Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Subaru
> Legacy / Liberty / Baja |
View Full Version :
Web
AF
Pages :
1
2
3
05 LGT Clean For Sale
99 Legacy WRX Brake Swap
2005 Legacy GT-What are your favorite tires?
2002 Subaru Legacy L 2.5
overheating--91 legacy--non turbo
1991 Subaru Legacy 16 valve, car dies after startup
94 Legacy DLC/OBD ?
Alternator
Where to buy parts for older Subaru's, 1993 Legacy
Legacy B4 trouble (not really)
How to get A/C compressor to engage.
Considering buying a 91 Legacy LS 4wd wagon
speed sensor 2 97 legacy postal wagon
!995 subaru legacy 2.2 starting
Help Please!!!!!!!!!Overheating
03 Legacy valve tap
92 Legacy runs rough when warmed up.
ABS MANUAL CODES 95 Legacy
Trunk Latch, 93 Legacy
speedo cable
overheating help
snow
CV Boot
98 subaru
98 Legacy GT sending unit question
oilll!!! fire? help!
Once again Single turbo conversion help needed.
Legacy GTB front mount intercooler
1992 Subaru Legacy Wagon
97 legacy - wiring keyless entry expertise needed
Cabin Filter
Subaru Wireing
90 legacy dies while driving
93 Legacy CKS and CMS troubleshooting
2005 Legacy GT Intake and Exhaust
Tuner on a budget
91 Legacy L Fwd - transmission or electrical?
93 Legacy starting issue
brake pedal pressure
1996 Legacy Power Antenna
Problems with my legacy, need help please!
92 legacy wont start after big bump
'91 legacy sluggish
99 Legacy brake issue?
should i replace the rear driveshafts?
96 legacy stalling
What size fuse do I use for FWD slot?
1996 legacy sedan
2000 GT Gas Milage/ Misc ?s
timing belt idlers
Legacy 95 Code P0420
Intermittent Hard Shifting. HELP!!!
Legacy Suspension Trouble shooting
Subaru Legacy 95 Keyless Remote
1990 subaru legacy
P0130 code problem for 1998 Legacy Outback
Legacy GT Mid pipe
Hesitation in to 1st Gear from engine-off stop.
Converting a Twin turbo to Single...
Removing factory stereo
1998 Legacy GT Wagon heater blender linkage
keyless entry problem
FS IL:2005 subaru legacy GT
Help with converters
95 legacy at oil temp light
91 liberty awd wagon air suspension problems
92 Legacy Wagon
Banging in turn ... 2001 Legacy GT
Got a P0420 DTC code right after new Fuel Filter.
Best Suspension components for legacy
ABS light 1990 legacy
Legacy Gt 1990 Problem
Torque Convert Input Shaft retention spring
2006 Subaru Legacy Spec B limited #159/500! For sale
defrost problem 1995 legacy
leaky tranny
leagacy parts interchange.
Legacy 95 (Leaky Water Pump)
p0105 map sensor
96 Legacy Wagon Oil Pump & Sensor ?'s
2006 Legacy odometer error???
starnge sound coming from back of car 91' legacy
91' legacy sun roof opens only when it feels like
rerweel drive legacy ????
B4 RSK Engine conversion
2000 B4 RSK Legacy Help
95 Legacy, Power Steering Pump Leak
1995 Subaru Legacy L 4door 2.2 L Flat 4... Help!!!!!
'92 Legacy spare tire placement
Engine will only idle for 5-8 seconds..Help me!
04 legacy cruise out???
getting a 97 legacy gt sedan
Legacy 95 (Bad CV Joint boot)
91 legacy abs problem 160,000 miles
Scan tools
91 lagacy wagon
91 Liberty powerless?
Knock Sensor
99 Legacy: takes a few seconds to go into Drive
99 Legacy; slight front vibration when braking...
Removing Torque converter from Drive Plate?
Pine Cone in Exhaust :S
93 Legacy issues: Should I buy?
06 Legacy
2004 Subaru Legacy Outback 3.0L VDC...Would you buy?
help! 93 subaru legacy wont start
92 Legacy turbo thumps when driving???
89 Legacy, Know any place to get Body parts
92 legacy ej22t problems
air flow meter problems
Help with codes P0171 and P0130
Help!!! Thermostat install problem.
91 awd turbo sport sedan starting problem
97 passenger wheel vibration
1996 subaru legacy dash lights
GM to Subaru
96 2.5 LSI Legacy wagon shield vibration?
