Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Saturn
> SC/SL/SW |
View Full Version :
SC/SL/SW
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
z1 performance module
Locked Ignition
Looking for a header
95 SC2 body kits?
Engine trouble with daughter's 97 SC2
V8 RWD Conversion
97 SC2 Problems
Coolant leak?
Name that part!
knocking in engine of 97 sl1
Motor and Tranny Mounts
Lug Pattern
Help
Cold air intake differences?
Cheap chip worth a flip?
95 Saturn Gauges Will Not Work
Factory Gauges
Universal Mufflers
Part for 92 SC
cluth replacement - 91 SL1 - Tranny won't come down.
1995 sl2 Engine swap, what years are compatible
just bought a gorgeous 95 SC2--need help on checking thermostat/cooling system!!
Whining on cassette player
O2 Sensor Problem!!!!
CD player installation
99 SL2 Won't Start. Juck clicking sounds
One more...
Another 2002 SL2 thing
2002 Sl2 Drinking Oil
s-icon body kit
93 sc2 for sale
Check out my new SL2 front mouth
saturn sc1
Looking for ideas on rough starting 99' SC
2000 SL1 losing oil into twighlight zone.
Knocking and gas pedal vibration
96 SC2 won't start
Rough on the engine?
SL2 head swap to SL1 Engine
95 Saturn. Need to remove & change door locks
96 SL2 misfire
1999-SL-The Oil drinker !
Another OverHeating Saturn
SL2 Performance
SL2 starts then immediately dies
Help.. . ... . .. .?? ..
body kits
`01 SC1 throttle lag
Aftermarket cams
hesitation and bucking
Sweet SL Bodykit!
91 SC1 Diagnostic Code 45
Parking Lamps
it's got kick!
Water pump?
Service Engine Soon
My car is a gas hog!!!
1994 Sedan makes tapping/putting noise
1995 Saturn SL2 wont start
1995 SL1 Automatic won't start
2002 SL2 Shifting Issue
broken window, need install info
sl2 problem
Engine lite stays on '95 Saturn Why?
fussy lil' saturn
Clicking / Clunking
Adding Coolant
replacing water pump
windshield wipers
95 saturn, 5 speed, tranny click when shifting???
Warning Chime Won't Stop
93 SC2 automatic seat belts binding
Emissoin Failed Need HELP
Service engine Code P1404?
leaky sunroof 92 sl2
Trans Slipping
95 SC1 Window issues and Temp Sensor issues
clutch/transmission
94 SC engine surging - O2 replaced
'92 SC2 problems?
Alternator question Please help
Chain or Belt???
ECM code 26 "check engine" light
leaky tranny
Clutch Problem? '94 SC2
Random loss of electricity when starting.
'98 SC2 Electrical Problems
94 sc2 keeps dying
A little help...
zero to 60
1996 SC 2 Suggestions Please
Marbles in my door?
after market parts
1996 SC2 Power Loss
Deka Batteries
coolant leak on sl2 2001
Automatic Seatbelts
how fast?
QUESTION: What does this warning light mean?
92 SC Won't Start
Revs when switched out of gear then slows
Is my coolant temp sensor bad?
where is the thremstat 1997 sl1
? about sl1
more Hp! a lot more!
Adjustable cam gears?????
Dtc 26
Brake pedal spring & coolant leak....
1999 sl2-shift knob
Electric Locks Don't Work
1998 Saturn SL2 Fuel filter?
Aftermarket sites...
keyless entry programming?
My 1997 Saturn all cool air no Hot air
93 SC2 worth buying?
Discussion about my 99 SC2
How big is too big
sunroof motor?
Service Engine Soon Light (2001 SC1)
97 SC2 engine woes...
95 saturn sc, oil light flutters off and on
Trunk latch won't open - Remote Pull Handle
Hood Problem
Where to sell '94 SL1?
Replacing a Trans in 95 SL2
98 Saturn SL floods in AM when starting
Engine Revs
Engine concern?
93 SL-1 SOHC to DOHC engine swap
Valve cover
Engine Vibration
Control cigarette lighter power with ignition?
Car Sterio...Wire Diagram
Head Gasket
How Do U Get Off A Shift Knob On A Sl-2
97 SL 1 Hood Anybody have one (BLACK)
1998 SC2 won't Crank
changing the alternator
99 SL1 Check Engine - MAP sensor
93 Saturn SC2 For Sale GREAT CAR!!!
Battery or alternator?
My Saturn Revs HIGH in Neutral
Engine Problem Help!!!
Engine Compression Ratios
APC Mufflers
Exhaust or Intake
sl2 engine swap
Alternator
1992 SC 5 speed - Clutch adjustable?
Loosing coolant
Oil in antifreeze 95 Saturn
shift lever (automatic)
Please Help Me!!!!
transmission fluid swap at dealer only?
Better Gear ratios
EGR Valve
SL2 battery removal
94 sl4?
Power door locks
1996 SL1 Brakes
muffler question
where to place floor jack
sl2 problems
1997 SL1 won't start
HIgh Idle and Cooling fan
coolant sensors for 92 saturn
make it loud
Auto Trans Thuds Into Reverse
Electrical problem??
1996 SL Idle Question
Sticky Gas Pedal - '96 SL2
1996 SL1 .... Tire skidding
1997 SL1 Alternator and Transmission
Oil Consumption
Backseat installation
Anyone Know some performance parts for the 95 SC2?
Preventing Theft.
Window Replacement ??
started sluggish now doesn't start..help
intermittent engine shut down/ starting
engine dying when punching gas
how many belts
Transmission
Loud Engine noise
sweet ass deal on ebay
lights
Please Help!
squeaking brakes
1995 Door Panel Removal
amp installayion
Service Engine Light On
Saturn Quit - won't start - Help!
Exhaust
Fan motor not working
two clicks and then engine stops
98 SL2 Trans problem?
quik questions
2001 SL-1 dies and won't restart.
block drain plug location?
HP for Humming noise from 2001 SL
air intake help
2 Questions about a SL2
performance parts search
Taking apart a Throttle Body ??????
Compression Numbers?
anti-freeze type...
SL1 aftermarket cruise control???
not car savvy...
caviler engine to a saturn
RPM Needle
Is the back seat big enough for 3 car seats?
Keyless Entry And Alarm Installation
car wont idle
98 SL2 Auto Trans Problems
1996 SL1 cigarette lighter help please
intermittantly dieing saturn
Intermitten door window operation:
Drain cooling system
My First Saturn
Catalytic Converter
remote keyless programming for sl2
I am the new guy and this is my ride.....
Help with door panel
2001 SC2 Windshield Damage Question...
Manual gearbox problem
exhaust problems
Hi Flow CAT
SL2 Valve Cover Gasket Replacement
idle problem - '96 SL1
1999 Sc2
Fan problem
Coolant Light?
engine swap?
emblem design
1997 Saturn SL1
1998 SL2 headliner removal
SL1 Stereo upgrade
Hotwires
SL1 specs
hotwires
'99 Saturn SL with cracked cylinder head
air conditioner
radiator
Street Racing
Changing door speakers
turbo manifold for '91 SL2?
Transmission or what?
I Locked My Keys In Help!!
Hp for under 300?
disconnect battery
Web
AF
