View Full Version : SC/SL/SW
Pages :
1 2 3 4 5 6 7 8 9 [ 10]
11 12 13
- 2002 SC2. Car Starts and Stalls...
- 97 sl2 intermittant won't start
- 93 SL2 stalling
- Reset Service Engine Soon light
- tire question
- fast idle in drive,park
- Daytime Lights
- CD Deck Problem
- 1995 Saturn SL1 Heater trouble please help!
- 97 SL2 starting problem
- 1994 Saturn SL2 TC
- how much power?
- Wiring question?
- injen intake on saturn sl 2
- Check Engine Light Code 0404
- What size rims?
- 92 sc2 has a weird problem
- Newbie here, looking for help with SW
- 2000 SL2 ignition switch replacement
- Big Thanks to Y'all
- 98 saturn sl2 hard to start and get running from acelleration to first gear
- Electrical problem
- need help!! 1997 SL1
- tie rods
- uhhh ooooo
- 97 Sl2 starting prlbem
- does 93-95 SL2 Cen Rear LENS fit SL?
- Power?
- Mechanical Problems!!!
- 95/96 headliner/roof panel sl2
- '98 SL2, P0341 -"CMP sensor signal out of range"...after a tune-up job
- Blower Motor Only Works On High
- more power baby
- '99 SL2 radio display backlight out
- uses 2 qts oil in 2 week -SL2 97
- OEM parts
- 94 sl1 mechanic probs
- Sl1 94 sound system question
- Starting problem 95 SC1
- Differences between SC, SL, and SW ?
- timming chain
- 94 sc2 lifter
- 02 SL1 engine "ticking"
- 1995 saturn sl2 wont start
- Starting and running problems linked?
- P0133 02 Sensor and P1406 Emissions Controller Codes
- struts
- Strange startup problem
- Rear Defroster Problem
- valve
- 94sl2 needs help
- a huge problem..??
- need parts for 95 sc1
- Service Engile Ligth is on after changing AIR Filter
- won't start/fuel gauge zero
- Removing A/C System
- Hp Sl2
- SL2 performance????
- how 2 get shifter knob off
- gauge pod
- 1997 SL2 Timing maps?
- '97 SC2 temp sensor
- Replacement Gauges for SL2
- How to install a cold air intake
- 95 SC2 Head Gasket
- Car won't start, just makes clicking noise
- '99 SL2 security system problems
- Electrical problem or what
- SL1 cold start problem
- goofy thing that happened over the weekend
- Speed mods for my 93 SC2
- My Wheel Fell Off!
- Thinking about a 01 sc2
- 02 SL1 OBD problem
- dead battery...dead keyless remote???
- 2002 sl1 1.9 soch (gurgeling noise from engine/trans
- Hestitates on acceleration
- looking for SL part
- can I save my radiator?
- 1994 Saturn SL1 acceleration Problems
- Anyone else have a leak into their 2002 SC?
- sl1
- Kick Panel Removal
- Seat Brackets for Racing Seat
- alarm install help
- I have a strange probem
- Coolant light
- Parting out a 95 sl2
- was i ripped off?
- 96sc2 wontstart bad mpg plugcarbonfouled
- 95 Saturn SL1 Headlight Questions **Please**
- 1995 SL2 Automatic Revving/Stalling etc...
- "new" 2001 SL2 tips?
- Musty Odor
- Start up problems
- 95 sc1 tranny or clutch problem
- Valve Train Noise
- Engine replacement '96 SL2
- shaving the head
- Air intake system
- 2002 Saturn SL1 cruise control???
- 95 SL parts Wanted
- parts interchange between sl-sw-sc
- 1997 Saturn SL1
- Advice: selling Saturn SC
- High idle when cold temps outside/moving but ok when stopped
- 2002 SL2 C/F Hood Fitting 97 SL2?
- 96 SC2 crank sensor
- Not another oil burning thread !
- Intake System Help
- HELP.. car cuts off when put in reverse
- 97 SC1 Service Engine Soon light
- sc2 window cleaning
- grinding noise?
- sl muffler help.
- code P0117
- '96 SL Clutch slipping
- Nasty Noise With Tranny
- EGR Question.
- looking for diecast models
- Bad Fuel pump?
- coilovers
- This clicking noise...HELP...
