View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13
  1. 1995 SL2 electrical issues.HELP PLEASE!!!
  2. 2002 SL Temperature Sensor
  3. saturn sputtering
  4. oil filters...
  5. SL1 - Brake Lights off went head lamps on
  6. Rough Ride
  7. 1996 sl2 5sp tranny
  8. High idle, engine loses power, bucks sometimes....
  9. Oil Filler Cap
  10. Help my Engine
  11. Saturn SL2 speakers
  12. Automatic shift cable
  13. saturn newbie
  14. window problem, please help!
  15. 1995 sl2 turn key....nothing happens HELP!!
  16. Replacing Seats with Aftermarket seats.
  17. Undercoat or oilspray?
  18. Code P0440 Evap Emission Ctll Malfunction
  19. installed new fuel pump, now runs rough
  20. Trunk latch stuck - HELP PLEASE
  21. bad clutch = high idle???
  22. Funny Noise in the Engine
  23. SC2 Suddenly no electrical
  24. 97 SC2 instrument lights
  25. Rough idle problem When engine light comes on
  26. Need advice on saturns..
  27. new member-93 saturn help please
  28. i love my saturn
  29. What does a "Brakes" light on my dash mean?
  30. When are new brakes needed?
  31. O2 sensors
  32. new to saturns
  33. Service Engine light on
  34. 1999 Saturn SC2
  35. 01 saturn sc1
  36. high idle that will never die!!!!
  37. Duplicolor Fabric & Vinyl
  38. 1998 Saturn SL2
  39. How do you get the rotors off
  40. Oil Additives-carbon cutdown and engine maintenance
  41. 1995 SL2 maintenance
  42. '95 SC2 EGR Valve
  43. proper jacking locations
  44. Need to know the name of the part..
  45. Engine block swap
  46. starting problems
  47. engine codes
  48. Wheels still for sale
  49. anyone looking for sl1 or sl2 parts?
  50. 94 sc1 engine light
  51. clutch rebuild
  52. 2 problems with '95 SL1
  53. 91 Saturn
  54. stock tweaks
  55. 98 SL1 Intermittent No Start/No Fire At Plugs
  56. 97 SC2 keyless entry
  57. car seems to start whenever it wants
  58. Key stuck in ignition?
  59. Computer Problem?
  60. Jumped incorrectly, not it won't start. Please help!
  61. Anyone need a parts car?
  62. 97 Saturn SL2 codes and Running problems
  63. noisy sunroof weatherstrip
  64. constant 4000 RPM after engine install
  65. My radiator..
  66. interior 97 sc2
  67. Wheels for sale
  68. 98 SL1 head? gasket? block? :(
  69. light reset
  70. '96 SL2 Starting Problems
  71. Blower fan turns on when car is off
  72. Want to buy a new engine.
  73. Floorboard leak help?
  74. 2000 SL1 Transaxle
  75. can you match a throttle body to any intake manifold
  76. Trans operation normal?
  77. stripped bolt
  78. Transaxle Seal
  79. '98 Saturn won't start
  80. help 2000 sl
  81. brake change
  82. Hard Starting, stalling & fuel smell
  83. Scan Tools Spec's
  84. 96 sc2 for sale
  85. 97 SL 1 Ignition smoke
  86. brakes pedal goes to floor
  87. battery light
  88. Header?
  89. cleaning IAC???
  90. 97 SL Electrical Problems
  91. wheel lock delima
  92. Is changing a tie rod a "do-it-yourself" job?
  93. My saturn got hit by some punk kids
  94. windshield wipers won't turn off
  95. 95 Sl1 Transmission
  96. exhaust
  97. Head Gasket
  98. 2001 SC2 Service Engine Soon Light / Codes
  99. OBX header
  100. Trunk lock blows fuse
  101. electrical problem
  102. Saturn SL 1995 - Wont Start
  103. is this a good buy
  104. radio changeout 2000 SL2
  105. Aftermarket Parts
  106. Wierd RPMs
  107. 96 SL2 turns over, won't start
  108. ac/heater low air output
  109. Power restriction
  110. swapping engine??
  111. Slamming between gears on an automatic
  112. 2000 SL2 Cruise/Hood release
  113. another way to save gas
  114. looking for knowledge on a 1.9l sc1
  115. Iceman or AEM?
  116. Saturn sl1, 2001, starting/ignition problem
  117. 99 sohc engine swap
  118. crack in the head: defective engine
  119. swapping out a 95 sl1 for newer?
  120. low mileage saturns
  121. The Slamming sound between gear changing
  122. 2001 SC2 Service Engine Light
  123. high idle
  124. slick 50?
  125. 2000 Saturn SL2 rear door handle removal
  126. crankshaft position sensor problem
  127. shifting sounds
  128. 2002 1.9 engine ??
