View Full Version : Grand Prix
  1. Trailing Arms
  2. cooling fan failure??
  3. losing coolant and its pissing me off
  4. transmission slipping into 2nd
  5. AC Problem
  6. gt 3.8 run's rough on idle
  7. Can I just buy a power steering pump reservoir?
  8. can i make my lights flash when locking car?
  9. HELP! Power Steering Bolt Broke Off in Block
  10. SRS Airbag lights intermittently
  11. Autometer Boost Gauge install
  12. No Air!
  13. she's finally black
  14. Freeze frame, what does all this mean?
  15. AC fan only working on highest setting
  16. 1997 pontiac gp drive axle boot replacement
  17. 1997 GTP Very Loud Rattle at Idle
  18. 1997 GTP problems
  19. underhood insulation
  20. Is my Temp Gauge Fried? 98GTP3800SC
  21. Vapor Lock?
  22. Yet again, a new issue...
  23. AC Unit+Cooling
  24. 1997 pontiac gp fuel line filter
  25. Coolant Leak?
  26. please help me!!!
  27. 1997 pontiac grand prix transmission filter change
  28. Missing Nut
  29. Need to know what way water flowing through heater
  30. 2000 GTP bogs on hard accelleration
  31. 00 gp still shakes
  32. Radio lamp replacment
  33. squeaking power steering
  34. Grand Prix/siren noise
  35. Plugged heater core?
  36. 97 gtp evap leak after LIM gasket replacement
  37. Alternator Overcharge?
  38. my GTP saved my life
  39. Abs light and trac control
  40. Parking Brake Issue ?
  41. GP won't start!!
  42. 2000 GTP dies at idle
  43. Car Will Not Start
  44. 99GPSE3.1 Fuel pump, starts and idles at 3200RPM
  45. 2005 Grand Prix ABS & TCS lights on after lowering
  46. Door Skins or New Doors ???
  47. 05 GTP Issues...
  48. Shifting Problems Grand Prix 2001
  49. 90 Grand Prix 3.1 help!
  50. GTP Temps sensors?
  51. Not a GP, but...
  52. Removing rear caliper on '08
  53. Cabin air filter
  54. Car shaking and making knocking sounds when accelerating
  55. Has anyone done this?
  56. Parking brake warning light on after bleeding brakes
  57. no overdrive
  58. o4 GP wheel bearing tourque
  59. DIC cause of problems?
  60. A look inside the drive by wire.
  61. Door/Trunk Lock
  62. 2005 Grand Prix GTP intermittent acceleration sluggishness misfire
  63. Soft pedal
  64. 2000 Grand Prix GT Stalling
  65. 97 3.1 overheating DESPERATE
  66. Control switch
  67. Idle dips stalls sometimes in park.
  68. 1999 Grand Prix differential EXPLODED
  69. 20mpg or less! what could be the problem?
  70. pulsating hum/whirl
  71. Need torque specs & pattern UIM LIM L26.
  72. P0141 O2 Sensor 2001 GP 3.1L
  73. Parking brake stuck
  74. 1998 grand prix GTP 3.8L V6 supercharged, random misfire
  75. some one please help 95 grand prix
  76. 1997 2nd design 4T60E Trans Bolts
  77. o4 gp roaring noise
  78. Cruise control quit 99SE 3.1
  79. Steering wheel - audio control backlight
  80. Heater control problem
  81. 2001 Grand Prix transmission won't shift
  82. wheel hub/ brakes
  83. AC Leak - 2001 GTP
  84. 2001 grand prix gtp rack and pinion help
  85. Grand Prix Running Hot
  86. Spoiler Rattle...04-08
  87. trans not shifting
  88. Need torque spec & pattern L26.
  89. 2000 GP SE dtc 0410 help
  90. Rought Idle/Smoke
  91. Parking Brake
  92. name that part
  93. 97 Granx Prix "Red" Temp Light Coming ON
  94. Transmission Problems?
  95. Long crank and low fuel pressure
  96. Rear Brake Pads
  97. Front end clunk when hitting bumps
  98. Need Help, Wiring issue/Short
  99. Instrument Cluster Trim Replacement?
  100. intermittent ps problem
  101. 91 Grand Prix 3.1 PCV and another question.
  102. 02 Sensor
  103. Known issues with 2006 and newer GP and MPG
  104. Purge Valve Testing and Diagnosis??
  105. First Failure with '08 GXP
  106. DIC not working
  107. 2001 GTP - Brake Pad Opinions?
  108. Possible Transmission Slip
  109. inner-outer tie rod replacement, how difficult?
  110. 2004 Grand Prix GTP Comp G - Strut Tower Brace
  111. FM Antenna Wire came off Rear Windshield
  112. 2001 GTP - Two Different Sounds
  113. HELP! 99 GTP overheats in summer no heat in the winter
  114. SRS airbag light
  115. 1997 pontiac grand prix brake caliper ABS
  116. 1998 pontiac grand prix 3.8 code p0171
  117. Security Light/PassKey III Issues
  118. A message to fellow GTP lovers
  119. 2001 GTP DTC Error Codes P1404 and P0128
  120. Intake gaskets leaking, help?
  121. O2 sensor simulator
  122. which size rim?
