View Full Version : Intrigue
Pages : 1 2 3 [4] 5 6 7 8
  1. Lights flickering and car display going nuts
  2. I need a stock 98 intrigue PCM file
  3. Want Feed-back on Hercules Tires
  4. speedometer pinned at 140mph
  5. fuel pump and sending unit
  6. ac switch question
  7. 1998 - Thermostat location
  8. Attention '98-'99 Intrigue Owners with SII 3800 Engine
  9. sun roof stuck
  10. Stereo Question
  11. 1999 Intrigue with Problem Starting
  12. 2002 Olds Intrigue
  13. Want Feed-back on Husky Tires
  14. DEX-COOL vs GREEN
  15. AC making rattle noise
  16. Passlock
  17. Driver's Side A/C Blowing Warm
  18. Overdrive not working
  19. 02 Oldsmobile Intrigue vs 04 Malibu
  20. Engine Over-heating on my 99 3.8L
  21. External Temperature reading
  22. Shifting out of park without applying brake
  23. Rear wheel bearing replacement for 2000 Intrigue
  24. Grand Prix hub for Intrigue?
  25. Security light
  26. Timing Chains and Miles
  27. Will 215065016 fit the Intrigue
  28. Need Help "I want to Pimp my Olds with rims"
  29. 99 intrigue codes
  30. A/C Needs Recharging
  31. 2000 Intrigue key switch
  32. Dead A/C Condensor
  33. Intake Gasket leak.. how to fix
  34. How do I change this?
  35. 99 Intrigue spitting out marble size balls
  36. Water Pump
  37. Miscellaneous problems
  38. 99 Olds Intrigue Will start run, and then won't
  39. Mild shudder on acceleration
  40. Brakes 01
  41. Car won't start, crazy electrical stuff. Help please!
  42. Squeaking
  43. Odd noise
  44. Shocks & struts
  45. ignition switch
  46. 99 Intrigue, Do Seats Come Down??
  47. 2000 GLS instrument cluster
  48. Time to change plug wires?
  49. Battery Terminal Corrosion
  50. Who knows tire sizes
  51. Spark plugs
  52. temp control, 2000 with 3.5
  53. fishtank sound, 2000 olds with 3.5
  54. stalling at 1/4 temp, 2000 gl
  55. 2000 intrigue
  56. 98 Normal Operating Temp
  57. Help My Rad fans will not come-on
  58. Water on Driver's Side Floorboard
  59. Installing Subwoofers with Bose system
  60. Gas Tank Filler Neck
  61. Thermostat housing
  62. 99 3.8L Runs for Only 10 Minutes
  63. What does the hose i marked in blue do/go to?
  64. Poll: Have you replaced camshaft or crankshaft position sensor on 3.5L intrigue?
  65. Have you replaced your ignition coil on your 3.5L intrigue?
  66. my intrigue problems
  67. What is this part, and what does it do?
  68. 2000 GLS My Story
  69. Removing 99 Intrigue Gauge Cluster
  70. 98 olds intrigue intake manifold
  71. 2000 GL/ stalling..starting...
  72. Service Vehicle Soon and Trac light
  73. 99 Intrigue running problems
  74. Starting Issues
  75. Window Molding
  76. Misfiring
  77. Headlight switch
  78. Are these intake manifold gasket failure symptoms?
  79. Temperature Fluctuations
  80. Rear Speaker Covers
  81. Gas gage not working
  82. Updated altoernator
  83. Part number for 2000 Olds Intrigue (TCC PWM solenoid)
  84. Power Steering hose/Pressure Hose
  85. how to change front left blinker light
  86. AutoEnginuity code reader
  87. Intrigue won't start, engine error codes
  88. Vibration in Pedals and Steering Wheel
  89. 2000 intrigue pcm
  90. Well guys, its at the dealer to be diagnosed
  91. new blower motor question
  92. blower motor
  93. recent P0300 and now low fuel pressure
  94. Custom Exhaust
  95. 99 Intrigue 3.8 Liter Poor Idle Leaking AntiFreeze
  96. Change oil light, when I just did under 1K ago
  97. Heat Problem... Need advice
  98. Service Engine Light and loss of power
  99. Intrigue 99 - Blower motor not working
  100. Olds 2000 Intrigue possible passlock problem
  101. Weird high pitched noise??
  102. 2000 3.5L Running hot. Need help
  103. Question about lowering springs!!
  104. ABS Brake Question On 98 Olds Intrigue
  105. Question about Cluster Guages
  106. ac/heat won't switch modes, blows through all vents?
