View Full Version : Grand Prix
- ABS, HVAC and DRL Problems
- 3.1 Engine miss on Cyl 2 & 3
- transmission fluid change question
- oil mixup =(
- removing power steering pump pulley
- AC Blower Fan Won't work on any settings
- Clear oil leak?
- large oil leak
- How often should I replace my fuel filter?
- 02 Grand Prix GTP Transmission Issue(s)
- stiff steering in both directions
- A/c not working. Need help!!!
- 1998 Pontiac grand prix transmission acting weird
- Pulsating Brakes
- 1997 GTP Overheating problems
- Crank pulley bolt thread size??
- Center console removal
- Pulsing and vibration while braking
- Radio Reception
- 99 Pontiac Grand Prix GT 3800 engine
- 1997 pontiac grand prix ball joints
- What fuse supplies voltage to.....
- blower motor just stopped working
- Emergency Brake Cable Problem
- How hard is it to replace tranny?
- drivers side CV shaft
- Passenger side clunk
- Driver side wheel clunking noise
- Any tips-FUEL tank replacement!!
- HELP!! car starting to OVERHEAT...
- grand prix wont start up
- Torque Converter Indecision
- Headlight Switch
- Power Steering (and more?) HELP!!
- Got some bad news yesterday...
- brake trac light need advice co550
- 1995 grand prix quarter window???
- 2004 Intake manifold deteoriating gaskets problem
- What is this dashboard part called?
- 99 GT axel seal leak
- Turbo vs Supercharger m90 top swap kit
- 1995 Pontiac Grand Prix v6 help!
- Re: 04 GTP Comp G, car bogging out
- 2004 Grand Prix headlight-turn signals not working
- 2000 grand prix noisy fuel pump?
- 3100 v6 leaking coolant from timing chain gasket?
- Rear View Mirror/Headlights
- 1997 pontiac grand prix code 121
- Replacing bushing in heater fan/blower?
- Replacing LIM Gaskets on 3.1L anything else?
- Magnasteer II Question
- Passenger Side Mirror Replacement question...
- 98 Grand Prix Wont Start, need help ASAP!
- 2002 SE leaking coolant
- 1997 gtp windows not working
- Process for tranny swap in 04 grand prix gt1
- 2004 gt1 not starting
- SES Code Reads P0440, Evap. Emission System
- 3800 supercharged series II engine problems
- '97 Grand Prix HVAC Problem
- 2001 GTP Speakers
- question about brakes....
- Rear Wheel Bearing Installation
- How much A/C PAG oil to add?
- Door won't open pls help
- 98 Grand Prix GT won't start
- MAF problem i think?
- Fuel Line part number
- abs light
- 2001 Grand Prix GT
- Speed Sensor
- Heated seat doesnt work
- 97 pont.grand.prix GT 3800 overheat and sludg in resi.
- "Performance Shift" button won't stay down
- front end noise
- EGR valve ticking
- Starting Problems
- Valve cover part numbers
- driver window controls
- 2000 gtp quit@roadside
- Shorter Dog Bones?
- Tuning a GTP PCM thats NOT in the car!
- Spark Plugs
- 2004 GP GT2 3.8 with growing list of electrical issues
- '02 Grand Prix Coolant Leak, Need Help
- Interior lights dead after switch and visor change
- front control arm bushing
- Engine noise when A/C or heat is off
- Coolant Temp Sensor and TPS sensor problems?
- Gas Gauge Reading Backwards
- 2001 Grand Prix GTP Performance Chip?
- removing control arm question
- 00 GTP Alarm/ dome light problem?
- HELP! Installed ported exhaust mani and now issues...
- 2002 3.1 thermostat removal
- 04 G/P GT2 couple of problems...
- 1997 pontiac grand prix engine miss& hesitation
- 1995 Grand Prix A/C Leak
- Front Suspension Question.
- 1995 3.1 replace crank sensor
- 2000 GP door locks,speedo,air bag light,MPG display,etc
- manually controlling the fans
- 97 GTP ABS problem
- A/C Electrical problem
- 97 Grand Prix AC compressor dead
- miss-fire at full throttle...any ideas?
- GTP Coolant Leak
- Car Jerks then RPM drops to 0
- Ignition Swich NOT WORKING!!
- `97 Grand Prix GT Noisy steering pump
- ABS light
- exhaust/gas smell
- any truth to this?
- Control Arm
- Car won't start after intake manifold gasket replacement
- '97 Grand Prix GT Blower Motor Resistor
- Wiper transmission
- Grand prix interior colors
- 2001 Grand Prix GTP Brake Upgrade
- 2000 Pontiac Grand Prix GT Drivers Door Lock Switch
- 1997 GTP overheating
- 1997 pontiac grand prix front hub sensor test
- reverse lights wont work...i need help
- 2002 GP/GT Troubleshooting Stall/Rev Engine
- Electrical prob
- ABS and TRAC off light on
- 2002 grand prix gtp transmisson question
- Inner tie rods going, going, gone again.
