View Full Version : Grand Prix
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55
  1. Trac.vs.ABS
  2. '96 SE, tranny chugging??
  3. What color for neons
  4. 93' grand prix stock rim custom design
  5. 2000 Dashboard Removal
  6. Silverstar vrs. Cyber White
  7. Just had my second flex plate replaced. Anyone else?
  8. Help Please!!
  9. Want to order your GXP?
  10. Ignition Switch Harness for sale
  11. Blown oil pan gasket
  12. Step by step How To: Changing Water Pump on GP
  13. XM Radio in 2000 GTP
  14. Remote programming for 98 Grand Prix help
  15. Air intakes systems
  16. interior speakers
  17. Theft Deterrant system
  18. Turn Signals
  19. steering wheel controls on non controlled steering wheel
  20. How to tighten emergency brake cable?
  21. 1997+ Grand Prix Owners with Non-Supercharged 3.8L V6 (L36 Plastic Intake)
  22. Anyone looking for a car???
  23. Spark control switch/module location/info
  24. turn signals not working
  25. Fast Fuel Burning
  26. a/c clutch and pulley 2002 GTP
  27. O2 Sensor Question
  28. Engine Management Systems
  29. info centre light,abs,trac off,check tire,engine,seat belt
  30. aftermarket stereo + steering controls
  31. '92 grand prix
  32. Need help with coolant leak...bad
  33. Big-L : KKid Testing HUD
  34. 2000 Grand Prix Keyless Entry Problems
  35. 95 ABS light on
  36. 98 Gp Power Window Assembly
  37. touch up paint help
  38. 98 GP front end
  39. air conditioning recharge
  40. 20 Inch Wheels on a Grand Prix??
  41. crankshaft position sensor, '01'
  42. Turbo kits and perfomance parts for LT3/C20GET
  43. Factory License Plate Cover??????
  44. 3.8 hot intake backfire
  45. Key stuck, but..............
  46. headlight eyebrows?
  47. engine swap
  48. 1991 Grand Prix help
  49. Anti-Theft and Keyless Remote ???
  50. buying used 1992 grand prix 3.1 v6
  51. 98 GTP - ABS Problems
  52. 91 fuel pump wiring diagram please?
  53. 90 Grand Prix glove compartment thumbwheel trouble
  54. Whining on left turns
  55. 98' Grand Prix
  56. FS: grand prix
  57. Big-L did you ever do this?
  58. window regulator replacement
  59. Error Code on 98'Grand Prix Radio
  60. water injection
  61. pcitures of a relocated PCM
  62. clueless
  63. Installing a Hud and GTP DIC
  64. Mall PGM fuse??? where is it?
  65. Neons in the Grill?
  66. Stock Alternator Amperage Rating
  67. No dipstick
  68. newbie here
  69. Slick-50
  70. no oil cap still run ok?
  71. Boost cut
  72. Bypassing Theft System For Remote Start
  73. Sad, sad day...
  74. Flame throwing exaust
  75. 3.8L swap with turbos... need opinions...
  76. Brakes
  77. Heat/AC Controls
  78. electric supercharger any one got any info???
  79. Trans. problems
  80. CPS and cruise control
  81. Supercharger parts, and "how to's"
  82. Burnt Oil Omfgbbq!!
  83. Types of Oil Matter?
  84. abs-trac off-check tire press lights on...still
  85. 97 GP Went DEAD at speed - now no start!
  86. Weird PCV
  87. STP Octane Booster
  88. 2004 Hyundai Tiburon GT vs 2000 GTP
  89. Change Oil Soon Light
  90. 1995 Pontiac Grand Prix GTP 3.4 DOHC Question
  91. Need new tires
  92. well just finished trying to get someone to do a u-bend delete
  93. engine swap 95 into a 96 3.1???
  94. 2000 GTP Tire Speed rating?
  95. chips & scratches?
  96. Problem again?
  97. passenger door "rub"
  98. 95 Grand Prix Parking/Dash Lights Out
  99. Replacing head gaskets ~ 95 GPSE 3.1
  100. Piston slap or rod knock?????
  101. 95 3.1L stumbles above 3K rpms
  102. Just an idea.
  103. Please Help!! Desperate Again!
  104. tensioner
  105. computer chip/ electric supercharger
  106. intake worth getting?
