View Full Version : Grand Prix
- New Owner of a 1999 GTP
- OK, you forgot last year
- does anyone know why?
- wet trunk and vaccum lines
- Overheating issues
- Question on spark plugs
- Dash Backlight on an '04 GTP
- motor is torn down, and i have a ?
- fuel filter replacement
- Drip from Blower motor
- how do I get code for problem triggering MIL
- 89 Grand Prix...Crank Position Sensor
- Valve seal removal
- 2004 keyless remote
- Loud Engine Chatter.
- turn signal affects the guages
- 2000 GP Preventative Maintenance
- new coil packs on 99 gt
- Car Reved up on its own! What should I do??
- power sunroof noise
- Gxp
- 1997 Grand Prix Fan Problems
- pcv valve
- mods for 97 gt
- HUD fading issue
- How diffucult to change this harness
- Painted calipers
- slight clunking when turning steering wheel
- Installing supercharger on 97 gt
- yet another super charger question
- center console 2
- Musty A/C
- cd stuck
- center consule
- IMPORTANT question about S/C pulley and A/C noise.
- 2004 Grand Prix Noises
- Car gettin Hot!!!
- 2000 Pontiac Grand Prix power window regulator..
- Headers, Sway bar and vibration
- ** 98 Grand Prix MANY Problems **
- No BRAKE Lights
- Major Problem Please Help!!!!
- Window
- shifting problem
- Fog Light Replacment
- Autotap software
- 1997GT - A/C Condenser Replacement- Help Please
- What can GM do?
- How to change...
- O2 sensor on a '94 bonn
- 2000 Pontiac ac/heater switch???
- Coolant Temperature Sensor (help!)
- Supercharger Swap
- a/c and auto dim headlights going wacky
- Point of a Resonator?
- Rust on inner rear strut tower.
- Engine temp, how low or high is yours?
- Couple Questions
- 1994 GP - Window track question ?
- Real 0-60 in sec
- 94 Grand Prix GTP Idle issues
- Exterior Temp Gauge?
- remote programming issues on 2000 GP
- Help-SES code is P0441 running out of ideas....
- installing a new stat
- Rear speakers
- Road rag? Yea, I'd say so.
- wont stay running
- Smoke coming from rear tire area on 88
- Couple gauges to get rid of.........
- SE under the hood mods????????
- '94 or '95 thats spittin and sputtern and just plain confussing
- knocking sound after intake gasket replacement
- New pulley. Squeak, why?
- super charger power loss 2000 gtp
- 2000 GTP 2Dr
- Free mod
- Same price as GM workers get
- repainting door trim
- Ever spend the day waxing your car, THEN
- Fast ticking sound from s/c???
- WAIT4ME PCM's AWESOME!!!!!!!
- OK who gets the worst gas mileage?
- trying to wire a set of neon lights
- thermostat
- Accesories for in dash cd player
- How to begin Modding your Grand Prix
- 2000 Grand Prix Gtp Intake Gaskets
- License Plate Bracket Insert
- Theft lock
- Cruise control quits going downhill
- boost guage
- GP help
- Ac Problems
- Resonator Removal
- Role Call
- Miles Per Gallon with A/C turned on....
- What are these called?
- SEC codes
- VP Racing Fuel in Grand Prix
- High rev, stall - high octane problem
- What MOD to do next!?
- pully question
- Gauges
- DIC Driver Information Computer
- 108,000 miles and going!
- changed top hose/hole in it since then.....
- Rear speakers
- Car Starting Problem
- 2000 pontiac Grand prix misfires when engine is cold
- Number of valves?
- 90 - Engine cuts out, doesnt charge/bad injectors
- In-Dash cd player removal
- trouble retrieving trouble codes..HELP!!!!
- Temp Gauge
- Service manuals 1998 Grand Prix
- Turbonator
- Grand Prix - Broken door handles
- NEED Answer to the **Ultimate Key Question**
- Parts Car: 95 gp GTP 3.4 DOHC
- Gtp
- engines
- Temp gauge error?
- Please help...Need opinions on this!
