View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14
  1. cooling fan and ac compressor inop
  2. Headlight problem '99 SL2
  3. Oil splatter from exhaust
  4. Passenger side mirror
  5. 93 Saturn SL2 DOHC Wheel Nut size
  6. HELP! diagnose dead alt?
  7. Used Saturn
  8. 1994 SL-2 Cold Rattle/Warm no rattle slight hesitation
  9. Power windows not going down...
  10. C-Clip Hell....
  11. hissing-like sound when brake/clutch pedal is pressed...???
  12. driver fender
  13. How long will a saturn last?
  14. Low Idle
  15. engine problem
  16. problem
  17. hi guys! How long the Saturn's warranty has? my car...
  18. afterblow feature
  19. 94 SL2 Transmission
  20. 94 SL2 Alternator Replacement
  21. Is my 96 SL-2 really near death?
  22. Sound coming from around serp belt
  23. 2001 sc1 idles high
  24. Transmission - 1995 SL1
  25. 1997 Satrun remote programing
  26. Transmission - 1995 SL1
  27. Saturn or Caprice?
  28. Installing factory sunroof on non-factory saturn
  29. Average Miles
  30. Acceleration cuts out when engine warms up
  31. problem with keyless locking and alarm
  32. 93 SL2 engine swap, now no injector signal. HELP!!!HUH?
  33. Reverse Swith Connector
  34. 96 Saturn SL1 wont start because of anti theft device
  35. SL2 - Oil on spark plugs
  36. Serpantine Belt
  37. 2001 bizz natch es
  38. 1997 SL2 Keyless Entry Question???
  39. troubling noise
  40. 2000 LW1 brake light prob
  41. Short Throw
  42. unstable idle, tach bounces around!
  43. All sorts of 2002 SL1 Problems
  44. high idle for 92 saturn
  45. What do you guys think?
  46. cost on repair of rod knock 2000 saturn 240Kmiles
  47. Short Ram Intake
  48. Replacing lifters...
  49. Battery light on and just put in a new battery. Help!
  50. 1.9 DOHC zero clearance?
  51. problem of cylinder compression
  52. 1.9L dohc head 4 sale
  53. window regulator and door skirt removal
  54. i changed my engine
  55. SL/ION swap
  56. Head Swap
  57. High idle
  58. pull cant come off?
  59. Air compressor going out..
  60. Engine Swap Saturn SL1 1995 into a Saturn SL 94
  61. New alternator on SC1
  62. Wipers not working
  63. Question for SL owners...
  64. PCV Valve
  65. engine swap
  66. Saturn SC2
  67. How many miles
  68. ignition switch problem-Saturn
  69. 1995 SW2 Auto Tranny Reverse Problem
  70. DOHC burner blues. Need advice.
  71. SL1 Service Engine Light
  72. Would not go into gear.
  73. wow saturn prolly one of the worst cars out there
  74. Suspension Noise
  75. Loud Popping when engine off!
  76. Outer Door Skin Removal
  77. Squeaky Clutch
  78. 99 SL2 - Dent Resist Panel Query
  79. 99 Saturn SL2 - Trim Paint Peel Issue
  80. Power Steering belt defect?
  81. Help with changing to Indiglo gauges on 2000 SL
  82. 1998 SC2 exhaust resonator
  83. problems with new motor
  84. What else fits?
  85. Dead Gas Gauge????
  86. 99 SC2 Brake Light Fuse
  87. dimmer lights?
  88. 99 Saturn SL2 - Struts
  89. Oil pan gasket replacement?
  90. IAT sensor
  91. Oil Disapears!!!!!
  92. two problems, possibly related?
  93. my sl is now on three cyclenders
  94. Reasonably priced Clutches
  95. 98 SL2 hard to start and runs like CRAP
  96. SOHC to DOHC?
  97. saturn sc2 targa top? Lambo Conversion? need input
  98. New here, with a bit of a problem...
  99. Every Saturn I have had burns oil. Fix?
  100. can u clean egr valve?
  101. 99 SC2 how do I replace my fan motor?
  102. 1996 SC2 Hesitates, Stalls w/ braking
  103. Store bought oil filters don't fit!
  104. 2001 SC1 misfiring
  105. 98 Saturn SL for sale!
  106. 94 Saturn SC2 DOHC Alternator mount or bracket?
  107. Trunk Release
  108. crankshaft bolt
  109. 94 sc4: check engine soon...a saga in the making
  110. does the Cold air intake actually do anything?
  111. cd player removal
  112. engine removal
  113. Looking for modified Front grill for 99 SL1
  114. Serpentine Belt
  115. Recharging 1993 Saturn AC
  116. 1996 SL2 Starting Problems
  117. Muffler band
  118. Where did my clutch go!?
  119. stalling in reverse
  120. Easy modifications to increase SL power?
  121. problems under low rpm
  122. Where's the evaporator on an SL-2?
  123. How do I clear check engine codes for a 2000 SC1??
  124. cracked resonater pipe
  125. 02 SOHC Turbokit???
