View Full Version : Tercel
Pages : 1 [2] 3
  1. wont shift back to 2wd
  2. 95 tercel dx hesitation on acceleration
  3. Tercel 94 Starting Problems
  4. power steering and ac belt
  5. Trecel '99 Headlights relay problem
  6. I Have a GT Turbo Starlet in NY
  7. 93 Tercel Head Bolts
  8. '87 has Shaky Steering
  9. Turn the Key, Click....nothing...
  10. 1990 to 1994 3ee engine differances please help!!!
  11. 92' not running right
  12. battery and brake lights on
  13. OUTRAGEOUSLY EXPENSIVE exhaust pipe?
  14. 83 Tercel overheating
  15. Removing interior door trim
  16. Break Light and Battery Light on
  17. Will these rims fit?
  18. Rubbing Grinding Sound, what is it?
  19. Pinking, pinging, timing adjustment
  20. Help. How do I remove the door lock
  21. Air intake and muffler questions
  22. 91 starter problems
  23. big obd problems 94
  24. 93 tercel 17mpg....running awful
  25. tercel 1992 model
  26. Bumping in front end on 85 hatchback
  27. 91Tercel - No Headlights
  28. 1991 Tercel Questions from a clueless owner
  29. Matchbox or Hot Wheels Tercel?
  30. high beam flickers w/left turn signal
  31. 92 vacuum line help please
  32. 87 tercel clutch job
  33. 91-94 Dashboard removal
  34. Struts And Cv Boots
  35. 91 Tercel rear Strut issue
  36. 1991 tercel...where is the fuel pump relay??
  37. Engine swap 1990 to 1991
  38. Engine Swap
  39. Help, '94 Tercel with Starting Issues...
  40. Problems with 88 tercel
  41. 94 Brake Problems need help
  42. I was installing my deck: out went the lights, clock ext.
  43. 93 Tercel headlight changes help!
  44. 40 amp buss fuse "CMH" code
  45. '85 tercel brake problems
  46. f/s custom turbo manifold
  47. getting a 93 or 94 tercel needs head gasket?
  48. Engine light is on
  49. repair manual
  50. rear side window replacement
  51. Master cylinder kit?
  52. 1995 Tercel Timing Belt Change FYI
  53. Celica Engine in Tercel ??
  54. Where to buy aftermarket corner lights?
  55. turbo tercel
  56. Tail lights won't go off....AC blows my fuses
  57. lug pattern ?
  58. Paseo tercel automatic trans interchangeability
  59. 1990 Tercel
  60. turn signals not working
  61. '90 Tercel NO SPARK
  62. First post, 1985 Tercel question
  63. 1996 Toyota Tercel Wiring Harness Diagram
  64. newbie wants help
  65. Strange electrical phantom...HELP!
  66. 92 Tercel rear seat removal
  67. 5efe head-3ee block
  68. Suspension ripoff in progress?
  69. Tercel brakes
  70. Noobie questions
  71. 1994 Toyota Tercel Engine Swap ??
  72. comaptible parts between '85 and '90 tercel?
  73. 93' engine replacement options
  74. Finally had to rebuild
  75. 96 tercel reciever wiring
  76. Strange A/C Problem
  77. Loud noise from motor
  78. 91 Tercel - erratic surging idle
  79. 95 wiring diagram
  80. toyota tercel 1988
  81. 92 Tercel woes
  82. Help, car problems
  83. 4efte
  84. 5E-FE Timing Belt Change
  85. Smoke coming out when starting
  86. 1995 Toyota Trecel
  87. 1983 tercel sr5 4x4 wagon clutch
  88. '91 Tercel - problem(s)
  89. 89 2dr tercel questions
  90. 82 trecel engine upgrade
  91. 1988 TERCEL >TIMING QUESTION??
  92. Kill Switch
  93. cant get the exhaust pipe off the manifold
  94. 94 Toyota Troubles..help!!
  95. 91 tercel wiper motor replacement, Need HELP!
  96. Radio and dome light
  97. Toyota stereo wire harness diagrams
  98. 94 Tercel Electrical Short - No Dash or Tail Lights
  99. 93 tercel wont start
  100. Aftermarket sunroof installation?
  101. '92 no lo-beams
  102. Motor problems with a 91' Tercel.....?
  103. Toyota Classified Thread
  104. 95 Tercel Repair Manual - woohoo!!!
  105. 94 rattling when stopped, started, parked, reverse..??
  106. 1982 Engine Swap?
  107. subwoofer + 4 speakers
  108. Coilovers
  109. Tercel stereo cross-references
  110. 95-99 rear spoiler
  111. Window tinting
  112. '93 tercel headlights won't turn off.
  113. 4wd
  114. 97 Tercel Valve Adjustment
  115. Removing paint from threads
  116. Chirping noise
  117. 1991 engine rebuild
  118. Replace solid rear seat with fold-down seat?
  119. Transmission problems I think
  120. Oil Leak trouble
  121. 95 tercel dx good car????
