Pontiac
> Grand Prix
View Full Version :
Grand Prix
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
Harsh Shifting
AC Clutch, ABS Ignition Fuse keeps blowing, Help!!!
"Upper torque strut/mount" Bolt Torque Specs
2004 GTP Issues
2000 Pontiac Grand Prix GTP Service help
Fluctuating Engine temp Guage and Coolant Leak
Daytime running light issue
Possibly a bad TPS and low LTFT? '97 GP GT
97' grand prix run hot
2000 grand prix gtp parting out
97 pontiac gp low side port for a/c?
What are instrument clusters going for these days?
2001 GTP vibes/shakes while accelerating
Resetting Security on 1995 Grand Prix?
2001 gp not starting after head gasket repair
1995 Grand Prix - Needles jump oddly - Intermittent start
High oil consumption 5300 AFM engine
Grand prix gtp help
97 gp rear door locked
Help! 1995 GP dies intermittently - not crankshaft sensor
Parking brake cable broke!
Need help: Car alarm installation
Heavy buzz about 1200 rpm
where'd all of the GTP's go???
2000 pontiac gp fuel
More half shaft issues
Small oil leak
1998 GTP power problem....
98 GTP ignition switch harness??
Two new problems: Ignition switch?
Alternator!!!!
99 GT Multiple misfires - SES light flashing non stop
Heater bypass elbows! HELP!
***Please Help***
Live data scan values?
2000 grand prix GTP
06 Transmission not shifting
engine rebuild 3.8l 2001
2004 GP Which computer stores mileage and Date
Power window problems
Master cylinder or brake booster?
2000 Grand Prix GT Check Engine Light
R.I.P Grand Prix
Torx safety screws
Bad Ignition Coil?
1997 Grand Prix GTP
95 GP - which crankshaft sensor is bad?
next performance mods????
Swaping 06 Grand Prix turn signal to fog/signal lights
97 grand prix gtp supercharger
1995 Grand Prix stumbling on acceleration
1999 GP Keyless Entry Module Help
97 gtp fan only working on high
Blinker problems
O2 Sensor Mess
2005 Pontiac Grand Prix GT Keyless Entry stopped working
Possibly the transmission?
Plugs/Wires/Ignition Coil= Shifting Issue?
2005 GP GTP would like to install factory remote start
Online Tire Shopping For The GP
Tires
Bose Questions....
ABS, Traction Control & Stability Control Lights
idle surge from 700 - 1000 rpm no ses light and loss of fuel mileage
Headlight Restoration:UV Clearcoat or Not ?
Brake conversion
98 GTP Boost under 50%
need a 2nd opinion regarding codes po442 and po440
Allignment after changing front struts?
Front door speakers
02 Grand Prix - Rubbing sound on front passenger tire
2005 GP GTP running very rich
Best replacement headlights?
Car Will Not Stay Started
Catalytic converter 1997 GP GT
Car smells like gas ??
94 Grand Prix loses electrical power
04 Grand Prix gt Gas cap warning
99 GP GT: Weird Steering Problem
2001 gtp dies when starting up?
Replacing seats 2005 GP
1997 GP GT Rear Bumper Cover
window switch went bad.
95 Grand Prix Stumbling
O2 Sensor
Car Randomly Dies Out
steering wheel noise
Tail light problem
Just Stopped Running
97 Grand Prix GT Power Steering grunt
Antifreeze leak into crankcase
P0420 code on 2008 Prix
2002 GP Battery/Charging System Light
2001 grand prix help needed wont pass emissions
02' Grand prix SE tries to die while stopped?
OEM Spark Plug and Wires Part #'s
Realistically....whats my GP GTP worth
Valve covers for 3.8L
Blower motor or Resistor?
service engine light
Cooling fans?
2008 GP GXP Charging System Failure
aftermarket fog lights for 97 - 03
Front Motor Mount
How often do you guys change your transmission fluid?
Tranny help
Series II 3800 engine cover
2001 Grand Prix GT coolant in oil
Removing door panel
PLEASE HELP!! 1999 GTP Start up problem!!
pontiac gtp supercharger idler pulley hexagonal socket extraction
a/c belt
grand prix gt 2001 trany problems
04 Gr Prix Supercharger leak?
Whinning Noise
push button starter & relocated hud switch
Lower Intake Manifold Replacement?
2005 GP GTP by disconnecting battery will it cause the radio to lockup
3.5 and 3.9
Please help me diagnose a vibration
2007 GP will not start
2000 GTP brake tube replacement
ATF Instead of Power Steering fluid
both headlights just went out!
blower motorproblems
2008 Pontiac GXP Transmission Reliability
Rack and pinion replacement
Changed engine, now tranny will not shift.
