View Full Version : Intrigue
Pages :
1 2 3 4 [ 5]
6 7 8
- Vanity Mirror / Visor
- Front struts lower bolt removal
- Whirring/grinding noise 2002 intrigue on startup
- Rattle Sound
- Loud Bang when turnning on Reverse
- Good deal on two repairs?
- check engine light blinking
- tranny with 3.29
- Learned an Expensive Lesson
- 2001 vibrates, flutters in drive
- 2002 oldsmobile Intrigue
- E-brake wont lock
- 2000 Intrigue - Major electrical problem
- 2000 Intrigue 3.5 Air Conditioning blows warm under acceleration
- Loosing a weld in strut tower.
- What Did I Do Wrong? - Horn Problem
- 2000 Transmission hard shift
- Is there away of lubing the Strut Bearings
- Trunk Cd Changer cable location?????
- replaceing alternator
- a/c hissing
- I have a 99 with a 3.8
- Any one with a Code Reader In Toronto Area
- Rad cooling Switch on 3.8L 99 Intrigue
- Silver plastic covers on engine there for a reason?
- someone is getting a custom throttle body!
- Poll: How long before changing spark plugs?
- fog light housing
- Trio of Problems
- Secondary Air Pump
- new to forum
- hints or tips
- 'groan' noise from steering
- DIY tranny flush?
- what color is your intrigue?
- Headlight problems.
- odometer issue?
- steering grind
- 2002 - replacing o2 sensors
- 2002 engine will not start
- New owner.....
- Poop's out at higher RPM's while accelerating
- 98 intrigue...ABS and BRAKE light
- How to change trans fluid
- A/C cool...not cold?!
- Intermitent A/C operation on 2000 Intrigue
- Changed my Own Oil on 2000 Intrigue
- Fuel Gauge Broke. Anyone ever fix there's
- Broken Motor Mount?
- a/c clutch fastener bolt
- Testing A/C clutch
- Dash board removal to fix A/C door
- Removing 99 Intrigue Steering Wheel
- Crankshaft Position Sensor
- 99 intrigue 3.5L engine making loud noise
- 98 3.8L Air Conditioning Problem
- PK2 Passlock 2 system failure and bypass proceedure
- All dash lights come on, headlights dim and car dies
- car pulls slightly to the right when...
- Service engine soon light -- again!!
- 99 3.8 shut off problems
- 1999 Rear View metal plate
- Cruise Control
- start up/dying probs
- Where is the fuel pressure regulator located in 2000 Intrigue (3.5)?
- 2002 3.5 Intrigue Tranny RPO
- Check engine light-Help
- 99 Intirgue overheating in idle
- Outside Temp Thermometer
- Engine Hesitation At Constant Speed
- 98 Intrique belt broke on engine temp went to hot
- Addco Front Swaybar
- Shifter got stuck in park
- Car starting/dying problems!!!
- throttle body spacer
- Starting
- Installing a Remote Starter.
- 99 Intrig. A/C & display itermittent operation
- How do I check fuel injector 4 for misfire?
- What are the cylander # layout on 3.5L?
- Anyone know how to change spark plugs?
- Engine Oil Pressure Switch
- HVAC fan not working
- Center console LED's not lit up...
- Engine Mount Replacement
- Gas Gauge Fluctuations
- Reverse glow gauges
- 2000 Intrigue Brake pulsations
- I am so lost when it comes to performance parts.. please help
- Would swapping my non digi climate control for a digi work?
- Shifting an automatic? Bad?
- Hole in firewall for amp/electronics install?
- 1998 Intrigue Engine Valve Problems
- More of a high pitched noise than a vibration....
- Door panel removal
- Leaking rear valve cover
- Severe coolant leak - please help
- Front wheel noise
- Setting time in Intrigue 98'??
- 2000 Intrigue - Changing the Coolant
- Engine Vibration! Help please...
- Repaint
- Crankshaft position sensor
- '99 Intrigue 3.5L fuel sensor shows 150%
- First post check it out
- Service Vehicle soon Light
- '99 intrigue 3.8L air conditioning problem
- P0410 Fix???
- Starting problems
- Numerous HVAC problems
- New and Old Members Please Read
- Plastic Roof Strips
- Power window problem
- Power Stearing leak question
- factory wires in stereo
- Weird electrical problems
- Another turning signal problem
- Bad Ignition Coil
- Bizarre odo behavior
- Dash lights blinking and needles going crazy
- Help With Ac
- 98 intrigue starting issues
- AC - ext. temprature stays at 32
- Hazard Lights work....Right side turn doesn't
- ABS and emergency brake lights
- Rear Brake Vibrating Noise
- Hard Start Issue Semi-Resolved
- waxed and washed....sort of
- Brakes
- Biggest rim size
- Xenon HID Light Bulb Replacement
- replacing the head unit with a bose
- Gurgling noise!!!
