Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
air breather?
92 grand prix se light problem?
strut question
Wheel noise
Ok Guys I need help again!!!
Sensor lights flicker, ABS & brake, car dies
calling all gp nuts
2000 GTP A/C intermittenly
Suspension for 94 gp se
97 GTP Engine woes
2000 GP SE Blower Motor Resistor
2001 GT Upgrade ?
buh
What about TR55IX Iridium Plugs??
Oil Pan Gasket Installation
brake line change
Hard time starting and rough idle
98 grand prix
bg fuel system cleaner
new muffler tips
Keyless (again)
help!! gtp won't start
how do i change the spark plugs
both my fans are not working and gets hot
New Crankshaft Balancer Pics
climate control reading celcius
Nissan Maxima Vs. 2000 Grand Prix GTP
K&N REPLACEMENT AIR FILTERS 2k GTP
Advice needed. flushing engine during intakee manifold gasket replacement
Alternator
SES Light...
installing window
No Cooling Fans
Daytime running lights not working & Fan
motor mounts, tranny mount
Air intake 2004 Comp G Grand Prix
Third break light?
need a transaxle off a 95' GT Grand PRix 3.4L
anyone know how to make the ls6 maf work on gtp
overheating!!1
92 SE No Cooling Fans or AC Clutch
any grand prixs in utah
yet another problem
why insulate wrap exhaust crossover?
4T60E Jerks from 1 to 2
car problem
body kits
lights flickering
1978 grand prix
trans question
Finally Lowered
1988 female needs help
Missfiring.
Service Manual
slotted and drilled rear rotors for oem
wrecked gtp
90 grand prix sputters and stops
90 grand prix turbo
tuning with ls1m
recall on 2000 gtp
question on kc and kr
Top speed
4T65E trans
2000 GTP Died ?
1989 Pontiac Grand Prix
stats on a gtp motor
dropping a tranny outta 95 3.4L GT
need help with monsoon upgrade
tranny kits
Who has the best shocks
replace oil pump
Strut-tower brace noticeable diff?
want info on the thrasher shift kit
do all 97+ GP GT's have the 4T65E trans?
Clearing DTC's
after market mods?
red fluid dripping from botom of 97 gt
p0420 catalyst efficiency below threhold bank 14
Trip computer light bulbs
How to replace Water Pump
my 97 grand prix
Deck installation Q
just got a 95 GT
Is +45 offset for 18x8.5 rim to high?
"ABS" & "Check Tire" Lamps coming on ??
1990 to 1994 interchangeable parts?
94' Grand prix Lug Nuts HELP!!!!!!!!!!!!!
stereo upgrade
prj gen2 fuel rails
Cleaning Under The Hood
reflectors or Lights on Door panels? 97+
grand prix recall
Help with removing door panel, 95 prix
upgrading the stock stereo - wiring?
Fuel filter replacement
Fan/DRL not working
About tire size & performance
NEED A WRECKED GTP 1997 + for swap
speedometer
idler pulley broke off
Are HUDs cool?
97-03 interior in a 94' se ????
Monsoon stereo display is gone
Monsoon display is gone
Keyless Remote Program Info - 04 Pontiac Grand Prix GTP?
Topping Up Supercharger Oil
Cannot find Cold air intake anywhere
SES code P0141
Paint code
Rusty Brake Components
96 - Climate Control stuck on Defrost/Floor bi-level
Problems with ABS light
no HUD! :( Can I add One?
1st brake job having to replace all 4 brake rotors
HUD help
Possessed GP.. Stalling etc. Bad ECM?
Problems with the Engine Pulleys
2004 Radio removal
1997 grand prix died
m90 or mp112
Engine Problems
94 - some issues
1999 wiring diagram
I need help bad, electrical issues making my hair gray!
Hurricane Horsepower Booster
Dashboard -speedo, tach, HUD, and gas gauges stopped working! help plz
Forged Pistons and Crankshaft
Supercharge an 02 GT to a GTP - HELP!!!
