View Full Version : SC/SL/SW
Pages :
1 2 3 4 [ 5]
6 7 8 9 10 11 12 13
- shifter problems... maybe worse?
- 99 sl2 lifter noise
- DRL's won't go off...
- Replacing Fuel filter
- FS: 94' SC2, cheap, needs work
- Cruise Control - 1995
- engine swap for 96 SL2
- Mystery light
- signal/hazard lights
- blown fuse?
- how do the engine come out of sl2
- fuel filter
- sierrap615
- 94 SL1 seatbelt light.
- '95 Saturn SL 4 Door
- 95 SC2 getting hot on gauge
- Loud Brakes
- 91 sl2 automatic trans
- 2001 Saturn SL Idle problems
- I have 2 questions
- Saturn----Low Oil Light
- Transmission Part Help
- '95 Saturn SL Repairs
- aftermarket steering wheel hub???help!!
- Fuel Filter
- 96 SL SES and Flashing Lights
- 1997 SC2 Vibration
- front brakes lock up
- Possible trans probs? (not related to the below post :) )
- 01 Sc2?
- new radio problem
- 2002 SL1 won't stay running computer problems
- more engine swap questions
- Dead Shifter in a 97 SL
- transmission problems... gulp, expert diagnosis needed
- error code
- What's 6 inches long, with 2 ball joints?
- RPM's surging
- AHHH!!! too many parts so little money...
- Revenge in a stock Saturn....
- 99 SL1 Rear Brake Diagram
- radio harness
- gas pedal
- 2000 SL1 Noise and Rough Idle
- do it yourselfers?
- how to remove alternator??
- Electrical Problems 1998 SC1 single cam
- body damage on front underside of '97 SL: to fix or not to fix
- what the %^&* please help me
- coolant temperature
- 94 Saturn SL2 wont start
- 99 SL1 Install Cruise Control??
- 92 SL Manual Transmission Problems
- 2000 sc2 DOHC intake crack??
- what repairs have you done
- ATF change
- how strong is the rear deck.
- Black oil
- Replacement of Starter on 99 SL2
- new engine
- sl2 engines
- Ac output temperature
- mass air flow senser
- starter bad or bad battery?
- spark plug wires
- 96 SL1 tranny?
- idiots lights?
- When at speed, changing lanes or quickly moving side to side is very sloppy, why
- EGR valve
- Emissions "not Ready"
- rotors
- '99 SL2 will not start
- Airbags Warning Light Stays On
- ignition tumbler????
- Cai
- can't see!!
- code 32
- electrical diagram for the tranny
- scam or will it actully work.
- Long Overdue A/T Maintenance
- Clear Corners
- obd connector
- Slipping Automatic Transmission??
- Adding a battery vs buying a new alternator...
- service book
- 92 Saturn SC Headlight Flicker
- interior trim
- serpertain belt
- Help!!!!
- is this normal?
- doping
- tire pressure
- AC probs
- aftermarket tail lights.
- outside mirror glass replacement
- I NEED A WINDSHEILD--Which will fit??
- k&n 57-3012
- 96 SL fuel relay
- 2002 sc2 problems
- Radiator rant....
- MAP sensor prob. . . still
- dome light
- turning brakes
- 99 Saturn SL1 Engine oil consumption
- Engine swap?
- Need help with car problem! Noisy metal noise...NOT BRAKES!
- Any suggestions would be much appreciated
- timing chain
- 93 SC2 Loosing Power
- Pics of my new amp...
- '98 sc2 in bad shape
- Tranny Question
- 96 SL2 Oil in the Spark Plugs
- problem with s.e.s!
- Emissions
- oh my god
- Oh boy, a new problem! 92 SL2 Clutch System
- Stalling in gear
- Blown Alternator/ problem with Amp
- about mods
- coolant gaugeis weird
- some ?s
- about traction control
- hey just brought a 1997 saturn sl2 w/manual trans
- Engine Swap
- servive engine soon!
