View Full Version : Grand Prix
- To whom may it concern . . .
- GTP Power Loss =(
- Lotek gauge holder screew covers
- PVC Valve Replacement - Help!!
- SLP 1.8:1 Aluminum Rockers & Pushrods
- 4t65e-hd In A Gt??
- Instant total loss of HVAC
- pontiac grandprix speed limiter (97's)only
- What's the most HP I can get out of a GT? After all Mods.
- Need Knob that turns on/off defroster,heater,Panel
- cleaning my headlamps,maybe
- Cooling fans not working
- loud pitched sound in cold start up
- Cold Start Problems
- air to fuel ratio guage install!?
- Heater blows cold air
- pulleys
- Different GTP Models
- interchangeable parts
- Grand Prix GT'S ONLY!!! Racing Info, Experiences W/ These Cars, Whatever (GT's ONLY)
- Braking in snow noise
- please help me
- low fuel guager and indicator light
- Factory AMP
- 3.1 intake gasket replacement procedure
- water in oil
- Check Engine Soon Light
- grand prix forums?
- Stock 97 GTP 1/8 Mile Times
- programing remote for 2003 grand prix se
- Just a quick question...
- Source for aftermarket GTP parts in Toronto ?
- performance
- Anyone here from Masschusetts or Connecticut ?? ??
- Any Tips
- Rough cold start 1999
- 01 pontiac keyless entry
- wont start
- Manual transmission
- 3100 SFI V6 Overheating (Coolant System) (1994-1999)
- 94 GTP exhaust question?
- Help with '94 GP SE
- 90 GP Lacks Power
- Power Steering Pump?
- GTP Reliability?
- 2003 Grand Prix GT2 1/4 Mile Times
- 2001 grand prix
- cruise control OTS
- HUD 99' fading in and out
- Wtb:
- Display for oil and gas mileage inside shows 0
- Help/ advice needed on replacing a control module...
- Car Chimes
- Installing 91 SE door handle
- CD player install Help!???
- engine swap
- Engine Coolant
- 1994 gtp for sale
- Tell me what you think about tunning your car for running a little bit hotter...
- smog check
- How can I shift to Neutral without the electrical system
- Electrical Problem
- Issues with a stubborn headrest
- 98 GP GT Auto headlights intermittent off and blower problem
- APEXI air/fuel controller
- How Many Miles?
- 1997 Grand Prix GT runs hot above 210
- Brake Pads
- Headlight Wiring Harness
- GTP engine cover?
- OEM Wheel for 1998 GTP Bright Red
- Sorry if this is in the wrong area, FS CUSTOM INTAKE!! MAKE OFFER
- Head lamp & Fog lamp #'s??
- Performance Options
- u bend
- Supercharger removal
- Engine Noise
- Tints Question and exhaust..??
- Stuck shifter and key
- Final Diagnosis : Rattle Clank Thunk
- 98 GT Blower Motor, where is it?
- diagnosis is ???
- for all the GTP guys here
- AirBags/Heater Core
- A common 3.4 GTP Problem that seems to lack an answer
- Area around GAS tank?
- Noise is drivin my up the walls!
- Fuel Pump Resistor Location
- A Pillar Gagues for a GT
- Help My Car Aint Working
- 2003 Special Edition
- 97 cant get out of park
- Heater Core
- 93 grand prix airbag and turn switch
- Guess it wasn't the supercharger after all...
- Service Engine Light - Poor performance
- 2000 GP SE 3.1 ABS/TRAC light
- 2000 GP SE 3.1 Coolant Problem
- 2000 Grand Prix Back Seat
- Car only goe's to 3 RPM's..
- Replaced Intake Gaskets Now won't run
- 1998 Gran Prix Key Sticking in Ignition
- Hot Tranny Problems!
- Ventilations Duct Problem
- Oxygen Sensor Unit
- swaping a l67 into an Se...(if at all possible)
- fuel filter
- Cold Engine Noise Problem
- Ok got the motor,trans&axles need so info
- Factory cd player
- Car just...died.
- Exhaust Tips
- rear end noise
- 99 Grand Prix GT please help water in the blower
- anyone know a website where...
- Anyone ever do a Engine swap?
- Whineing at around 2500 rpms >> Please help
- tap tap thump THUMP CLANKACLANK - Supercharger Woes
- Exhaust
- Brake Light Problem
- More GTP Problems!!!