Coolant leak
2001 GTP - Fuel Injectors
multiple issues with 03 grand prix
99 GT revs up and down
02 GP 3.8 oil pan removal
04 GT1 ABS/Traction Control light
GP totalled and insurance ???'s
Diagnosis Engine and Control arm?
Engine Temperature gauge
Control Arm & Sway Bar
1997 gp transmission hesitation reverse
Replacing the starter
Fuel Sending unit
1999 Grand Prix - Can't remove key - shift lock question
AC not blowing cold air - some questions
1997 gp lower control arm replacement
New ride!
2006 GP GT Radio Issue with AM Band
Radio Whine In '04 GP
2008 GP GXP-Oil Fouled Spark Plug-Twice!
2002 Grand Prix GTP coolant leak
Need to find a part
Blower Motor and Automatic Headlights Intermittent
replaced crankshaft position sensor now car wont start
A/C Evaporator
Unlock radio the 1800 # doesnt work
Rotors
Manually shut off torque converter?
Exhaust leak. Options?
Transmission issue (94 gtp)
car audio
Ac=no cool air blowing
Checking ABS light w/o scan tool
2007 grand prix gt
Windshield Washer Pump
Update on Blower Motor Problems
04 pontiac gp speed and mileage controled by computer or speedometer
Rotor coating
2000 GT A/C Compressor?
scrapping noises,after front struts replace it!
transmission problems
Burned CDs
auto tranny temp sender
My 97 2door grand prix is has four leaks and etc HELP
HELP!! No Headlights
To flush or not to flush, plus spark plugs ?
hello fellow grand prix'rs :)
Radio compatibility
GXP getting into 12s without cam or forced induction?
1997 Pontiac Grand Prix GTP Trans problems
Has anyone here replaced a clock spring on a 2008 & up Prix?
Coolant bleeder valve
2004 GP Low Oil Level Warning Won't Clear Off
BLOWER have you seen this before??
What kind of tires u got on your GP?
2002 GP AC intermitant problem
Error codes P0101 and P0121
2005 Grand Prix SE. poor fuel economy and power loss
popping noise
Stalling question
Torque Converter locking up too early
Oil Leak on 2002 Grand Prix 3.8
ABS Scan Tool for 2002 Grand Prix 3.8
power steering pump swap
Do I need new struts?
Need to remove airbag from 2008 Prix steering wheel
2001 grand prix new coolant temp sensor problem
Front Stabilizer Bar Bushing Brackets
power steering whine
how do i tell what supercharger i got ?
ebay front lip
2001 Grand Prix GTP - P0205 & P0305
GTP at 252K
Front Stabilizer Bar - 99 GTP
2007 grand prix gt
Will shift to drive but stays in park. Please help.
2001 Grand Prix AC control stuck
new car
98 Pontiac Grand Prix GTP Steering Column Filler
window problems
Power Steering Pump Squeaking
Bye Bye GTP..
2001 GTP - totaled
2004 Hard start when warm
Drive axle nut woes on 2004 Prix
Blower Problems
Scribing Struts on replacement
What to do about rust?
Trying to Diagnose Massive Oil Leak - 98 GT
Transmission housing broke. Help!
Blower Motor/Interior Vents
04 gran prix hard steering problem
custom tuning?
'04 GP Low Oil Level Light
mystery plug. please help
2002 pontiac grand prix gtp rear bumper
2002 intake manifold gasket replacement
Rear Speakers Not Working
2002 Grand Prix MPG improvement and Check Engine Light gone!!! fixed by chance
2002 Grand Prix Rear Disk Brake Hub Assembly Removal
whistle from air intake?
air filter in a '06GP
alternator pulley 97 gp
Air bags to replace leaky air shocks
Need help diagnosing a P0411 Secondary Air issue
Clock spring
98 Pontiac Grand Prix GT Stalls when Hot p0171
Removing steering wheel
sudden major coolant leak 3.1 litre SE
97 3.8 into 2002?
control arm issue
Intermittent high idle
1997 grand prix fog or smoke like through vent of air condioning
Intake Plenum Gasket, or Valve Cover Gaskets
1998 looses fuel pressure
Drivers Instrument Lights
Major problem with my Grand Prix
whats going on with my car
Oil Filter
Starting Issue
2000 gt shifting weird
1997 Air conditioning and vent stop or cycle while driving
