View Full Version : Legacy / Liberty / Baja
Pages : 1 2 [3] 4
  1. 97 Legacy automatic, no 4th shift
  2. gears and shafts, for sport sedan??
  3. 1995 Legacy Wagon Electrical Problems
  4. 01' legacy gt
  5. engine "clicking" noise
  6. 05 Manual tranny tips
  7. Header Wrap
  8. transmission trouble?
  9. 93 automatic transmission trouble
  10. Largest wheel I can run?
  11. Legacy 2000, doesn't start
  12. need 1990 legacy bodykit!!!
  13. 95 legacy key broken off in the ignition
  14. 93 legacy body kits
  15. info on 93 legacy
  16. 91 legacy reliability?
  17. 92 legacy air suspension swap out
  18. abs ring
  19. HELP! Whine/whistling with automatic transmission
  20. Automatic to Manual Transmission?
  21. rea spoiler
  22. Oil Cooler
  23. car won't start
  24. 97 Legacy needs Head Gasket
  25. '94 Legacy Outdoor TI....unusual model? Suspension Problems?
  26. Intake For 93 Legacy
  27. no spark
  28. 92 legacy problems
  29. 2.5 gt
  30. EJ22T motor swap into '92 legacy
  31. Fuseably Link
  32. CD Player removal
  33. 05 Legacy Tranny Problem
  34. 1991 legacy problems
  35. Lowering spring
  36. Tach?
  37. new gt
  38. Projector Headlights
  39. Can Beru Spark Plugs be used with Legacy '00
  40. 2001 Legacy GT Limited Upgrades?
  41. Legacy Wagon CHEEP
  42. Legacy GT retune to 95 RON
  43. 97 legacy misfire
  44. Legacy Fuel Type?
  45. Need Help!
  46. Transmission leak
  47. 96Legacy cylinder misfires
  48. Cold air intake for '93 Legacy???
  49. Power Pulley Kits Question
  50. 2001 Legacy Shop Manuals
  51. Looking for Outback Sway Bar to fit my 99 GT Wagon
  52. Camshaft/Crankshaft sensors
  53. Help Me With My 93 Subaru Legacy
  54. Jammed Shoulder Belt Retractor
  55. Need HELP!! DEAD 99' LEGACY Anniv.
  56. Looking for Exhaust
  57. 1997 Legacy GT keyless help
  58. Compatible?
  59. 4WD is screwed up on Legacy
  60. i need some inupt from everybody
  61. need help picking a new motor
  62. How to modify an '01 Legacy GT Limited?
  63. 2 cylinders out?
  64. 2005 legacy sti !!!!!
  65. clutch change
  66. MY98 Legacy 2.5GT Misfire
  67. Arcing ignition coils normal?
  68. Servicing
  69. Front BEarings
  70. Car choking itself
  71. legacy 2.2gx,1992 only sparking on 2 ht leads
  72. Brembo vs Bendix Rotors ? (Legacy 95)
  73. New guy w/93 legacy AT what can I do with it?
  74. flywheel spins, timing belt dosent (90' legacy)
  75. 2001 Legacy GT Limited Loud Exhaust and Reduced Acceleration
  76. Buying '98 Legacy L Wagon - advice?
  77. legacy down on power
  78. B-Pillar Creak Start/Stop Some Bumbs
  79. 90 legacy intake!!!help!!!!!!!
  80. 90 Legacy L AWD M/T
  81. High Temps
  82. Tail lights converter wiring for trailer??? For older 94-95 Subaru Legacy
  83. Tweeter size?
  84. Tornado Air/Fuel Saver
  85. Legacy 2000 GT Dash Backlight
  86. Air Filter Question
  87. dash light in a 93 rs
  88. subaru legacy wagon engine swap
  89. Wanted! MY99 Legacy GT Wagon aftermarket parts!
  90. Tail lights
  91. Any Legacy Owners in Las Vegas?
  92. 93 legacy engine swap
  93. 17" WRX wheels on 96 legacy?
  94. door mirror wanted (Left side)
  95. Fuel economy 96 gtb
  96. power sunroof disassemble
  97. 1997 Legacy chassis
  98. el glow reverce gaiges
  99. '99 Legacy Outback- Speedometer Intermittent
  100. Looking for intake for 99 Legacy GT
  101. Low Idle
  102. Statistics on 1992 Legacy Wagon, also a couple of questions...
  103. seat replacement 97 Legacy
  104. Problems starting??
  105. HLA O-rings
  106. Legacy (91) Transmission Trouble - help!
  107. brake replacement instruction help needed
  108. Awd
  109. aftermarket
  110. '91 Legacy Speedometer
  111. Legacy OEM Stereo
  112. air/fuel Mixture & ECUs
  113. Legacy Cooling fans staying on
  114. Manual tranny in an LS?
  115. Reverse Glow Gauges 2000 Legacy
  116. intake sensor upgrade
  117. Legacy info?
  118. 96 Legacy Rear Wheel noise while cornering
  119. 1996 Legacy GT / Air flow meter problem
  120. After market seats for Legacy
  121. check engine light
  122. pictures of the baja hood on my 04 legacy...hoodscoop...finally...