- Airlifts(airbags w/e you want to call them) for a 1997 saturn sl2
- 99 SL2 High idle at start
- need help from all u experts--rough startin' 95
- 1994 sl1 manual trans .. got probs
- cv joint
- Windsheild Washer
- body q?
- 1997 Saturn SL1. MUST SEE!
- 1996 saturn SL-2 rear window off track
- 00-02 SL kit update
- 1999 Saturn SL2 Instrument Cluster Removal?
- 93 saturn SC2
- How do I change the Water Pump on a 96 SL2?
- hmmmm
- Lookin For Hp
- grounding kit
- shaking at all speeds...
- high idle on 99 SL1
- hey guys
- brake rotors
- saturn sl 97 start up
- Trouble Starting
- Decrease In Gas Mileage
- spolier fine scratches
- motor swap
- oil pan gasket
- 92 Saturn With Oil On Plugs
- Car Accident 94 SL2
- Start Up Problems
- Glow Face Gauges... funny spot
- What Does This Code Mean?
- my 94 SL2 vs. a 99 SC2
- Me Again - 1996 SC2
- power seatbelt motor?
- Duals???
- Overcooling
- Sc1/sc2
- i need help with looks on my 1999 sl-2
- Locking with keyless entry causes horn to beep constanlty
- 94 SL 2, Power steering pump, Broken mounting bolt
- need help! engine check light with rough idle!
- im having probles with my saturn
- throw out bearing problems!!!
- 94 Saturn power window
- Idle problem, please help!
- saturn performance
- Hey engine and muffler fans!!!!!!!!!!!!
- Occasional engine lights
- how do u take door panels of a 1997 saturn sl2
- 2000 SL2 Spark Plug Gap
- 94 Saturn SL Fan
- Diagnostic Trouble Code P0137
- dip in rpm's in 2nd gear
- Shaking on rapid acceleration
- 1996 SC2 Problems, Help?
- Egr Valve.
- Service Engine light is on....
- Saturn sc2 Spark Problem
- euro lamps
- Speedometer problem?
- Compression check
- 2001 SL2 running hot and surging while driving
- '00 SL1 won't start
- please help, need 95 SC2 1.9L DOHC engine info
- 1993 SL2 timing chain or belt
- CV joints i think
- help rough idle
- caster for '97 SC1
- Rims on my saturn
- Keyless entry for 98 SL2
- replacing '92 engine with '93 or '94
- 2001 SL1 Help!
- New Saturn Owner yay
- quarter mile times
- saturn leaks on passenger mat!!!!!!!!!!!
- why buy plastic?
- 95 Saturn Clutch
- '94 SL1 Acceleration problem
- 1993 SC2 loses power when switching gears.
- Flowmaster for a 97 sl2?
- 99 SL2 Shop Service Manuals
- steering wheel shaking
- Throttle unstable at low RPM's. 97SL
- 1999 Saturn rust spots on hood
- 92 saturn sc2 door lock module?
- coilovers
- spark plug wires
- SC2 completly dead - won't start
- cooling fan and ac compressor inop
- Headlight problem '99 SL2
- Oil splatter from exhaust
- Passenger side mirror
- 93 Saturn SL2 DOHC Wheel Nut size
- HELP! diagnose dead alt?
- Used Saturn
- 1994 SL-2 Cold Rattle/Warm no rattle slight hesitation
- Power windows not going down...
- C-Clip Hell....
- hissing-like sound when brake/clutch pedal is pressed...???
- driver fender
- How long will a saturn last?
- Low Idle
- engine problem
- problem
- hi guys! How long the Saturn's warranty has? my car...
- afterblow feature
- 94 SL2 Transmission
- 94 SL2 Alternator Replacement
- Is my 96 SL-2 really near death?
- Sound coming from around serp belt
- 2001 sc1 idles high
- Transmission - 1995 SL1
- 1997 Satrun remote programing
- Saturn or Caprice?
- Installing factory sunroof on non-factory saturn
- Average Miles
- Acceleration cuts out when engine warms up
- problem with keyless locking and alarm
- 93 SL2 engine swap, now no injector signal. HELP!!!HUH?
- Reverse Swith Connector
- 96 Saturn SL1 wont start because of anti theft device
- SL2 - Oil on spark plugs
- Serpantine Belt
- 2001 bizz natch es
