View Full Version : SC/SL/SW
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13
  1. unstable idle, tach bounces around!
  2. All sorts of 2002 SL1 Problems
  3. high idle for 92 saturn
  4. What do you guys think?
  5. cost on repair of rod knock 2000 saturn 240Kmiles
  6. Short Ram Intake
  7. Replacing lifters...
  8. Battery light on and just put in a new battery. Help!
  9. 1.9 DOHC zero clearance?
  10. problem of cylinder compression
  11. 1.9L dohc head 4 sale
  12. window regulator and door skirt removal
  13. i changed my engine
  14. SL/ION swap
  15. Head Swap
  16. High idle
  17. pull cant come off?
  18. Air compressor going out..
  19. Engine Swap Saturn SL1 1995 into a Saturn SL 94
  20. New alternator on SC1
  21. Wipers not working
  22. Question for SL owners...
  23. PCV Valve
  24. engine swap
  25. Saturn SC2
  26. How many miles
  27. ignition switch problem-Saturn
  28. 1995 SW2 Auto Tranny Reverse Problem
  29. DOHC burner blues. Need advice.
  30. SL1 Service Engine Light
  31. Would not go into gear.
  32. wow saturn prolly one of the worst cars out there
  33. Suspension Noise
  34. Loud Popping when engine off!
  35. Outer Door Skin Removal
  36. Squeaky Clutch
  37. 99 SL2 - Dent Resist Panel Query
  38. 99 Saturn SL2 - Trim Paint Peel Issue
  39. Power Steering belt defect?
  40. Help with changing to Indiglo gauges on 2000 SL
  41. 1998 SC2 exhaust resonator
  42. problems with new motor
  43. What else fits?
  44. Dead Gas Gauge????
  45. 99 SC2 Brake Light Fuse
  46. dimmer lights?
  47. 99 Saturn SL2 - Struts
  48. Oil pan gasket replacement?
  49. IAT sensor
  50. Oil Disapears!!!!!
  51. two problems, possibly related?
  52. my sl is now on three cyclenders
  53. Reasonably priced Clutches
  54. 98 SL2 hard to start and runs like CRAP
  55. SOHC to DOHC?
  56. saturn sc2 targa top? Lambo Conversion? need input
  57. New here, with a bit of a problem...
  58. Every Saturn I have had burns oil. Fix?
  59. can u clean egr valve?
  60. 99 SC2 how do I replace my fan motor?
  61. 1996 SC2 Hesitates, Stalls w/ braking
  62. Store bought oil filters don't fit!
  63. 2001 SC1 misfiring
  64. 98 Saturn SL for sale!
  65. 94 Saturn SC2 DOHC Alternator mount or bracket?
  66. Trunk Release
  67. crankshaft bolt
  68. 94 sc4: check engine soon...a saga in the making
  69. does the Cold air intake actually do anything?
  70. cd player removal
  71. engine removal
  72. Looking for modified Front grill for 99 SL1
  73. Serpentine Belt
  74. Recharging 1993 Saturn AC
  75. 1996 SL2 Starting Problems
  76. Muffler band
  77. Where did my clutch go!?
  78. stalling in reverse
  79. Easy modifications to increase SL power?
  80. problems under low rpm
  81. Where's the evaporator on an SL-2?
  82. How do I clear check engine codes for a 2000 SC1??
  83. cracked resonater pipe
  84. 02 SOHC Turbokit???
  85. help wit 96 sc2
  86. 2001 sc2 ignition lock cylinder
  87. 1993 Sc
  88. Removal of drivers side door panel
  89. hesitation and stalling
  90. Rear Spoiler Removal
  91. 92 SC Cooling Fan
  92. 97 Saturn hard to start
  93. Headlights wont go down
  94. Re: Rings stuck to block???
  95. AC Recharge on '96 SC1
  96. '96 SC1 Door Handles stay up!
  97. parts interchangability
  98. need help to program 2001 sl2 remote please
  99. Troubles with interlock transaxle...?
  100. '95 SC1 getting too hot
  101. 1996 sl2
  102. Misfire
  103. speedometer/odometer not working
  104. 93 sc2 tranny
  105. installing cruise control on 01
  106. How do I reset "Change Oil Soon" light
  107. 93 Saturn Power Locks
  108. How long before transmission die? 95 Saturn SL1 Auto
  109. 97 Sl2 Dohc
  110. Mechanic Recommendation
  111. a/c problem
  112. Retrieveing ECM Codes
  113. sticking throttle cable
  114. Anyone looking for a '98 Saturn SL?
  115. silver lining
  116. oil light and coolant light stays on after engine swap.
  117. Whats Up
  118. plastic body panels go bye-bye?
