View Full Version : Intrigue
Pages : 1 2 [3] 4 5 6 7 8
  1. Dead 99 Intrigue
  2. 98 Intrigue - Misfire or transmission?
  3. What do you use, 5W30 or 10W30??
  4. 1999 Intrigue rebuid snag
  5. '98 Won't take gas, rollover check valve?
  6. Antennas on 01 intrigue gls?
  7. Troubleshooting keyless remote programming
  8. GM's Engine Problems, Solved with easy Fix
  9. im stumped
  10. Will 5x114.3 Rims Fit on Our Intrigue's
  11. got a doner car
  12. 1-2 Shudder
  13. Sticky Shift Knob/Button
  14. Oil in rear cylinder?
  15. Washer pump 01
  16. ac compressor
  17. need new motor
  18. climate control went out...HELP! its cold out!!
  19. Help with 99 Intrigue climate control or blower motor resistor
  20. got it runing
  21. 99 Intrigue, lug caps needed
  22. battery indicator-real simple
  23. CLimate Control cluster/Auto headlights not working
  24. Oh... S*%t!!!
  25. 2000 3.5L AIR pump system
  26. 1999 oldsmobile intrigue/security light
  27. 1999 oldsmobile intrigue/stalling
  28. Fuel level sensor
  29. Electrical System Pulsing
  30. 2000 Intrigue blower motor works sometimes
  31. so never seen!
  32. Trans Problem as well
  33. cooling fan problem
  34. Fog Lights
  35. water pump replacment on 98'
  36. 98 intrigue trans problems
  37. Check Engine LIght - P0101
  38. 98 Intrigue headlight/heater problem
  39. Cluck noise when steering 00 intrigue
  40. a/c recharge
  41. where can the coolant leak be?
  42. Transmission - OD troubles
  43. Subwoofer Wiring
  44. 99 Intrigue - replacing just the mirror glass on the drivers side?
  45. cure for water on pass. floor?
  46. How to install fan motor on 99 intrigue
  47. 99 Intrigue - Dirvers Side Window
  48. please help!!
  49. Energy Suspension Bushings
  50. intrigue transmission fluid change
  51. adjusting rocker arms?
  52. oil dipstick tube location?
  53. reinstalling a coil pack problem
  54. Strange things are happening
  55. Crankshaft Position Sensor Question
  56. a/c not working fuse keeps blowing
  57. Changing PCV on 3.8L engine
  58. Expert advice needed!
  59. Maintenance on 2000 Intrigue
  60. 1999 Olds Intrique Gage and Warning Lights
  61. 1999 olds intri 3.8 wont start
  62. seems alot of people have tranny issues..heres mine
  63. 1998 olds intrique 3.8 broken starter snout housing
  64. 1998 olds intrique 3.8
  65. OIL Leak
  66. Firing Order
  67. Clunk when braking in reverse
  68. check engine soon stays steady, blinks periodically, rough idle, driveable?
  69. Transmission Problems
  70. blinkers?!?
  71. weeked chores, spark plugs, pads/rotors etc
  72. Starting problems
  73. Transmission Problem (No OD)
  74. AC is stuck on and some doors wont open on 2000
  75. Coolant Color?
  76. Location of ground screw for HVAC
  77. Night view mirror broke
  78. Won't start
  79. Tire pressure?
  80. Passenger power seat-doesn't work
  81. 99 Olds Intrigue transmission problems
  82. Fuel door release latch
  83. blinkers
  84. Blower Resistor?
  85. Steering left - noise/hard to turn
  86. Airbag cover open?
  87. Rough Shifts
  88. Transmission Troubles
  89. Tire or Bearing noise? LR tire/wheel
  90. looking for 2001 ign harness diagram
  91. oil consumption
  92. Transmission filter change
  93. 1999 Intrigue Climate Control Problems
  94. Fuel Bleeding Down in Fuel Rail Quickly
  95. 99 Intrigue Hard Starting
  96. Transmission Problems with 98?
  97. hi - airbag light
  98. How to measure Tire Tread Depth
  99. transmission pan gasket
  100. 1998 Intrigue, New member looking for advice
  101. Is it Possible?
  102. White smoke at startup
  103. DTC code questions
  104. CKS or camshaft sensor needed (2000 Intrigue)
  105. found the leak, water pump or line (with pic)
  106. Resonator has a hole in it
  107. Starter On Its Way Out???
  108. coolant capacity
  109. My Heater Core Just Blew 2nd time
  110. 2002 Intrigue Blower Motor
  111. 99 Intigue front bumper cover and fenders
  112. Can I Replace my 3.5 ENGINE with a 3.8 series II-SAME YEAR
  113. No Speedometer or Odometer
  114. Power steering fluid reservoir location?
  115. 2000 GLS - troubleshooting P0410 code (service engine soon light)
  116. How do I install switch to turn on Cooling Fans
  117. think im loosing coolant...or not?
  118. Drive axle Olds Intrigue
  119. Transmission Fluid Color
  120. Coolant Change - Engine Drain Plug
  121. Cranks Long before Starting
  122. 2000 Intrigue, difficult starting when warm
  123. Anyone put on different fog lights
  124. Any change Exhaust on 3.5L
  125. 2001, coolant overflow question
  126. Car can't start at all its been 4days
  127. Electrical! Gauges moving without keys in!
  128. Cold Air Intake and Air Pump?
  129. Rubber covers to headlights/plugs up the hole
  130. Passlock disabled but stalling persist
  131. 99 intrigue will not start... new starter, new battery, i dont know what to do
  132. 2000 3.5L stalling after starting
  133. 99 Intrigue tracion control, abs & airbag light flash. Blower motor cuts in and out.
