View Full Version : SC/SL/SW
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13
  1. 99 sl2 w/ slow tranny leak
  2. how much is too much?
  3. 2000 sl engine codes 0507(hi idle) and 0301(cyl 1 misfire)
  4. turn signal not working. help please!
  5. Wont start
  6. my 1995 saturn sc2 needs help!!
  7. 1994 saturn front passenger side axles po out of place
  8. 1997 SC2 moves in neutral - automatic transmission
  9. engine codes
  10. 1993 SC2 Speedometer
  11. 1995 SL2 having problems
  12. Strut Mount or Strut Assembly?
  13. Wobbly tire.........causing front brake problem
  14. brakes giving out.......lound squeeie/rubbing.....pedal all the way 2 the floor
  15. 98 SL2 idle/ stall problem???
  16. 1996 Saturn Won't turn over!! Help!!
  17. 99 SL1 automatic trans removal
  18. Brakes rubbing on rotor...WHY?
  19. 98sl2
  20. PPPPPPPPLLLLLLZZZZZZ help
  21. removing a head from a 99 sl2
  22. My 98 SL1 just won't go
  23. 1997 Saturn SL2 Tranny Issue!!
  24. 1994 saturn has starting problem only in cold?
  25. brakes rubbing on rotor is this common with saturn
  26. Can't get any heat????
  27. 96 sc2 wont start
  28. 1995 SL2 wheel choices???
  29. need tranny or car
  30. 1999 saturn sl1
  31. 95 SL1 Instrument Lights!! HELP!!
  32. Radiator
  33. Please helllllp 95 saturn
  34. in need of parts for 1994 saturn ls1
  35. 97 SC1 Repair???
  36. 1993 SL transmission fluid leaking problem
  37. Missing Sl2
  38. 1999 SL Code P 1623
  39. Where is fuel filter located on 1998 SL2?
  40. 99 Saturn SL1 washer fluid behaviour
  41. Just bought a 1998 Saturn SL2/Automatic
  42. Short? Coolant issues
  43. 99 Saturn SL1 washer
  44. 1997 SL2 - Won't Start Sometimes, Security Lock Out?
  45. 1998 saturn SL2 won't start unless the gas pedal is held in
  46. don't wanna do it
  47. 1993 SL2 5 speed manual trans-it pops out of 3rd gear often
  48. 97 sl2 wont start!!!
  49. fuel gauge problem
  50. 1994 Saturn Sedan jerk/punch when ever shifting
  51. 1999 Saturn SL2 Crankshaft Position Sensor Location
  52. There's gotta be a way
  53. car cigarette lighter socket
  54. Cant Remove Negative Battery Terminal Nut
  55. 2001 sl2
  56. Saturn SL code question
  57. 91-92 sc2/sl2 header on 99 sl2
  58. 96 SL1 Alarm Problem
  59. 92 Saturn - Inaccurate O2 Sensor Code
  60. 1998 saturn sl1 seat belt ????
  61. one dead cylinder
  62. new saturns
  63. Gas Mileage Decreasing
  64. hesitation in acceleration
  65. '97 SL2 won't crank, weird...
  66. cylinder 3 misfire
  67. misfiriing SL1
  68. ABS light and Brake light both on
  69. wierd idle problem after ECTS change
  70. 1998 saturn SL2 won't start
  71. 2001 SC2 Help!
  72. 1998 SL2 coolant problem
  73. Re: I am new and I love cars...
  74. Linkage / Transmission??? 94 SL
  75. Losing speed and power
  76. 1996 Saturn SL1 high temp low coolant light
  77. 2002 SL2 won't start
  78. 92 SL power issues
  79. Intake Question
  80. Spark Plugs Choices
  81. 2001 sc1 - would you buy it?
  82. 96 sl2 coolant light
  83. 1997 SL2 Manual transmission leak
  84. misfiring and can't hold an idle
  85. no reverse
  86. replace dohc with sohc
  87. 2001 SC2 Engine :(
  88. What would cause this type of vibration?
  89. 1999 sl saturn transimission leaking w/ high whinning sound
  90. 1999 Saturn SL2 Cranks but Won't Start
  91. gettin' rid of her
  92. 99 SL1 Base Pan
  93. Saturn 2002 SL2 No Start - No Electrical
  94. Lots of oil on 1 spark plug
  95. very high Fuel Consumption
  96. '99 SC2 Brakes
  97. replacing the head gasket tips
  98. Motor Swap (will it work?)
  99. 97 Saturn SC2/Ignition Problem.
  100. side mirrors
  101. 2001 saturn sl1 will not start when hot
  102. 94 SL Growling noise
  103. body panel repair/replace
  104. Ratteling when accelerating?
  105. 94 Saturn SL Idle probs
  106. 97 SC1 over heating
  107. Wipers don't work after new ignition install
  108. 95 SL2 Trans problem!
  109. Power Window problem
  110. weird noise when turning in reverse
  111. 1996 sl1 stalling
  112. Engine Interchange... hmm...
  113. Delayed Speedo Needle
  114. Alternator is fine battery isn’t charging.
  115. '98 SL1 starting problems
  116. 1998 saturn
  117. starting problem...????
