View Full Version : Intrigue
Pages : 1 [2] 3 4 5 6 7 8
  1. 99 Intrigue - 4 struts replaced. Notes from the job
  2. heater not blowing
  3. 2001 Intrigue - Air Pump ?
  4. bad fourth gear
  5. Advice on replacing Rear Struts
  6. trans tune seafoam question
  7. Long term fuel trim is incorrect
  8. 99 Intrige won't start - acting stange
  9. My shifter button broke how do I change it
  10. Help with draining the antifreeze
  11. Window switch
  12. Is my climate control syst working correctly?
  13. sometimes sluggish somtimes not
  14. Pics of my tranny woes... YIKES!
  15. Disabling Passlock?
  16. Didn't see this coming, BLOWER INOP!
  17. 1998 V6 car shakes when shifting to Reverse
  18. New guy with a few questions...
  19. 98 Olds Power Steering Issue
  20. 2000 3.5L Intrigue running cool
  21. Power Steering Fluid needs to be changed
  22. fuse keeps blowing out
  23. AC only comes out of the driver side
  24. Thermostat project update....and then some.
  25. Need advice on a few things with my '98 3.8L
  26. 2002 Intrigue GX -- couple of problems..
  27. Coolant flush?
  28. Tranny Update--metal in pan! 02 49,000 miles
  29. feel my pain
  30. Getting Dealer only parts online in Canada
  31. blower resistor replacement
  32. Serpentine Belt Info Needed
  33. 02 GLS New to me @ 48000 miles-Thoughts.
  34. This is Nuts. I am on my 3rd Heater Core
  35. 2002 intrigue
  36. 3.5L possible major engine failure
  37. Brake Problem
  38. Orfice tube location!!
  39. Buying an Intrigue with issues
  40. A/C blows warm air
  41. Front wheel hubs & trust yr mechanic
  42. Which W-body cars had stiff suspensions?
  43. transmission - how do you know it needs service
  44. Problem with brakes
  45. Whats Limp Mode how's it work
  46. window issues - driver's side is the only control that works
  47. Paint chipping
  48. OIL leak
  49. GMPP trailing arms rattle
  50. Hydraulic Lifter Rattle
  51. whining noise with increased RPM's / Acceleration
  52. blower
  53. Installing fuel pressure regulator 3.5 engine
  54. Remote Trunk Lock Failure
  55. ABS Motor / Power Steering Issue
  56. Low coolant sensor
  57. AC cooling issue.. Cooling fans not coming on
  58. 1998 Intrigue
  59. After Market Stereo Problems - Wiring.
  60. leak when rains
  61. Coolant Leak
  62. Window Switch gone batty
  63. AC drain?
  64. Hot air/Cold air
  65. many problems, probably one source
  66. Polyurethane bushings
  67. No start event/Theft Deterrent Re-Learn procedure
  68. Airbag module
  69. 3.5L K&N Air Filter
  70. Squid treatment for my oil burner motor
  71. Tripod joint question
  72. ABS Sensor issues
  73. Secondary Air Injection Pump Problem
  74. AC Compresor not coming on
  75. Oil smoking When checking oil after running
  76. 1999 OLDSMOBILE 3.5 INTRIGUE Replacing the V-Groove Belt
  77. 98 intrique ac switch ?
  78. 98 intrique w/ rattle in passenger rear
  79. Wipers completely powered down
  80. What all do I need when replacing struts?
  81. 99 Intrigue 3.5L motor mounts?
  82. 99 Intrigue 3.5L. Loud bang noise now car won't start
  83. wipers wont shut off
  84. Just passed emissions 00 gx but have ?'s
  85. Climate Control Reads wrong on Outside Temp
  86. Intrigue Mileage
  87. Service Vehicle Soon and Trac Off lights.
  88. windows problems
  89. 1998 Intrigue Ac Blower
  90. Weird Stuff Happening 2000 Intrigue
  91. quick help needed
  92. In the middle of UIM & LIM gasket replacement, couple Q's
  93. emissions failure/check engine light. please help!
  94. Another starting problem
  95. 3.5L Intake Manifold Gasket? Coolant use, occasional stalling
  96. Doors unlock, but won't lock...
  97. 2000 3.5L sometimes won't start
  98. SES light, O2 Sensor(s)?
  99. Changing Blower Motor Resistor
  100. 3 vehicles with bad PCS!
  101. blinker problem
  102. Strange noise!!
  103. Crankshaft and camshaft sensor failure after replacement?
  104. Cleaning the Ignition Switch: I really screwed it up
  105. Front sway bar broken?
  106. 99-3.8, Engine stumbles at Times
  107. Directional bulb keeps malfunctioning.
  108. obd scanner recommendations
  109. antifreeze loss?
  110. Can anyone explain these codes?
  111. Metal Brake Lines
  112. Replacing the Bose Head Unit
  113. '98 3.8 upper & lower intake manifold gasket & plenum replacement help (kinda windy)
  114. Is the 3.5 Intrigue worth it in the long run?
  115. how to silence noisy brakes
  116. Trouble starting when warm; occasional shut down when driving
  117. 2000 Intrigue No Overdrive
  118. 99 Intrigue - troubling starting when car is warm - begins to idle rough
  119. Iridium IX Plug #TR55IX
  120. 98 Intrigue, burning oil now?