  134. Possible transmission leak
  135. Hard to Start
  136. Parking brake malfunction...
  137. HVAC Air Conditioning recirculate mode issues
  138. Starting/Electrical problem?
  139. Air Condition Blows Out Every Vent
  140. whistling front end at high speeds
  141. 99 intrigue- only driver can control windows
  142. Cleaning Mass Air Flow Sensor?
  143. Goodbye!!
  144. How to Replace Spark Plugs for 1999 Olds Intrigue
  145. Service Vechicle Soon/ABS/Trac Off
  146. Water Drainage
  147. 2000 GLS Blown Fuse Ign 0: PCM & BCM
  148. Car jolts
  149. Intrigue Starting/Passlock problem??!!! 1998 intrigue
  150. Transmission Problem
  151. My Overheating Issues
  152. help needed on front sway bar
  153. Transmission Drain Plug
  154. Ignition Switch Removal?
  155. Would you recommened Flushing Power Steering
  156. high pitch metallic sound
  157. Where to find tranny ID Code?
  158. I fixed my over-heating problem
  159. Disable automatic headlights
  160. Need some advise
  161. 2002 olds A/C mode control
  162. Looking for walkthrough ... electrical troubleshooting of TCC Stuck On tranny prob
  163. 99 Intrigue 3.5L rumbles when accelerating and when idlying in dirve
  164. driver a/c hot pass a/c cold, discovered FIX
  165. a/c compressor high pitched squeal
  166. service engine soon
  167. Whats the best exhaust diameter for Intrigues
  168. ISS Lube
  169. Transmission shift solenoid
  170. Crankshaft variance learn procedure
  171. 99 Intirgue Service Engine Soon warning light
  172. Weak Battery
  173. AC running when set to defrost?
  174. fog lights not working
  175. hard to start sometimes...hot or cold
  176. 2000 Intrigue - TCC Stuck On
  177. 2000 Intrige maintenance items
  178. Hope I can get some help...
  179. I've got a warning light problem
  180. Very Dissappointed With Gas Milage
  181. 1999 Intrique Fuel Gauge
  182. Service Engine Soon Light and Car Does Not Start
  183. Would you Trade a 1999 Intrigue fir a 300ZX
  184. 2001 Olds Intrigue
  185. misfire...wont rev past 4k
  186. how do I fill a/c with freon
  187. Oil drain plug stuck
  188. 1998 Intrigue Switch Problem
  189. Quick Question What Size fuel Tank in 99 I may be getting bad mileage
  190. TSB #010523011A - Rattle type noise coming from front of vehicle
  191. hot a/c on drivers side
  192. 99 Intrigue Front Sway Bar Replacement
  193. Adding Info Stalling 1998 Intrigue
  194. The Resonator split at the seem
  195. Body Control Module (BCM) HELP PLEASE
  196. 98 Olds Intrigue Ac Issues.
  197. Is the Intrigue's 3.5 Northstar a performance engine?
  198. AC vent ducting and warm drivers side air
  199. My Overheating problem
  200. I installed Michelin Hydro Edge Tires
  201. 11 or 12 inch rotors?
  202. Recharge A/C '99 (3.8L)
  203. Where is the odometer milage kept
  204. 2001 Intrigue 3.5 engine
  205. 99 intrigue, ever thought of cutting springs??
  206. The tach needle stuck to the very right
  207. airbag/antilock/brake lights on
  208. Is thare a way of Replacing coolant Elbo at base of lower intake
  209. 1999 Intrigue GLS(3.5 L) performance chip.
  210. Intrigue maintenance manual.
  211. 1999 Intrigue GLS(3.5 L) transmission slipping.
  212. atoyota4x4 post here about your overheating
  213. Passenger doors will not unlock
  214. High miler 98 with bad tranny shutter
  215. blower only works on high
  216. The Horror the Horror Loosing Coolant
  217. 2001 Intrigue CEL on.
  218. 2001 oldsmobile intrigue 3.5
  219. Rear View Mirror fell off
  220. Hesitation
  221. Temperature Gage gone crazy-3.8L
  222. Service Vehicle/Abs/Trac/PCS lights
  223. Po300, Po385, And Po1372 Error Codes For A 2000 Oldsmobile Intrigue
  224. Plugs and brakes...ugh
  225. Need some help
  226. Autolite Alt. For Olds?
  227. Windshield Washer Fluid Leak
  228. Hard Start when warm
  229. Replacing the Ignition Cylinder
  230. A/C light flickers but won't turn on, no cold air
  231. Anyone replace Neutral safety switch
  232. intrigue vacuum lines. Need boot
  233. warning lights illuminated last night while driving
  234. Help !! 99 3.5L Random Multiple Misfire
  235. Autobahn suspension
  236. Stainless fender well molding
  237. Rear end sways
  238. Am I Imagining Things
  239. A/C Condenser for 3.8L
  240. Fuel Gauge on Top Side of pin
  241. Chiltons Repair Manual
  242. What is a fair price for a 1999 Intrigue
  243. Radio stays on after doors open
  244. Parking lights(turn signals) not working right?
  245. Interior swap question
  246. 3800 Won't Fire (start)
  247. Warped Rotors?
  248. Squirrelly Odometer
  249. Overheating!?
  250. 1999 Intrigue 3.5 engine rough idle
