudder on acceleration
- Brakes 01
- Car won't start, crazy electrical stuff. Help please!
- Squeaking
- Odd noise
- Shocks & struts
- ignition switch
- 99 Intrigue, Do Seats Come Down??
- 2000 GLS instrument cluster
- Time to change plug wires?
- Battery Terminal Corrosion
- Who knows tire sizes
- Spark plugs
- temp control, 2000 with 3.5
- fishtank sound, 2000 olds with 3.5
- stalling at 1/4 temp, 2000 gl
- 2000 intrigue
- 98 Normal Operating Temp
- Help My Rad fans will not come-on
- Water on Driver's Side Floorboard
- Installing Subwoofers with Bose system
- Gas Tank Filler Neck
- Thermostat housing
- 99 3.8L Runs for Only 10 Minutes
- What does the hose i marked in blue do/go to?
- Poll: Have you replaced camshaft or crankshaft position sensor on 3.5L intrigue?
- Have you replaced your ignition coil on your 3.5L intrigue?
- my intrigue problems
- What is this part, and what does it do?
- 2000 GLS My Story
- Removing 99 Intrigue Gauge Cluster
- 98 olds intrigue intake manifold
- 2000 GL/ stalling..starting...
- Service Vehicle Soon and Trac light
- 99 Intrigue running problems
- Starting Issues
- Window Molding
- Misfiring
- Headlight switch
- Are these intake manifold gasket failure symptoms?
- Temperature Fluctuations
- Rear Speaker Covers
- Gas gage not working
- Updated altoernator
- Part number for 2000 Olds Intrigue (TCC PWM solenoid)
- Power Steering hose/Pressure Hose
- how to change front left blinker light
- AutoEnginuity code reader
- Intrigue won't start, engine error codes
- Vibration in Pedals and Steering Wheel
- 2000 intrigue pcm
- Well guys, its at the dealer to be diagnosed
- new blower motor question
- blower motor
- recent P0300 and now low fuel pressure
- Custom Exhaust
- 99 Intrigue 3.8 Liter Poor Idle Leaking AntiFreeze
- Change oil light, when I just did under 1K ago
- Heat Problem... Need advice
- Service Engine Light and loss of power
- Intrigue 99 - Blower motor not working
- Olds 2000 Intrigue possible passlock problem
- Weird high pitched noise??
- 2000 3.5L Running hot. Need help
- Question about lowering springs!!
- ABS Brake Question On 98 Olds Intrigue
- Question about Cluster Guages
- ac/heat won't switch modes, blows through all vents?
- Automatic Climate Control shuts off periodically...
- Service Engine soon light and loss of power
- 99 Olds starting probs
- Oil cloud out of exhaust
- 98 oil pump diagram
- Antifreeze leak - Repair shop said.......
- over heating
- Another Engine Debate
- 2000 3.5L Water Pump Replacement
- 98' Intrigue Fuse relay box
- Body Kit & Custom Gauges For Olds Intriuge
- Tensioner Pully
- Passlock Problem disable
- Crankshaft Position Sensor
- Replacing Driver Side mirror
- What's this warning light?
- Radio question
- Weak Engine
- Rear tire camber
- Windshield Wiper Arm
- inner tie rod ends
- Car Shakes/Jerks while Accelerating
- Intrigue aftermarket headlight upgrades:
- Auto shifter wont shift out of park
- Intrigue engine mount
- Driver Sideview mirror
- rear window steam
- 2000 Intrigue Stalling
- Auto-headlights dimmer than manual
- Starting problem
- Condensation in Trunk
- 1999 Intrigue Clunk
- 1998 Intrigue Electrical Problems!!!!
- 2000 Intrigue P0101 P0410
