View Full Version : SC/SL/SW
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12 13
- 98 Sl2 Trany slip
- 2001 sc2 door appliques
- 2001 sc2 instrument cluster lens
- Manual Trany SWAP... questions..
- New Condensor in order but a question.
- obd2 torque converter code
- 96 Saturn SL1 sucks in all anti freeze and battery light comes on
- 98 SC1 leaking oil - what should I do?
- 95 SL1 check engine light only when hot
- interested in saturn
- 1999 SW vibration from headlight
- Oil light
- 96 sc2 dies when braking
- 95 Saturn SW2 ac compressor
- 1999 Saturn SL1 - power locks rattling, windows not working
- manual transmission slips when hot
- 97 headliner replacement?
- High Idle
- Radiator Replacement inquiry... urgent!
- crank but no start
- Manual Passenger side mirror replacement
- wipers???
- drive axle
- odometer light out
- Newbie with questions - 1994 SC1
- Clutch/Transmission Problem?
- Deal or No Deal
- Radiator Fan
- 1996 Saturn SL 1.9 SOHC high idle
- '98 Computer
- Timing chain replacement interval
- no juice! car sits dead!
- Transmission: Reverse dosn't work.
- help car wont start
- How do I install my new timing chain?
- motor swap
- how to relieve fuel system pressure in 96 SL1
- 96 Saturn SL1 diagram of engine
- 99 SC2 A/C Recharge
- Deal or No Deal on a 2000 SL1
- Leak?
- Crank but won't start
- 2002 SL1 Rear knocking noise
- starting problems
- spring or ping noise when stopping and turning right
- 98 sl2 rpm vs speed
- Mods for 96 Saturn SW1 5-speed
- 96 Saturn SL1 Cracked Head
- weak brakes
- Speaking of dash lights...
- no dash lights?
- 93 saturn sl2 stock car-- Wont rev over 4 grand
- Idol keeps fluctuating
- help on changing transmission.
- Suspension Advice - lots of vibration- help
- 1997 sl2 - a few questions
- 96 SL1 making noise when stopped?
- 2001 SL2 wont start and fuel gauge reads empty
- 2001 SC1 Instrument Panel
- 1999 SL Oil Burner- please help
- saturn sl2 clank sound?
- Starting problems
- 97 SL2 Air Conditioner (eletrical problems)
- 2002 sc1 gas guage reads empty
- What seats will fit a 97 SL1
- 92 Sc2
- !look at this post!
- weird noise
- Hard Shift from 1st to 2nd
- 94 SL1 Questions
- SL1 OBX header
- 1994 Saturn sc2
- 95 saturn with 96 engine. runs fine but doesnt shift right..
- stressed out
- possibilities
- Squeaking serpentine belt at idle
- Car won't start, MAF???
- temp gauge help ---95SL1 engine swapped with 97SL1
- Replacing Wheel Bearings
- 96 SL1 noise from wheels all the time
- Engine diagram needed
- obd11 codes
- 95 SL1 Oil Burning
- troble code po300 repair
- 2002 saturn sl
- 93 Saturn SL2 Vibrates sputters
- How can i rig a temp horn switch up
- Tranny Problem
- No accerleration and hissing noise.
- Engine transmission swap questions.
- 95 Saturn LS Low Idle
- Saturn 1/4 times
- engine clicking
- Occasional Jerk while accelerating
- Engine Gaskets
- Idle is High
- Stalling while slowing down
- Hesitating on Acceleration
- hey fellas
- 97 saturn overheating
- Swap
- fog lamps
- 96 SL1 Cracked head
- my 96 saturn wont start
- temp gauge
- pros and cons
- Engine & Transaxle swap
- misfire when hot
- motor swap question
- 3 Cylinders
- My Car is Possessed!
- Auto Trany problem
- 2002 saturn
- Noise when turning. HELP!
- Radiator Question
- Air Intake
- Vehicle died and will not turn over
- wont run
- '92 Saturn SC auto shoulder strap dead
- engine accerlerates 3 diff times when slowing down
- Slammin into Reverse with foot on brake!!!
- 99 SL2 stalling at high speed
- 2002 transmission
- 95 sohc locked up
- 94 sc2 missing when it warms up
- Won't start after engine swap
- I'm stumped!! (ignition/oil issues?)
- 97 Won't Start Sometimes! PLZ HELP!!
