View Full Version : Legacy / Liberty / Baja
Pages : 1 [2] 3
  1. '90 Legacy Timing Belt trouble
  2. Help!
  3. during hard acceleration engine light come on
  4. Transmission Not Enagaging - Intermittant
  5. 1991 engine stalling - any ideas?
  6. can ya help a girl out?
  7. mirror replacement
  8. 90-93 legacy auto to 5spd swap ?'s
  9. Oil leak / burning
  10. occasional kiss firing in #4 cylinder
  11. NON-CIRCULATING RADIATOR blowing cold air
  12. High Idle
  13. Need 1997 Legacy Engine
  14. 91 legacy tranny
  15. electrical problem?
  16. Legacy power windows
  17. 92 Legacy wagon (4wd)
  18. ej22 turbo
  19. 2006 Legacy 2.5GT
  20. Great deal on tires for 2001 Legacy or not?
  21. Brake Problem - 96 Subaru Legacy Outback 4-W/D
  22. Overheats after EXACTLY 12 miles every time
  23. ecutek legacy remap resulting in check engine light
  24. Legacy GT Twin Turbo
  25. Not very quick??
  26. 99 Legacy misfire
  27. 2005 Subaru Baja Sport Turbo Five Speed
  28. Accessories for a 2003 Liberty (Legacy)
  29. Dies, hard to start
  30. What is it ?? 1996 GTB
  31. Purchase of a vehicle
  32. 92 Halfshafts
  33. Check Engine light
  34. problems with under 98 octane fuel on jdm legacy
  35. anybody wanna buy b4 sti
  36. i have a gravel like noise after 5500rpm in my b4
  37. 1993 Legacy Tailights
  38. 1996 to 2001 Legacy's, Any Chronic problems ?
  39. Two timing belt engine help - '89 1.8 Soob
  40. Will you treat your new Subaru with Simoniz System 5?
  41. Poll - Do you purchase xtended warranty on your new Subaru?
  42. 2005 2.5i question
  43. HELP!! smoke coming from left hand side of engine bay
  44. 1990 Legacy, Wierd Starting Problem
  45. VSS 1 and 2
  46. Air Flow Meter Compatibility
  47. 92 legacy, won't start
  48. boost?
  49. 2000 Legacy Brakes - service manual needed
  50. 1992 engine in 1990 legacy
  51. Lighted Shifter Knob that Lights up With the beat of the music
  52. Check Engine Light - '97 legacy
  53. FS: '99 Legacy GT in NY...needs work
  54. adding keyless entry to 98 legacy
  55. Does the Baja use the same keyless entry remote as the Legacy?
  56. engine swap
  57. Legacy engine transplant
  58. turbo on 99 impreza?
  59. Replacement tires for '03 GT Sedan?
  60. HELP! Intense "thumping" while accelerating
  61. Race question
  62. 2.2 vs 2.5
  63. Engine Swap
  64. 97 Legacy GT...... Brake issue
  65. i got me a 91 legacy sports turbo sedan with not air con
  66. Can someone help me out?
  67. '92 Legacy Motor Install Help
  68. Legacy Convertible
  69. 97 GTB Airbag Light
  70. Wanted: 1999 Legacy Transmission 5spd Manual
  71. turbo?
  72. 96 legacy head gasket seepage
  73. 1990 Legacy tachometer quits working
  74. Custom Turbo Instructions???
  75. Looking at buying a '93 Legacy LSi Wagon
  76. TD05 on 1990 legacy
  77. car won't start after hot
  78. Battery change, ticking sound...
  79. Impreza bumper kit on a Legacy?
  80. FS: '98 Legacy L Wagon $3,000!!
  81. Air conditioner STINKS
  82. to race or not to race
  83. 95 legacy LS
  84. 92 Legacy Auto Transmission Problem
  85. Starting Problems
  86. 93 subaru legacy
  87. check engine light
  88. Gas float
  89. Traction Control System
  90. Spoiler lights on 95 legacy
  91. cd player legacy 2005 awd
  92. Changing legacy belts
  93. Cold Air System on my 1997 Legacy GT
  94. Help--intermittent stalling problem
  95. "Check Engine" light on-really a problem?
  96. oil in my radiator
  97. Need Head Gasket - What Else Should I do?
  98. '97 2.2 upgrades? MSD/intake/shifter/SS-lines?
  99. new ings+1 Aero Kit
  100. 97 keyless programming
  101. 99 wagon speedometer works when it wants to, HELP
  102. Mysterious Engine Revving on my 97 GT - Help
  103. 98 Motor into 90 Legacy? HELP!
  104. Socal: Looking for a 05-06 Legacy for testing, will pay $200.
  105. 97 Legacy GT - Why is there oil in my water?