  123. Feel like a noob.
  124. Died
  125. Oil leak (video + several pics)
  126. l67 RWD transmission question
  127. Stinking O2!!!
  128. where is the knock sensor? (1995 GTP 3.4 dohc)
  129. 02 GT 3.8 warm start issue
  130. PCV valve
  131. Coolant leak on 01 GTP and is their LIM write up?
  132. 2005 Grand Prix Steering wheel replacement
  133. Rattling noise when accelerating and vibration
  134. 2000GP - head gasket/LIM gasket?
  135. 2000 GP vibration under acceleration - right turns
  136. "free" mods, intakes, etc
  137. Shift lock actuator plug diagram
  138. trans flush
  139. pic of my blown IM gasket; replaced; still getting SES light. Ideas?
  140. Left Side Drive Shaft
  141. 2000 Grand Prix Key won't turn
  142. instrument lights not working, center consol still working
  143. 1997 pontiac gp brake noise
  144. radio very dim, new bulb didn't fix it
  145. Code P0452
  146. 2000 pontiac GTP
  147. Oxygen sensors
  148. throttle body spacer?
  149. 1993 Grand Prix shifts, but will not go into gear.
  150. Power Windows don't work - any of them!
  151. Water under rear bench seat
  152. Intermittent ABS problem
  153. 2001 GTP Plastic Heater Hose Fittings
  154. Parking Brake problem
  155. Post Your Ride and Mileage 2011
  156. Odd noise from front end
  157. 2001 Grand Prix Mystery Hose
  158. 2001 gtp p1404, p0404
  159. 1997 GTP fuel pump issue, pretty sure
  160. Major anti freeze leak
  161. trunk question/ fuel gauge
  162. Fuel pump resistor
  163. new fuel pump/has power but doesnt turn on
  164. 97 gp front brake caliper mount
  165. Low Oil Light
  166. Did my trans just die? :(
  167. audi people dont help, will you?
  168. After tune up, car dies or won't start
  169. Need tips or advice for repairs
  170. amp install
  171. Struts?
  172. Fuel gauge on Full all the time
  173. 97 gp lower control arms
  174. Torque Strut Mounts
  175. Spark Plugs, coils, wires???
  176. GTP Intake
  177. excessive oil leak.
  178. Crankcase Oil Filter
  179. Which battery to use???
  180. Grand Prix No Start, Burnt post on main Relay
  181. all over the road
  182. 02 grn prix no fuel gauge and cant get the key out
  183. 97 GTP wheel bearings
  184. Intermittent No-start problem
  185. 02 grand prix trouble code po137
  186. 97 GP GT Dash Lights not Working
  187. Grand Prix "Take a Break" Thread
  188. MAJOR electrical problem
  189. gas mileage
  190. Aftermarket Air Filters
  191. Intermitent blower motor
  192. 02 Gtp doors unlocking themselves
  193. Keyless fobs that don't work.
  194. 99 GTP Transmission
  195. Wiper Electrical Problem
  196. wiper motor assembly stripped
  197. Random stalling issue
  198. DIC not working
  199. 02 GTP Tune up
  200. 4T60E Question
  201. Start and stall, doesn't idle
  202. Keyless remote?
  203. Climate control weird problem
  204. 04 GP GT2 starting problem, headsup display, and broken dash
  205. 2003 Grand Prix Losing Power
  206. 2001 GTP Tranny / Shifter Question
  207. 93 3.4L Power Steering Hose Replacement
  208. Keyless entry
  209. Smell from heater core
  210. 97 GTP Keyless Entry Question
  211. ELECTRICAL problem running lights
  212. Congratulations tblake-Tim
  213. 2002 GT Plug Wire Suggestion
  214. Temp gauge and heater
  215. Remote Starters
  216. Different problems out of nowhere!
  217. tail lights operating randomly
  218. Pioneer radio install in 05 Grand Prix GT
  219. 98GTP - Should I get horn or lights with remote lock?
  220. 99 Grand Prix GTP Transmission issues?
  221. im considering doing this. i need everyone's input!
  222. '04 GT Heater core
  223. Heat/AC issue
  224. New Headlights
  225. Looking into a 98-01 or so Grand Prix
  226. I have a repair manual but is there a video or detailed walkthru for 95 GTP LIM/UIM gasket replacement??
  227. blower motor resistor, blower or both?
  228. super charger losing power
  229. 02 GP GT Bogs when giving gas
  230. So...the GT is totaled
  231. 2005 GTP Need New Catalytic Converter
  232. 01 GT, Rattles When Turning and Accelerating at the Same Time
  233. I need help with an odd transmission issue
  234. Highbeam issues
  235. Half shaft replacement
  236. Replacing control arm
  237. 2004 Steering Rack Question
  238. heated pass seat
  239. 01 GP GT stuck in park
  240. Parking Brake Adjustment
  241. 04 GTP loss of boost
  242. Head liner is rattling
  243. 95 Grand Prix hesitation
  244. Service Engine Code PO404
  245. 2006 GP GXP temp control light question
  246. Erratic gas gauge/electrical issue?
  247. 2002 grand prix gtp p0420 again.
  248. Heater Control Question
  249. Another Transmission Problem
  250. 2000 GTP Constant battery Draw