  123. Legacy GTB BG5 Japan model,engine code 23?
  124. Turbo kit for my legacy B4 2002
  125. 1998 USDM 4 wheel disc brakes
  126. Legacy Outback Fog Light
  127. Reset check engine light
  128. Subaru Legacy 4WD L Used parts 1991-94
  129. New Shifter Help
  130. starter help
  131. All members please read this
  132. GT ground effects on an 97 L?
  133. Rebuild engine or buy used import?
  134. New legacy, need suggestions
  135. Check Engine Light Problem 99 legacy wgn
  136. Invite to all first generation Legacy owners
  137. EJ20 help needed
  138. Lifter Tick
  139. NEW legacy?
  140. changing 4WD
  141. 96 Legacy Dash Lights
  142. Rear Rotors on a 93 Legacy
  143. Will Baja turbo hood fit on 04 Legacy?
  144. What kind of fluid to use in auto?
  145. '91 Legacy Turbo
  146. front crossmember
  147. Legacy GT Twin Turbo Parts/Help Needed
  148. Strange shake
  149. Shifting an Automatic
  150. Exhaust question (heat / flow)
  151. lowering springs for the 2004 legacy L
  152. Subaru Legacy GT (turbo) 2005 in the US!!
  153. soob noob...any major differences between the L and the GT?
  154. 4WD Operation?
  155. Help!!!! My Moonroof Stuck Open On My 93 Legacy Ej22t
  156. Protection strips Legacy.
  157. Subaru Front Brake Pad Kit (NIB) P/N 2629AC041
  158. FS: CF Dash Kit 96 Legacy!
  159. 1998 Legacy GT Cooling problem
  160. High Octane?
  161. My New Legacy B4 2002 Need Help
  162. Legacy make over
  163. Any Difference between 97 auto, and 98 5-spd
  164. Car audio help, and just sayin hi
  165. legacy dash (fluorescent one )
  166. Legacy gt ej20 tranny convertion
  167. Powerless Subaru
  168. 4 SALE: 97 Legacy GT 5 spd!!!!!
  169. 2000 gt legacy power mods
  170. engine mods
  171. Brake Problems
  172. Forsale: '93 Legacy Turbo 5-speed
  173. GTB vs GTB E-Tune
  174. other forums
  175. Coverted from Auto to 5 speed
  176. bodykits
  177. engine code
  178. Legacy Sport Sedan
  179. 2000 dashboard
  180. 91 Legacy Alternator problems
  181. 2.2 Turbo Kit
  182. turbo
  183. 98 Legacy
  184. bad 99 auto-tranny/replaced w/01 HELP!!!
  185. 91 Legacy Air Struts
  186. Legacy GT-B Twin Turbo Advice needed.
  187. 97 Legacy GT for sale
  188. Un-Childproofing Rear Windows
  189. Front Panel Lights went out after installing new stereo deck
  190. For Sale Stromung Exhaust '00-'04 Legacy Wagon/Outback/Baha
  191. Legacy Purchase
  192. 1998 Legacy GT Limited Body Kits?
  193. Excessive Brake Pad Wear 2002 Wagon L
  194. Legacy GT A/T bad fuel economy
  195. Rims on a 98 Legacy L
  196. Checking Engine Codes
  197. Wannabe WRX? Grandma Car?!?!?!?!
  198. Swap?
  199. What extras does 250TB have over 250T?
  200. Retrofit of Hill Holder in '04 Legacy/Outback???
  201. specs on Legacy EJ206DXBKE engine
  202. twin turbo 94 wagon
  203. tranny bad and acting up. long. help...
  204. 1997 Legacy GT durability
  205. GTB or not GTB
  206. 97 2.5gt
  207. Turbo Power for the Legacy!
  208. I just got a 1990 legacy L sedan power problem????
  209. Legacy 91
  210. Impreza VS Legacy hood???
  211. Recall
  212. Legacy GT (twin turbo) info
  213. I got new tires yaay!
  214. Legacy 03
  215. blood type B4
  216. Need an exhaust, 2000 Legacy GT, HELP
  217. Engine Check Light
  218. Coldair Intake Kit ??????????????
  219. axle problem oin 91 legacy
  220. what to do!!!
  221. what to do!!
  222. New Legacy article
  223. Anti Sway Bar Mount broken
  224. Legacy Boost ?
  225. Keyless entry
  226. 1996 Legacy GT 2.5L Heater Problems
  227. where can I get a JDM hood for a 2000 Legacy GT
  228. Replacing Legacy Seatcovers
  229. Pictures
  230. Performance
  231. rust repair
  232. subaru sti legacy b4
  233. new to this board and got a question?
  234. WTB: 91-93 Legacy Turbo
  235. help .. .1990 leagcy
  236. GT Wagon is AWESOME CAR when weather gets bad!
  237. Hello - Legacy B4 Anyone??!!
  238. B4 Rsk ???
  239. Got An Intake! And Lights!
  240. what what should I get?
  241. Rimmer Supercharger
  242. Legacy - Weird Shudder ??
  243. I'm new and got a lil bit of questions
  244. Differences in Subaru Legacy Wagons (2000+)
  245. new body kit
  246. The saddest sight I have ever seen
  247. Do you know how to solve this Legacy GT Problem?
  248. Link to a cool Legacy Tuner!
  249. Washer Lights
  250. B4 Pictures
