Our Community is 662,000 Strong. Join Us.
View Full Version : Solara
  1. 2003 Solar 4cyl
  2. Changing Display from metric to imperial
  3. clearing P0446
  4. Any collision experts?
  5. 99 solara p0302 code oil leak next to #2 cyl
  6. 99 Solara - one dim doesn't light
  7. Solara Fuel Pump replaced - won't start
  8. Adventures in Doing Your Brakes For The First Time and It Becoming A $%*# Story
  9. Spark Plug Replacement
  10. Someone please help me!! :)
  11. wheel shaking prolem
  12. 2008 Solara question
  13. 02 solara fuel filter
  14. What size axle nut deep socket 4 an 04 solara
  15. I need some advice: Regular or premium gas?
  16. 04 How to do Solara valve seal replacement
  17. '00 solara i4 5sfe - no tension on kickdown cable
  18. Oxygen Sensor Replacement
  19. What is this part found in my door?
  20. Spark Plug Maintenance Intervals
  21. 2005 Solara Battery Replacement Tips...
  22. Missing DVD on my 06 Solara JBL GPS
  23. 99 Solara dipstick length?
  24. 99 v6 solara
  25. 2001 Solara Conv. White Smoke on start up
  26. Programming Remotes 2006 Solara-Works good
  27. 99 Solara V6 Auto Axle Fluid
  28. Good deal?
  29. removing entire wiper not just the blades
  30. Recliner adjuster !
  31. Need Input
  32. 1999 Solara SLE
  33. Clutch Problem
  34. '04 Master Key duplicate programming steps?
  35. 2006 toyota solara keyless entry instructions help
  36. Power from a 4 cylinder???
  37. 99 Solara intermittent starting problems
  38. Idle' problem after installing spark plugs
  39. haveing problem auto up/down on driver side window
  40. 99 Solara oil light on and engine problem
  41. Intermittant smoke from exhaust
  42. 2001 Solora V6 SLE Suspension Rattle
  43. How to service engine and change window motor?
  44. headlight adjustment
  45. Loud Engine noise from my 99 solara
  46. fuel filter 1999 Solara
  47. help smoke from tail pipe?????
  48. How do I change the emblems on the back?
  49. 06 solara: how do i change display frm metric
  50. change to manuel
  51. Engine question
  52. Headlights or fog lights
  53. acetone to increase MPG?
  54. Remote Start on 05 Solara?
  55. check engine light ???
  56. Need Some Help...
  57. 2002 Solara: Check engine & trac light
  58. Toyota Approves Use of 0W-20 and 5W-20 GF-4 Oils
  59. Solara 99 clutch service
  60. 2000 Solara Garage Door Opener
  61. Solara 99 tachometer just quit!
  62. 99 v-6 sludge=
  63. Help With Navigation System
  64. chutch help
  65. air filter question
  66. Hesitation with Passing Gear (downshifting)
  67. 1999 17" Toyota TRD Wheel
  68. Change an 99 solora that is auotmatic to manual how hard is it?
  69. solara garage opener
  70. solara short shifter & keyless question
  71. new solara problems
  72. Manual transmission Solaras
  73. does 05 solara come with stock amplier?
  74. Installation Of Toyota Xm Kit
  75. Clock and mirrors don't work
  76. Winshield Washer Light
  77. Ecu
  78. 01 solara I want to do a AT to 5spd how do I?
  79. '01 Solara with I4 Need some help modding
  80. Tire Warning Light
  81. wat do yall think of this pair of head lights?
  82. Couple questions about 02 Solara
  83. Oil Change Frequency
  84. Navigation System Software Update
  85. Programing remotes?
  86. Eibach Springs for 99-01 Solaras
  87. Solara fitted all season matts
  88. rattling noise problem
  89. Programming remote (FOB) for 2004 Toyota Solara
  90. Trailer Hitch for Bike rack
  91. program grage door opener 05 solra sle?
  92. 2002 idle speed too slow
  93. Tokico Struts For 1st gen solaras
  94. Taking off rear side panels
  95. 2005 Solara Mods
  96. 4 cylinder Solara questions
  97. Supra engine in Solara?
  98. Key is stuck
  99. 2002 solara transponder key program
  100. 2005 Solara SLE and seatbelts
  101. New Toyota Classified Forum
  102. New Toyota Classified Thread
  103. '99 Solara Panel Disassembly for CD player replacement
  104. 2004/5 Solara convertible
  105. Just got 99 Solara SE, need mod advice
  106. 2001 Solara Check engine and trac control light on
  107. solara convertible
  108. 2004 solara performance
  109. timing adjustments?
  110. 2002 Solara - Passenger door speaker problem
  111. 99 Solara remove rear driver side wall panel
  112. Throttle hesitation
  113. 99 Solara Suspension
  114. Help With Stereo
  115. pioneer stereo
  116. brake noise
  117. Solara bumper
  118. Program Remote to 2004 Solara
  119. GAS MILEAGE 2004 Solara 6 Cylinder
  120. Problems starting
  121. audio
  122. Solara Hard Ride
  123. CD Player skips
  124. Debadge
  125. solara DIY
  126. how to tell if my 02 camry has Keyless reciever?
  127. Solara starts and then kills
  128. 99 Solara 'hiccups' at steady speed
  129. What to do with a 99' Solara?
  130. No sound from stereo and convertible not working
  131. 2000 Solara
  132. 2000 Solara Brake noise
  133. Convertible top Water leaks
  134. Cleaner for Convertible top???
  135. Hum in radio after battery change
  136. 2004 Toyota Solara
  137. Brake light on a 99
  138. Solara Rims
  139. newb,.. supercharge?$
  140. Celica, MR2 Will Die After ’05- U killed 'em
  141. white pearl
  142. SOLARA break pads
  143. solara t shirt
  144. white faced gauges
  145. Hard To Find
  146. hard starting my 22re
  147. Fueling problems
  148. vacuum diagrams
  149. 2004 Solara Mods
  150. Turbo for 04?
  151. 2000 Solara question
  152. Newbie here.
  153. CD Changer error/lockups
  154. Engine swap
  155. 2000 solara headlight condensation
  156. Tacoma Engine
  157. My TRD Solara
  158. keysless trunk remote programing
  159. oem wood dash trim
  160. 99 solara rear speakers removal
  161. '00 Solara Keyless Entry Help
  162. Can you put a 17X8 wheel on a Solara?
  163. Bug/Rock Deflector for 2003 Solara
  164. beautiful car thats a lil too expensive
  165. Front grill
  166. Model Cars
  167. FS: BBS/TRD wheels w/tires
  168. FS: 18X7.5 AXIS SE7ENs(Gunmetal)
  169. 2004 Solara
  170. There really isn't much i can ad to my car!
  171. What the?
  172. mods/turbo kit for solara?
  173. no one is posting
  174. Fs: 2000 Trd Toyota Solara Sle V6
  175. TRD Solara
  176. v6 throttle body wanted
  177. door panel
  178. 7lb Pulley
  179. Convertables:
  180. =)