- Changing 96 grand prix 3100 to 96 bonneville3800 sII
- 97 GTP radio code (Delco)
- uneducated about polishing....
- primer?
- Parking Brake Light Always On!
- how do i ....
- Correct pulley for '04
- rattling
- slipping with 3.0 pulley?
- BigL or GTP Dad please help
- 1991 grand prix se head
- AC doesnt work
- Bad Wheel Bearing?
- 92 Gp Le 3.1
- brake shudder 2001 grand prix
- Just the mirror glass?
- Engine Noise
- front end, trac
- 1989 GP Dash Instruments
- In dash Radio for 1991 pontiac grand prix se
- High Idle in Park and Neutral
- 98 Grand prix engine swap
- battery problems
- Scanning Price
- AC Compressor not kicking in
- Grand Prix GT '98 Overheat...
- Steering wheel radio controls / problems
- camshaft breakage
- Resistor or Ignition
- brakes
- cat shot already????
- '93 gp le keyless entry
- www.Performanceleathers.com
- Replacing ignition lock cylinder on 97 gp
- Help me find a vacuum line for my 95 GP SE
- 95 Gp Se 3100sfi
- 93 Pontiac G. Prix Rear Pad HELP
- just bought a GP, what should I look for?
- 95 GP...Downshift problems
- engine hesitating
- Pulling wheel bearing - which slide hammer?
- Keyless Entry Program
- 1997 GTP please help
- Coolant leak
- motor switch
- 2000 GT Power.steering Dead? Dying? Please help.
- Automatic Locks
- Trouble shooting an SES fault
- 91 GP Speed Sensor question
- my 1997 GTP makes lots of knocking noise ...
- TOO MUCH BOOST!!! supercharger problems
- Keep blowing Fuses! Help *see diagram*
- Loose door panels
- Prestone Extended Life Coolant
- that new GXP!!!
- Window Problems!
- Grand Prix Spoiler/Map Light Replacement
- GTP Transmission on a GT....possible?
- You know your a Redneck, WHEN
- Supercharger going bad (no whine)
- 1990 ABS and Eng prob
- Belt question
- car alarms
- Intake Gaskets Help
- foglight replacing
- Old Polish, Good, Bad or OK??
- Ported Throttle Body
- 2000 GP HU Upgrade
- Oxygen Sensor
- How much oil for 2004 Grand Prix?
- 1995 Grand Prix SE Overheating
- Rearview Mirror!
- 100,000 mile tuneup
- supercharger/intercooled question
- Need help with window
- First Mods
- 2002 Grand Prix Accelerator Sticking
- Reliability?
- Changing Spark Plug Wires, 2000 GT
- where's a mall or bcm fuse?
- 91 gp cooling problem
- AC won't shut off (w/car off)
- grand prix gt electrical HELP!!
- Anti Theft Stero System Code
- Lens Cover Fell Off
- Inspection Problems...exhaust
- help - need shocks
- Seat cover matierals...which is better?
- "MALL PGM" FUSE
- Anyone have a SLP Exhaust?
- my service engine light.....
- Fuel additives
- is this a good platform
- 3800 stalls then surges when warm
- Cooling Fans '95 GP
- Engine light on... Mechanics cant figure it out.. can u?
- Tire pressure light on
- Ext warranty policy...
- Help! Full throttle bogging out
- Car caught on fire!
- Diagonal Brace Removal, 2000 GT
- GM recall #03034 engine coolant leak
- Replacing Driver Side Mirror
- how to install boost gauge
- abs: master cylinder went dry
- plug swap
- Chime sound!!!!
- keyless entry
- Turn Signal Titanium Bulbs
- What do you guys think of this kit..
- 17's on my gp
- Thumping Sound While Driving
- touch up help
- DIC into GT
- Need Help with oil change light......
- Wire Harness Upgrade and Bulb Selection
- Help with Tire selection
- 3800 rebuild questions
- 2000 GT Weird Sound and engine shake
- windshield wiper problem...module?
- Exhaust cut out?
- Wiper problems anyone?
- New Grand Prix Owner, Has A Couple Questions
- failed emissions
- Bit of a miss, surges at cruising speed
- Speaker Problem