  119. New to board...92 Saturn SC2
  120. Keyless Entry
  121. New Guy
  122. '95 SC1 for Sale
  123. 95 Dakote Leaks When It Rains
  124. Key stuck in ignition.
  125. how 2 pull up codes on dodge pickup
  126. 95 SL1 Wipers won't shut off
  127. SL-1 Remote control
  128. A/C stoped blowing cold air
  129. Blower and Power Windows Not Working!!!
  130. 97 SL2 Serpentine Accessory Belt
  131. power drain and not the alternator
  132. My Saturn Experience
  133. 94 SL! hesitation
  134. 92 DOHC Fan problem
  135. clutch master cylinder
  136. 2001 Saturn SC2 Amplifier Installation - Need Help
  137. fenders and doors
  138. 94 sohc swap for a 99 dohc? is it possible
  139. Location Of Egr Valve
  140. Clutch Adjustment?
  141. Window motor removal
  142. whirring sound in engine
  143. Fuel Injection Cleaners
  144. Need Advice On The Next Step
  145. Oil shooting out of exhaust of 99sc2
  146. HELP Passing Emissions 95 SL1
  147. 1992 Saturn SC problems
  148. Lose Of Compression
  149. Service Engine Light Flashes
  150. door locks
  151. Temperature Going Hot then Cold
  152. check engine light blinks
  153. oil
  154. cherry bomb turbo II muffler
  155. Problem with battery draining
  156. voltage
  157. 2001 SC1--Poor Handling in Windy Conditions
  158. Tint Removal
  159. dohc engine in SOHC SL?
  160. Burning Oil
  161. 99 SC1 Engine swap sohc to twin cam. QUESTIONS?
  162. gauge panal lights ( 99 SL1 )
  163. OEM Saturn parts
  164. 4 lug hubcaps on a 5 lug wheels
  165. Driver power window problems
  166. QUESTION about do-it-yourself A/C refrigerant recharging
  167. Trannie problem, please help!
  168. 97 SL2 Won't Start When Hot
  169. 95 SC 1 - Door Panel Help
  170. Car Sterio help please
  171. Engine Revs on it's own when in idle
  172. '99 sc2 needs a timing chain
  173. Air Temperature Sensor
  174. SL1 Stalled
  175. Cooling Temp Sensor?
  176. sl opinions
  177. how do you to deativate the daytime running lamps?
  178. 98 SL2 resonator pipe
  179. 92 cooling fan and code 45
  180. Wanted: Factory set of wiper blades
  181. Oil Pressure Light
  182. fast idle when car is rolling
  183. these sl2's are quick :)
  184. '02 SL2 front seat bolts
  185. Headlights
  186. steering
  187. Another Manifold Question and Search
  188. Short Ram Intake
  189. 2000 SL1 power windows
  190. saturn insurance
  191. Cold Air Intake Install
  192. 2000 SL1. How do I set the radio clock?
  193. Front End Vibration
  194. '94 SL2 Parting out, make an offer...
  195. Suspension
  196. Tranny... Clutch? --> Problem
  197. ajusting window alignment
  198. 94 sl2 wont start, brakes cause lights to go off
  199. Dash Lights not working
  200. 1.9L SOHC engines in the 96-99 S-series?
  201. 97 SC2 sputtering after rain.
  202. SL1 Rear Tires Wearing Out Quick
  203. Steel Wheels
  204. Question for all Saturn drivers!!
  205. 94 sl2 body kit
  206. Leaking door in 95 SL2
  207. question about gauges
  208. Oil in spark plug socket
  209. clutch always engaged?
  210. High Idle
  211. coolant replacement
  212. 91 sl w/dohc help!!!!
  213. 96 SC2 switch/ac problems
  214. car shakes when stopped
  215. Multiple Causes for Service Engine Soon Light
  216. Tech Help - Ignition Module
  217. Need Help - '94 SL2 Won't Turn Over When Hot
  218. 96 SC2 Alternator and Headlight
  219. 2001 sl1 won't start sometimes... PLEASE HELP ME!
  220. Dash lights not fuses PLZ HELP
  221. New!!!!
  222. Fan will not shut off?
  223. Lights left ON chime won't work
  224. Twistec mounts
  225. purchasing problem
  226. head gasket replacement
  227. 1999 saturn idle and hesitating and stall
  228. help my man
  229. Transmission!
  230. Windows 93 SL1
  231. intermittant electrical problem
  232. turbocharging
  233. 95 sc2 won't run right
  234. NEED HELP, ODOMETER doesnt work.
  235. oil in radiator overfill
  236. It keeps shutting off
  237. My Wifes 99 SL1 review.
  238. replace the brakes
  239. sunroof removal
  240. engine swap 93 sc2
  241. idle air control valve?????????
  242. 94 Saturn body kits
  243. plz help me!!
  244. Considering Buying a 92 Saturn SL2
  245. Where can i find a Cold air intake for my 97 sc2
  246. is it normal for a Saturn to run kind of hot?????
  247. z1 performance module
  248. Locked Ignition
  249. Looking for a header
  250. 95 SC2 body kits?
