View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13
  1. holes
  2. transmission fluid
  3. 1995 SL1 Won't Start - Please Take A Look :)
  4. o2 sensor?
  5. Looking for a parts suplier
  6. S Series paint problem
  7. 93 SL1 Code 26 and 32
  8. sl moter mount question
  9. SL2 Wheel stud replacement
  10. Aftermarket power locks
  11. 1996 Saturn SL Cylinder Miss....
  12. Where is the therman fan switch
  13. HELP! PO706 transmission trouble code
  14. header?/euros?
  15. tick tick
  16. whinning noise
  17. plugs/wires?
  18. dag nabit not this
  19. idling speed
  20. Tune up?
  21. where to find cheapest saturn parts (body)
  22. chick car?
  23. S.e.r.g.
  24. unladen weight..
  25. removing rear speaker grills in 93 saturn SC2
  26. oil on spark plugs
  27. 1996 SC2 Service Light!
  28. my 91 sl2 is dumping fuel into cly. 1 ????
  29. Programing a Keyless Entry for 1999 Saturn
  30. 96 Radiator Leak
  31. Wheel size on 93 SC2
  32. 1992 Saturn RPMs acting weird
  33. sporatic idle, can't start with out murdering accellerator
  34. Speakers
  35. '92 DOHC Engine Swap
  36. A/C Clutch
  37. How do you remove rear door handle 96 SL2?
  38. d.i.y. c.a.i.
  39. 2002 Sc2
  40. gauges
  41. Hard to start when hot!!
  42. fan
  43. 1994 SL1 parts for sale
  44. 94 sl2 wierd shifting HELP!!!
  45. odometer problems
  46. cooling fan
  47. SL2 engine overheat/ AC cuts out/ uses oil
  48. intake ?
  49. turbo
  50. New project
  51. used parts
  52. how much would a manual conversion be?
  53. Powertrain Control Module
  54. Problems shifting into 2nd
  55. Power Lock Problem
  56. 1996 Sc1 Head Gasket Change - Hlp Plz
  57. temperature sending unit won't come off
  58. Antifreeze leaking out of reserve
  59. firestone tires
  60. P0133, P1133, and P0341 in Saturn SC1
  61. '98 Saturn SL-1 doesn't start
  62. where's my horn?
  63. smoking abit
  64. door wires
  65. door panel
  66. Check engine light problem?
  67. what does everyone think?
  68. '96 saturn sc1 wont start. PLZ HELP...
  69. 2001 Saturn sc performance upgrade
  70. fuel tank Sending unit
  71. Drag racing?
  72. pcm
  73. saturn sl1 have radio want to install cd player--power acoustik cd player-- how to do
  74. rebuiler licence
  75. Converting A/C to R-134a?
  76. 1997 sc1 parting out
  77. keeping fluids cool
  78. '95 SL1 Computer code 26
  79. EGR lost it's magic smoke?
  80. Find OE number
  81. 1994 Saturn SC1 Headliner
  82. owners manual
  83. cat back exhaust
  84. Euro tail lights
  85. Question bout engine computers
  86. coolant/antifreeze refill
  87. cold air intake
  88. 95 sl2 transmission to 95 sl1
  89. 2002 Engine in a 95 SC1????
  90. tail light
  91. Rear sway bar mounts
  92. 1995 SL Clutch Pedal
  93. engine swaps
  94. DOHC for SOHC
  95. 1994 SL Failed Emissions - HELP
  96. high rpm at idle
  97. freezing car parts to save gas
  98. '97 Saturn SL1 - smoke in cabin
  99. How to quieten up the cabin?
  100. 96 sl1
  101. Engine Block Drain Plug
  102. 1992 SL2 white guages?
  103. steering column swap
  104. Engine Tends to overheat while idling/stopped
  105. some progress pics of my work
  106. Stop Leak in Auto Trans.?
  107. Fuel Guage
  108. nos purging
  109. Theoretically speaker....
  110. A/c Blower Stopped
  111. 95 Saturn SL1
  112. 92 sc2 high beams
  113. '96 Sc aftermarket Springs
  114. how do you post pics
  115. codes P0117; P0125; P0711 ?
  116. Engine whirring/whining SL-1
  117. Job Offer!!! Sweeeeet!!!
  118. Code trouble SC2 1997
  119. White Face Gauges print out
  120. Radiator Fan Question
  121. how to remove my door assembly?
