View Full Version : SC/SL/SW
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. 99 sl2 wiper problems
  2. 1991 saturn wont start when hot
  3. 95 SC1 Mosquito Spayer
  4. O2 Sensor or motor mounts?
  5. 2001 Saturn SC1 Quarter Panel
  6. 95 SL1 starter spins don't engage
  7. transmision swop for a 99 saturn sl1
  8. My waterflow tank is always empty, help
  9. 92' saturn starts runs...then stalls untill it gets warm
  10. Wolfman's Reverse Slam Remedy
  11. 2001 Saturn SC1 Reverse Slam
  12. gas pedal question?
  13. Drive Axle Seal installation
  14. 99 SL1 key problems
  15. 93 SC2 stalls service Cant get a code
  16. timing cover gasket
  17. 99 sl2
  18. Murder Mystery Oil Soak How-to
  19. 1998 sl1
  20. Revving when clutch in
  21. '01 SL2 Front end vibration/shimmy shake......HELP!!
  22. 96 motor and tranny swap
  23. SL Spring Special
  24. How Good Are SL1's and 2's?
  25. 01 sl2 Timing Chain Replacement
  26. 1999 s/w
  27. Flex pipe size?
  28. radio time adjustment
  29. radio locked
  30. 01 SC1 scraping & grinding when brake low spds
  31. ok, probly last thread i make in the SL section...
  32. 93 SL2 O2 Sensor
  33. Automatice saturn wont shift right
  34. 94 sl2 auto trans prob when cold
  35. car shuts off
  36. high mileage-extremely poor fuel efficiency
  37. rough idling/rpm fluctuating
  38. 95 SL2 manual will not start
  39. had a little misshap..
  40. 93 SL2 idle problems
  41. 94 Saturn SC2 Engine Locked Up
  42. 2000 Sl2
  43. What are the rpm's at 60 mph
  44. '96 SL2 running rough
  45. Theft-Deterrent Radio
  46. "Service Engine Soon" Light Problems
  47. 99 saturn sc,
  48. Glove compartment won't open, any ideas?
  49. bad viberations-96 sc2
  50. idle is ruff
  51. 94 Saturn SL1 Smokes Bad.....
  52. 1998 SC1 gas mileage
  53. O2 sensor locations......?
  54. P0341---'01 SC1 1.9L SOHC Manual
  55. Funny noise
  56. Radiator extraction for 97' SL 1.9L SOHC(Procedures)
  57. 94 SC2 Problems
  58. 97' SOHC manual tranny fluid change.
  59. 99 Saturn SC2-horn
  60. 97 saturn sc-how to change a fuel pump?
  61. just got a new header..
  62. 2000 SL2 turns over will not fire
  63. fuse
  64. 99 saturn SL1, Coolant temp.
  65. coolant change/flush
  66. 93 SC2 Starting issues
  67. 1994 Saturn Fuel System Problems
  68. Need help of certified saturn mechanic
  69. 98 saturn manual trans hard to shift
  70. Goopy coolant
  71. Driving lights not working
  72. Oil Pressure and Suction seals
  73. sc2 gas mileage
  74. 93 saturn serious fuel system problem
  75. 93 SL2 automatic
  76. vibration when im braking
  77. 1996 saturn sl1 coolant drainage? help
  78. low coolant/high temp light intermittent flashing
  79. difference between a 2001 sl2 motor and a 99 sl2 motor
  80. 98 sw1 em. brake light stays on
  81. 98 sw1 em. brake light stays on
  82. My SC2 keeps blowing fan relays
  83. 2002 SL2 - Engine Pings...
  84. 96 saturn sl1 air dam
  85. Im looking for a website about engines
  86. 97 SL manual trans won't start
  87. 1998 Saturn SL2 flickering dash panal lights
  88. 99 saturn sl2 keyfob programming
  89. 1995 Saturn SL2 Gas Pedal Problem
  90. Loud Engine
  91. won't stay running
  92. 99 sl2 headlight dim
  93. Few problems with my Saturn.
  94. 95 sl2 cuts out on hard take off
  95. 1995 Saturn SC2 smoking at idle and missing
  96. 92 saturn sl1 wont start
  97. Type of Coolant
  98. traction control switch
  99. 92 saturn sl
  100. 1998 Saturn SL2 has high idle?
  101. 01 SC1 Morning Sickness
  102. Transmission clunks/stuck in third
  103. service engine soon and ignition takes 2nd attempt to start
  104. Keyless won't work and Passlock is disabling engine.
  105. HELP!!! 98 Saturn SL2
  106. Help! Parking Pin broken or what?
  107. I have 2 problems, (1) horn doesn't work (2) airbag light stays on
  108. questions re 1998 SC1
  109. Silly Harmonic Balancer, Crankshaft Pulley quesion
  110. 92 starts then dies
  111. 98 saturn sl2 Flashing coolant light
  112. 94 saturn SL1 Front bearing Hub - transaxle noise
  113. 92 saturn
  114. won't shift into 1st or 2nd
  115. Saturn Engine Swap Dohc to Sohc Please help!
  116. 93 sl1
  117. Ill Saturn
  118. Twin Loop
  119. Specs
  120. 2001 sl2 whine noise over 40 mph
  121. 01 SL2 Cant Get Ignition to work with new key
  122. Rattling during acceleration
  123. 1998 Saturn SL A/C Not Working
  124. 92 saturn sc hesitating and running rich
  125. 97 saturn sc2 wont turn over
  126. 1.9 DOHC High mileage ??