  118. 94 SL2 Radio error 01
  119. 97 SL2 Front Door Speaker Grill
  120. Sounds like spark knock then stops!
  121. How do the headlight assem come apart?
  122. Air through vents after A/C is turned off
  123. 99 Saturn SL-parkiing brake
  124. Saturn will stall when gas is released at high speeds.
  125. intermittent start 98 SL2
  126. Shifts slow
  127. 98 SL2 misfire - ignition module?
  128. exhaust flex section needs replacing\ 93 sl 1
  129. 1998 Saturn SL2 P0706 P0731 codes
  130. goofy shifting
  131. 2002 Saturn SL Reverse Lights not working
  132. burning oil
  133. 1992 SL2 intermittent running funny.
  134. help:new tranny in 1995 saturn sc2.
  135. mini me swap
  136. auto tranny issues(long bt detailed post)
  137. 95 Saturn SC2
  138. Worn coil packs, running rich.
  139. fumes!!!
  140. axles
  141. 97 saturn misfire in #1
  142. Smoking
  143. 97 SC2 hesitation shifting/accelerating
  144. 2000 SL tail light/back up light problem
  145. vibration at speed
  146. Possibly gettin rid of the ol' wagon....
  147. Possibly gettin rid of the ol' wagon....
  148. door panel removal
  149. Question about replacing O2 sensor.
  150. Help!!! the car shakes in idle and going up hills
  151. engine oil capacity
  152. No Interior Lights
  153. Interference engines?
  154. Strange auto shift pattern?
  155. High RPMs, clutch problem?
  156. Cold Air Intake System
  157. Weird Problem at Startup...must rev engine '01 SC2
  158. SL1 Ignition Switch
  159. 1997 Saturn SC2 Speed Issues
  160. Question for Saturn Master Tech!!!!
  161. n00b's door won't open
  162. 93 Sohc Sl1 Idle Problems
  163. needs a 74 inch serpentine belt
  164. water pump
  165. Saturn sl2 automatic transmission first gear only
  166. Starter for 99 Saturn SW1 wagon
  167. No Back Up Lights
  168. Question about rebuilding an engine...
  169. Do Eibach Springs give you better handling?
  170. shift knob removal
  171. Major Starting Problems, Please Help!!
  172. '94 Saturn SL2-Lost Keys
  173. Considering buying a used (cheap) S-series Saturn
  174. SL2 Tranny Problem PLEASE HELP
  175. engine missing when hot?
  176. swap problems been down for over a month now!!!!!
  177. Advance Auto Parts OBDII Codes
  178. Dash Break Light coming on
  179. 2001 SL1 Security Light Problems
  180. Wont Start
  181. HELP!Crazy stuff happening with 1997 SL2
  182. Cooling fan won't turn on - even with AC engaged
  183. need 94 sc2 interior parts
  184. 94 sl2 wont start
  185. Alternator help
  186. pcm
  187. sunroof frame rust
  188. 02 sl1 starts, then stalls
  189. *instrument Panel*
  190. Radiator and condenser
  191. SL1 radiator replacement
  192. SES light still
  193. modding a 94 sc 2
  194. 2001 Saturn SL1 Fan Motor
  195. AC repair advice
  196. 95 SC2 power loss with steering wheel rattle
  197. Keyless remote not working
  198. radio doesnt work
  199. 2002 SL2 Exhaust Hangers ?
  200. engine and trans swap
  201. Serious wiring problems [1992 SL2]
  202. PLEASE HELP 94 sc1 wont go into 1st gear
  203. 92 SOHC heads into 95 SOHC
  204. 95 SC2 Anti-Lock brakes Help
  205. 92 Sohc A/t Into 94 Dohc A/t
  206. 92 SL2 DOHC Lots of problems
  207. loud squeaking?
  208. Possible ways to change radio
  209. What causes tire pressure loss?
  210. Exhaust?$?$?
  211. saturn sc1 2001 intake question
  212. Starter question
  213. Help Antitheft
  214. Speedometer needle osillates at zero when turning on or off ignition
  215. fluid info
  216. 92 LS1 running rich
  217. Front bumper repair
  218. Coolant refilling problem!
  219. struts
  220. 97 window motor
  221. Oil sending unit making check engine light come on?
  222. Its doing wierd things
  223. Unknown code
  224. Valve cover paint peeling - Overheated?
  225. 97 sc2 Saturn Security System
  226. 134 or 12
  227. Fuel Injectors?
  228. 96 SC1 fuel pump troubles..
  229. **HELP** 93 SC2 Idling at 3,000 rpms
  230. vibrating noise from pulley
  231. obd2 code 0794
  232. 93 saturn sl-2 low idle and intermidiate starting after running awhile
  233. Low Idling 2002 SL2
  234. Harmonic Balancer/Crankshaft Pulley
  235. 1994 driver door chime won't stop while door is open...
  236. Hideous Squeak from my '94 SL2
  237. 99 SC1 slow and hesitant to accelerate
  238. manual-shifter cable
  239. Exhaust mods
  240. '96 SC1 coolant overflowing
  241. drivers seat adjustment
  242. 97 Saturn sc2 will not start
  243. '97 SL manual shifter loose and floppy but still got home
  244. 95 DOHC SC2 engine swap.... will newer engines fit?
  245. radiatior issues
  246. hollow noise
  247. Serious Car issues (98 SC1). Im clueless
  248. I have a question
  249. exhaust flex pipe needs replacing\ 93 sl 1
  250. using for racing