"91 Legacy Electrical Problems...
2003 subaru baja
Legacy Transmission Trouble
Do all 2003 Legacy 2.5 (auto/manual) have a rear LSD?
99 Legacy-vibrating, check engine light blinks, cyln. #4 misfire
98 Subaru Legacy GT - Wagon
98 Subaru Legacy GT
Gas Tank for 1991 Legacy
Can't Downshift to First.
95 Legacy Wagon Trouble code
1990 Legacy Heat Blowers Stopped
97 Legacy Wagon AUTo wagon CEL HELP
96 liberty(legacy) starting + stalling +
91 Legacy Sport Sedan Electrical Questions
98 Legacy L Wagon
Thinking of buying a 2006 Baja. Thoughts?
Subaru Legacy Vibration
moniters not ready
Subaru Transmission Problem
1994 Legacy Wagon Ping noise
95 Legacy Starting Problem
can this legacy be repaired???
1997 Legacy overheating
'93 Subaru Legacy Wagon cold weather starting problem
fan is not stopping after changing radiator
GTB parallel turbo
94 subaru legacy code 51
96 legacy abs problems....
97 Legacy GT Sedan
02 Legacy hesitation - any ideas?
95 Legacy L Wagon ABS Problem
Shift handle position on a 92 legacy
2003 Legacy maintainance
1990 subaru cv joint replacement?
Programming Key FOB on 06 Legacy
2000 Legacy stalls on startup in cold weather
92 Legacy Help
96 Legacy Wagon 138K miles
few probs
91 axles replacement/any special steps?
Brake pad installation problem 96 Legacy wagon
1992 Subaru Legacy engine knock when warm!
1990 Legacy service repair manual section 2?
91 Legacy OIL light
93 Legacy with 05 WRX Parts?
96 Legacy wagon - rear speaker install
92 Subaru, Starter is Good, But Flex Plate Spins freely. ???
knock sensor
dash lights
Fog Light Relay
obd II code #1507 ?? whats it mean?
Legacy tuned by STI
how much play in rear half shafts
96 legacy looses power, why?
A\C and knock sensor
at what milege should timing belt be changed
MPG for 93 legacy
legacy door lock
air compressor 93 legacy
Bought a 90 Leg L, several questions
1990 legacy gauges
95 legacy wagon 2.2 timing belt 92000 mls
1993 legacy parts
Transmission Filter (external)
where can i buy a fuel gauge from?
1998 Legacy outback COLOR
any one help
should I buy it?
timing questions...needs to be set...
Is it possible to keep a responsive acceleration at all time for your 05 Legacy GT?
suspension?
Tires?
clunk in the rear
For Sale 95 Legacy LSi
Trans fluid
Legacy/WRX transmission swap?
91 Legacy, Flashing power light after starting car
Aftermarket Rims
wheel hop?
help! car is ticking when you turn only
92 legacy parts?
lights, lights, lights
91 legacy
Overfilled Trans
92 Idle problems
The old check engine light ?
1990 Legacy LS needs your help PLEASE
1998 legacy changing fron seal ???Please Help
Subaru Advice Please
93 Legacy L Engine wont start in the cold
Quick Question
2 wheel drive
AWD Solenoid problem
Resetting keyless entry
Any info would be great
Brake Free Play Adjustment
93 legacy, suspect fuel system problem
seat hearters in 97 legacy wagon
Anyone know about wiring a CD player to my 1995 legacy?
Cam Position Sensor help
2001 Subaru Legacy alternator replacement
95 legacy wagon help needed!
90 legacy sedan stock looking for upgrades
97' Legacy GT Replaced USDM with JDM EJ25
what to do with Mom's clunker
Swapping STi parts into 92 Legacy
1990 Legacy GT Engine Issues
Lights flashing after new battery installed.
Engine Surges in cold weather
Little Black Button
what parts arecompatable between the EJ22 and the EJ25?
Subaru Legacy Wagon '94
1991 awd legacy turbo kit?
Quality mechanic search?
'96 Outback Shocks
2006 Subaru 2.5 GT spec.B
99 Legacy wagon stereo upgrade
96 wagon noise in rear cargo
NZ Insurance Questions...
1991 Subaru Legacy engine light stays on
Need some parts
The new girl nextdoor w/ a subaru baja
reverse lights
93 legacy water pump question.
Electrical System
95 Legacy stuck in park won't start
Ocassional Starting Problem
Interior Lights
Elctrical problem
Web
AF
