View Full Version : Grand Prix
- Driver door water drip guard
- 2001 Grand Prix ABS Traction control lights
- Oil leak after rebuilding tranny
- 06 Grand Prix Supercharger
- Transmission mount question
- Whining noise when rpms increase
- Rear Speaker 01 Grand Prix
- Belt and/or pulley noise
- Aftermarket Security System?
- 2000 grand prix gt runs and idles ruff when it warms up
- window motor
- HELP, horrible noise coming from under the hood
- sunroof seal
- 02 Grand Prix 3.8L AutoTrans, Car Jerks Under Load
- Trans Cooler
- fuel issue
- Which Strut?
- 2006 GP Steering Issue
- brake job
- 1999 GTP supercharged setting maf codes, tp sensor and others
- Car of the future
- Metal coolant hoses...
- bleeding brakes alone
- Front License Plate Bracket
- Not cranking.
- 2002 Grand Prix SE -- Knocking Sound
- p1406 on 97 GA 3.1
- Ignition switch related repair question
- ac compressor replacement
- Caliper Bolts Question
- 00 GTP High Pressure Power Steering Hose
- Idle Pulley Noise?
- 2006 gp factory navigation system bearing noise
- Overheating 2001
- 2000 Grand Prix PCM Communication Issue
- Tranny oil temperature gage?
- Intake plenum
- New On Forum
- how much coolant?
- 2001 GTP Unknown Battery Discharge
- grand prix gtp Iss
- 2001 Grand Prix HVAC
- They finally got me
- 2000 GTP -Help with supercharger
- boost gauge help...
- 02 GP SE Blower problem
- car won't crank....have tried/done
- 2004 GTP Brakes
- Electrical Problems - Turn signals + Random stalling
- Rear Strut Shock Knocking
- ABS, Trac Off, Check tire press lights stuck on
- Using Seafoam
- How to replace fuel solenoid/valve?
- Blower Switch
- Rear suspension noise
- intake manifold gasket procedure?
- Throttle Position Sensor
- which exhaust for GTP supercharged
- Squeaking when turn Left
- Burning Antifreeze-01 GT
- audio steering control (randam dancing)
- Would these fit?
- 2000 gp gtp power steering hose replacement
- Chirrping almost screaming noise, only when in drive.
- Brakes dragging
- 1996 grand prix
- 02 grand prix replaced alt. now car no start & no elect power HELP!
- 98 GTP cutting out at 4000 rpms????
- GTP Fuel Economy
- how do you put front license plate on 2004 GP?
- Small oil leak
- Suspension Clunk
- Passkey and Engine codes
- P0410 Secondary Air Pump Malfunction
- 2005 Intake/fuel/idle/misfire problems
- 2000 GTP - how to re-install harmonic balancer
- Rotor Replacement
- Quality Aftermarket Headlamps
- What do I do now!!!
- 2000 Axle Assembly Replacement
- Blinker problem
- 2001 Pontiac Grand Prix Valve Covers
- 2001 Pontiac Grand Prix Torque Mounts
- 2001 Grand Prix Control Arm Installation
- Car died with P0101
- no power
- VSS code and no reverse?
- 1991 3.1 Runs rough when warm
- 89 2.8 Timing Chain Woes- Advise needed!
- 2003 No Headlights
- zzp catless downpipe??
- Alternator/Battery/or Serpentine Belt?
- installing remote start
- What is this?????
- got power, but no idiot lights.
- Re: Check engine light blinking
- 2002 grand prix gtp transmission problem?
- 2002 gtp tires
- 2002 grand prix gtp control arm
- Surging RPM's
- fuel filter vs pump
- gtp problems
- scangauge 2
- Resonator delete
- Engine idle and P0440
- Weird noises coming from?
- Demodding nightmare...
- Rear Power Window, Help Please.
- Location of fuel filter 90 GP.
- Cars almost dead, how to prolong the life by a few months?
- not a grand prix but please please help
- Adding an extra PK3M key to 2000 Grand Prix.
- 04 GP Low washer Fluid/Start Problem
- Seafoaming through PCV vacuum line?
- GP wont start?
- Part Number for Radio Lamp
- Coolant Leakage
- 3800 series II
- 2000 Grand Prix GT Tire Problems
- 94 grand prix rear end?
- 2000 Grand Prix GT Headlight Problems
- 1994 Grand Prix
- Valve Cover Gasket Replacement questions
- Oil leak; might be intake gasket
- Grand Prix no start mystery
- blower motor replacement
- Code P1406
- 97 grand prix head gasket job
- O2 sensor thread pitch and diameter
- 98 Grand Prix GTP wont start...