- 2003 gp coolant leak
- SES after changing plugs
- Firmer Brake Pedal?
- Buzzing noise
- Air Conditioning Help
- Daytona Pace Car Bluebook value
- Ofifice Tube Location
- Shifting Down - What does it tell you?
- ABS/Tract Off lights on.
- how to remove rear bearing hub 2000 gp gt
- 2002 pontiac grand prix climate control unit
- Complete Strut Assembley Installation
- HELP! Need Alignment ANswers QUICK!
- 2002 with odd noise in a rear wheel when braking.
- I have to ask...
- '02 Grand Prix bent subframe
- HELP!! F Body Brake Upgrade
- wires beside water pump caught fire
- Hi, IN REFERENCE TO OTHER POST
- Hi, I NEED YOUR HELP AGAIN!!! PLEASE ASAP!
- PLEASE HELP! Slipping transmission...
- A/C recharging help?
- '97 Grand Prix Brake fluid reservoir change
- rack and pinion,need advice removing lines
- Trans issues after fluid/filter change
- Exhaust system.....
- Brake Job
- 2000 Grand Prix Gt stalling??
- 1997 pontiac grand prix inside rear view mirror
- Old Transmission for new one?
- 2002 grand prix gtp abs codes
- supercharger leaking!!
- ayone ever hear of, or used these?
- new tires
- fuel pump diagram
- Fuel pump strainer
- Is it OK to use exhaust wrap?
- blowing fuses
- 2002 Grand Prix Lag/Bogging at Wide open throttle
- Engine valve tap?
- Car not starting - Replaced CPS
- 2002 grand prix gtp fuel pressure
- Grand Prix HVAC issues
- '97 Grand prix takes long to start, P0441 DTC and bubbling brake pedal
- 2006 Grand Prix Battery Drain
- 97 GTP Transmission leak
- Rear seal leak
- Acceleration decrease and engine shaking
- 1992 GP Won't Idle
- gtp cv problems
- Mods Available for '05-'08 Grand Prix GXP
- '00 Sepentine Drive Belt Instructions
- 1994 grand prix engine
- air conditioner 2003 grand prix
- how to separate ball joint from spindle
- Time For A Brake Bleed
- Grand Prix A/C problem
- 95 rear transverse spring
- valve springs install
- 2005 GT dash and DIC issues
- The 3.4 Plan
- Locked out
- 98 Intrigue with loud whine - need help
- 2001 Grand Prix Air Conditioning Compressor
- GTP issues
- serpentine belt diagram
- Need to Bleed Air From 2001 GP Engine Coolant
- MAF sensor or ported throttle body
- P0141 "Rear 02 Sensor"
- Radio very static
- 2000 Grand Prix Squealing once warm
- Boost control solenoid
- 2002 Pontiac Grand Prix stop light circuit
- Another gas mileage post
- 1997 pontiac gp a/c relay
- MAF Sensor
- Come 'on hopefully someone will know what this problem is!!!
- Need 2004 GP Radio code
- Say good by
- 02 GTP Water Pump
- Different transmission series for 2000 GTP?
- 2002 pontiac grand prix gtp front end clunk
- 2002 gtp spark plugs
- 93 grand prix radiator fans not coming on
- sagging fuel door helppp
- Fuel Pump help
- Diagnosing noise - wheel bearing?
- 2000 GTP rearview mirror replace
- key is stuck
- not shifting when supposed to
- 2002 Window Issues
- raise the vehicle
- weird noise underhood and jerky after full stop
- Heads Up Display very Dim
- Hard Shifts
- GP died.
- 1997 pontiac gp hub play
- 2002 grand prix stumble
- axle nut size
- 1997 pontiac grand prix tranny question
- Trans lines to radiator
- Rear Wheel Bearings
- Supercharger rattle repair
- gtp engine miss
- 1997 pontiac gp ball joint repair
- Additional Key
- This part came from my GP (HELP!)
- Oil Pan Gasket
- new struts...fitment problems...
- Engine Wiring harness gt to gtp
- '98 gtp perfered shift works intermitently
- Gtp swap
- 1964 Grand Prix
- Crankshaft position sensor
- Plug "blew" out of #6 cylinder
- Replace O2 Sensor?
- 04 GTP removing front seats
- New hub assemblies are on order
- Painting GP brake rotors
- 06 3800 SC Fuel Filter
- Fog lights? Best upgrade?
- 96 GP brake light short
