Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
rims
power window motor/regulator
front sway bar replacement question
Front struts
Replace DexCool after 140k?
2001 Grand Prix GTP Chronic Overheating Problem
Kr
'94 ventilation blend door - vacuum?
1993 Grand Prix - Lower ball joint
Rough idle after LIM and SS IC install
Finally finished new bumper! What do you think?
MAF question?
05 gt low fuel light
How do I remove the lower fuel injector O-ring?
a/c clutch
fuel gauge issues
Serpentine belt alignment?
2000 Grand Prix~Security Light blinking.
I have a miss I can't figure out
question about car stereo and amp.
Post Your Average MPG (GTP's ONLY PLEASE)
Coolant Resevoir Removal
Labor Cost for Valve Cover Gaskets?
Need your opinion on struts and springs
GXP Hood On GTP?
rookie f#$k up
Found grease, CV boot
inner/outer belt moldings
911...Need help, Shift kit problems
Steering wheel clicking and sticking
S/C'er Pulley Questions
battery is suddenly dead
Brakes squeal only after it rains
auto-dim rear view mirror
MAF sensor no start?
94 Grand Prix SE 3.1 V6 127k backfires barely runs
Crankshaft Position Sensor Replacement
95 GTP 3.4 left turn engine issue???
02 grand prix gt wont go over 3500-3600 rpm
2002 gtp gas door sagging
Window glass
Surging RPM Problem At Freeway Speeds - Help Diagnosing
01 GP SE Sudden missfire
Question for those who've done rear struts
Sealing Strip
Can't remove key in Grand Prix
171 dtc
Need torque specs for LIM and SC
Seat Belt
01 Grand Prix DRL Problem
removal procedure ac line
2002 Grand Prix SE Aftermarket Radio Install
Front End Shaking
Transmission problem?
engine knocking/ticking noise.
Thanks to Richtazz
new door handles dont work
2000 Grand Prix - Window and radio don't work
Start out shift problems
Help with a miss
1999 Grand Prix GT transmission problem?
Car bogs or dies when accelerating. I can't figure it out!!!
Radio locked
Rear wheels own at bottom.
clunking noise at a crawl
dealership or not?
Evaporative System Not Ready
2008 GP Street Scene grilles
Electrical problems
A/C Mystery... help
P0172 Code
P0172
'08 Prix rear strut rattling noise
Removing steering column cover
Battery
2001-3.8 engine ABS and Traction Contol light
AMP HELP for GP
Wiper problems
install new belt to bypass AC compressor
Pontiac/Oldsmobile 3.8 engine
A/C Odd Problem! 3800 V6
NEED AC HELP (Az is hell 108 degrees)
Grand prix starting trouble
radiator flush
Turn signal Problem!
A/C Problem
*** w-body coil-over upper spring perch ***
Windshield Washer Pump
1997 Grand Prix GT
here we go again...
Fog Light switch Causing Problems 99GTP
HVAC Blower works only sporatically
Wix oil filters
S/C Coupler Replaced.. Rotor question
A/C problem
Poor acceleration after slowing down
belt tensioner / 2000 grand prix gt / 3800
Putting Rims
keyless remote.
Low oil Light
2002 gtp rack LEAKING AGAIN!!!
Problem Related to Heater Blower Motor
Surging Problems 98 GTP
3100 Grand Prix SE Knock Retard
Oil Type
1998 grand prix gt key won't turn
tune up parts
Losing coolant
brake problems
2000 GP GT Tune-up
Idle issues continue
Orifice Tube and Low Pressure Switch bypass
2000 Grand Prix GT Will Not Idle
changing headlight system from sealed beams to just changing the bulbs
2002 4T60E slam shifting
Rim size question for 2003 GTP.
2003 headlight/ac problems
3.4 to 3.1 engine swap will this work?
99 GTP orifice tube location
01 grand prix radio conversion
92 grand prix se
Remote Light-Up
Minor radio problems
Replaced Ignition Switch now wont turn off.
Stumped_97gt stalls
Bad Sensor?
