View Full Version : Intrigue
Pages :
1 [ 2]
3 4 5 6 7 8
- Torque Converter acting up
- Bose Radio?
- '01 Intrigue: Gas Guage Not Working....
- P0446: Evaporative emission control system malfunction
- Radio Issue, please help !!!
- Cruise Control Issue
- Preignition pinging?
- Keyless entry on ALL 99's...are you sure???
- Transmisson fluid lube guard additive
- Which coolant? Green, Dex, Universal?
- Pics of cleaning the ignition switch security light gone
- 99 Intrigue - 4 struts replaced. Notes from the job
- heater not blowing
- 2001 Intrigue - Air Pump ?
- bad fourth gear
- Advice on replacing Rear Struts
- trans tune seafoam question
- Long term fuel trim is incorrect
- 99 Intrige won't start - acting stange
- My shifter button broke how do I change it
- Help with draining the antifreeze
- Window switch
- Is my climate control syst working correctly?
- sometimes sluggish somtimes not
- Pics of my tranny woes... YIKES!
- Disabling Passlock?
- Didn't see this coming, BLOWER INOP!
- 1998 V6 car shakes when shifting to Reverse
- New guy with a few questions...
- 98 Olds Power Steering Issue
- 2000 3.5L Intrigue running cool
- Power Steering Fluid needs to be changed
- fuse keeps blowing out
- AC only comes out of the driver side
- Thermostat project update....and then some.
- Need advice on a few things with my '98 3.8L
- 2002 Intrigue GX -- couple of problems..
- Coolant flush?
- Tranny Update--metal in pan! 02 49,000 miles
- feel my pain
- Getting Dealer only parts online in Canada
- blower resistor replacement
- Serpentine Belt Info Needed
- 02 GLS New to me @ 48000 miles-Thoughts.
- This is Nuts. I am on my 3rd Heater Core
- 2002 intrigue
- 3.5L possible major engine failure
- Brake Problem
- Orfice tube location!!
- Buying an Intrigue with issues
- A/C blows warm air
- Front wheel hubs & trust yr mechanic
- Which W-body cars had stiff suspensions?
- transmission - how do you know it needs service
- Problem with brakes
- Whats Limp Mode how's it work
- window issues - driver's side is the only control that works
- Paint chipping
- OIL leak
- GMPP trailing arms rattle
- Hydraulic Lifter Rattle
- whining noise with increased RPM's / Acceleration
- blower
- Installing fuel pressure regulator 3.5 engine
- Remote Trunk Lock Failure
- ABS Motor / Power Steering Issue
- Low coolant sensor
- AC cooling issue.. Cooling fans not coming on
- 1998 Intrigue
- After Market Stereo Problems - Wiring.
- leak when rains
- Coolant Leak
- Window Switch gone batty
- AC drain?
- Hot air/Cold air
- many problems, probably one source
- Polyurethane bushings
- No start event/Theft Deterrent Re-Learn procedure
- Airbag module
- 3.5L K&N Air Filter
- Squid treatment for my oil burner motor
- Tripod joint question
- ABS Sensor issues
- Secondary Air Injection Pump Problem
- AC Compresor not coming on
- Oil smoking When checking oil after running
- 1999 OLDSMOBILE 3.5 INTRIGUE Replacing the V-Groove Belt
- 98 intrique ac switch ?
- 98 intrique w/ rattle in passenger rear
- Wipers completely powered down
- What all do I need when replacing struts?
- 99 Intrigue 3.5L motor mounts?
- 99 Intrigue 3.5L. Loud bang noise now car won't start
- wipers wont shut off
- Just passed emissions 00 gx but have ?'s
- Climate Control Reads wrong on Outside Temp
- Intrigue Mileage
- Service Vehicle Soon and Trac Off lights.
- windows problems
- 1998 Intrigue Ac Blower
- Weird Stuff Happening 2000 Intrigue
- quick help needed
- In the middle of UIM & LIM gasket replacement, couple Q's
- emissions failure/check engine light. please help!
- Another starting problem
- 3.5L Intake Manifold Gasket? Coolant use, occasional stalling
- Doors unlock, but won't lock...
- 2000 3.5L sometimes won't start
- SES light, O2 Sensor(s)?
- Changing Blower Motor Resistor
- 3 vehicles with bad PCS!
- blinker problem
- Strange noise!!
- Crankshaft and camshaft sensor failure after replacement?
- Cleaning the Ignition Switch: I really screwed it up
- Front sway bar broken?
- 99-3.8, Engine stumbles at Times
- Directional bulb keeps malfunctioning.
- obd scanner recommendations
- antifreeze loss?
- Can anyone explain these codes?