- Air Bag Dash Cover/Insert Replacement
- car starts its self, dash lights out ramdomly
- Top end knocking when hot
- Replacing Oxygen Sensor
- Bad Compressor?
- wierd question
- Wheel Bearings 98 Intrigue
- FS 2001 - 2005 Remote Fobs(2)
- tranny prob may need flush?!!
- Penzoil Platinum Oil full Synthetic
- Window Troubles
- replacing the bose head unit
- fuses
- Sticky Gas Pedal
- what brand tires do you have?
- burning oil, which oil is best?
- please help...guage prob + sum others
- 99 3.5L Engine Change - Other years?
- Crankshaft Sensor replacement...
- Aftermarket Rims
- SES, PCS, ABS, trac all lights on Help
- 99 olds intrigue 3.5
- car running lean?
- 98 intrigue air conditioner
- Check out this Intrigue its superchargered
- Miles to a tank of gas??
- 2000 oldsmobile intrique heating problem 3.5
- Fuel gauge is acting funny
- Engine shutting off
- extended warranty '02 Intrigue
- AC Compressor for 2000 Olds Intrigue
- 2000 3.5 misfire
- Starting Problems
- What kind of MPG do you get?
- Looking at a 2002 GX
- New Transmission in 1998 Intrigue
- Very Confused And Need Help!!!!!
- Peeling rubber sill
- White film on PCV valve???
- Sagging Headliner
- ignition-no tune-up
- Will my car go 'stupid'?
- Stuck cassette tape
- Ac Light Stays On Whenever Heat Is On
- '98, brake & abs light on, bad shifting, and other issues
- Service Engine Soon Light
- Adjustments to Bose Amp?
- cars puking gas
- Spark Plugs
- Motor mount
- Multiple Cylinder Misfire, 3.8
- no crank at all!!!!!!!!
- interior climate fan making a clicky sound
- 99 Olds License Plate Light
- Low Oil Light
- Help!!!!
- Bought AC Delco Platniums, NGK were in the box???
- need help for new injector(s)
- 2000 intrigue climate control question and a couple others....
- 2001 Gear change problem
- Changing a crank position sensor
- Climate Temperature Sensor
- car shuts off while driving
- How do i get the dam door panel off?
- replacing 3.8 intake gasket
- stuck r. f. brake caliper
- A few Audio wiring questions..4 my new 98.
- Help, many problems
- newbie, just bought a 98...few questions
- hard shift when hot
- 98 Intrigue S/C possibly?
- Sporadic High Idle
- Is it my tire or something else?
- 98 intrigue service engine light
- Calibration of 2000 Intrigue Rear View Mirror With Compass and Thermometer
- 2000 Intrigue - Heating up in Cold Weather
- 99 intrigue rough running/starting
- Starter Replacement
- Engine Temp./No Heat ????
- Please give me good advice
- Hard to start sometimes
- Locking Gas Cap
- Bad Fan Motor- Any1 Know How to Replace
- Where in the world is the power steering check?
- Anyone know how to remove change tray?
- '98 Intrigue Power Window Problem
- Foul Smell
- Timing Belt Replacement
- Tech2 C-code list
- How do you replace brake fluid
- Strut-Tower Bar
- 98 intrigue wipers stuck in vertical position
- Intermittent starting problem
- HID Light Conversion
- Changing the Blinkers
- 1998 olds,pbile intrique hot and cold temp
- 2000 intrigue A/C clutch bearing removal
- Here is a new one for you, at least for me it is
- late shift
- 2001 intrigue no start
- Stuck Emergency brake
- ABS and BRAKE light are on
- where is the cdplayer interface located?
- Over charging issue with alternator
- Groaning sound when stopped in drive
- Confused Oldsmobile Intrigue 2000 Owner
- UPDATE!! on "What the Heck is going on" Message
- automatic headlights
- ses light on
- Control Arm Bushings
- Gas Cap Actuator
- 99 Olds Intrigue (3.8l) strut noise? also ps noise,vibs.
- What the heck is going on?? Need Help!
- Security Problem i think?
- Recall and TSB lists in MS-Excel format
