View Full Version : Grand Prix
- let's put it to rest...
- shift kit???
- Error Code 446???
- i got beat
- Strange clicking noise from behind the dash!
- Need used supercharger for 97 GTP
- Digital horsepower
- gas lines
- 180 tstat
- tie rods
- really bugging me what should i do?
- a/c blower switch or blower motor?
- 95 grand prix wheel controls
- Problem with 93 Transmission
- Firewall...GRRR
- ECU programming
- Rear Deck Speakers?
- 2000gp trans whine????
- anyone sells just the power window motor, not attached to regulator?
- Fenderwell or Ram Air???
- what engine?
- Tensioner on 98 Grand Prix
- Do I Need To?
- Pulsating accelarating problems
- 97 GTP vs 97 Taurus V8 SHO
- Ext. Service policy 04 GTP
- dilemma for my 95 GTP
- hi and stuff
- Rear window removal
- Which CAI to get: MSP or ZZP?
- 99 GP GT shift problem. Please help ASAP.
- Keyless entry on 2001 grand prix
- headlights ...
- Performance Shift
- underbody neons
- Something's odd! Shifting unusually.
- 03 gtp low whistle noise? is this normal?
- changing sealed headlight system to composit headlights
- What should I upgrade on my '01 Prix GT 1st?
- 99 Grand Prix fans not coming on!
- shifts
- 97 GP oil leak
- A/C compressor replacement
- '04 Steering wheel position (problem)?
- wheel speed sensor
- supercharger oil
- Engine management unit
- driver power window not working
- 97 GT Fuel Gauge Problems/ Rearview Mirror
- '90 Grand Prix HEADACHES
- gran prix stalling
- AC light keeps going out...
- 04' GTP Won't start
- Electric superchargers!!!
- speakers
- 89 Grand Prix the Limited Edition
- 1990 Cooling problem, Purge air??
- Front Bumper Cover Loose
- 95 Grand Prix & Spin-Flow Oil Filter?
- 91 Grand Prix Troubles
- 99 Grand Prix SES code 0327-Knock Sensor
- {please help} u-bend info
- Rear-end Noise
- [HELP] Misfire on Cylinder 3
- 04' Gtp Cai
- How Much will the transmission take?
- Fuel pump won't shut off
- Cruise failure
- Eibacks installed and looking an alternative to Tokicos and KYB's
- color for my 1995 grand prix GTP ?
- 89 tranny won't 2-3 shift
- 97 Grand Prix won't come out of park
- rear brakes
- Different wing design for '04 GP
- Light covers/street scene grilles
- 1996 Grand Prix Won't Start
- 04 GTP tire spin
- Tinting my own windows......
- lower ride=lower mpg?
- 2004 Gtp
- Fan works on high only ..defrost dead
- 03 gtp
- 97 GTP crank sensor
- Fuel injectors
- Make it faster
- 1990 GP SE rear brake help
- Anybody know what connector PED-34 is for? (loc'd behind battery near RH fender inner
- 20 Rims" on 2002 Grand Prix
- SES Light and loss of acceleration
- Dynomax Superturbo mufflers
- 1994 Grand Prix won't start, loss of 12V power
- replacement struts
- engine problem
- how to change intake manifold gasket
- System - Good Ground
- older style GP body kit...will work from 89-96
- 3.1 litre gen II performance?(Vroom Vroom)
- pressure control solenoid
- Changing Supercharger Oil, and a recap of the wet floorboard problem
- doors
- Got rust ??
- Low fuel pressure lean fuel code 171
- Help with U Bend
- 1995 GTP Will not crank. Have power to accessories
- 1995 sleeper GTP?
- no acceleration after stop
- New Exhust System
- Engine Light
- engine swaP!?!?
- Rearview Mirror Compass stuck on North, what are 8 wires for?
- 94 1st gear only; typical ground issue?
- Better Gains from Stage 2 Heads/Cam or an intercooler?
- what is a U-bend
- 1998 GTP Sway bar broken?
- DIC Not Turning On???
- egr
- Brake Calipers
- clock and radio light
- Car Runs Few Sec Then Turns Off Is Fixed
- 3.4 pulley economy
- 2000 gt rough starts power in an out
- No Instrument Cluster Lights
- 90 Grand Prix stalls like its going into diag mode
- Leak in Passenger side
- Help!!!
