Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
x tune headers?????
Dual Climate Zone Problems
97 GTP Transmission pan gasket
LIM gems among junk
Automatic starter for 2000 Grand Prix GT
Solid or hydraulic motor mount?
2001 GTP Flashing Service Engine Soon Light
Lumbar problem 99 GTP
abs and tcs light coming on when i hit bumps
oxygen sensor question
92 gp se
car overheating
Upper Radiator Hose Collapsed
96 Grand Prix SE with 3.1 v6
2000 grand prix 3.8L wont start
92 gp 3.4 dual cam problem
Craziest problem ever
Tamper resistant torx tool for MAF ?
4T60E transmission temp sensor
wont rev past 4,000???
car not same when cold
Oil level sensor bad or gremlins?
OK to unplug MAF sensor and drive car?
A Plethora of Strut & Shock Questions
GPS as opposed to odometer
Plugs and Wires
Car pulling to left
Oil Pressure Sensor Location
Parking Brake Light staying on?
2000 gtp Iridium plugs
Vibrating and Popping
A.I.R Solenoid
2006 GT "check gas cap" light on
oil in coolant overflow
P0411 code PCM?
Relays behind the glove box
Need Speaker
Dumb Defroster Question
DIC not working properly, a few other things
92 gp pass rear caliper
headlight/fog lights
HID's and stock headlight housings
2000 GP With Very Bad Shuttering
Gm part # confirmation
Brakes Recommendations
DIC and AC problems
90 grand prix brake pedal stays down
02 gas guage
Instrument cluster Kph or Mph
hard shifting into reverse from park????
fix for hesitation/stutter intermittently
droaning noise from front end?
Phenolic Blower Spacer?
100,000 miles
How Many Miles On Your '97-'03 Grand Prix?
Headlight switch
2004 GP Heated Seats
Antifreeze problem
Steering Wheel Lights
can i get a bigger supercharger
'98 3.8 GT N/A knock or lifter after tranny rebuild
Leaking Head?
93 gp se..trans bad?or sensor?
Power Steering Filter?
Grand Prix GTP transmission problem
Stalls right after start up?
Top swap, or motor swap?
92 gp se antifreeze leak, minor
1992 grand prix 3.1 fuel pump wont turn off.
please help 3.1 not starting
GTP Coolant Leak again...HELP
2000 Grand Prix Head Gasket Replacement
2001 Grand Prix GTP - Rack Pinion
97-00 GP Trivia
Analog to Digital DIC help!
2003 Grand Prix - shifter intermittently locks
!!!Major Transmission PROBLEM!!!
2001 GTP Headlight problem????
issue with Check engine light
1994 3.1L strong exhaust smell, high fuel consumption
Removing side moulding
radio display 1/2 lit
97 gtp
Lost my GTP
Sluggish miss in the lower RPMs
Where can you safely place jack stands on a 2000 Grand Prix in the back?
What Product to Lube Door Hinges?
Heating Problem
v8 in a 00 gtp ??????
Ignition issues
got a sweet deal
02 GP lunges while at a stop
Starter on a 2000 Grand Prix
Is it the Multifunction Switch??
02 grand prix 3.8 starting problem
Parking Brake Not Holding
1992 oil gauge help
2000 GP GT ignition change out problems
Automatic Lock cycles repeatedly
strut questions
1990 grand prix questions
95 Grand Prix cooling fan problem.
Turbo system?
Auto start question
Windshield wiper fluid reservoir
Replacing rear pads and rotors 01 Grand Prix
Ipod in 2004 GP
Torque Converter Questions...Again
How does the DIC MPG work?
Ignition switch
Shocks for a 2006 GP lowered 1.5"
94 g p security
Tranny slipping? 2003 Grand Prix SE
Run a VIN?
locking wheel lug nuts
engine swap?
gtp problems?