- 2003 GP Cabin Air Filter
- poor gas mileage
- GP 98 low heat
- 2002 GP 3.1 blower
- V5 ac compressor clutch plate tool
- 1997 GTP Bumper replacement procedure?
- 2004 Grand Prix No Heat
- Parts and Performance Sources
- crankshaft circuit
- scan tool
- 99 Grand Prix P1870 Transmission Component Slipping
- Anybody have a scanner?
- '04 Comp G Transmission Question
- crazy fluctuating engine temps/ low coolant
- Tbl with BCM, causing a battery drain!
- Help
- 2002 pontiac gran prix 3.1 power steering pump
- Proportioning Valve Replacement
- Gas gauge flucuation 03 gp gt
- DHP, or INTENSE PCM in my OLDS LSS
- Next performance Mod??
- Car running cold
- 2008 grand prix ipod integration
- EGR Valve for 2000 Grand Prix Error Code
- ac compressor
- 1995 Pontiac Gran Prix broken hood release cable.
- 1995 Pontiac Gran Prix 3.1L engine whine
- Adding Oil
- 2004 Grand Prix GT1 Flasher Relay
- drilled t-stat?
- oil burning smell antifreeze disappearing?
- 3.1 oil filter blowes gasket instantly HELP
- hard upshift and no rpm gage
- Brake Bleeding
- 3.8 engine diff than 3.8 supercharged engine
- one more problem i need help with
- 97 GTP- Service Engine Soon Light
- problems with my turn signals
- 99' GTP won't go!!:(
- Upper Intake Manifold - Intrigue 98, Service Engine Light on
- Does anyone have a writeup on replacing a pressure control solenoid?
- door latches 99 grand prix
- fans comes on with engine start
- Another odd sound
- gas gauge
- GTP fuel pump resistor problem...
- P0420 Again
- 2004 Grand Prix GT trim piece missing
- 04 grand prix misfire highway issues, HELP!!
- 2006 Grand Prix GT supercharged w/128k on it
- 2001 pont. grand prix 3.8l
- Grand Prix tries start while running and driving
- 99gtp p0171
- Rear Spark Plug Removel Tips on 01 GTP
- Help with Locks
- '97 grand prix gt sedan engine tick
- 3.4 engine swap
- SRS AIR BAG light
- Ford Explorer Sport Trac
- o2 sensors
- recall for spark plug channel
- GP cold-weather heater
- Possessed Grand Prix? Locks and Heater Blower
- low coolant light when cold
- windshield washer pump
- F-Body brakes and brake lines
- Fuel Pump Problem
- Radio problems/ Rt rear window won't move/ Lights dim when shifted in Reverse
- Porting your throttle body
- Gxp 5300 v8
- Trans Gear Ratio???
- enhanced dtc ???
- Ignition Problem
- Failed Emissions
- Nasty rattling/knocking noise, 98 LSS
- Engine at Startup
- Tire Pressure in winter
- Emergency: Car shut off while driving!
- Part Number for Bottom Bumper Guard
- front bumper question
- how many o2 sensors does a gtp have
- PO108 - M.A.P. sensor high input?
- XM Radio Problem
- L36 Fuel Rail Quick Disconnect O-Ring P/N?
- Windshield washers don't work. '01
- NOT the shifter solenoid - what else could it be??
- Car charger not working!
- RPM drops when shifting 3-4th gear
- low oil level light
- headlights
- ABS Light Came On...
- 97-03 GP sedan seats in a coupe?
- new struts.. alignment?
- question about noise
- Traction control 96 gtp
- intake hoses
- 2001 grand prix se wont start
- slipping gears, whirling noise
- 99 GTP Climate Control not adjusting
- HID headlights and HID fogs
- tachometer help
- Wipers turn on for no reason
- ABS light / codes?
- dash removal
- 2000 GP - No rear lights
- Changing Vac setup from 97 GTP to 98+ Spec
- shift knob
- GTP+Rain=Crazy idle
- ZZP Oil Volume kit...where the heck does it go?
- IAC doesn't do its job
- 2001 gp se won't stay running
- 1997 grand prix se low coolant sensor
- 1994 gran prix 3.4 cold start problem
- wipers staying up.
- cd player wont play
- 94 Grand Prix cold start problem
- Tire & Rim Size Questions
- Fuel Treatments
- Fuel leak in the engine compartment
- Screeching Pulleys
