Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Subaru
> Legacy / Liberty / Baja |
View Full Version :
Web
AF
Pages :
1
2
3
Help Me With My 93 Subaru Legacy
Jammed Shoulder Belt Retractor
Need HELP!! DEAD 99' LEGACY Anniv.
Looking for Exhaust
1997 Legacy GT keyless help
Compatible?
4WD is screwed up on Legacy
i need some inupt from everybody
need help picking a new motor
How to modify an '01 Legacy GT Limited?
2 cylinders out?
2005 legacy sti !!!!!
clutch change
MY98 Legacy 2.5GT Misfire
Arcing ignition coils normal?
Servicing
Front BEarings
Car choking itself
legacy 2.2gx,1992 only sparking on 2 ht leads
Brembo vs Bendix Rotors ? (Legacy 95)
New guy w/93 legacy AT what can I do with it?
flywheel spins, timing belt dosent (90' legacy)
2001 Legacy GT Limited Loud Exhaust and Reduced Acceleration
Buying '98 Legacy L Wagon - advice?
legacy down on power
B-Pillar Creak Start/Stop Some Bumbs
90 legacy intake!!!help!!!!!!!
90 Legacy L AWD M/T
High Temps
Tail lights converter wiring for trailer??? For older 94-95 Subaru Legacy
Tweeter size?
Tornado Air/Fuel Saver
Legacy 2000 GT Dash Backlight
Air Filter Question
dash light in a 93 rs
subaru legacy wagon engine swap
Wanted! MY99 Legacy GT Wagon aftermarket parts!
Tail lights
Any Legacy Owners in Las Vegas?
93 legacy engine swap
17" WRX wheels on 96 legacy?
door mirror wanted (Left side)
Fuel economy 96 gtb
power sunroof disassemble
1997 Legacy chassis
el glow reverce gaiges
'99 Legacy Outback- Speedometer Intermittent
Looking for intake for 99 Legacy GT
Low Idle
Statistics on 1992 Legacy Wagon, also a couple of questions...
seat replacement 97 Legacy
Problems starting??
HLA O-rings
Legacy (91) Transmission Trouble - help!
brake replacement instruction help needed
Awd
aftermarket
'91 Legacy Speedometer
Legacy OEM Stereo
air/fuel Mixture & ECUs
Legacy Cooling fans staying on
Manual tranny in an LS?
Reverse Glow Gauges 2000 Legacy
intake sensor upgrade
Legacy info?
96 Legacy Rear Wheel noise while cornering
1996 Legacy GT / Air flow meter problem
After market seats for Legacy
check engine light
pictures of the baja hood on my 04 legacy...hoodscoop...finally...
Legacy GTB BG5 Japan model,engine code 23?
Turbo kit for my legacy B4 2002
1998 USDM 4 wheel disc brakes
Legacy Outback Fog Light
Reset check engine light
Subaru Legacy 4WD L Used parts 1991-94
New Shifter Help
starter help
All members please read this
GT ground effects on an 97 L?
Rebuild engine or buy used import?
New legacy, need suggestions
Check Engine Light Problem 99 legacy wgn
Invite to all first generation Legacy owners
EJ20 help needed
Lifter Tick
NEW legacy?
changing 4WD
96 Legacy Dash Lights
Rear Rotors on a 93 Legacy
Will Baja turbo hood fit on 04 Legacy?
What kind of fluid to use in auto?
'91 Legacy Turbo
front crossmember
Legacy GT Twin Turbo Parts/Help Needed
Strange shake
Shifting an Automatic
Exhaust question (heat / flow)
lowering springs for the 2004 legacy L
Subaru Legacy GT (turbo) 2005 in the US!!
soob noob...any major differences between the L and the GT?
4WD Operation?
Help!!!! My Moonroof Stuck Open On My 93 Legacy Ej22t
Protection strips Legacy.
Subaru Front Brake Pad Kit (NIB) P/N 2629AC041
FS: CF Dash Kit 96 Legacy!
1998 Legacy GT Cooling problem
High Octane?
My New Legacy B4 2002 Need Help
Legacy make over
Any Difference between 97 auto, and 98 5-spd
Car audio help, and just sayin hi
legacy dash (fluorescent one )
Legacy gt ej20 tranny convertion
Powerless Subaru
4 SALE: 97 Legacy GT 5 spd!!!!!
2000 gt legacy power mods
engine mods
Brake Problems
Forsale: '93 Legacy Turbo 5-speed
GTB vs GTB E-Tune
other forums
Coverted from Auto to 5 speed
bodykits
engine code
Legacy Sport Sedan
2000 dashboard
91 Legacy Alternator problems
2.2 Turbo Kit
turbo
98 Legacy
bad 99 auto-tranny/replaced w/01 HELP!!!
91 Legacy Air Struts
Legacy GT-B Twin Turbo Advice needed.
97 Legacy GT for sale
Un-Childproofing Rear Windows
Front Panel Lights went out after installing new stereo deck
For Sale Stromung Exhaust '00-'04 Legacy Wagon/Outback/Baha
Legacy Purchase
1998 Legacy GT Limited Body Kits?
Excessive Brake Pad Wear 2002 Wagon L
Legacy GT A/T bad fuel economy
Rims on a 98 Legacy L
Checking Engine Codes
Wannabe WRX? Grandma Car?!?!?!?!
Swap?
What extras does 250TB have over 250T?
Retrofit of Hill Holder in '04 Legacy/Outback???
specs on Legacy EJ206DXBKE engine
twin turbo 94 wagon
tranny bad and acting up. long. help...
1997 Legacy GT durability
GTB or not GTB
97 2.5gt
Turbo Power for the Legacy!
I just got a 1990 legacy L sedan power problem????
Legacy 91
Impreza VS Legacy hood???
Recall
Legacy GT (twin turbo) info
I got new tires yaay!
Legacy 03
blood type B4
Need an exhaust, 2000 Legacy GT, HELP
Engine Check Light
Coldair Intake Kit ??????????????
axle problem oin 91 legacy
what to do!!!
what to do!!
New Legacy article
Anti Sway Bar Mount broken
Legacy Boost ?
Keyless entry
1996 Legacy GT 2.5L Heater Problems
where can I get a JDM hood for a 2000 Legacy GT
Replacing Legacy Seatcovers
Pictures
Performance
rust repair
subaru sti legacy b4
new to this board and got a question?
WTB: 91-93 Legacy Turbo
help .. .1990 leagcy
GT Wagon is AWESOME CAR when weather gets bad!
Hello - Legacy B4 Anyone??!!
B4 Rsk ???
Got An Intake! And Lights!
what what should I get?
Rimmer Supercharger
Legacy - Weird Shudder ??
I'm new and got a lil bit of questions
Differences in Subaru Legacy Wagons (2000+)
new body kit
The saddest sight I have ever seen
Do you know how to solve this Legacy GT Problem?
Link to a cool Legacy Tuner!
Washer Lights
B4 Pictures
q about ignition
RS Turbo
Looking to buy a legacy turbo
rsr or rs-ra specs and differences
H-6 with manual trans
I've reached the limits of the stock injectors
Loss of idle vacuum...
anybody out there......
glasspak on a turbo....
Toyo Proxes T1-S
Body Mods?
Helloooooooo...
Legacy B4 RSK Website
Legacy Turbo
H6
Web
AF
