Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
Just raced my 97GT in the quater mile
Turbocharged GTP?
Keeping a Black GTP Clean
Fender Flare/Lip Trim
Mobil 1, Royal Purple, or Amsoil
rear speaker replacement 97-GTP
Air in cooloing system
1999 GP - Heater External Temperature Reading
Smaller Pulley and Transmission Cooler
Horsepower Increase??
mod'e a '92 grand prix???
"Bogging" at low speeds
PFYC Reprogrammed PCM
wipers don't work on high
a/c stops blowing under acceleration
98 gp door lock problem
Aftermarket pcm question
Posting pictures
89 GP steering wheel removal??
Help with this Code?????
Gapping NGK TR6 with these mods...
Emissions problem
Starting, Electrical Problems on 91' GPSE
MSP cai vs. Wizaired cai...Which is better?
SLP CAI and PCM Location
manual temperature controls
drivers info panel on 98
Alternator for 98
groove in rotor
its not the resistor
need some help
Blower Motor!!!!!
NEED TO TURN "SERVICE ENGINE SOON" LIGHT OFF!!!
Speedometer and gas gauge
Top Speeds for a 2000 GTP
Changing 94 se tranny
steering wheel radio controls
I Have LOTS of questions for all of you
New pcm and Passkey III?
Transmission problem
Symptoms of Cracked Heads
Service Engine Light - OBD
Water leak on the front passanger side
Brake light wiring
Changing the battery, possibly alternator - then what ?
trans noise?
Grand Prix Clunking HELP!!!
2000 GTP Performance Chips
Source for emblems?
99 grand prix rear seats
TRAC OFF warning light
Is a 93 Grand Prix good?? Compared to My Tbird that was Wrecked??
1993 Fuel pump replacment
WOT Question
Electronics
Interior sun fade problem
blower motor problem
Looking for 93 Grand Prix 2 door 3.1 L eng.
Selling my car
91 grand prix parts for sale
wanted 91 gtp front end
1989 Grand Prix Instrument cluster
? for ppl w/ smaller pulley on their gtps...
what bonds w/o corrusion from gas/vapors
What`s The Code Of Oxigen Sensor
radio help
Mustang vs GTP
'93 GP starting problem
battery terminal psot
does anyone know anything about supercharging or turbocharging a 3100 engine
Anyone with a used high flow cat with ubend delete and KR->
How do I pull my old radio/CD player? 95GTP
Grand Prix body kit for sale... MAKE AN OFFER
Mileage dropping quickly.
DHP perfomance shift and GT
Transmission Problems
cruise control vacuum
performance shift problems
thrasher or intense tranny???
tranny issues - wont shift - jerks into gear
Air baq question
99 GT & SE Loosing power
Supercharger belt?
Using Oil, Overheating and Mis-shifting
DHP or Intense for GT 3.8
Monsoon stereo as replacement??
Ignition switch for 1993 Grand Prix
Drilled Zzp-tstat Question
Newby's Radio Question
98 GP GT Intermittant Tach / Trac Off light
98 Grand Prix Power steering problems
Ram-air hood question
SLP ram air hood grilles
new rotors
98GT steering wheel volume control
Strange electrical problems
1979 grand prix
Can't keep my 99 GP running
saab t3 turbos(3) excellent cond.
Custom Strut tower bars
Thrasher shift kit
checked my gas milage on 91 Grand Prix GT
Rounded lug nut
94 GTP starting problem
evap purge
95 grand prix overheating and wanting to die. PLEAS HELP, I BEG YOU!
Oil Leaks on 97 GTP
i'm going drag racing and need some tips
Racing Pedals
performance struts?
tran/interior lights 1995 GP SE
85 Gran Prix 5.0liter Carb Swap??
V.1 DHP PCM w/180 thermo, autolite 105, and 3.4" cause problems?
ram air hood
1999 GTP Computer Display
1994 Pontiac Grand Prix Speaker Help!!! PLEASE HELP!!!
Delco CD Player
Daytime running lights
finding an oil leak on 97 gp
blower motor resistor
Newbie question - re: start up
suggestions dual/single or dual/dual?