2000 GTP Blowing Fuel Pump Fuses
Ball Like Vacuum Canister
I have a question
2000 Pontiac Grand Prix GT problem while starting?
1989 2.8 not running right
Driver Side Door Window
timing chain broke
Bad mpg
Coolant reservoir removal?
Where is the horn?
surging & dying once normal operating temp. is reached
super or turbo? more for your $$$$$
Serpentine belt
Tire size HELP!
i need ed morad's number anyone have it?
Painting the interior
Backlight for Headlight Switch?
Impact Wrench/Torque Guns
inner tie rods
Automatic Transmission Problems?
Steering Wheel Replacement Turned On Air Bag Light
p0133 again
ZZP strut tower brackets?
240hp uh?
99 Gtp 157k Poppin tuneup cherry hah
hesitation
another ABS/Trac thread
tranny line disconnect
Same old question. Cant find an easy answer.
auxiliarly pwr outlet problem
99 GTP oil pan & gasket
99' GTP power steering issue
HVAC Air Movement Issue
Anyone install a drain plug on their tranny?
too many miles?????
Wheel noises...?
98 grand prix se
What's a radio unlock code?
Transmission filter lip seal removal - how?
Power steering pump.
Check Coolant Light
2000 Grand Prix GT- not starting
Disconnected air hose
leeking antifreeze from pcv valve any sugestions?
heads up display problems
i need help
Buzzing humm in the dash
98 Grand Prix Will not start.
Help with fuel filter change on an '04
Help! Trying to remove power steering pump
GTP making weird noise?!?
Pontiac and Cadillac Conversion
speed bleeder valves
rear struts
99 GTP ac & antifreeze problem
Headlight Problem
Need Help With 2001 GP blower motor issue
98 Grand prix Gt oil filter
ball joint perhaps?
02 3.1 losing coolant by tensioner
harmonic balancer confusion
Wheel Hub/Noise Question
99 gran prix 3800II help please
95 GTP oil leak question
Strut Replacement @ 126,000 mi
SES keeps coming on
removing interior door panel
losing tranny fluid
Front Hub bearing replacement 2002 GT
losing coolant
Is $600 worth it?
Low coolant light
Error code
Knock and Crank Sensor
1.8 Roller Rockers
decide to ask here also
Throttle body cleaning
RPM Dropout
02 Grand Prix Climate Control/Daytime lights Issue
So, my '08 Prix has no external fuel filter
Black Stone Lab Oil Results
PCV Valve Question
Low coolant level light
part id
Oil in the Floor?
Power Steering Whine
Driver side window help!!!
daytime running lamps
97 GTP firing orders
gasket for s/c snout
97 GP manual HVAC blows only hot air
01' GP GT shift lock problems......
Headlights
Better Gas Milage???
Need help with gas gage!
01 GP GT removing shift knob
01 GP GT 3800 V6 Oil in Radiator
no ses port readout
Totally stumped!!!!
Replacing Rack and Pinion in 2001 Grand Prix GTP
issue with A/c
starting problem...
Spark Plugs
Pulling the fuse (fuel pump)
99 gtp headlights issue
What is the correct Window Regulator for a 1999 Grand Prix???
new cd player with Bose speakers
AC Mystery
Ac compressor location
dimming lights, power surges? help mee
need help with coolant leak. see pic
low pitch noise
Please help with CV SHAFT
99 grand prix GTP headlights problems
Thread-locker on valve cover bolts.
Window Regulator Replacement Guide/Instructions?
Key Stuck in Ignition 2002 GT
2001 Grand Prix GTP Start Hesitation
2001 GTP Power Steering Pump Whining
Remote Keyless Entry Programming
1999 gtp abs light code p1571
2002 Grand Prix Blower Motor/Resistor
word of mouth
Need your opinion with Exhaust
2000 gtp - crank sensor replacement
Engine stall at stop (occasional)
trans issue at wot
Blower Motor
2000 Grand Prix SE Starting Problems
Power Steering Help
3.1 v6 bottom motor mount location
Lifter clicking / seafom?
92 gp driver side window