  107. Automatic Climate Control shuts off periodically...
  108. Service Engine soon light and loss of power
  109. 99 Olds starting probs
  110. Oil cloud out of exhaust
  111. 98 oil pump diagram
  112. Antifreeze leak - Repair shop said.......
  113. over heating
  114. Another Engine Debate
  115. 2000 3.5L Water Pump Replacement
  116. 98' Intrigue Fuse relay box
  117. Body Kit & Custom Gauges For Olds Intriuge
  118. Tensioner Pully
  119. Passlock Problem disable
  120. Crankshaft Position Sensor
  121. Replacing Driver Side mirror
  122. What's this warning light?
  123. Radio question
  124. Weak Engine
  125. Rear tire camber
  126. Windshield Wiper Arm
  127. inner tie rod ends
  128. Car Shakes/Jerks while Accelerating
  129. Intrigue aftermarket headlight upgrades:
  130. Auto shifter wont shift out of park
  131. Intrigue engine mount
  132. Driver Sideview mirror
  133. rear window steam
  134. 2000 Intrigue Stalling
  135. Auto-headlights dimmer than manual
  136. Starting problem
  137. Condensation in Trunk
  138. 1999 Intrigue Clunk
  139. 1998 Intrigue Electrical Problems!!!!
  140. 2000 Intrigue P0101 P0410
  141. Starting Problem
  142. Lights are burning out
  143. 99 3.5 radiator removal
  144. Suspension Noise
  145. Fog Lamps constantly requiring replacement
  146. 99 Intrigue Transmission Mount
  147. Bad noise while turning left.
  148. How to remove rear spoiler
  149. 98 Intrigue Climate Control Fan Noise
  150. P0301 problem
  151. My fenderwell intake with pics!
  152. bad ignition switch?
  153. Gear Ratio Change
  154. 3.5 Timing Chain/Tensioner R/R
  155. info on control arms
  156. Where can I get Dex-cool
  157. New Member/Hi
  158. Guidelines for buying a Used Intrigue:
  159. Location of Turbine speed control (part)
  160. Don't lower your Intrigue
  161. Odometer question
  162. New muffler/resonator pipe for '99 3.5L
  163. Blower motor not working on lower settings. Could it be the resistors or resistor mod
  164. 99 Intrigue "How to check power steering Fluid"
  165. Increase Gas Mileage
  166. Where's The Darn Power Steering Fluid Go??
  167. Climate control unit question
  168. sensors
  169. Exhaust Sputtering
  170. Cv R/r
  171. Reset Oil change light
  172. Bad Ball Joints
  173. Slight coolant odor
  174. help ! mass air flow sensor
  175. How do you replace an altenator?
  176. 12" rotors and struts question
  177. Windshield Wiper Problems
  178. How Much would you pay for a 99 Intrigue
  179. Aux Input Static
  180. head light flickering
  181. CV Drive Shaft Replacement
  182. 2000 Intrigue - 113k - Burns Oil - Synthetic?
  183. Re: Genera test vehicle search, CA.
  184. Paint Code
  185. Engine light on....
  186. Driverside window regulator
  187. Some dealer claims to want Intrigues
  188. Q; Replacing rear blinker bulbs
  189. 99 Intrigue GX Keyless Entry question...HELP!
  190. Defrost not clearing window
  191. Alternator
  192. Bad news from Tranzgenic
  193. tranny shifting hard
  194. Antifreeze change
  195. Multiple problems... Can anybody help???
  196. How to test the coil Pack
  197. Still necessary to disc. battery on recharge?
  198. window problem
  199. 2000 Intrigue engine dies
  200. Head lights are all Foggy
  201. "Yatzee Shaker"
  202. Power steering and brake fluid flush
  203. Trans filter change
  204. 3.5 vs 3.8 Intrigue
  205. problem with breaks
  206. Rear Defroster Does Not Work
  207. my newest mod
  208. '98 no start, SES on, 5 DTC's
  209. Break Problem
  210. Turn Signals...
  211. Which hose is heater inlet 1998
  212. Parts for '98 Intrigue
  213. Change all hoses?
  214. Steering question
  215. Winterizing your car:
  216. po171
  217. Am I going to kill my car (or myself)?
  218. 2000 Intrigue...P0385 code
  219. Will a cobalt wheel bearing Hub fit an Intrigue
  220. Downloading repair manual?
  221. My Car refused to start!!
  222. 2000 Intrigue location of blinker relay or other possible problem question
  223. Color of Remote Wire on 99 Oldsmobile Intrigue
  224. just a couple pics, nothin fancy
  225. Interior Lights not working
  226. 2000 intrigue abs
  227. How do you remove - front seat headrests?
  228. Update to noise while idleing
  229. Dead compressor?
  230. Flushing coolent
  231. Front wheel speed sensor
  232. '02 3.5 intake manifold cleaning?
  233. Cold air intake
  234. 98 Intrigue spark plug changing
  235. How do I remove the Steering Wheel
  236. Intrigue dead, no power, won't jump
  237. FIX IT OR GET RID OF IT 98 intrigue 130,000k
  238. no start,no crank
  239. Steering noise
  240. Service Engine Soon light after gas fill up
  241. Aftermarket Wheel bearing hub assembly
  242. Front strut replacement, '98 intrigue
  243. front bumper replacement
  244. 2001 Intrigue, a strange security problem
  245. a/c only works on high - '98 intrigue
  246. Installing a Fuel Pump
  247. Which Haynes repair manual for a 1998 Intrigue
  248. 99 Intrigue - NO start (new BCM)
  249. Power Window parts?
  250. what type of wrench?