- Metal Brake Lines
- Replacing the Bose Head Unit
- '98 3.8 upper & lower intake manifold gasket & plenum replacement help (kinda windy)
- Is the 3.5 Intrigue worth it in the long run?
- how to silence noisy brakes
- Trouble starting when warm; occasional shut down when driving
- 2000 Intrigue No Overdrive
- 99 Intrigue - troubling starting when car is warm - begins to idle rough
- Iridium IX Plug #TR55IX
- 98 Intrigue, burning oil now?
- 98 3800 wont start
- 2000 GLS 3.5L - recommended power steering fluid
- 1998 cluster replacement
- new hubs = noise..DAMN
- 2001 Intrigue; has power, won't crank or start
- factory stereo wire info
- 98 Olds Intigue.Code P0102 MAF/VAF What does it mean?
- Steering Gear Failure
- Olds Intrigue 99 Sunvisors Both Sides
- Bumping under front end of car
- What's going on with my car?
- trans problems
- 2000 intrigue 3.5 not starting after running out of gas.
- 2000 Intrigue - Turn Signal Problem
- 2000 Intrigue rear strut replacement
- Remove sun visor
- starter location 99 intrigue 3.5
- Third Brake Light Flasher
- Air dam
- 3.5 coolant drain
- Anti-Lock Light is On
- About to change Hub Bearing Torque spec?
- Water Noise in Dash
- noise when turning
- Power Sunroof/moonroof mechanism broke
- OBDII DLC connector
- 12 spoke Alumninum Wheels
- rear cam cover gaskets (finally)
- Fuel pressure regulator or electrical?
- Temp gauge
- Car hesitates while driving down the road.
- what is this called
- Clicking before starting
- Did the '98 Intrigue have an air dam under the radiator?
- Turn Signal Indicators
- Won't start - Clicking under dash from
- clunking noise while turning
- Governor on 2001 Olds Intrigue
- Repair Manual?
- 1998 (3.8 liter engine) Oil leak
- Looking for Climate Control Unit
- Guide: Accessing the rear speakers in your Intrigue
- Rear Panel Removal
- ABS/TracOff/Anti-Lock radio going in/out
- Keyless entry problem
- Minor Electrical Issues
- 2000 GLS Hard-starting Resolved!
- cut off - hit curb
- Climate Control Doors
- Stalling and hard to start
- How do I change Crank shaft sensor?
- Windshield Chip question
- Tiger Paw Touring T vs. BF Goodrich Pro Series
- Re: Blend Door (with pictures and the common problem)
- nothing is working
- Engine, airpump, or something else? help!
- Help!!
- flashing ses light
- 2000 Intrigue...starter? ignition switch?? HELP!!
- Another Starting Issue
- Flashing Instrument Cluster
- Loose window control panel
- Amplifier Power Wire
- Horn Not Working
- Drivers window very slow
- 1998 Intrigue Front Speaker Replacement
- Trunk Space
- Check Engine Light
- Auxiliary Audio Source
- Prestone Antifreeze
- Air Dam
- My radiator/coolant light keeps blinking on my 1998 Oldsmobile Intrigue.
- All power went out and won't start!!!!!
- 98 Intrigue cranks slow, but starts
- wont start and no spark but cranks
- Abs Control Module Not Working??
- New spark plugs at 100k miles
- Heater Cores or Heater Fan....HELP
- Is there a brake fluid 'dipstick'?
- '99 Inttrigue 3.8 misfire
- Plug Wires
- Shift Kit Installed
- Wiggle and Rattle in 2000 Intrigue
- 98 3800 won't start
- 02 Intrigue coolant leak questions
- Trunk Lid Support
- A/C Flush-Recharge
- Lights replacement on 99 Intrigue
- Climate control problem (2000 GX)
- Passenger-side Wiper not working
- PO102 code during inspection
- brakes
- Odd noise while stopping
- Starting issue a bit different than the rest...
- Wipers park in middle of windsheild
- HID's
- High Mileage
- Brake fluid resevoir emoval
- tune up
- Parts For Intrique?
- Help Starting Issue. Doesn't want to start sometimes
- Climate Control
- Strange cords found behind radio
- Misfiring and ticking
- Electrical Problems
- Chasis Lube?
- keyless entry and door problem
- remote car starter
- another blower motor/fan prob.
- 2 new CKP and 1 new CPS. 10,000 miles and both bad again!?!
- Transmission
- 2000 intrigue starting madness
- Radiator fan problem
- No traction control
- Long cranking before starting up and Service Vehicle Soon lights up.
- Hard tire spin
- 2000 Intrigue
- Front Valve Cover install pics.
- 2 Problems New Member