- Need a new engine for my95 GTP....
- MiniTurbine Sounds Like 3k RPM to up
- I need Help
- missing out
- Programming Remote Keyless 98 GP
- Break Lights HELP!!! NEED ADVICE
- funny smell inside of car
- Intermittent SES & engine idle speed fluctuations (99GT)
- HVAC Blower 99GT
- 97+ gt/gtp what's the difference
- Low beams won't turn on
- TCS and launch
- Parting out a 1971 Grand Prix
- 1996 Grand Prix (Cruise Control)
- changing spark plugs
- Where can i get parts?
- Can a GTP run fine without Supercharger Belt?
- changing sc oil
- 1995 Pontiac Grand Prix SE, Car shut off when I hit 110 mph
- Someone can help me!!!!
- Coolant Senor (Code 15)
- GTP pulleys
- 92 3.1 SE P/S and SES problem
- SE 3.8 bumper swap
- Problem with timed door locks
- rocker-to-valve gap / valve ticking
- Any mods. for 01 g.p s.e
- Need Engine Parts Bad!!!!!
- 2000 Grand Prix radio static
- 2000 Grand Prix wet floor
- '96 Grand Prix SE
- 1991 Grand prix temperature gauge problem
- Need help with driving lights?
- dashkit????
- Tire size question...
- Hi everyone.. I'm new to this forum and already have a question..
- help programming keyless entry 2001 g. prix
- 2000 Radio Swap
- Door handles for sale anyone??
- 90 3.1 runs like POS PLEASE HELP!!!
- 89 GP dies when stopped and in drive
- Low Trac
- Radiator fan waits too long to come on?
- Got a 2004 GTP Comp G
- Arizona owners
- Best modification under $500
- Programming keyless entry remote
- FS: 1985 Grand Prix
- RPM problems in park or neutral
- '00 Rear Speakers not working
- 89 GP Dies when given gas!
- supercharger oil
- tired of stalling....very disgusted
- Battery light came on, power steering disabled, accelaration blogged down and
- exhaust upgrade suggestions
- ABS/TRAC lights & no cruise control
- keyless programing
- amp install
- 1993 Grand Prix gauge conversion
- Idle Problem
- 97 GPGT hesitation, bogging down on accelleration
- temp light is on
- Back speakers don't work all the time
- transmission issues
- Electrical???????
- 2004GP aftermarket needs...want to go faster
- exhaust question
- Where can I get a volume knob for a 95 Grand Prix?
- I'm looking to buy............... .....
- 1997 GP GT - ABS Lights always on
- GT - Rear Door Panel Removal
- New/ Used Rims
- 98 gtp failure
- Help with replacing speakers 1999 GT
- Can I easily add a SuperCharger to my stock GP GT?
- anyone fron Indiana?
- code help
- New/used Tires And Wheels Wanted
- Anyone Interested In Group Buy Of Hid Lights
- Check Gauges??
- alternator
- Theft deterrent systems problems??
- Service Engine Soon Light
- '97 Grand Prix Electronic Problems?
- 88-93 bra 4 sale
- 3800 V6 modification tips - any good Cams our there???
- 99 GT Theft Lock
- I hear this whine in many GP GT's...Is it normal?
- 9007 HID Conversion Kits
- Head-Up Display doesn't show radio stations
- Wet passenger floor
- runs 5 seconds then shuts down???
- Paint
- Foglights
- Exhaust/Off the line power
- supercharger oil change
- Wrecked Grand Prix
- DHP PRD Need answer!
- Trying to get horsepower!
- Need cheap or free mods to help toast rice!!
- Anyone Else Have This Problem?
- need help on supercharger
- TB screen
- painted grills
- tires and rims
- I Need Help Fast With My Lights!!!!!
- New discounted price on Grand Prix hoods
- daytime running lights??
- Replace the Stock Radio/with CD Radio
- faqs
- Power steering belt
- Beginner
- 2004 grand prix
- Help!!!
- nitrous oxide kits
- Hi Everyone
- HELP! Electrical problem. car just quits!
- Aftermarket intake & exhaust
- Horn Location on the 97 Grand Prix GTP
- Someone please have the awnser
- Coolant problem
- Grand Prix 2000, Remote reprogramming
- grand prix transmission slip
- GP GT brake issue
- soupin up my grand prix 98
- menber special price on grand prix hoods