Cold air questions
2001 gtp car is hard to start
Electrical problem???
Do GM trannys Whine?
Catching the Dexcool problem early?
Directions on how to Change a Crack Head
In need of a tranny
1995 GP Rear Susp. Problem
Over Heating
Brake noise?
Head
grand prix - not just a car...also a #@@$!$ over 18 please
2000 GT HUD Prewired??
91 Grand prix power problem
parts 3.1
grand prix shirt
Stock boost gauge??
cruise control problem
cranks but doesn't run
New to the board
changing alternator on 95 grand prix gtp
Free intake for 97-01 GP in SoCal area
Removing Governments
Roller Rocker Arms Question!
overhead dome lights
Once And For All : Body Kit
Is this a good buy?
Andys Auto Sport Body Kit!!
Loud Humming Noise At 35mph
cowl hood
93 grand prix Engine surges when accelarating and Idles high then drops to normal.
Chip Or Not To Chip?
99 GP GT OverheatTemp fluctates
93.trany.no.gears
waterpump
map sensor location in 92 3.1
turn signal causes smoke to come out of steering wheel ????????? help
Factory Delco CD player question
pcm gp to regal?
89 grand prix steering wheel removal
Vibration while driving ?
interior pillars
fuel pump or resistor
anybody need fuel resistor kit?
Windsheild wiper motor
92 SE Goodies ??????
driving light bulbs
fuel systems
wiring relay in trunk floor
Starts then stops
Comparing Exhausts...
body kit
body kit
2000 GP wiper ?
2000 -Help!!Can't get key out of ignition
clear corners
Air Intake Kits For 2001 Grand Prix Gt 3.8l
Headlight Adjustment HELP!!!
95 grand prix se transmission problem
fuel pump resistor
stall at stop
Overheating (details included)
How to replace drive belt on 2001 Grand Prix GT
Cylinder Head Torque required!
replace tie rods?
Hesitation and Service Engine Light
New problem now
02SE front bearings bad at 70K
aftermarket exhaust
fuel pump issues
turbo for gtp
89 GP jerky shaking feeling
You Want To Know This!!!!!!!!
off topic
overheating
fuel?
Rear Struts
99 Gran Prix 3.1 fan problem
Coolant like Mushy Brownies
installation costs
spark plugs......
Changing the battery 1992 grand prix
Ecm won't fire injectors
2000 GTP brake issues
Help! RPMs Bounce
Cone Filter to MAF 04' GTP
low coolant light
whineing 2000 gp
black wheels?
98 Isuzu Transmission
grommet in floor
A/C-97 Blowing cold on passenger and hot on driver side
replacing DIC
Running power wire from battery to amp in '98 Grand Prix GT
Where To Buy Keyless Entry Remotes
2001 GP GT and "clunk" sound?!
transmission or sensor?
shift knob
GTP Door Mouldings
Car shuts off and will not start - 3.8L
m90 snout w/ optional 3.4" pulley
GTP Super Charger Rattle
header wraps
HELP!!! MY 94 grand prix was STOLEN!!!
the 4 door that pontiac never made !
Anyone have an extra 4T60 tranny Buffalo NY
locating oxygen sensor
someone help with electronics...!!
Really poor gas mileage-no answers from GM
Cylinder Head Gasket
wet floor board??
Radio CD Player Skipping
door glass
need parts?
96 Grand Prix 3.1L over heating - cooling fans not working when ac is off
Speed sensor location; 2000 Grand Prix 3.1
Knock Sensor?
95 GP Aftermarket tail light lenses???
02 gt
Water pump removal Pontiac 98 grand prix SE V6
Hi all.Newbie with questions.95 se
Day Time Running Lights
dash removal
89 radio removal
Security light is on and car will not start
louvers
Spark Plugs
Cylinder Heads