  107. 91 grandprix
  108. Tubrocharged Gt
  109. some broad in a mustang
  110. 1997 Grand Prix is Stalling
  111. Please Help!!!!!!!!!desperate!!!!!
  112. ? about 04 gtp
  113. No Heat
  114. Who is a member of the 150 MPH+ Club?
  115. wont go over 3000 rpm
  116. diffrence in HP series 1 and series 2 3800SC
  117. 94 coolant replacement
  118. 1-2-3 or just drive
  119. crazy window/electrical problem
  120. ?transmission
  121. Looking 4 98 GP Blower motor
  122. anti-theft 1995 grand prix
  123. 1996 Grand Prix GTP vs. 2000 Monte Carlo SS
  124. cold start engine noise
  125. Coolant in oil
  126. GTP coolant leak
  127. GP vs golf gti 1.8t
  128. Poor idle when engine is cold
  129. radiator sludge
  130. SES light thrown with CAI
  131. Change oil light
  132. Hissing Noise From Engine, possibly intake manifold
  133. One Man's Art.............
  134. South Dakota any one? Car show?
  135. O2 sensor
  136. Cars clean, BUT........... Rated "R"
  137. new to this forum
  138. Looking for AUTOMETER Z Series gauges
  139. Strut mounts and Struts
  140. 1997 grand prix gt - engine shuts off
  141. T-top Option for Grand Prix's
  142. What Cam?
  143. electrical issues
  144. 3.8L information
  145. what do u think?
  146. Smooth Riding
  147. Oil filter.
  148. noise from back bottom of engine
  149. Transmission
  150. '79 Grand Prix won't start
  151. ODB II Code 0420 - Catalyst System Efficiency Below Threshold (Bank 1)
  152. What kind of bolts are used on 95 grand prix wheel bearing/hub assembly?
  153. thinking on buying this 94 gtp
  154. 96 GP Air Conditioning troubles
  155. 2nd Battery
  156. HELP locked in ,can't get out
  157. roller rocker upgrade
  158. Installing a Stereo System
  159. 89 3.1 into a 98 GP...
  160. Strange Electical Problems 97 GP GT Sedan
  161. Water Leaking
  162. 96 GP Door Handle
  163. New Transmition Pricing
  164. Annoying Sound??
  165. Fuse box
  166. Buying GTP help with prices
  167. I think I have a Tranny Problem
  168. Radio lamp out
  169. Wheel Bearings & Rear Brakes on '95 Grand Prix...
  170. Roof Rails
  171. 97 pontiac grandprix v6 stalls please help me!!!
  172. MAF Sensor .. Easy or Hard
  173. Belt replacement....
  174. 6x9's on a '00 GP SE
  175. adding keyless entry
  176. 1989 grand prix for sale (cheap)
  177. GTP Daytona 500 Edition Value
  178. High speed/low coolant light
  179. A goodbuy?
  180. coolant loss
  181. Please Help Me!!!!!!!!!!
  182. Help!!!!
  183. I think I may have found a new hobby.
  184. quick ?
  185. Strange noises
  186. 2005 Monsoon system info please?
  187. Stock HP of a GT?
  188. Gotta Love the Trunk
  189. gtp vs acura rsx , dodge srt-4
  190. DTC P0650 ... won't run
  191. low coolant light - help?
  192. eeprom programming
  193. anti theft radio Codes HELP!!
  194. 98 GTP problems?
  195. speed govenor
  196. Key Stuck After Shutoff
  197. 94 still overheating w/intake gaskets replaced
  198. 3.4 dohc 91 pontiac
  199. U-Bend Help
  200. Transmission or Electrical???
  201. Stalls, P0336, tach stops working
  202. turbo
  203. wizaired
  204. Anybody ever wait forever for their DHP pcm?
  205. trans problems
  206. 2004 grand prix gt keyless entry problems
  207. 89, 2.8 engine problums
  208. RKE for 1998 Grand Prix
  209. 2000 Grand Prix Stalling Problem
  210. To all people with blower motor problem!!!
  211. sound clip
  212. CD Player Skips
  213. stalled out part 2
  214. GP dome light stays on
  215. Strange grinding noise from tranny
  216. coolant on driver side floor matt
  217. pics of my beater
  218. pics?
  219. Stalled out
  220. Maintenance on a 99gtp
  221. part numbers
  222. wont shift from second to third
  223. Need Grill. Can't find grill. MUST FIND GRILL!
  224. EGR Trouble Code
  225. Who has really fixed the leak???
  226. Keyless entry program for 99 Grand Prix GT
  227. Crankshaft pulley trying to come off
  228. a gpse with a 3400 swap
  229. 92 grand prix stalling
  230. 94 grand prix question
  231. Synthetic oil....
  232. '89 grand prix with engine problems...help?
  233. key codes for ignition 1994 grand prix se 3.4
  234. HUD 1994 grang prix se 3.4
  235. Transmission
  236. anti theft sytem gp gt 98
  237. Question for you GTP guys
  238. Power steering probs
  239. 94 grand prix se
  240. GM may get rid of Pontiac or Buick
  241. Grand Prix GTP
  242. squirrels in my ride
  243. 2000 GP trans problem....help?
  244. Rear Defog.....
  245. MotorVac
  246. Need help with subs and amps?!
  247. looking at 97 GTP w/160,000
  248. offset for rims
  249. supercharge oil flush
  250. Delco Plugs