- This is a post on Saturnfans.com that I made and thought.
- Saturn Sunroof
- Tranny swap question..
- Deal Breaker?
- fuse blowing problem
- Head Swap
- crapy resale value.
- energy suspension
- Electric problem
- Milage increase?
- HELP! 94 SC2 with SERIOUS problems
- 97 SC2 Shifting problem
- 2000 saturn ignition questions
- overheating car
- third brake light question
- automatic shifter
- Power Window Motor/Door skin
- Possible parts off a 95 SL2
- 96 sc1
- Just bought an 2002 SL2
- Nos
- 97 SC2 purchase
- idle speeds
- 97 SC2 Bad transmission
- random thought.
- hard time starting
- '01 SL2 won't start
- to change or not to change
- sensor replacement.
- How many gears does a 98 sc1 coupe auto have?
- 94 SL1 SOHC manual transmission bad!
- SL2: Rebuilt from Salvage
- Very Old Saturn Paint Job I Designed
- Another 98 SL2 with odd problems
- 1995 SL A/C Problem
- gas mileage going bad????
- Sl3?
- 98 SL2 weird Electrical....wont start HELP?!!
- power seat?
- service light on?
- cooling fan always on.
- oil burn or leak?
- 1994 Saturn SL2: Odometer failure?
- engine light
- rumbling or rubbing noises
- how much is it worth?
- '99 SL2 squeal after start
- Stupid question about the EGR System
- I lost my keys....
- starting up
- directed to saturn speed_ 12
- Location of Fuel Filter in 02 SL2
- another saturn gone
- 8 mph in 1st gear
- Quill Bearing
- SOHC-DOHC more info...
- Sohc-dohc...
- '93 SL1, engine sounds like it has a woodpecker in it. Thanks Meineke!
- mixing oil.
- Wiper Delay Problem
- a few issues (speedometer, door panel)
- 94 sl1 motor mount
- Tranny still messed up.... '98 SL2 Auto
- whats the diff?
- 2000 Sl2 Ignition Woes
- uhh.....i'm stumped
- sounds like a beetle
- 2000 sl2 o2 sensor
- 95 SC2 Slight Knock
- Saturn 99 SL1 ECT check and replacement
- cd player
- Oil in Spark Plug Well
- rear quarter panel replacement question
- Anyone know the stock power to weight ratio numbers?
- Trunk Problem
- Where is the knock sensor?
- gas milage
- 95 Sc2 Uses Oil
- Loose Side Mirror(Glass)
- It's that time...
- new trunk lid
- Tranny Or Fuel?!?!?!?
- rear license plate light
- 2001 sc1 W/ auto to 96 sl2 W/ manual
- Buy Me! 94 Sc2 $1800
- 2nd time transmission broke
- 99 SL1 RPM and coolant needles
- 97 saturn wierd problem, please help!!
- r34 bodykit
- Any good ideas?
- Le5,lsj,lnf,l61,l66
- parking brake chime won't stop
- jump start smoke
- sl2 oil plug
- Fuel leak from canister in '98 SL1
- Gone in 60 Seconds!!
- brake caliper mounting bolts
- 94 Sl1 Sohc
- speed sensor
- map sensor
- 99 SL1 drivebelt replacement
- custom work worth it?
- 96 SL2 Oil in Cylinders
- Average Costs?
- alternater plug
- bad milage
- 95 sl sohc with oil problem
- Free 1992 SC2. No Engine. Good for Parts.
- check engine light on but no codes
- my Poor Staurn
- Starting Issues!!!
- window tinting
- squealing
- trouble codes, 0341, 0507
- 1995 Sl Sohc
- Security System Issue
- Body Kit For A 91-95 SL1/ SL2 For sale
- Another 99 SL2 OBD II code
- po741
- 97 sc2 not starting
- Engine Codes...
- 95 SL2 Leaking Oil