  127. Engine and Transmission Swap
  128. 92 Wil Not Start!
  129. 92 Saturn SL2 sometimes stalls when I do a quick reverse
  130. 93 tranny leak
  131. I need Help!!
  132. Please help: Key won't release from ignition
  133. Strut assembly or strut mounts?
  134. Car wont start. Cranks Fine.
  135. 02 Saturn Transmission
  136. Strange "vibration"
  137. 97 SL2 Manual Tranny Fluid
  138. 1992 SL 1.9L SOHC No Fuel
  139. 1997 SL2 Cruise Control Problem
  140. Need rear brake help FAST
  141. K&N intake results??
  142. model explanations SL1,SC1 ect.
  143. Have to change waterpump on 97 SL1
  144. wont start but starter spins
  145. 1997 Saturn SL2 Auto Transmission
  146. 1998 saturn
  147. 95 SL2 down shift issue
  148. 98 SL A/C not cold anymore
  149. 1999 sc2 motor
  150. 99 Saturn SC1 Hood interchange
  151. 96 sc2 noises
  152. 97 SL2 Engine Removal Conficting Information
  153. How to check rear wheel hub bearings?
  154. 93 SC2 Oil Pressure Release Valve
  155. saturn high idle and vibration
  156. Saturn Oil Pressure Issue
  157. Realistic SL mpg and K/N air filter
  158. 93 coolant sensor
  159. not sure
  160. 1998 SL-II Reverse not working - HELP!!!
  161. wire diagram
  162. 94 Saturn sedan A/C not working
  163. Transmission Heat Noise
  164. 1997 SC2 Spark Knock?
  165. 99 SC1 Turn signal fuse blows PLEASE HELP
  166. 1995 Saturn SC2 Overheating Issue
  167. Weird noise
  168. se code p1336
  169. Help, car jerks/rocks when accelerating
  170. S Series Oil Consumption
  171. 96 SC1 Dash lights do not work
  172. 94 SL No Compression
  173. SL1 Blowby?
  174. 98 sl1 inspection problems
  175. Mileage Expectations '98 SLI AT
  176. 98 SL motor/transaxle mounts?
  177. 2002 SL2 - Engine Pings...
  178. 98 SL with 99 TPS?
  179. 96 belt prob
  180. Coolant problem.
  181. Starter Relay Location on Saturn SL2 2001.
  182. Saturn SL 2001 Starting Problems.
  183. 1999 saturn sc2
  184. SC2 Hard To Shift Into Gear.....
  185. fuel filter
  186. 1997 SL coolant refill procedure
  187. 97 SL2 Intermittent Engine cut off problems
  188. 01 SC1 wiper motor
  189. throttle positon sensor promblem in saturn sl2
  190. 2002 SC2 with a problem I can't seem to identify...
  191. SC2 CD player...
  192. 1998 saturn sc2
  193. radio/CD Player goes off when car come to a stop
  194. 01 sc1 gas mileage
  195. HELP!! Saturn SL2
  196. 95 SL2 Transmission Issue
  197. overheating problem
  198. 2002 SC1 3dr coupe....Audio System
  199. 2000 SL2 A/C Diode
  200. Temperature/transmission issue
  201. 97 SL1 Exhaust
  202. CLutch Problem
  203. Heater Hose Replacement Question
  204. door panel removal
  205. hey there i need an exhaust manifold for my turbo system
  206. 93 SL2 slight miss
  207. 2002 SC2 - Tensioner pulley - bolt size?
  208. 94 SL1 rear lights and dash lights issuse
  209. O2 Sensor Problem???
  210. 1994 SL1 transmission fluid leak
  211. i need an exhuast manifold
  212. 95 SL2 Brake problem
  213. 1999 Sc2 Saturn
  214. trying to turbo charge my 92 saturn sc
  215. Stalling!
  216. Transmission Issue/ Coincidence???
  217. Brakes on rear driver side making funny sounds
  218. 2000 SW2 alternator
  219. Thinking about buying a '97 SC2
  220. Engine Mechanical problem
  221. is a 1992 sl1 engine interchangable with a 1992 sl2 engine
  222. 2001 SL2 1.9 liter Fuel filter location
  223. 02 - SL-2 Automatic Dies in reverse down hills...
  224. 2002 SL2 No Power
  225. '00-'02 SOHC Intake Manifold Gasket Replacement How-to
  226. CEL on
  227. brake pads and rotors
  228. 98 sl2
  229. ABS light on
  230. NO Reverse!...94sc1 1.9l
  231. 1995 Saturn Sc....In dire need of help
  232. Windsheild Wiper problem
  233. 2001 SC1, how did i do?
  234. High Rev on idle
  235. engine knock/low compression
  236. No Spark out of Coil
  237. 1994 saturn front passenger side axles replace
  238. 2000 sl2 still having problem Please Help!
  239. need a little help
  240. 1995 saturn 5speed 1.9l
  241. 92 sl1 radiator change
  242. 1997 SW1 Fuel Pump Problem
  243. new starter. igniton wont crank .lights but no chime when key in ignition
  244. Timing Belt
  245. Transaxles on the passender side dissconnected
  246. 99 sl2 w/ slow tranny leak
  247. how much is too much?
  248. 2000 sl engine codes 0507(hi idle) and 0301(cyl 1 misfire)
  249. turn signal not working. help please!
  250. Wont start