2000 gtp wont idle
are the 6x9s and the 4inch speakers in the rear supposed to be tied together?
odd p0102 code
AC Compressor change out procedure
2004 Heads up display
Oil help sythetic or nooo
Uh oh. Another missing S/C Belt - 99GTP 127k
Need Help
grand prix oil filters
motor swap
New here, have a question...
3.1 Request
Power steering fluid leak on low pressure line
94' grand prix
99 gtp radiator won't drain
Brake bleed
1997 Grand Prix transmission problem
03 grand prix loss of power
Lights out on PRNDL center console
Ignition Switch?
Doug grand prix nitemare
Problem with pass side aircondition 98 Grand prix
Rotors
Security light
Greasing Fittings
Check Engine light
GM L67 LIM Gasket (Faulty Design?)
Replace both valve cover gaskets?
Loose Wheel Hub?
Supercharger oil?
Bad Crankshaft Seal
Driver Information Center
1996 GTP clunks under load
bad MAF?
"Check Gas Cap"
reduced engine power
noise in 3800sc 2004 gtp lifter?
power steering help!
1994 Grand prix keyless entry module location
electric window won't go down
02 transmission/ tach question
'02 Grand Prix Unknown problem/random dying in traffic.
Rim Compatibility
2006 Grand Prix GT - Power Windows & Locks Not Working
control arm
blower motor trouble?
Misfire then fine?
94 GP 3.1 shakes BAD and will not pull itself
2000 GTP Obsolete A/C Hose - Help Finding
Low Coolant Light Blinking- Part III
2001 3.1 a/c problems
2002 3.1 grrand prix hesitatation
timing a 3.1l
P0113 DTC Grand Prix vs Mouse
My doors keep unlocking themselves
Scan Tool question!!
99 Grand Prix Stereo shuts randomly off - When warm??
Solenoids
air not blowing through vents properly
SRS airbag light flashes then dies
1994 Pontiac Grand Prix
2004 climate control
Alternator bracket help (pics?)
spark plug gap
1996 GTP Specs??
1995 Grand Prix Headlights
99 Prix A/C leaking freon
?????????s again
MAF sensor help 97 Grand Prix GT
wet carpet on pass side ??
Please Help me Quickly (condensor o-ring)
2000 GP GT Stance
New filter with Seafoam
Front End Metallic Clunking
Is this a good buy?
External Filter for 4T60E A/T?
PCV Valve
95' Grand Prix Turbo?
Ideas for resurrecting my GP
How To Remove The Cup Holder?
Vacuum hose
Car audio question 05 GT
ABS light still on after HUB replacement
new 2008 pontiac grand prix
2001 Grand Prix HELP!
To Everyone
Turn Signal repair
98 Pontiac Grand Prix AC Compressor oil level check
MAF Cleaner experiment
Knock Retard (How much is too much?)
01 Grand Prix GT front Axle Nut torque
Help! Clicking in engine and a sputter
1999 GTP Surging
1989 grandprix pwr windows dont work?
Condenser/radiator replacement? 99gtp
Did I get jacked by my Garage? 97 Grand Prix
Where to obtain a OBD1 code reader
Recharging Air Conditioner on my 2000 Grand Prix GT
check engine light comes on only when a/c is on
bad problems with 3100 wires / tubes
3.1 transmission interchange question
2000 GTP alignment specs
Need advice - 2004 GP GT1 (only 22,400km)
3.1 interchange info please.
2002 Grand Prix GT - Jerking issues
Becoming a Auto DIYer and other questions
ABS Trac Off light
Rear door panel removal/fix
1991 Grand Prix 3.1L Code 43
2004 Grand Prix Braking Problem Please Help
Good brake upgrade?
How to tap in to the Battery terminal ?
Transmission slippy?
Headlight Warning Chime and no cluster illum.
Grand prix window problem helppp!!!!!!!!
a/c blowing cold on pass not driver
Fuel Problems?
Water Pump Gasket & Sealant/ Tensioner O-ring Questions
A Gulping Sound?
Brake Job Parts?
2000 GTP issue with Coolant Temp Sensor
t-stat how to get to it
Re-position '01 GP headlight
Steering wheel crooked after alignment