Need help dropping tranny out
Free Hood Raffle
bone stock 04 comp g 1/4 times
Female that need some gtp help!!
Whats the best cool air intake system for a 3.4L V6 GTP
18" Eagle 077s brand new!
wiring harness....engine swap
Aftermarket engine parts
DIC Module for 99 GTP
Dual stripe kit
Aftermarket pulley options for 3.8's supercharger?
Help...SES Light is on
2000 Grand Prix GT Rear Speakers
99 GTP missfires
Supercharger Coupler Question
Power window
Cutout and cat-removal
1969-1972 Grand Prix Parts
belt squeals!!!
!!! ABS & "Check Tire Press" Light On! HELP!!
2000 Pontiac GrandPrix Headlight problem
No Check Engine Light in 93 Grand Prix 3.1L
99 GP GT - Is adding a supercharger an option?
pontiac grand prix reliabality
directionals still out/94 SE..help!
98 Grand Prix GTP whistles!
Hole before the cat
motor swap/chang
My 99 Gp Jerks Over 2000 Rpm
Grand Prix Exhaust
I really really want an aftermarket exhaust
TOG big bore exhaust manifolds
Warm drivers cold passenger a/c problem
new member looking for help
Taking mufflers off?
battery/alternator
New Member Here
Window removal HELP!!!!
pulley puller
hey guys look at this
Rough engine at 50MPH doing 1500RPM
Sunroof Visor
Airbox Opening
vibration and grease
jerky shifting
Code 14 & 53 '91 GP
Custom Intake
93 gp upgrades?
Are all wheels interchangeable for years 97-03?
Water in Cabin Fan
93 pontiac died
1982 Pontiac Grand Prix Emissions Removal
Engine Misfire
Need help with high octane gas problems.
water.
Cams and aircare
O2 Sensor
resistor block
The most likely causes of misfiring.
Any tips for aiming headlights and fog lamps?
heads up! 04 gtp owners
Tranny Temp
tranny
94 GP SE Major Problems
oil light
Wheel Bearings
blower motor.
gas meter
Help! 1998 Gtp Problem
99 Grand Prix Overheating What Now
Exhaust Recommendations?
1996 GTP Fob Help (Keyless Entry)
95 Grand Prix HUD question
83 gp posi diff?
what is the widest tire that will fit 99 gtp
Question on Knock Retard
hole in firewall?
Any of you guys heard of B+G Sport Lowering Springs?
It is time to be creative. To all the ones interested on keep the flame going
turn signals/hazard not working-help!
Rims/
First mods for 97 GTP
60 ft time
1993 Grand Prix hesitation?
'98 GP GT Blower Doesn't work on Settings 1-2
'98 Grand Prix rear 6x9 speaker replacement
One heck of a race
Help with location of oil level sensor?
keyless entry for 98 gtp
Broken Blower Motor
Change Headlight bulbs?
wheels 18x8.5 or 18x9
what kind of exhaust????
Driver's Side Door Problems?
Tune-up time.....
GP Heater Resister
3.1L supercharger??
stock 0-60 times in a 4 door gt?
Locking Gas Cap for '04
rusted brake lines
'99 GTP Thermometer probs
Audio Problem 2000 GP
cylinder missfire
2000 GTP Stalls Out
3" or 2 1/2" exhaust ???
angry
Tachometer
Cargo Net - 04 GP
89 V6-191 3.1L. Stalling & Surging
92 LE or 92 Saturn SL2?
Engine swap or just rebuild...
GM Top Engine Cleaner
Exhaust Prollems!!!!
gtp stalling
Are there a lot of problems with 97 gtps?
Exhaust Coming Off?
Fuel usage
Check engine light
ambers and fogs on only????
Gtp Dic
GTP Sluggish at 40 mph
Car Stereo Removal