  122. so, i keep changing my mind about a turbo
  123. 1992 Saturn SL2 - Problems Read
  124. fender wells
  125. 92 sc2 turbo or nitro
  126. 97 SL2 Aftermarket Pistons
  127. '00 SL2 Cooling problem
  128. engine swap
  129. SC2 hide a way headlights
  130. Faster Turn Signals
  131. thinkin about cutting into airbags for mod.. opions please
  132. PSP mod! .. lol
  133. Thats Why I Bought My Saturn...
  134. Location of Air Temp Sensor and IAC?
  135. new clutch, flywheel, halfshafts, and now even bigger problems!
  136. new cam an lifters
  137. wtf does the Intake Resonator do?
  138. Does the PCM control the MPH readout?
  139. Sister's Saturn wont start! Need help!!
  140. 99 SL engine trouble
  141. Car Power Off
  142. 92 calipler problems
  143. 1992 saturn spun bearing ?
  144. Lost Threads
  145. Rebuilding A 1995 Sc2 Motor
  146. '99 SL2 idle speed
  147. clutch replacement 95 sl1
  148. Post Pics Of Your Car!!!
  149. Resetting The Service Engine Soon Light
  150. 1997 Saturn SL Transmission + Options?
  151. valve job
  152. Want to make a real difference??????????
  153. car stalls
  154. Is there no way to pull codes for yourself?
  155. windshield
  156. 1996 saturn sc
  157. Burnt Valve
  158. Air Bag Deployment,
  159. Swapping Parts
  160. 95 sl hard shift and hard start
  161. Saturn Reliability Help
  162. 96 motor swap
  163. any hi po mods
  164. Muffler For 95' SC2
  165. Sunroof
  166. New stereo system installed.
  167. trouble code 51
  168. miss or hesitation during acceleration
  169. 96 SC1 speaker question
  170. Too Many Problems!!!
  171. fan malfunction
  172. new air intake
  173. trunk mod
  174. wanting brights on same time as low beams. please help
  175. 98 questions
  176. women !!!
  177. trunk rattle from bass
  178. 93 5speed Saturn SC with the shakes!!
  179. Need parts for 98 SC2
  180. Coolant Temp Sensor or ECP sensor?
  181. Saturn Mods
  182. Keys open 2 cars...
  183. Power Window problem 97' SC2
  184. Selling My Car
  185. Painted valve cover
  186. 1994 Saturn Homecoming Edition????
  187. service light
  188. Need help getting clutch to engage the starter, within the next 24 hours...
  189. door locks
  190. 1993 Saturn with code 26 & 32
  191. airbags
  192. engine codes
  193. fuel injectors
  194. idle drops consistantly
  195. Specs & Name Of Your Saturn
  196. c02 sensor
  197. e check
  198. crankshaft bolt into a scrapyard (mountain of a molehill)
  199. 94 Sl2 To 95 Sc2 Engine Swap
  200. 1.9L dead cylinder???
  201. taillights
  202. 97 sl2 cant find the problem
  203. vrooommm possible?
  204. Flip-Flop Trunk
  205. 5 Minute Shut Down
  206. I need help identifying....
  207. Ground wire kits
  208. 94 sc2 throttle position sensor switch
  209. Trouble Code 15 -- '95 SC1--Need help with resistance
  210. 97 sl2 questions
  211. window jerk
  212. my saturn was on fire-electrical wiring help
  213. Hub or Strut????
  214. 1998 saturn after-market a/c system
  215. EGR Valve T/S
  216. CPS location
  217. 98 engine swap
  218. Cooling Fan Fuse Blowing Constantly
  219. Coolant Leak
  220. overheats in warm weather only
  221. 94 SL Engine Light Question
  222. 92 Saturn SC2 Stalling.
  223. performance question
  224. Pink Coolant?
  225. Ignition Switch Problem.....Help...
  226. Wouldn't have believed it if I hadn't seen it!
  227. Idle, rpm, gas problems with a 93 SL-1 Automatic
  228. re -build
  229. 98 Saturn SL1
  230. Tire Rubs Brake Line When Turned To Right SC1
  231. 95 SL-1 Engine/Tranny Problem???
  232. body work
  233. Soaping Your Belts?
  234. muffler help
  235. Saturn still running rich and dying
  236. 1994 sl1 tempature light on any help?
  237. low spark condition while cranking
  238. need transmission for 94' sl1
  239. coolant
  240. this is a bs ? but i got to ask
  241. 92 saturn sc2 trouble codes needed
  242. I need a fuel door!
  243. speedometer off
  244. glow gauges problem
  245. High Idle in Neutral
  246. HELP I Broke 3 Transmissions!!!
  247. best way to change the clutch
  248. 96 SL2 oil pump cover
  249. overheating
  250. '02 sl2 any major problems?