  106. wiring for a motor swap
  107. Sheet metal rattling noise
  108. 93 legacy squealing
  109. 05 legacy gt mods
  110. brakes
  111. ABS Problem-ideas?
  112. 2000 Legacy Idle Control System Malfunction
  113. motor swap
  114. A/C cycling 92 legacy
  115. Subaru Legacy NY Meeting
  116. Wheel Offset for my '97 GT
  117. 96 Gt check engine light
  118. 94 Legacy doesnt want to shift
  119. Car audio pro's
  120. legacy gt 0-60 performance
  121. 1996 Legacy-been sitting, will not start now
  122. 2000 wagon cd player
  123. Changing fuel filter
  124. Speedometer not working
  125. 2004 Legacy Air Box
  126. trans problem
  127. 89 Legacy wont start after jump
  128. Boost gauge
  129. Change timing belt
  130. cv axle problem
  131. Interesting story
  132. 2001 Legacy wagon clutch shudder
  133. Aftermarket CD deck for '05 Legacy?
  134. sti parts in '05 Legacy GT?
  135. Malfunction codes
  136. anti lock brakes skid
  137. occasional transmission problem
  138. body swap
  139. Brullen equal length header
  140. lock tight was used on harmonic balancer bolt...
  141. my new car...
  142. EJ 20 Coils
  143. 90 leagacy not starting
  144. transmission rear seal
  145. Dash light change
  146. transmission issue
  147. ForSale: BD Legacy w/ over 5k in upgrades
  148. 97 subaru legacy RS twin turbo
  149. hEATER CORE
  150. '92 Legacy Wagon w/ Air Ride Suspension
  151. turbo help
  152. Do you have to replace all four tires when one blows
  153. wrx engine
  154. Electronic height adjustable suspension
  155. Need 97 Legacy GT Engine
  156. 14 seconds is all?
  157. 1998 Subaru 250T: looking for a model description
  158. Old worn out clutch
  159. how to remove vehicle speed sensor?? 91 L FWD
  160. 1991 Subaru Legacy Problems
  161. Legacy GT to B4/s401 conversion
  162. Buzzing sound from back of 92 wagon
  163. Engine swap and tranny question.
  164. Hard 1-2 shift?
  165. check engine light 97 legacy GT
  166. Difference between Legacy GT/GTB?
  167. 96 Liberty 2.2L GX - putting/low idle (Australia)
  168. Subaru engine vibration / shake
  169. 1994 Legacy cold starting problems
  170. 96 subaru legacy mis fire!!!
  171. 93 Legacy Body kit...
  172. Changing engine fluids Legacy 1996 GTB
  173. Cooling fans
  174. Egg smell + check engine light
  175. JDM lighting for 1990 Legacy Wagon???????
  176. Engine swaps for 97 legacy
  177. Help questions on 97 legacy
  178. 96 Legacy Outback (2.5L) ticking
  179. Problem 93 Legacy Alternator or Battery or?
  180. Legacy wagon electrical problems
  181. 1991 Legacy doesn't move anymore
  182. Engine coolant temperature sensor
  183. Legacy 1995 stuck in park
  184. 1998 engine misfire code
  185. 1998 Legacy startijng problem
  186. help me find inexpensive stock exhaust
  187. 91 Legacy Tranny jerking
  188. MAF Bypass
  189. Diff probs
  190. 95 legacy AWD not working
  191. 93 Legacy will not start
  192. morette headlights
  193. Warning light
  194. 05 legacy gt
  195. 97 impreza alternator problem
  196. Legacy Acceleration Problem
  197. Fuel Mileage
  198. Buy A Legacy!?
  199. 97 Legacy automatic, no 4th shift
  200. gears and shafts, for sport sedan??
  201. 1995 Legacy Wagon Electrical Problems
  202. 01' legacy gt
  203. engine "clicking" noise
  204. 05 Manual tranny tips
  205. Header Wrap
  206. transmission trouble?
  207. 93 automatic transmission trouble
  208. Largest wheel I can run?
  209. Legacy 2000, doesn't start
  210. need 1990 legacy bodykit!!!
  211. 95 legacy key broken off in the ignition
  212. 93 legacy body kits
  213. info on 93 legacy
  214. 91 legacy reliability?
  215. 92 legacy air suspension swap out
  216. abs ring
  217. HELP! Whine/whistling with automatic transmission
  218. Automatic to Manual Transmission?
  219. rea spoiler
  220. Oil Cooler
  221. car won't start
  222. 97 Legacy needs Head Gasket
  223. '94 Legacy Outdoor TI....unusual model? Suspension Problems?
  224. Intake For 93 Legacy
  225. no spark
  226. 92 legacy problems
  227. 2.5 gt
  228. EJ22T motor swap into '92 legacy
  229. Fuseably Link
  230. CD Player removal
  231. 05 Legacy Tranny Problem
  232. 1991 legacy problems
  233. Lowering spring
  234. Tach?
  235. new gt
  236. Projector Headlights
  237. Can Beru Spark Plugs be used with Legacy '00
  238. 2001 Legacy GT Limited Upgrades?
  239. Legacy Wagon CHEEP
  240. Legacy GT retune to 95 RON
  241. 97 legacy misfire
  242. Legacy Fuel Type?
  243. Need Help!
  244. Transmission leak
  245. 96Legacy cylinder misfires
  246. Cold air intake for '93 Legacy???
  247. Power Pulley Kits Question
  248. 2001 Legacy Shop Manuals
  249. Looking for Outback Sway Bar to fit my 99 GT Wagon
  250. Camshaft/Crankshaft sensors