  122. How to remove headlight
  123. 95 Tercel dashboard clock
  124. 93 Tercel engine Swap
  125. 96 tercel 5efe -low oil pressure warning light ?
  126. 84 toyota tercel 4x4 trans problem help
  127. 1991 Toyota Tercel + Engine Swap
  128. '85 trecel, bad idle, no power, loud banging
  129. What Engine /performance Swaps 91 tercel
  130. Swapping Engines?
  131. 93 tercel oil leak bad
  132. 87 Tercel. Shift Problems
  133. rear suspension on 1985 Tercel sedan
  134. 1987 Tercel dies electrically....
  135. Idling HIGH
  136. 4efte swap
  137. 95 Tercel Fog Problem???
  138. Heat Selector Cable?
  139. '84 Tercel 4WD shifter
  140. 1990 Tercel questions
  141. EGR valve
  142. 1990 tercel kick down cable adjustment?
  143. replacing windsheild washer pump???
  144. 91 tercel died
  145. locked keys.....
  146. 95 Tercel Bucking?
  147. 1982 trans swap
  148. 99 tercel
  149. 93 Transmission Problems
  150. Good auto repair shop in Tucson??
  151. 93 tercel heads
  152. 97 tercel won't start
  153. Dash mounted clock
  154. 86 tercel
  155. 86 Tercel Transmission change?
  156. 90 tercel would not head up??
  157. 91 Tercel
  158. 96 toyota tercel-charging problem
  159. Best motor for price??
  160. 92 tercel 2dr coupe specs
  161. Check Engine Light & Heater Core
  162. 95-98 Swap of 1ZZ-FE or 4A-GE
  163. tercel won't start
  164. emmissions help
  165. stereo installation
  166. Carb Problem??
  167. tercel 5 spd swap help
  168. 94 tercel want help!
  169. Transmission Failure Need Help ASAP
  170. 83 Toyota Tercel Sr5 Wagon
  171. Hesitation and poor acceleration 96 Tercel
  172. Brake / Tail light cover
  173. Fifth Generation Changes
  174. Driver seat broken! (96 Tercel)
  175. how much hp does a 92 tercel have???
  176. how to...???
  177. Replacing starter on Toyota Tercel 93
  178. Tercel4WD Community
  179. Rear seat removal help!
  180. 77 Celica
  181. 83 Tercel Sr5 4wd Wagon-exhaust Manifold
  182. Thought I knew what I was doing
  183. '83 Tercel Engine Dies After Start
  184. Strange Caliper Trouble
  185. missing conector
  186. How To Change My Brakes
  187. Accelration Problems
  188. Power Steering leak
  189. speedo
  190. Couple of questions:)
  191. engine replacement
  192. squeaking noise on startup and bad gas mileage
  193. my 83 TERCEL wont start aT all...HELP!
  194. shuddering Tercel on the highway...
  195. 96 headlight question
  196. Engine Swap a 3a-c with 4a-c 85 wagon 4x4
  197. 1998 Tercel w/ a blown engine
  198. Blue Book Value?
  199. tercel
  200. Runs, but will not move?
  201. Heater no go
  202. SO MANY QUESTIONS Trecel 95
  203. RH Side View Mirror with remote
  204. Does a repair manual for 96 tercel exist?
  205. 1990 tercel troubleshooting tips, my story...
  206. engine needs replacement
  207. Hard Starting
  208. any difference?
  209. key won't turn
  210. check codes 97 Tercel
  211. Brake Question
  212. 1997 tercel od/off
  213. How much hp does a '96 Tercel have?
  214. Engine Swap
  215. 4efte rear wheel drive
  216. is it possable?
  217. EGR system error
  218. Wanted: '82 or older Tercel.
  219. 82 Tercel price?
  220. replacement engine for an 87
  221. help with oil leak and sealents
  222. Starlet Body Parts
  223. Replace Fuel Filter & Main Line - 95 Tercel
  224. torque setting
  225. USDM 95-99 Tercel F5 Series Body Kit
  226. 1990 carb suggestions...???
  227. I swapped door panels
  228. Clattering Sound when accelerate
  229. timing belt
  230. something draining battery
  231. How do I get this damn dash off?!?!
  232. Cost to replace starter?
  233. 5EFE tercel/paseo motor question
  234. Service engine light on...
  235. 99 Tercel - Starter motor came on while driving
  236. front wheel bearings
  237. need perf upgrade info
  238. How do I take the dashboard off of a 93 tercel?
  239. 90' Tercel Parts......F R E E !!!!!!!!!!!!!
  240. 1991 Engine swap for a 1995
  241. tercel and paseo springs
  242. exhaust problem
  243. Need front end body parts 94 Tercel DX
  244. Engine Freeze problem
  245. Car Dead-Need Help
  246. Help Me swap my engine.
  247. corner lamps?
  248. 91 tercel deluxe auto?
  249. Lights become dim
  250. Hesitant start, unknown electrical problem.
