View Full Version : 924/944/968
Pages : [1] 2 3 4
  1. 1984 porsche 944
  2. 1984 944 fog lights
  3. AC Switch late 944/968
  4. I have a porsche 944 with an '89 NA engine - it's missfiring...?
  5. 944Fest @ Nelson Ledges OH June 5th - 7th
  6. Battery wont charge?
  7. Temperature gauge shoots straight up?
  8. FOR SALE: 944 parts
  9. Wanted: 968 mirrors
  10. 944 cuts off
  11. Porsche Dash Plastic
  12. 968 tiptronic or manual?
  13. Screamer
  14. S2-968 Head Swap?
  15. 944 online.com
  16. 944 gt3
  17. 1986 944 not starting...
  18. 944Fest 2008 @ Mid Ohio (DE EVENT) - Registration Now Open -
  19. 1985.5 Porsche 944 runs rich
  20. air-oil separator
  21. 944 Odometer Behaviors
  22. 944 Cam belt slipped?
  23. 944 Timing Belt/balance Belt
  24. oli problem
  25. fun in a 944
  26. 86 924 Lsd
  27. chevy 350 conversion
  28. 85.5 Porsche 944 cranking problems
  29. 78 924 Rear Seatbelts
  30. 1986 944 Turbo For Sale
  31. reliability? specs?
  32. Rear Wheel camber
  33. Relay problems
  34. Performancechips.com
  35. Is this a good deal (link)
  36. 944 Cooling Fan Not working
  37. oil pressure 86 944
  38. make a fair offer
  39. Bad Fuel Pressure Regulator?
  40. '86 944 making loud road noises
  41. i finally got it
  42. Parting out an 83 Euro if anyone needs something.
  43. 83 944?
  44. 84' 944 starter?
  45. 944s wheels
  46. 944 Serpent belt NO A/C
  47. 924-944
  48. '78 924: Which fuse is which? :P
  49. Do I really need my Catalytic on my '83 944??
  50. Water pump issues!!!!
  51. 944 turbo???
  52. Wanted: bargain 944 convertible in UK
  53. Wanted: bargain 944 convertible
  54. 944 buying questions
  55. 944 Block Swap
  56. Fuel Pump DME Relay!
  57. Just bought a 944! I have some questions!
  58. '86 944n/a Stalling Problems
  59. looking at a 944
  60. Rear Hatch
  61. timing belt etc.
  62. 944 light problems
  63. apples to oranges
  64. mods
  65. Riding with kids in a 944 cabriolet
  66. timing belt
  67. 944 turbo porsche part car, need any parts?
  68. 1987 Porsche 944 Renegade
  69. RB26DETT in Porsche 944?
  70. body panels of 924
  71. Alignment adjustments....
  72. Slotted rotors for '86 944 Turbo?
  73. 944 Track Time
  74. Porsche 944 Oil in Water
  75. 87 944 turbo starting problem
  76. 944 vs. toyota supra, how can i do it?
  77. wheels for 84 944
  78. My new 944
  79. Pumping up Hydraulic valve How
  80. How do get the rear crank seal out?
  81. Help! Vacuum leak, miss fire, 951
  82. 85 late 944 started after sitting valve chatter
  83. Need Radio Immediately
  84. 1985 Porsche 944 late n/a
  85. 91 twin turbo supra engine in 944
  86. how much to sell.
  87. 89 944 will crank, but will not turn over.
  88. Paint job cost
  89. Installing racing seats and harnesses
  90. Opinions
  91. Replacing Tranni-Torque Shaft "Coupler"
  92. 84 Porsche944
  93. selling my 944turbo cheap
  94. selling my 944turbo cheap
  95. won't start
  96. cheap 944 modifications
  97. 951 Rev Limiter?
  98. Starting Clutch Job, Any Pointers?....Please
  99. 944S noise problem
  100. Modify 944 engine
  101. 944 S2.....which tyres??
  102. Pressure Problems
  103. change sensors when chenging the brake pads??
  104. What Is a realistic price to modify 951 motor
  105. when to change oil/air and fuel filters?
  106. K&N air filter increases ther engine noise?
  107. 84 porsche 944 hybrid question
  108. Porsche 944 w/ LS 1?
  109. sunroof relay question
  110. 1983 944 stuck in neutral and can't shift into any gear
  111. 951 fs in ohio
  112. Looking for a Switch
  113. I think I Need a clutch kit now. *sigh*
  114. starts but stalls immediately
  115. time for timing belt...
  116. 944 Factory Shop manuals (6) for sale: Ebay
  117. 944 body kit for SALE!!!
  118. new and just bought a porsche 944
  119. oil leak...