- 02 sl1 misfires 58k miles
- 2002 SL2 Stall followed by no start/power
- 94 SL1 power loss, pep boys says bad comp
- poss blower motor or fuse?
- Help!
- '95 SL1 steering wheel
- Idle problem
- wont crank
- 1995 Saturn SL2 Cold Start Problem HELP!
- Engine Idols high 2-2.5 RPM
- Engine Swap
- Another cooling problem
- 96 Saturn sc1..hood will not open
- Valve Cover
- Front Wheel Rattling Problem...
- 1996 Saturn SL1 heat guage problem
- Saturn Known For Starter Issues?
- 93 SC2 won't idle
- msd ignition coil question
- floor jack
- SL1 Transmission Issue
- Son wrecked 94 sl1..have some repair questions
- 2001 saturn sl1
- anyone have problems with washer fluid not squirting?
- 26 QDM fault
- line out convertor
- headers and cold air intake
- Transmission Problem Maybe?
- A few questions... cleaning and rattling
- fuse marked "body"
- PCMb fuse
- how to change a head unit
- seatbelt problems
- 95 SL Horrible sound when turning!
- 95 SE hydraulic clutch
- complaint: noisy lifter / correction:________
- ignition cylinder
- '97 SL2 seems to drift
- vibrating alot when cold
- '97 SW1 Manual Trans. Troubles
- 98 Sl1
- 91- present saturns w/ bad transaxles
- 97 Saturn SC2 Remote Start
- 95 SL2 sometimes wont start
- Leaking
- anyone convert a 93 sc2 to a different fuel?
- Radiator Fan
- High RPM, Low Coolant Temp
- Over heating
- My Saturn SL2 is making an awful noise when I start it...
- replaced EGR valve
- 99 Saturn SL1, OBD code : P401
- spark plugs
- Driving me crazy!
- 99 saturn sl2 mods
- Trouble Starting Car
- 92 SL2 ABS light
- Stabilizer Bar Installation
- Front Wheel/possibly rotter problems...
- Check Engine light
- Coolant reservoir cap leak
- 96 Saturn SC2 - SES Light Help Please
- Smoke on deceleration
- Shifter connecting to cable problem
- 93 Saturn Won't Start Dealer claim its a Bad Fuse Box
- 97 saturn helllppp!!!
- 97 Dohc starting trouble
- A/C not blowing air like it used to.
- Lost 1st,2nd,5th and rev. :(
- 96 SL1 Clicking Noise
- 97 sl2 won't crank
- 1998 SL High RPM’s When Changing Gears!
- no heat
- 95 SL2 stalled...
- 99 saturn "Service Engine Soon" light
- aftermarket radio issue on 95 sc2
- is grinding related to motor mount?
- 1992 SL1 144K Acceleration Problem
- Idle to fast after highway driving
- 95 SL2 with occasional drivability trouble
- 92 SL2 Automatic - Multiple Problems
- sc clunks and growls upon in first upon rapid acceleration
- Where is mass flow sensor 98 sl saturn?
- '94 SC2 used, contains after-market alarm
- Door is stuck shut!!!!HELP!!!!!!!!!
- Clutch Pressure plate
- Rough shifting
- 95Saturn SL2, Won't start unless gas pedal is to the Floor
- idle due to bad o2?
- SL 2001 not starting while engine is still warm
- 1999 SL2 Automatic, Which engines will fit?
- Hide away headlight noise on SC2
- Headlight moisture 2002 sc1?
- 99 Starting mystery
- 1.9l boost question
- electrical issues
- Sl1 electronics problem
- from a dead stop at a light my car is a pain to get in gear
- shake when in gear at a light
- Manual Transmission Woes
- Where Should Jack Stands Be Placed
- Light.. Won't.. Stop.. Blinking..
- 94 SL2 Odometer failure
- 99 SL is hard to steer
- remote door locks
- 95 SL cat converter trouble
- 2001 SC-2 please help
- change in idle speed
- Smoke from under SW and no start
- '95 Saturn Cruise Control
- fuel comsumption
- when to use a hotter plug
- 1999 Saturn SC2 hood
- front license plate on '01 SL1
- 98 sl rebuild
- sl-2 question
- 92 an 96 engine differences?
- shifter problems... maybe worse?
- 99 sl2 lifter noise
- DRL's won't go off...
- Replacing Fuel filter
