View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13
  1. overheating?
  2. Removing the idler pulley
  3. Wiper halfway up
  4. 97 sc 2 ring job $$ =
  5. oil consumption,97 sc2 =
  6. Reverse problems
  7. Shifting Problems
  8. Front left wheel noise
  9. Speedometer doen't work when it cold out. 97' SC2
  10. SOHC to DOHC swap???
  11. 94 Saturn SC2 parts car, anyone need parts?
  12. Trouble Code 11
  13. Saturn SL1 running rough
  14. saturn sc2 1992 won't start
  15. running rich, dying, aaargh!!!
  16. aftermarket pcv and oil burning?
  17. 98 Saturn SL1 won't stay running
  18. saturn SL1,1999 fuel filter replacement
  19. Another Car wont start-wierd spark timing...
  20. 94 sc2 intermittent rough or fast idle
  21. WHAT DAMAGE CAN BE CAUSED BY NOT CHANGEING YOUR Oil REGULARY?
  22. Intake 2000 SL1
  23. compression test-loss of power
  24. I need help
  25. Car will not start
  26. coilovers
  27. 95 SL2 Auto Hangs Up In Gear
  28. 96 SOHC into a 95
  29. 98 SL2 oil light
  30. Rear tire problem
  31. 2001 SC1 a/c problem
  32. Absolute electrical failure in '97 SL4
  33. Left brake light not working
  34. motor vibration in drive and thumping in front when slowing down.
  35. saturn sl1 transmission problems
  36. HELP i need to remove door
  37. 93 SC2 Dash Harness Relay
  38. intake question for SL1
  39. is there any thing out there
  40. 96 SL1 Can't get into First Gear
  41. intake module
  42. Saturn SL2
  43. 96 SL2 cranks but won't start
  44. Oil weight, Valve cover change...
  45. 97 saturn sc2 engine cradle or k-frame
  46. which Hologen lights to use (H.I.B)
  47. Locked Ignition Cylinder 94 SL2
  48. Saturn Cooling Fans
  49. Car audio
  50. '95 SL1 Third Brake light works tail brake lights dont'
  51. Aquired a 94 Saturn...3000 rpm idle??
  52. semi-stall?
  53. Pulley
  54. has this been done yet im sure it has
  55. 95 SL2 wont start
  56. Sputtering.
  57. 94 SC2 Bad thumping in right tire
  58. oil pressure gauge
  59. bogging at idle
  60. gauges
  61. 96 SL2 Clutch
  62. hmmm build up or trash heap
  63. When does an engine need rebuilt?
  64. transmission?
  65. have $$ - need a hood from a '92 to '96 SC2 - LA area
  66. Engine cranks, but no fire
  67. Interior Panels for my 99 Saturn SL
  68. My car accelerates on its own....
  69. just a quick question
  70. 95 SL1 oil dripping out tailpipe
  71. headlights and dash lights
  72. loose shifter
  73. SL-1 2000 Automatic Transmission Problems...
  74. transmission removal
  75. 99 Saturn SL1,Radiator Cap location
  76. motor swap
  77. For
  78. SL1 won't start; low fuel pressure
  79. Prospective purchase of '95 SC1
  80. sc2 engine rebuild...just read it
  81. Help won't start
  82. question about 2000 SL1
  83. moisture in headlamps
  84. 1996 si1 how many miles will it go
  85. SL1 Engine Getting Louder
  86. 2 questions. Interior Lights & Sterio.
  87. 2000 sc1 jerks when slowing down
  88. I need a part name
  89. saturn engine swap 1992 sohc-1999 soch
  90. Looking for BodyKit Saturn SC2
  91. parts for 2000 SL1
  92. Sl1
  93. 2000 Sl1
  94. fan not working
  95. sterio in sc2
  96. intermittant instrument cluster
  97. SL2 Alarm problem
  98. 2001 Saturn SL1 throttle position sensor question
  99. Rattling in driver door
  100. Maybe i can help
  101. 94 sl1 stalls
  102. Suggestions for 95 Saturn sc2
  103. auto tranny to manual
  104. Need Some Help 92 SL twin Cam Clutch Problems
  105. FS 93 Saturn SC2 Orlando, FL
  106. High O2 reading, but PCM still sending rich command!
  107. High Coolant Temp and Low Coolant Warning Lights flashing
  108. 1997 Saturn SW1 Keyless Entry Programming?
  109. Saturn SC2 2001 clicking noises / check engine light
  110. spark plug
  111. cylinder head necessities
  112. Cutout switch for fuel pump
  113. sl1 rpm rising
  114. Ecu?
  115. race car
  116. 95 Twin Cam Trans wont shift warm
  117. not a fix
  118. Bought This From Ebay...... Urgent
  119. What is a (transaxle) shaft bearing?
  120. alignment
  121. valve cover repair
  122. Gas milage
  123. Stopping Funny
  124. Car Won't Start...Need Help!!!!
  125. 94 SL2 DOHC Engine interchange ?