  120. beating on a 944T
  121. 944 Sunroof
  122. 944 turbo
  123. Regarding Mass Airflow Sensor
  124. 1979 Porsche 924 *died* need help
  125. Clean sub/amp install
  126. LS1 in 951?
  127. Leaky Fuel Rail...Again
  128. Nasty Idle Noise
  129. 944 tuning potential
  130. 944 custom exhaust and stock exhaust
  131. Cleaning out garage-late alum. control arms
  132. 944 N/A fog lamps
  133. project car
  134. 944 for sale
  135. 944S Porsche 1988
  136. Porsche 968 Info
  137. 944 turbo caprio i want comments
  138. 944 turbo caprio i want comments
  139. Want to buy a porsche..
  140. Possible to use 968 headlites on a 944?
  141. A few things with my 944, please help
  142. engine fan
  143. HELP! 300hp+ Needed Which Engine Should I go with?
  144. '87 944 Oil fill tube leak
  145. Help Trans problem... no first or second
  146. CD player wiring? K&N FIPK? and chip?
  147. Mo30 Wishbone/control Arm
  148. rear shoulder belts
  149. 89 Auto 944
  150. Click click click click ck ckckckck!
  151. fire, burned stuff, and emissions control
  152. 1986 Porshe 944 Oil Pressure Light
  153. Thinking about buying...
  154. Buying a 86' 944
  155. General Info
  156. fuel pump wires
  157. Upgrade to 968 6 speed Tranmission
  158. Cooling fans won't turn off!
  159. sunroof removal
  160. engine wont keep running
  161. 944 fuel filter
  162. Screws for Fans?
  163. F/S Porche
  164. F/S 1981 924 turbo
  165. Fuel Problem
  166. vr6 into a 944
  167. 83 Porsche motor oil leak, were to look?
  168. Will Turbo Axles Fit On Late 86 944???
  169. loose shifter?
  170. Just bought 944
  171. Help.... IT WONT START! ('88 NA)
  172. 2.5 crank shaft for sale
  173. Top Gear (tv show) w/ 944
  174. Dash light Change?!?!?
  175. 924 and 944 Transaxil
  176. Shopping: 924 vs. 944
  177. balance shaft
  178. 944 starts then stalls never figure this one out
  179. Right Rear Fender
  180. 944 to 951 can it be done?
  181. New door
  182. 944 s mods???
  183. prepping 924S for spec 944
  184. Cold air intake?
  185. 944 NA Auto
  186. Engine swap.
  187. Taking apart rear view mirror?
  188. Help!!!
  189. Washer Fluid Tank
  190. 944fest '05!!
  191. Need door panels
  192. dont ya just love porsches?
  193. WTB: Burgundy/Plaid cloth seat 1988 Turbo
  194. What to look for.
  195. 1985 Or 1985 1/2?
  196. Transmission: Auto to Mannual
  197. Auto VS Manual
  198. 2nd Driver side key hole?
  199. new paint job
  200. new motor
  201. NA engine Turbo Upgrade?
  202. Best ideas for finding a 944???
  203. Upgrades and Engine Capabilities
  204. New 944 owner with questions
  205. issues with 944 S
  206. '95 968 cab for sale, 56K miles, one-owner, $21,500, beautiful car!
  207. 86 944 Fs
  208. buy 84 944 ??????
  209. Help, buying a 944 question
  210. popup headlights
  211. 944 Lsd???
  212. 86 944 hard start, cold or warm engine
  213. turboing the 944
  214. air bag and belt light
  215. My trans is whining now.....
  216. Pinion Bearing Issues with 95 968 w/LSD?
  217. Yo
  218. will a 924 hood fit on a 944?
  219. Fabcar control arms for '87 and later cars
  220. Horn
  221. rear hatch/ int. light problems.
  222. light bulbs
  223. early 944 clutch problem
  224. Parts sites
  225. 944 leaking antifreeze, transmission sound
  226. Drivers side window sticking
  227. ECU/DME pinnout if some one has one.
  228. New 944 owner
  229. WTB Rear end For 1988 Base Model
  230. want to sell my porsche
  231. 968 oil, tires, and specs
  232. 944 fans don't engage unless AC is on
  233. Buying a porsche 951 need some advice
  234. 944 oil cooler
  235. turbo upgrade
  236. rough idle in first five minutes gas smell
  237. Battery drained
  238. Just got a 944... Questions
  239. Boot Luggage Cover. Any1 Selling?
  240. need a clutch
  241. 944 Runs Rough
  242. Lpg Conversion??
  243. 944 Runs Rough when damp
  244. Fans eat my battery......
  245. porsche wash
  246. 944 Turbo - interference design
  247. Porsche Performance harness bar for 944
  248. 944S vs Turbo Question
  249. auto trans linkage-1987 944na
  250. $3k '87 Porsche 924 S Coupe