  126. help wit 96 sc2
  127. 2001 sc2 ignition lock cylinder
  128. 1993 Sc
  129. Removal of drivers side door panel
  130. hesitation and stalling
  131. Rear Spoiler Removal
  132. 92 SC Cooling Fan
  133. 97 Saturn hard to start
  134. Headlights wont go down
  135. Re: Rings stuck to block???
  136. AC Recharge on '96 SC1
  137. '96 SC1 Door Handles stay up!
  138. parts interchangability
  139. need help to program 2001 sl2 remote please
  140. Troubles with interlock transaxle...?
  141. '95 SC1 getting too hot
  142. 1996 sl2
  143. Misfire
  144. speedometer/odometer not working
  145. 93 sc2 tranny
  146. installing cruise control on 01
  147. How do I reset "Change Oil Soon" light
  148. 93 Saturn Power Locks
  149. How long before transmission die? 95 Saturn SL1 Auto
  150. 97 Sl2 Dohc
  151. Mechanic Recommendation
  152. a/c problem
  153. Retrieveing ECM Codes
  154. sticking throttle cable
  155. Anyone looking for a '98 Saturn SL?
  156. silver lining
  157. oil light and coolant light stays on after engine swap.
  158. Whats Up
  159. plastic body panels go bye-bye?
  160. New to board...92 Saturn SC2
  161. Keyless Entry
  162. New Guy
  163. '95 SC1 for Sale
  164. 95 Dakote Leaks When It Rains
  165. Key stuck in ignition.
  166. how 2 pull up codes on dodge pickup
  167. 95 SL1 Wipers won't shut off
  168. SL-1 Remote control
  169. A/C stoped blowing cold air
  170. Blower and Power Windows Not Working!!!
  171. 97 SL2 Serpentine Accessory Belt
  172. power drain and not the alternator
  173. My Saturn Experience
  174. 94 SL! hesitation
  175. 92 DOHC Fan problem
  176. clutch master cylinder
  177. 2001 Saturn SC2 Amplifier Installation - Need Help
  178. fenders and doors
  179. 94 sohc swap for a 99 dohc? is it possible
  180. Location Of Egr Valve
  181. Clutch Adjustment?
  182. Window motor removal
  183. whirring sound in engine
  184. Fuel Injection Cleaners
  185. Need Advice On The Next Step
  186. Oil shooting out of exhaust of 99sc2
  187. HELP Passing Emissions 95 SL1
  188. 1992 Saturn SC problems
  189. Lose Of Compression
  190. Service Engine Light Flashes
  191. door locks
  192. Temperature Going Hot then Cold
  193. check engine light blinks
  194. oil
  195. cherry bomb turbo II muffler
  196. Problem with battery draining
  197. voltage
  198. 2001 SC1--Poor Handling in Windy Conditions
  199. Tint Removal
  200. dohc engine in SOHC SL?
  201. Burning Oil
  202. 99 SC1 Engine swap sohc to twin cam. QUESTIONS?
  203. gauge panal lights ( 99 SL1 )
  204. OEM Saturn parts
  205. 4 lug hubcaps on a 5 lug wheels
  206. Driver power window problems
  207. QUESTION about do-it-yourself A/C refrigerant recharging
  208. Trannie problem, please help!
  209. 97 SL2 Won't Start When Hot
  210. 95 SC 1 - Door Panel Help
  211. Car Sterio help please
  212. Engine Revs on it's own when in idle
  213. '99 sc2 needs a timing chain
  214. Air Temperature Sensor
  215. SL1 Stalled
  216. Cooling Temp Sensor?
  217. sl opinions
  218. how do you to deativate the daytime running lamps?
  219. 98 SL2 resonator pipe
  220. 92 cooling fan and code 45
  221. Wanted: Factory set of wiper blades
  222. Oil Pressure Light
  223. fast idle when car is rolling
  224. these sl2's are quick :)
  225. '02 SL2 front seat bolts
  226. Headlights
  227. steering
  228. Another Manifold Question and Search
  229. Short Ram Intake
  230. 2000 SL1 power windows
  231. saturn insurance
  232. Cold Air Intake Install
  233. 2000 SL1. How do I set the radio clock?
  234. Front End Vibration
  235. '94 SL2 Parting out, make an offer...
  236. Suspension
  237. Tranny... Clutch? --> Problem
  238. ajusting window alignment
  239. 94 sl2 wont start, brakes cause lights to go off
  240. Dash Lights not working
  241. 1.9L SOHC engines in the 96-99 S-series?
  242. 97 SC2 sputtering after rain.
  243. SL1 Rear Tires Wearing Out Quick
  244. Steel Wheels
  245. Question for all Saturn drivers!!
  246. 94 sl2 body kit
  247. Leaking door in 95 SL2
  248. question about gauges
  249. Oil in spark plug socket
  250. clutch always engaged?