  126. '94 SL-1 SOHC ----- Aftermarket Gauges???
  127. Struts with springs mounted?
  128. is it safe to remove?.....
  129. removing the dash cluster
  130. New Catalytic Converter
  131. 2001 Saturn SL-Help!
  132. Some Header Help Pleaseeee! Want some opinions on my car as well!
  133. belt tensioner?
  134. '95 SL2 for sale (engine work or parts car)
  135. what could be running my battery down
  136. what is the diff..?
  137. Oil system cleaners?
  138. WHAT ARE some good ways to get HP
  139. EGR Valve Options ???
  140. 96 Twin misses on start up
  141. 1999 SW1 Wagon opinions
  142. Key Stuck in Ignition
  143. ABS light comes on and off
  144. Vehicle Won't Start!!! Please Help!!!!
  145. Rapid clicking when accelerating/hard clutch release
  146. wheel squeaks after warm up
  147. Custom taillight help
  148. cylinder head and cam
  149. injector fuse blows
  150. 99Sc1
  151. Wierd rattle noise behind idler pulley
  152. Transmission probs?
  153. radiator hose
  154. Should I fix it or get rid of it??????
  155. 2001 SC2, locator/alarm keeps randomly going off
  156. Very rough idle in cold and after exhaust replacement
  157. 1992 motor swap sohc
  158. Non-functioning windshield washer pump...
  159. 99 SC1 check engine light
  160. 2000 SL2 MIL - EVAP system small leak
  161. what do I try now?
  162. No Dash Lights
  163. Installing new speakers, new deck, subs and an amp, would like some help please
  164. Car Stalls When Braking
  165. 150k service recommendations
  166. Rebuilt Tranny
  167. 94 sl2 hard start
  168. head gasket replacement
  169. Auto transmission mystery
  170. Shadetree mechanic without a tree....
  171. Need help, axle/hub
  172. sensor location
  173. 97 SL fuel pump problems -- again
  174. Problem shifting out of park
  175. Saturn SL Problems... :(
  176. Wipers are streaking
  177. Radio problem in 93 SL2
  178. slave cylinder help please
  179. answer and you get a cookie....
  180. One Hard Screw
  181. 02 SL turbo kit
  182. ?
  183. Need some parts bad, Please help
  184. Need Help Bad Please!!!!
  185. Slight Pause During Acceleration
  186. 99 Saturn Homecoming Edition, Tell me more about em..
  187. New Alternator, but....
  188. CV Joint dilemma
  189. SL2 Transmission swap
  190. Intermittent Start
  191. Just got a new ECT and car is still stalling...
  192. 1999 SC1 Type of Coolant?
  193. Horn problem
  194. shifter - maybe clutch?
  195. Need to find this part...
  196. Saturn Sc2 02 Radio Harness.
  197. running rich
  198. 99 SC1 Alternator Question
  199. Finding a vibration in the front
  200. Erratic RPM Indications
  201. replaced ECTS, still having same problem!
  202. Cannot shift my 1995 Saturn SL2...
  203. Those great headers need a great gasket kit
  204. 2001 sl2 down shift problem
  205. 96 SL service light
  206. Odd, Odd Dash/Electrical Problem
  207. Looking to Trade 96 maxima for 95-98 sc1 or sc2
  208. 97 SC1 DRLs
  209. Fuel pump and filter location?
  210. Reverse Problems
  211. 98 Saturn SL Won't Start- New Battery
  212. Upgrading 96 SC1 with SC2 front end
  213. Exhaust Questions
  214. 1998 SL1 Engine Info
  215. 2000 Saturn SL1 Bulldog remote starter
  216. 96 saturn sl2
  217. wheel bearing
  218. plug missing electrode, going thru coolant
  219. custom headlights
  220. 96 SL-remove speakers
  221. Lost a gear
  222. 2000 Saturn Sl1 Remote Programing
  223. About how much for an ECT from dealership?
  224. changed the CTS and cleaning the IAT tomorrow...
  225. I think it may be possessed........
  226. Stuck and dont know what to do......HELP...
  227. security light,car won't start
  228. best place to mount a radar detector
  229. loud squeeling noise - not belt
  230. Wierd Horn Problem
  231. Need a new ECTS? Check this out...
  232. 2001 SL2 idler pulley prob
  233. Please help!! 1995 SW2
  234. automatic trans shifting
  235. 01 SL Cylinder 1 misfire after plug change?
  236. starter on 98 sl2
  237. 1997 sw:.. aif? afi? ifa? help please
  238. '98 SL2 stalls/hesitates @ 4000 rpm
  239. 91 SC running rich
  240. 1992 SC DOHC Cluth Problems
  241. gear configuration.. 97 sohc auto
  242. Ects
  243. Service Warning Light
  244. spoiler removal
  245. brakes drag...
  246. dropping a manual into my car
  247. New to the saturn family!!!!!!!
  248. wanna make my exhaust louder.. please help
  249. blinkers stopped working
  250. 2002 SC2. Car Starts and Stalls...