  129. brake change.
  130. Please help!
  131. 97 SC2 will not start ????
  132. tranny fluid?????
  133. 99sc2(manual) wont start
  134. engine rev.
  135. gas mileage survey
  136. oil changes.
  137. Car wont start
  138. car starts but stops immediately; please help
  139. '93 SC2 for sale......
  140. radiator fan operation
  141. Saved $130 with fix for manual shift linkage
  142. 1998 SL1 Speakers
  143. 91 SL2: How to flush & replace Power Steering Fluid
  144. key stuck in ignition 95 saturn dohc
  145. largest sized rims?
  146. 2000 sl2 bodkit
  147. fuel injectors
  148. 1994 SC1 Sunroof
  149. car hesitates while shifting
  150. headlights
  151. Saturn SL2 won't start-not the starter
  152. Changing the fuel filter on a 93 Saturn SC2
  153. Question about oil.
  154. 1997 SC1 fuse diagram? electrical prob :(
  155. O2 sensor
  156. replacing belt
  157. 1995 SC1 wont start or turn over nothing
  158. How to change the oil filter on an SL2?
  159. 94 SL2 Stalls when driving
  160. high idol
  161. 1994 SL2 Wont Start
  162. 99 Saturn SL2 Check Engine Light
  163. O2 sensor and Camshaft Position problems
  164. ticking sound from tranny
  165. WTB saturn ignition coil - read i have questions
  166. My saturn wont start
  167. 91 SL2 Strange Noise Problem
  168. wheel/rims
  169. '94 SL Odometer Gear Tooth Count?
  170. Aftermarket Cruise Control
  171. I have a 99 SC2
  172. push button ignition
  173. Idle speed is 2100 rpm
  174. Cooling Fan
  175. 1998 Saturn Warning Lights
  176. K & N
  177. 98 SL1 Stalls at cruise speed?
  178. door chime
  179. Need help on center console removal on 93 SL
  180. A couple of questions
  181. Idling High/Dieseling at shut off/accelerates on it's own/too much fuel
  182. dash brake light
  183. shudder
  184. weight
  185. 95 SL2 stalls at stop after 3,000rpm rev
  186. trouble code
  187. Front end body parts
  188. Oil in Cylinder no. 1
  189. dual exhaust
  190. SC II Front Brakelines
  191. 95 Saturn SC2 Floods
  192. 1996 Saturn SL1 1.9L oil in overflow tank
  193. Flip Up Headlights
  194. pcm testing
  195. How do i change clutch in 1991 sc without pulling the motor ? Can it be done?
  196. Dexron III synthetic or Blend atf fluik
  197. horse power?
  198. Newbie Advice Needed - Rattling Noise in Car
  199. c.a.i.
  200. this is weird wonder if it really works
  201. 97 SL2 keyless entry system
  202. My Tranny is acting up , HELP ME!!!
  203. 1996 SC Low coolant light
  204. PLEASE HELP!!! radio locked
  205. speed o meter stopped working
  206. Fs: Injen Short Ram $100 (brand New)
  207. 95 sl2 only fires on starter fluid please help!!!
  208. 98 SC2 Starter
  209. Engine Compression
  210. Service Engine Soon light on 99 SL2
  211. 97 sc2 manual shift linkage
  212. 95 sl transmission problems...need help ASAP!!
  213. speedometer
  214. speaker screws
  215. Pops out of 2nd gear
  216. Seatbelt doesn't work!
  217. 92 sc ignition problems (coil goes in and out)
  218. Headliner and Modifications...?
  219. Left front wheel
  220. Scratch Remover
  221. How much oil for a 94 SC2?
  222. SL2 Head Gasket
  223. Electrical WIERD Starting/Running/AC Shuts my car off Problem
  224. Can I replace my own muffler? ('94 SL1)
  225. car hesitates
  226. 94 SL2 many small problems.
  227. 92 saturn shuts off after 20 seconds
  228. Anti-Lock Brake Issue
  229. Coolant temp sensor
  230. trouble code 26
  231. I need some help here...
  232. Phsyco cooling fan from hell.
  233. Wheels
  234. I found headers!!
  235. Reliable engine for 91 SC2
  236. Left wheel ticking, service engine soon?
  237. Color Change
  238. High Idle, then 30mins b4 u can start up the car
  239. ignition system...
  240. i am looking for some specs
  241. cooling system problem
  242. Popping the hood without a hood cable?
  243. Plugs
  244. Cold Air Intake
  245. swapping sl2 parts
  246. service engine light mystery
  247. Service light = lose power
  248. '98 SL Clutch or Transmission problem
  249. gas tank
  250. odometer.