- Drivers Information Center
- New Hood sale Price
- 4 Sale 2000 GTP Pace Car Silver Custom
- 3800 S/C, Trans Problems!
- Crappy acceleration 3.8V6
- Body kit for Grand Prix??
- HA.. I could have died!!!
- AUGH! Chick needs help! Which keyless remote for a 98 Grand Prix GTP??
- Runs Few Sec Turns Off
- Where does this wire go?
- 1995 gran prix leaks coolant
- size of rotor bearing nut
- how much fuel pressure should it be 97 gtp
- 99 GT fuel filter
- using 95 gtp mass airflow sensor on 94 gp se
- Driver's side mirror replacement?
- wow shouldn't have done that
- how much time should it take for pwr windows from fully down to fully up?
- HELP!!! 97 GT Brakes Stuck!!!
- does anyone no where the crank shaft sensor is on 97 gtp
- my abs light on my 2001 grand prix
- speedometer/odometer problem
- 1998 Grand prix GTP major front end noise...HELP PLEASE!!
- '00 gt toggle switch?!
- 91 Grand Prix 3.1L Just Died
- No spare in the Ignition Control Module
- Clunk in Reverse
- 13 MPG Fuel Economy at City?
- fuel resistor
- muffler sound
- Anybody lowered with Vogtland?
- DTC problem: GM Serv. Dept Rip-off! Need Expert Advice, cough technicians...
- what do you think of this super charger kit..
- '97 gt shift kit
- 92 Grand Prix oil leak
- estimated HP after mods
- Mufflers and the sound that they make
- 97 grand prix stereo prob
- rough start and low MPG, is it tune-up time?
- Side Door guards on GP
- haha... body kit paint...
- Changing Spark Plugs on 2001 Grand Prix
- CPS in 89' GP...HELP!!!
- where to sell my gtp
- 1993 Grand Prix SE ~ allignment???
- Cooling Fans don't turn on
- How much new fuel pump cost 97 gtp
- 97 gtp runs for few sec then turns off
- Headlight Assembly Install - Line up the right and left side!
- Need Help - Engine Dies
- Break Problems
- Shifting out of Park when car off...Possible? 94 GP
- 2004 Keyless Entry
- Help With 99 Gtp
- 2000 Grand prix coolant light low???
- Sunroof with Overhead council?
- Stereo Fading in and out
- 1999 Grand Am Side Panels
- LOW OIL LEVEL Light on cold start!
- Cold start hesitation until working temp is achieved
- Problem with 2000 grand prix!
- blown engine
- HA My goal is Achjieved!!!!
- programming keyless entry 00 grand prix
- Engine Management System
- New 1998 Grand Prix GT
- Hood latch problems
- A/C doesn't work in my 95 prix
- Inoperative power window
- 97 resister question
- Air Filter
- Is transmission normal?
- Newbi with a 1996
- 91 GPSE 3.4 died, will not start
- air condition clutch pulley
- Which Thermostat?
- Supercharger, Turbo, etc... on an SE
- Trouble Programming Remote...Not a Repeat!
- Performance Shift Button Question
- aftermarket exhaust volumes
- Cylinder numbers question!
- remote start
- track racing tips
- supercharger
- mods? maybe?
- anybody got advice, over 100 K mile advice !!!
- A/C-Drivers side blows hot and the other blows cold-no zones
- Door won't shut
- over heating
- Power locks
- Borla!
- CHECK THIS OUT>>> IMPORTANT
- Damn this keyless entry......
- 89 GP Stalling/Speedometer
- Swapping DIC
- Questions about the tranny cooler! HELP!
- Rotating Engine to change spark plugs
- 1989 Grand Prix LE audio question
- "Low Coolant Level" Light
- Help
- Suspension mods to get lower 60'?
- GTP ideas....
- Grand Prix Body Kit Paint
- supercharger
- flowmasters
- regulator question
- hi-performance
- 1870 and 0442 Codes
- Check this site out
- Guys need to replace the resonator after the cat ...
- Healdlight switch
- Engine temperature question
- SES can't resolve problem
- 180 or 160 TSTAT ON A HOT WEATHER!!
- A/C Blower?
- not cool
- IAT extension question
- 95 grand prix se
- ses light on
- 2004 GP GTP Shows wrong day of week on trip computer but correct date
- the warning sound is gone
- How can I change my headlight
- Stereo System
- ac and window
- 1994 GTP Scanner/Code Reader