  121. 98 3800 wont start
  122. 2000 GLS 3.5L - recommended power steering fluid
  123. 1998 cluster replacement
  124. new hubs = noise..DAMN
  125. 2001 Intrigue; has power, won't crank or start
  126. factory stereo wire info
  127. 98 Olds Intigue.Code P0102 MAF/VAF What does it mean?
  128. Steering Gear Failure
  129. Olds Intrigue 99 Sunvisors Both Sides
  130. Bumping under front end of car
  131. What's going on with my car?
  132. trans problems
  133. 2000 intrigue 3.5 not starting after running out of gas.
  134. 2000 Intrigue - Turn Signal Problem
  135. 2000 Intrigue rear strut replacement
  136. Remove sun visor
  137. starter location 99 intrigue 3.5
  138. Third Brake Light Flasher
  139. Air dam
  140. 3.5 coolant drain
  141. Anti-Lock Light is On
  142. About to change Hub Bearing Torque spec?
  143. Water Noise in Dash
  144. noise when turning
  145. Power Sunroof/moonroof mechanism broke
  146. OBDII DLC connector
  147. 12 spoke Alumninum Wheels
  148. rear cam cover gaskets (finally)
  149. Fuel pressure regulator or electrical?
  150. Temp gauge
  151. Car hesitates while driving down the road.
  152. what is this called
  153. Clicking before starting
  154. Did the '98 Intrigue have an air dam under the radiator?
  155. Turn Signal Indicators
  156. Won't start - Clicking under dash from
  157. clunking noise while turning
  158. Governor on 2001 Olds Intrigue
  159. Repair Manual?
  160. 1998 (3.8 liter engine) Oil leak
  161. Looking for Climate Control Unit
  162. Guide: Accessing the rear speakers in your Intrigue
  163. Rear Panel Removal
  164. ABS/TracOff/Anti-Lock radio going in/out
  165. Keyless entry problem
  166. Minor Electrical Issues
  167. 2000 GLS Hard-starting Resolved!
  168. cut off - hit curb
  169. Climate Control Doors
  170. Stalling and hard to start
  171. How do I change Crank shaft sensor?
  172. Windshield Chip question
  173. Tiger Paw Touring T vs. BF Goodrich Pro Series
  174. Re: Blend Door (with pictures and the common problem)
  175. nothing is working
  176. Engine, airpump, or something else? help!
  177. Help!!
  178. flashing ses light
  179. 2000 Intrigue...starter? ignition switch?? HELP!!
  180. Another Starting Issue
  181. Flashing Instrument Cluster
  182. Loose window control panel
  183. Amplifier Power Wire
  184. Horn Not Working
  185. Drivers window very slow
  186. 1998 Intrigue Front Speaker Replacement
  187. Trunk Space
  188. Check Engine Light
  189. Auxiliary Audio Source
  190. Prestone Antifreeze
  191. Air Dam
  192. My radiator/coolant light keeps blinking on my 1998 Oldsmobile Intrigue.
  193. All power went out and won't start!!!!!
  194. 98 Intrigue cranks slow, but starts
  195. wont start and no spark but cranks
  196. Abs Control Module Not Working??
  197. New spark plugs at 100k miles
  198. Heater Cores or Heater Fan....HELP
  199. Is there a brake fluid 'dipstick'?
  200. '99 Inttrigue 3.8 misfire
  201. Plug Wires
  202. Shift Kit Installed
  203. Wiggle and Rattle in 2000 Intrigue
  204. 98 3800 won't start
  205. 02 Intrigue coolant leak questions
  206. Trunk Lid Support
  207. A/C Flush-Recharge
  208. Lights replacement on 99 Intrigue
  209. Climate control problem (2000 GX)
  210. Passenger-side Wiper not working
  211. PO102 code during inspection
  212. brakes
  213. Odd noise while stopping
  214. Starting issue a bit different than the rest...
  215. Wipers park in middle of windsheild
  216. HID's
  217. High Mileage
  218. Brake fluid resevoir emoval
  219. tune up
  220. Parts For Intrique?
  221. Help Starting Issue. Doesn't want to start sometimes
  222. Climate Control
  223. Strange cords found behind radio
  224. Misfiring and ticking
  225. Electrical Problems
  226. Chasis Lube?
  227. keyless entry and door problem
  228. remote car starter
  229. another blower motor/fan prob.
  230. 2 new CKP and 1 new CPS. 10,000 miles and both bad again!?!
  231. Transmission
  232. 2000 intrigue starting madness
  233. Radiator fan problem
  234. No traction control
  235. Long cranking before starting up and Service Vehicle Soon lights up.
  236. Hard tire spin
  237. 2000 Intrigue
  238. Front Valve Cover install pics.
  239. 2 Problems New Member
  240. Oil Consumption Questions
  241. Security light
  242. Check Engine Light
  243. LED dash replacement?
  244. Turn signal problem
  245. 2000 Olds with 36,000 miles on it
  246. Maybe, just maybe, I should .....
  247. Drivers side door intrument control panel lights
  248. Wiper Blade Park
  249. Hazard light switch part number
  250. Change Oil Light
